01411.2-00
01411.2-00
    STEGO
01411.2-00 数据手册
SMART SENSOR CSS 014 | DC 24 V >>Analog/digital interface >>Small size >>Easy clip and/or screw fixing >>Quick connection (M12 plug-in connector) >>High accuracy >>Large temperature and humidity range >>Various application areas (IEC 61010-1/DIN EN 61010-1) The compact Smart Sensor CSS 014 electronically records temperature and humidity and converts the measured data into a standardized analog 4-20 mA or a digital IO-Link signal. The converted value signals can be utilized or further processed by a control or monitoring unit, e.g. a PLC control. The Smart Sensor is suitable for installation inside and outside the enclosure, even in harsh environmental conditions as can be found in the wind power industry: in shielded outdoor areas and exposed to vibrations. TECHNICAL DATA Protection type IP57 Pin assignment for 4-pin M12 round plug connector Art. No. Interface Measuring signals analog (4-20 mA)/digital (IO-Link) digital (IO-Link) temperature, humidity events, diagnosis, device data Max. reaction time 3 min. Load resistance (external) ≤ 500 Ω (4-20 mA only) Connection M12 round plug connector, IEC 61076-2-101, 4-pin, A-coded, shielded Electrical protection Reverse-polarity, short circuit, overvoltage protection Mounting clip for 35 mm DIN rail, EN 60715 and screw fixing M5 Casing plastic according to UL94 V-0, light grey Dimensions 140 x 40 x 38 mm Weight approx. 50 g Fitting position vertical, connection on top Storage temperature -40 to +85 °C (-40 to +185 °F) Operating/Storage humidity max. 90 % RH (non-condensing) Protection type/Protection class IP20 (sensor only IP57) / III (SELV) Approvals VDE and UL File No. E500143 (acc. to IEC 61010-1/DIN EN 61010-1) Note other measuring ranges on request analog 4-20 mA Example of connection Operating voltage Power consumption max. Temperature measuring range Humidity measuring range Operating temperature 01420.2-00 4-20 mA (analog) DC 24 V (DC 12-30 V) 1.8 W (typically 0.4 W) -40 to +60 °C (-40 to +144 °F) ± 1 K 0 to 100 % RH ± 4%1 -40 to +70 °C (-40 to +158 °F) 01411.2-00 IO-Link (digital, specified acc. to version 1.1) DC 24 V (DC 18-30 V) 0.3 W -40 to +80 °C (-40 to +176 °F) ± 0.3 K 0 to 100% RH ± 3%1 -40 to +80 °C (-40 to +176 °F) ¹ Tolerance within 20 to 80 % RH (please request diagram for tolerances outside this range). www.stego.de | www.stego.co.uk | www.stegonorden.se 8585 08.07.2019 | Specifications are subject to change without notice. Errors and omissions excepted. Suitability of this product for its intended use and any associated risks must be determined by the end customer/buyer in its final application. MONITORING STEGO - PRODUCT CATALOGUE TECHNICAL DATASHEET
01411.2-00 价格&库存
很抱歉,暂时无法提供与“01411.2-00”相匹配的价格&库存,您可以联系我们找货
    • 1+1781.01607
    • 5+1602.91863
    库存:20
