40TECHNICAL
40
HEATING
DATASHEET
HAZARDOUS AREA HEATER
CREx 020 | 50 W to 200 W (T4)
>>For areas with explosion hazard
>>Large convection surface
>>Clip and screw flange fixing
>>Ready-to-use with strain relief
>>Maintenance free
>>Temperature class T4
www.stego.de | www.stego.co.uk | www.stegonorden.se
PRODUCT CATALOGUE - STEGO
Photo Art. No. 02042.0-00
TECHNICAL DATA
Temperature class
Ex Protection type
Gases
Dusts
D
25
II 2 GD
Ex db IIC T4 Gb
Ex tb IIIC T135°C Db IP66
Ambient temperature
-60 to +50 °C (-76 to +122 °F)
Surface temperature
max. +135 °C (+275 °F)
Heating element
high performance cartridge
Heating body
aluminium profile, silver anodised
Connection
silicone cable (halogen-free) 3 x 0.75 mm², length 1 m
Connection PE
0.75 to 2.5 mm²
Mounting
clip for 35 mm DIN rail, EN 60715
for heating body sizes 80 x 48 mm and 120 x 60 mm;
screw fixing with 2 plug-on flanges for all heating body sizes,
optional widthwise mounting
Fitting position
vertical airflow (connection on bottom)
Storage temperature
-60 to +85 °C (-76 to +185 °F)
Operating/Storage humidity
max. 90 % RH (non-condensing)
Protection type/Protection class
IP66 / I (earthed)
Approvals
EPS 16 ATEX 1 109 X
IECEx EPS 16.0048X
EAC
X
H
W
T4
CREx 020 with
screw flange fixing
CREx 020 with
clip fixing
Clip fixing
Screw flange fixing
Operating voltage
Heating capacity
Rec. pre-fuse T
(time-delayed)
Dimensions
(D x W x H)
Weight approx.
Art. No.
Art. No.
Hole spacing X
02041.0-00
02041.0-10
150 mm
AC 230 V
50 W
0.5 A
80 x 48 x 110 mm
0.7 kg
02041.9-00
02041.9-10
150 mm
AC 120 V
50 W
1.0 A
80 x 48 x 110 mm
0.7 kg
02042.0-00
02042.0-10
225 mm
AC 230 V
100 W
1.0 A
120 x 60 x 180 mm
1.4 kg
02042.9-00
02042.9-10
225 mm
AC 120 V
100 W
2.0 A
120 x 60 x 180 mm
1.4 kg
02043.0-10
275 mm
AC 230 V
150 W
1.5 A
160 x 80 x 220 mm
2.3 kg
02043.9-10
275 mm
AC 120 V
150 W
3.0 A
160 x 80 x 220 mm
2.3 kg
02044.0-10
350 mm
AC 230 V
200 W
2.0 A
160 x 80 x 300 mm
2.8 kg
02044.9-10
350 mm
AC 120 V
200 W
4.0 A
160 x 80 x 300 mm
2.8 kg
04.04.2017 | Specifications are subject to change without notice. Errors and omissions excepted. Suitability of this product for its intended use and any associated risks must be determined by the end customer/buyer in its final application.
Compact convection heater of temperature class T4 (135 °C max.) for use in areas with explosion hazard for
prevention of formation of condensation, temperature fluctuations, and for protection against frost in control
and switch cabinets, as well as in measuring equipment.
很抱歉,暂时无法提供与“02041.0-10”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+1536.867241+198.83480
- 5+1373.712665+177.72640
