02541.1-01
    STEGO
02541.1-01 数据手册
LED 025 Light Energy saving LED technology Wide voltage range LED 025 Light with magnet mount Integrated power unit Magnet or screw mount Wide variety of connections LED 025 Light with screw mount The LED 025 light series is suitable for all types of panels and enclosures, especially where space is at a premium. These lights have a very long service life due to the use of LED technology. They are available with powerful non-slip rubberized magnets allowing them to be easily positioned in any steel enclosure. Screw mounting is also available as an option. The power output allows up to 10 lights to be connected to each other (daisy chain) with both the input and output plugs snap-locking into place. Lighting On/off switch or motion sensor | Technical Data On/off switch light w/magnet mount Power consumption max. 5 W (~ 75 W incandescent bulb) Luminosity 290 Lm Lamp type LED, 120° angle of radiation light color - daylight, color temperature - 6,500 K Service life 60,000 hrs. at 68 °F (20 °C) Connection 2-pole plug with snap lock AC: max. 2.5 A / AC 240 V, white cable DC: max. 2.5 A / DC 60 V, blue cable Magnet mount end view Screw mount end view Housing plastic, transparent Mounting magnet or M5 screws (not included), 9.8” (250 mm) centers; screw torque 2 Nm max. Operating temperature -22 to +140 °F (-30 to +60 °C) Storage temperature -40 to +185 °F (-40 to +85 °C) Dimensions magnet mount - 13.8 x 1.3 x 1.3” (351 x 34 x 32 mm) screw mount - 13.8 x 1.4 x 1.3” (351 x 36 x 32 mm) Motion sensor light w/magnet mount Part No. - magnet mount 02540.0-00 02540.1-00 02541.0-00 02541.1-00 1) Passive II (double insulated) Protection type IP20 Accessories input and output plug, cable for supply or connection Approvals UL File No. E234324, VDE Note available with a 19” front panel Screw mount end view Part No. - screw mount 02540.0-01 02540.1-01 02541.0-01 02541.1-01 Operating voltage AC 100-240 V, 50/60 Hz (min. AC 90 V, max. AC 265 V) DC 24-48 V (min. DC 20 V, max. DC 60 V) AC 100-240 V, 50/60 Hz (min. AC 90 V, max. AC 265 V) DC 24-48 V (min. DC 20 V, max. DC 60 V) Switch type on/off switch on/off switch PIR motion sensor 1) PIR motion sensor 1) Weight 4.8 oz. (135 g) 4.8 oz. (135 g) 5.0 oz. (140 g) 5.0 oz. (140 g) Infrared (PIR) motion sensor is factory pre-set to turn the light off 6 minutes after all motion ceases Specifications are subject to change without notice. Suitability of this product for its intended use and any associated risks must be determined by the end customer/ buyer in its final application. STEGO, Inc. · 1395 South Marietta Parkway · Building 800 · Marietta, GA 30067 · Tel: (770) 984-0858 · Fax: (770) 984-0615 Toll free: 1-888-783-4611 (US & Canada only) · www.stegousa.com LED025/11-12/US Magnet mount end view Protection class LED 025 Light - Accessories Connection cable with input connector and wire leads 1 Photo: Connection cable, Part No. 244357 Lighting Part No. 244357 244361 Model connection cable 2 x AWG 16 with input connector connection cable 2 x AWG 16 with input connector Length 2.0 m 2.0 m Voltage AC DC Extension cable with 2 connectors for daisy chain (input & output) connection Color connector: white - cable: white connector: blue - cable: white Approvals UL, VDE UL, VDE 2 1 2 2 Connection example Photo: Connection cable, Part No. 244359 Part No. 244359 244363 Model extension cable 2 x AWG 16 with 2 connectors extension cable 2 x AWG 16 with 2 connectors Length 1.0 m 1.0 m Voltage AC DC Color connectors: white - cable: white connectors: blue - cable: white Approvals UL, VDE UL, VDE The lights are easily connected via quick connection plugs or extension cables -- up to 10 lights can be daisy-chained this way. The snap-lock connectors ensure a stable electrical connection even when subjected to vibration. Input / output connectors Photo: Input connector, Part No. 264057 Part No. 264057 264058 264059 264060 Photo: Output connector, Part No. 264058 Model input connector output connector input connector output connector Voltage AC AC DC DC Color white white blue blue Approvals UL, VDE UL, VDE UL, VDE UL, VDE Switch type on/off switch on/off switch PIR motion sensor 1) PIR motion sensor 1) Weight 4.8 oz. (135 g) 4.8 oz. (135 g) 5.0 oz. (140 g) 5.0 oz. (140 g) LED025A/11-12/US Light kit with input connector included Part No. - magnet mount 02540.0-00-0003 02540.1-00-0003 02541.0-00-0003 02541.1-00-0003 1) Passive Part No. - screw mount 02540.0-01-0003 02540.1-01-0003 02541.0-01-0003 02541.1-01-0003 Operating voltage AC 100-240 V, 50/60 Hz (min. AC 90 V, max. AC 265 V) DC 24-48 V (min. DC 20 V, max. DC 60 V) AC 100-240 V, 50/60 Hz (min. AC 90 V, max. AC 265 V) DC 24-48 V (min. DC 20 V, max. DC 60 V) Infrared (PIR) motion sensor is factory pre-set to turn the light off 6 minutes after all motion ceases Specifications are subject to change without notice. Suitability of this product for its intended use and any associated risks must be determined by the end customer/ buyer in its final application. STEGO, Inc. · 1395 South Marietta Parkway · Building 800 · Marietta, GA 30067 · Tel: (770) 984-0858 · Fax: (770) 984-0615 Toll free: 1-888-783-4611 (US & Canada only) · www.stegousa.com
02541.1-01 价格&库存
很抱歉,暂时无法提供与“02541.1-01”相匹配的价格&库存,您可以联系我们找货
  • 1+1653.225731+206.58660
  • 3+1487.016953+185.81720
  • 5+1283.822655+160.42610
库存:1
