03060.0-01
03060.0-01
    STEGO
03060.0-01 数据手册
30 HEATING TECHNICAL DATASHEET COMPACT HIGH-PERFORMANCE FAN HEATER (SEMICONDUCTOR) CS 030 | 1,200W >>Compact design >>High heating performance >>Double insulated >>Integrated thermostat (optional) www.stego.de | www.stego.co.uk | www.stegonorden.se PRODUCT CATALOGUE - STEGO TECHNICAL DATA Heating element PTC resistor - temperature limiting Temperature safety cut-out to protect against overheating in case of fan failure, automatic reset Axial fan, ball bearing airflow 160m³/h, free flow service life 50,000h at +25°C (+77°F) Connection 2-pole max. 2.5mm², clamping screw with strain relief, torque 0.8Nm max. Casing plastic according to UL94 V-0, black Mounting screw fixing (M5) Fitting position vertical airflow (air outlet up) – other fitting positions possible Dimensions 168 x 145 x 120mm Weight approx. 1.2kg Operating/Storage temperature -45 to +70°C (-49 to +158°F) Operating/Storage humidity max. 90% RH (non-condensing) Protection type/Protection class IP20 / II (double insulated) Heating capacity / Ambient temperature diagram CS 030 Heating capacity (W) Connection diagram Temperature (°C) Art. No. Model Operating voltage Heating capacity¹ Inrush current max. Pre-fuse T (time-delay) Setting range² Approvals 03060.0-00 Fan Heater with thermostat 230VAC, 50/60Hz 1,200W 13A 8A 0 to +60°C VDE + UL File No. E150057³ 03060.0-01 Fan Heater without thermostat 230VAC, 50/60Hz 1,200W 13A 8A - VDE + UL File No. E150057³ 03060.9-00 Fan Heater with thermostat 120VAC, 50/60Hz 1,200W 16A 10A +32 to +140°F UL File No. E150057³ 03060.9-01 Fan Heater without thermostat 120VAC, 50/60Hz 1,200W 16A 10A - UL File No. E150057³ ¹ at +20°C (+68°F) ambient temperature; ² Switch temperature difference 7K (±4K tolerance); ³ according to UL 508A, NITW File on request 20.03.2013 | Specifications are subject to change without notice. Errors and omissions excepted. Suitability of this product for its intended use and any associated risks must be determined by the end customer/buyer in its final application. The compact high performance fan heater prevents formation of condensation and frost and provides an evenly distributed interior air temperature in enclosures with electric/electronic components. The plastic housing provides double insulation and acts as protection against contact. The fan heater is available with optional integrated thermostat for temperature control. The CS 030 was designed as a stationary unit for the bottom of the enclosure. For wall fixing the fan heater CS 130 is recommended.
03060.0-01 价格&库存
很抱歉,暂时无法提供与“03060.0-01”相匹配的价格&库存,您可以联系我们找货
  • 1+1829.83614
  • 25+1793.23150
  • 50+1757.36625
  • 100+1646.54219
库存:10
