Toll free: 1-888-783-4611 (US & Canada only) · www.stegousa.com
>>Compact size
>>Flat design
www.stegousa.com
SPACE-SAVING FAN HEATER (fan included)
HVI 030 | 500 - 700 W
>>Built-in overheat protection
>>Twist clip or screw mountable
TECHNICAL DATA
Heating element
high performance cartridge
Temperature safety cut-out
with automatic reset and second-tier one shot fuse
Axial fan, ball bearing
service life 50,000 h at +77 °F (+25 °C)
Air flow, free blowing
88 cfm (150 m³/h)
Connection
2-pole dual pressure clamp for solid wire AWG 14 max. (2.5 mm²),
stranded wire (with wire end ferrule) AWG 16 max. (1.5 mm²)
Housing
plastic, UL 94V-0, black
Mounting
twist clip for 35 mm DIN rail, EN 60715 or
M6 screws and washers (not included), torque 2 Nm max.
Mounting position
vertical airflow (air outlet up)
Operating temperature
UL: +14 to +104 °F (-10 to +40 °C)
VDE: +14 to +122 °F (-10 to +50 °C)
Storage temperature
-49 to +158 °F (-45 to +70 °C)
Operating / Storage humidity
max. 90 %RH (non-condensing)
Dimensions
6.65 x 5.0 x 3.5" (169 x 127 x 89 mm)
Weight
approx. 3.1 lbs (1.4 kg)
Protection class / Protection type
heater: II (double insulated), fan: I (grounded) / IP20
Approvals
VDE, UL File No. E234324, GOST-R
Note
other heating capacities and voltages available on request
View: back side
Twist clip mount
Screw mount
Important note: Heater may only be operated together with fan (min. 88 cfm).
Danger of overheating!
Part No. - twist clip mounting
Part No. - screw mounting
Operating voltage
Heating capacity
03082.0-00
03082.0-01
AC 230 V, 50/60 Hz
700 W
Pre-fuse T (time-delay)
4A
03082.9-00
03082.9-01
AC 120 V, 50/60 Hz
700 W
8A
03083.0-00
03083.0-01
AC 230 V, 50/60 Hz
600 W
3.15 A
03083.9-00
03083.9-01
AC 120 V, 50/60 Hz
600 W
6.3 A
03084.0-00
03084.0-01
AC 230 V, 50/60 Hz
500 W
3.15 A
03084.9-00
03084.9-01
AC 120 V, 50/60 Hz
500 W
6.3 A
08.08.2014 | Specifications are subject to change without notice. Suitability of this product for its intended use and any associated risks must be determined by the end customer/buyer in its final application.
The compact high-performance fan heater prevents formation of condensation and provides an evenly distributed
interior air temperature in enclosures with electric/electronic components. The heater may only be operated
together with a fan, but is also available without axial fan (for self-installation). The fan heaters are available
with two different mounting systems – either mounting by screws or with a new and unique twist clip mounting
system. These options allow for a quick and easy installation of the fan heater.
很抱歉,暂时无法提供与“03083.0-01”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+1887.773951+243.69580
- 5+1678.040745+216.62100
- 国内价格
- 1+1762.84424
- 5+1566.98171
