Toll free: 1-888-783-4611 (US & Canada only) · www.stegousa.com
www.stegousa.com
TOUCH-SAFE PTC HEATER
CSF 060 | 50-150 W
>>Low surface temperature
>>Integrated thermostat
>>Compact size
>>Wide voltage range
>>Double insulated protection
>>DIN rail mountable
TECHNICAL DATA
1
Operating voltage1
AC 120-240 V (min. 110 V, max. 265 V)
Heating capacity
see table
Heating element
PTC resistor - temperature limiting
Surface temperature
< 176 °F (80 °C), except upper protective grill
Connection
4-pole terminal AWG 14 max (2.5 mm²), torque 0.8 Nm max.
Housing
plastic, UL 94V-0, black
Mounting
clip for 35 mm DIN rail, EN 60715
Mounting position
vertical
Operating / Storage temperature
-40 to +158 °F (-40 to +70 °C) / -49 to +158 °F (-45 to +70 °C)
Operating / Storage humidity
max. 90 %RH (non-condensing)
Protection class / Protection type
II (double insulated) / IP20
Approvals
VDE, GOST TR
Operating high voltage heaters below AC 140 V reduces heating performance by approx. 10%.
Wiring example
Heating Power (W)
CSF 060 Heater
Ambient Temperature
Part No.
Heating
capacity²
Max. current
(inrush)
Air outlet
temperature³
Switch-off
temperature4
Switch-on
temperature4
Dimensions
Weight (approx.)
06001.0-00
50 W
2.5 A
187 °F (86 °C)
59 °F (15 °C)
41 °F (5 °C)
5.24 x 2.36 x 3.54” (133 x 60 x 90 mm)
10.8 oz. (305 g)
06002.0-00
50 W
2.5 A
187 °F (86 °C)
77 °F (25 °C)
59 °F (15 °C)
10.8 oz. (305 g)
06011.0-00
100 W
4.5 A
248 °F (120 °C)
59 °F (15 °C)
41 °F (5 °C)
11.2 oz. (320 g)
06012.0-00
100 W
4.5 A
248 °F (120 °C)
77 °F (25 °C)
59 °F (15 °C)
11.2 oz. (320 g)
06021.0-00
150 W
8.0 A
293 °F (145 °C)
59 °F (15 °C)
41 °F (5 °C)
6.8 x 2.36 x 3.54” (173 x 60 x 90 mm)
15.9 oz. (450 g)
06022.0-00
150 W
8.0 A
293 °F (145 °C)
77 °F (25 °C)
59 °F (15 °C)
15.9 oz. (450 g)
see Heating Power / Ambient Temperature diagram; measured 2” (50 mm) above protective grill; tolerance of ± 5K
Note: Other Switch-off and Switch-on temperatures on request
2
3
4
08.08.2014 | Specifications are subject to change without notice. Suitability of this product for its intended use and any associated risks must be determined by the end customer/buyer in its final application.
The CSF 060 is a touch-safe heater for use in enclosures. The design of the heater utilizes natural convection
which results in a circulating current of warm air. The surface temperatures on the accessible side surfaces of
the housing are minimized as a result of the heater design. This model with plug-in thermostat does not require
additional wiring. The CSF 060 is also available in a version without thermostat (CS 060).
很抱歉,暂时无法提供与“06001.0-00”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+517.063771+66.89600
- 10+465.2700510+60.19510
