2100/220
2100/220
    KEITHLEY
    KEITHLEY - 2100/220 - Bench Digital Multimeter, 2100 Series, 1 kV, 3 A, 6.5 Digit
2100/220 数据手册
The Model 2100 USB Digital Multimeter is the newest member of Keithley’s family of high performance DMMs. Its high accuracy (38ppm), 6½-digit resolution is ideal for critical measurements. The Model 2100 features 11 measurement functions and 8 math functions to easily accommodate the most commonly measured parameters. All accessories, such as USB cable, probes, and software, are included with the Model 2100. With its unique combination of high precision and low total cost of ownership, the Model 2100 is an unbeatable value for R&D engineers, test engineers, scientists, and students making basic precision measurements on the bench and in system applications. • High precision 6½-digit DMM for critical measurements at a 5½-digit price • 11 measurement functions cover most commonly measured parameters • Fully specified accuracies on all functions for ISO-compliant results • Included PC software utilities for graphing and data sharing in both Microsoft® Word and Excel High Precision, Low Cost The Model 2100 provides stability, accuracy, and speed at a very low cost. It has 0.0038% 1-year basic DC voltage accuracy on the 10V range and 0.013% 1-year basic resistance accuracy on the 10kW range. At 6½ digits, the Model 2100 delivers 50 triggered rdgs/s via the USB remote interface. At the fast 4½ digit setting, it reads over 2000 rdgs/s into its 2000 reading internal buffer. The Model 2100 provides a wide number of measurement ranges and functions: • DC voltage: 0.1V, 1V, 10V, 100V, and 1000V • AC voltage: 0.1V, 1V, 10V, 100V, and 750V • DC current: 10mA, 100mA, 1A, and 3A • AC current: 1A and 3A • Two- and four-wire resistance: 100W, 1kW, 10kW, 100kW, 1MW, 10MW, and 100MW • Frequency: From 3Hz to 300kHz • Rugged construction for durability in bench/portable applications • Period measurement • Selectable front/rear inputs facilitate bench or rack use • Programmable A-D converter and filter settings for signal to noise optimization • Includes all accessories, such as startup software, USB cable, power cable, and safety test lead, for lowest total cost DIGITAL MULTIMETERS & SYSTEMS 6½-Digit USB Digital Multimeter • CE compliant and UL listed • TMC compliant USB 2.0 interface for use with SCPI test programs • Diode measurement Additionally, eight mathematical operations can be performed on measurement readings: RATIO, %, Min/Max, NULL, Limits, mX+b, dB, and dBm testing. Microsoft Office, Word, and Excel add-in tools allow remote storage and recall of the measured values from these applications. A graphing utility enables charting of measurements versus time for trending and noise observations. The TMC compliant USB remote interface enables control from a PC for consistent test/calibration procedure execution and easy re-use of existing SCPI programs, including Agilent Model 34401A command emulation. Simple to Use The Model 2100 can be setup quickly and is very easy to use. It has a high contrast front panel and keypad that are intuitive and user-friendly. An easy to read 5×7 dot matrix, vacuum fluorescent display (VFD) offers three-color annunciators so users can easily distinguish each function symbol by its color. Strength and Versatility With its rugged construction and rubber bumpers, the Model 2100 has the durability to withstand bench, portable, or stacking applications. A sturdy carrying handle facilitates transportability. 1.888.KEITHLEY (U.S. only) www.keithley.com A Greater Measure of Confidence Low cost 6½-digit DMM for portable, bench, and USB-based system applications Low cost 6½-digit DMM for portable, bench, and USB-based system applications 2100 2100/100 6½-digit USB Digital Multimeter (100V) 2100/120 6½-digit USB Digital Multimeter (120V) 2100/220 6½-digit USB Digital Multimeter (220V) 2100/230-240 6½-digit USB Digital Multimeter (230-240V) Applications The Model 2100 USB Digital Multimeter is ideal for applications in: electronic device, circuit, module, and product testing; low cost production testing of electrical and electronic components, sub-assemblies, and end products; and student lab assignments. Typical applications include: • Test Engineers: Manual and semi-automatic electrical functional test • Development Engineers: Electrical/electronic circuit and product validation • Service/Calibration Technicians: Electronic product repair and calibration • Research Scientists: Electrical and physics experiments testing • Engineering Students: Electronic device and circuits experiment testing Accessories Supplied Instruction manual on CD, Specifications, LabVIEW® Driver, Keithley I/O Layer, USB Cable, Power Cable, Safety Test Leads, KI-Tool, and KI-Link Add-in (Both Microsoft Word and Excel versions) Accessories Available Rack Mount Kits 4299-3 Single Rack Mount Kit 4299-4 Dual Rack Mount Kit 8605 High Performance Modular Test Leads 8606 High Performance Modular Probe Kit Services Available 2100/120-3Y-EW 1 Year Factory Warranty extended to 3 years from date of shipment C/2100/120-3Y-DATA 3 (Z540-1 compliant) Calibrations within 3 years of purchase for Model 2100/120* C/2100/120-3Y-ISO 3 (ISO-17025 accredited) Calibrations within 3 years of purchase for Model 2100/120* *Not available in all countries Startup Software, PC Utilities Included The KI-Tool application provides charting and graphing capabilities without programming to simplify setup, checkout, and basic measurement applications requiring graphical data representation. Scale, offset, and level can be adjusted to fine tune images for visual evaluation of signal and noise elements over time. It also includes tabular data and SCPI command prompt windows for maximum flexibility. Data sets can also be saved to disk files. The Microsoft Excel Add-In utility is also included and provides quick data import into a standard Microsoft Excel spreadsheet, including selectable graphing, instrument settings, and number of data points collected. Data can then be analyzed through standard or optional Microsoft Excel functions, including graphical, statistical, and trend charting. A version supporting Microsoft Word is also included for direct data import into reports. 1.888.KEITHLEY (U.S. only) www.keithley.com A Greater Measure of Confidence Low cost 6½-digit DMM for portable, bench, and USB-based system applications Ordering Information 6½-Digit USB Digital Multimeter DIGITAL MULTIMETERS & SYSTEMS Low cost 6½-digit DMM for portable, bench, and USB-based system applications 2100 2100 6½-Digit USB Digital Multimeter Specifications Function DC Voltage Model 2100 specifications Function DCI (DC Current) Function Resistance2 Diode Test Continuity Range 100.0000 mV 1.000000 V 10.00000 V 100.0000 V 1000.000 V Resolution 0.1 µV 1.0 µV 10 µV 100 µV 1 mV Input Resistance >10 GW >10 GW >10 GW 10 MW 10 MW 1 Year, 23°C ±5°C 0.0055 + 0.0040 0.0045 + 0.0008 0.0038 + 0.0006 0.0050 + 0.0007 0.0055 + 0.0010 Range 10.00000 mA 100.0000 mA 1.000000 A 3.00000 A Resolution 10 nA 100 nA 1 µA 10 µA Shunt Resistance 5.1 W 5.1 W 0.1 W 0.1 W 1 Year, 23°C ±5°C 0.055 + 0.025 0.055 + 0.006 0.120 + 0.015 0.150 + 0.025 Range 100.0000 W 1.000000 kW 10.00000 kW 100.0000 kW 1.000000 MW 10.00000 MW 100.0000 MW 1.0000 V 1000.00 W Resolution 100 µW 1 mW 10 mW 100 mW 1 W 10 W 100 W 10 µV 10 mW Test Current 1 mA 1 mA 100 µA 10 µA 5 µA 500 nA 500 nA||10 MW 1 mA 1 mA 1 Year, 23°C ±5°C 0.015 + 0.005 0.015 + 0.002 0.013 + 0.002 0.015 + 0.002 0.017 + 0.002 0.045 + 0.002 1.00  + 0.020 0.040 + 0.020 0.024 + 0.030 DC Notes 1. Specifications valid after two hour warm-up. a. ADC set for continuous trigger operation. b. Input bias current
2100/220 价格&库存
很抱歉,暂时无法提供与“2100/220”相匹配的价格&库存,您可以联系我们找货
    • 1+17029.17497
    库存:1
