2260B-800-4
2260B-800-4
    KEITHLEY
    KEITHLEY - 2260B-800-4 - Bench Power Supply, Multi Range DC, Programmable, 1 Output, 0 V, 800 V, 0 A...
2260B-800-4 数据手册
Series 2260B Programmable DC Power Supplies W 3-Y ar ea ra r nt y • 360W, 720W, and 1080W versions with voltages up to 800V and currents up to 108A • Programmable internal resistance simulates battery output • Choose from analog control, USB, LAN, or optional GPIB interface for automated control • Fit six 71mm wide 360W units or three 142mm wide 720W units or two 214mm wide 1080W units in a standard rack width to minimize bench and test system space Source a wide range of voltages and currents with the 360W, 720W, or 1080W Series 2260B Programmable DC Power Supplies. Choose from 12 versions with voltage output of 30V, 80V, 250V or 800V. The 360W versions can output current of 36A, 13.5A, 4.5A, or 1.44A; the 720W models can output 72A, 27A, 9A, or 2.88A; and the 1080W instruments can output 108A, 40.5A, 13.5A or 4.32A. This wide range of output voltages and current, combined with multiple interface choices, makes the Series 2260B ideal for use in a wide range of applications, including research and design, quality control, and production test. Control the Voltage or Current Rise Time to Reduce Inrush Current and Prevent Device Damage Series 2260B power supplies have programmable rise time (or slew rate) control to prevent potentially dangerous inrush currents from flowing into loads that have low resistance when power is initially supplied. Either voltage or current rise time can be controlled. With voltage slew rate control, voltage rise time can range from a slow, 0.1V/s to a high speed of 1600V/s for the 800V supplies. When operating under constant current control, output current rise time can be programmed from a low slew rate of 0.001A/s to a maximum value of 216A/s for the Model 2260B-30-108. Programming a current rise time puts the Series 2260B power supplies in a constant current control priority mode in which the current slew rate limits the rate at which the voltage rises across the device under test (DUT.) In addition to controlling rise time, fall time can also be programmed; fall time values can be different from rise time values. Delivery of power to a load can be precisely controlled to prevent overshoot spikes and excessive amounts of inrush current, eliminating damage to components, modules, or devices and generating more precise characteristic I-V curves for components such as LEDs. APPLICATIONS 40V/s • Environmental test, stress test, and accelerated life testing 20V/s • LED and high power component testing   5V/s 10V/s • Automotive testing • Battery research and test • Production test Precisely control voltage rise time with the variable slew rate control. WWW.KEITHLEY.COM Programmable DC power supplies • Constant current priority setting reduces voltage and current overshoot when powering LEDs DC POWER SUPPLIES Programmable DC power supplies • Programmable voltage or current rise and fall times prevents damage to low impedance loads from inrush current Programmable DC power supplies Ordering Information 2260B-30-36 Programmable DC 360W Power Supply, 30V, 36A 2260B-80-13 Programmable DC 360W Power Supply, 80V, 13.5A 2260B-250-4 Programmable DC 360W Power Supply, 250V, 4.5A 2260B-800-1 Programmable DC 360W Power Supply, 800V, 1.44A 2260B-30-72 Programmable DC 720W Power Supply, 30V, 72A 2260B-80-27 Programmable DC 720W Power Supply, 80V, 27A 2260B-250-9 Programmable DC 720W Power Supply, 250V, 9A 2260B-800-2 Programmable DC 720W Power Supply, 800V, 2.88A 2260B-30-108 Programmable DC 1080W Power Supply, 30V, 108A 2260B-80-40 Programmable DC 1080W Power Supply, 80V, 40.5A 2260B-250-13 Programmable DC 1080W Power Supply, 250V, 13.5A 2260B-800-4 Programmable DC 1080W Power Supply, 800V, 4.32A DC POWER SUPPLIES Accessories Supplied 2260B Basic Accessory Kit (for 30V and 80V models) 2260B-010 Basic Accessories Kit (for 250V/800V Series) Quick Start Guide Documentation CD with Manuals and Software Drivers Test Lead Set (for 30V and 80V models) 2260-009 Test Lead (for 250V/800V models) USB Cable Power Cord Certificate of Traceable Calibration WWW.KEITHLEY.COM Programmable DC Power Supplies Emulate the Response of a Battery Test a circuit or device under the most realistic conditions by applying a test source with the output resistance that is equivalent to the output resistance of the actual source that will be used to power the circuit or device. For example, a battery has a varying internal resistance, and a device powered by a battery will have a voltage applied to the device that is reduced by the voltage drop across the battery’s internal resistance. Versions of the Series 2260B power supplies can have an internal resistance up to 555Ω to simulate a wide range of battery chemistries and load conditions. 10V @ 4Ω load Internal Resistance = 0Ω I = 2.5A Internal Resistance = 0.9Ω I=10V/(4Ω + 0.9Ω) = 2.04A VLoad = 10V – (2.04A*0.9Ω) = 8.16V Internal Resistance = 1.8Ω I = 10V/(4Ω + 1.8Ω) = 1.72A VLoad = 10V – (1.72A*1.8Ω) = 6.90V Internal Resistance = 2.7Ω I = 10V/(4Ω + 2.7Ω) = 1.49A VLoad = 10V – (1.49A*2.7Ω) = 5.98V Use the programmable internal resistance to simulate a battery’s output. In this example, a Model 2260B-80-13 power supply is simulating a 10V battery whose internal resistance is 0W, 0.9W, 1.8W, and 2.7W. The resulting voltage at the output terminals drops from 10V to 5.98V due to the voltage drop across the internal resistance of the battery. Flexible and Fast for Automated Test Systems With their USB, LAN, or optional GPIB interfaces, Series 2260B power supplies will work in any automated system. In addition, these power supplies have an analog control capability that can control outputs via an external voltage and resistance. Furthermore, Series 2260B power supplies feature fast discharge capability to quickly dissipate the voltage on the output. These power supplies also have a fast, 1ms transient recovery time to load changes. This combination of fast discharge time and fast transient response minimizes critical test time in automated test systems. Programmable DC power supplies Series 2260B Programmable DC Power Supplies ACCESSORIES AVAILABLE 2260-001 Accessory Kit 2260-002 Simple IDC Tool 2260-003 Contact Removal Tool 2260-004 Basic Accessories kit 2260-005 Cable for 2 units in Series connection 2260-006 Cable for 2 units in Parallel connection 2260-007 Cable for 3 units in Parallel connection 2260-008 Test Lead Set with Lugs 2260-009 Test Leads (250V, 800V models) 2260-010 Basic Accessories Kit (250V, 800V models) 2260B-EXTERM-HV Extended Terminal (for 250V/800V HV models) 2260B-GPIB-USB GPIB-to-USB Adapter 2260B-EXTERM Extended Terminal 2260B-RMK-JIS Rack Mount Kit (JIS racks) 2260B-RMK-EIA Rack Mount Kit (EIA racks) USB-B-1 USB Cable SERVICES AVAILABLE Model Number*-EW A signal generator (top plot) controls the 2260B to create a complex DC supply waveform (bottom plot) that simulates both a voltage drop due to a large inrush current and noise on the DC supply line. Rear panel of 360W models. WWW.KEITHLEY.COM Rear panel of 720W models. 3-year factory warranty extended to 1 additional year from date of shipment Model Number*-5Y-EW 3-year factory warranty extended to 5 years from date of shipment C/Model Number*-3Y-STD KeithleyCare® 3 Year Standard Calibration Plan C/Model Number*-3Y-DAT KeithleyCare 3 Year Calibration with Data Plan C/Model Number*-5Y-STD KeithleyCare 5 Year Standard Calibration Plan C/Model Number*-5Y-DAT KeithleyCare 5 Year Calibration with Data Plan * Replace the specific power supply model number in place of Model Number to generate the appropriate model number for a service item. For example, for Model 2260B-30-36, a 1-year extended warranty model number would be 2260B-30-36-1-EW. Rear panel of 1080W models. Programmable DC power supplies Model 2110 specifications Create Custom Voltage Source Waveforms An internal test sequence mode allows the Series 2260B supplies to output a set of voltage levels for varying time intervals at each level. The test sequence can be stored and used repeatedly to determine DUT performance at number of voltage levels. In addition, the analog input control can be used to create voltage profiles that simulate how a battery responds to a fast changing load current requirement such as a large inrush current. Also, generate a combined DC output level with an AC signal superimposed on it to test how a circuit responds to noise on its DC power source. The analog input control parameter can be either a voltage input or a resistance input. With this analog control capability, numerous types of DC supply signals can be generated to test circuits and devices under a wide range of circumstances. DC POWER SUPPLIES Series 2260B Series 2260B Programmable DC Power Supplies 2260B30-36 2260B30-72 2260B30-108 2260B80-13 2260B80-27 2260B80-40 2260B250-4 2260B250-9 2260B250-13 2260B800-1 2260B800-2 2260B800-4 0–30 V 0–36 A 360 W 0–30 V 0–72 A 720 W 0–30 V 0–108 A 1080 W 0–80 V 0–13.5 A 360 W 0–80 V 0–27 A 720 W 0–80 V 0–40.5 A 1080 W 0–250 V 0–4.5 A 360 W 0–250 V 0–9 A 720 W 0–250 V 0–13.5 A 1080 W 0–800 V 0–1.44 A 360 W 0–800 V 0–2.88 A 720 W 0–800 V 0–4.32 A 1080 W RIPPLE AND NOISE (Noise bandwidth 20 MHz, ripple bandwidth 1 MHz) 60 mV 80 mV 100 mV 60 mV 80 mV CV p-p 7 mV 11 mV 14 mV 7 mV 11 mV CV rms 72 mA 144 mA 216 mA 27 mA 54 mA CC rms 100 mV 14 mV 81 mA 80 mV 15 mV 10 mA 100 mV 15 mV 20 mA 120 mV 15 mV 30 mA 150 mV 30 mV 5 mA 200 mV 30 mV 10 mA 200 mV 30 mV 15 mA PROGRAMMING ACCURACY 0.1% + Voltage 10 mV 0.1% + Current 30 mA Series 2260B specifications OUTPUT RATING Voltage Current Power 0.1% + 10 mV 0.1% + 60 mA 0.1% + 10 mV 0.1% + 100 mA 0.1% + 10 mV 0.1% + 10 mA 0.1% + 10 mV 0.1% + 30 mA 0.1% + 10 mV 0.1% + 40 mA 0.1% + 200 mV 0.1% + 5 mA 0.1% + 200 mV 0.1% + 10 mA 0.1% + 200 mV 0.1% + 15 mA 0.1% + 400 mV 0.1% + 2 mA 0.1% + 400 mV 0.1% + 4 mA 0.1% + 400 mV 0.1% + 6 mA 0.1% + 10 mV 0.1% + 30 mA 0.1% + 10 mV 0.1% + 60 mA 0.1% + 10 mV 0.1% + 100 mA 0.1% + 10 mV 0.1% + 10 mA 0.1% + 10 mV 0.1% + 30 mA 0.1% + 10 mV 0.1% + 40 mA 0.1% + 200 mV 0.1% + 5 mA 0.1% + 200 mV 0.1% + 10 mA 0.1% + 200 mV 0.1% + 15 mA 0.1% + 400 mV 0.1% + 2 mA 0.1% + 400 mV 0.1% + 4 mA 0.1% + 400 mV 0.1% + 6 mA 50 ms 50 ms 500 ms 50 ms 50 ms 500 ms 50 ms 50 ms 500 ms 50 ms 50 ms 500 ms 50 ms 50 ms 500 ms 50 ms 50 ms 500 ms 100 ms 150 ms 1200 ms 100 ms 150 ms 1200 ms 100 ms 150 ms 1200 ms 150 ms 300 ms 2000 ms 150 ms 300 ms 2000 ms 150 ms 300 ms 2000 ms 1 ms 1 ms 1 ms 1 ms 1 ms 1 ms 2 ms 2 ms 2 ms 2 ms 2 ms 2 ms PROGRAMMING RESOLUTION (by PC Remote Control Mode) 1 mV 1 mV 1 mV 2 mV Voltage 1 mA 2 mA 3 mA 1 mA Current 2 mV 2 mA 2 mV 3 mA 5 mV 1 mA 5 mV 1 mA 5 mV 1 mA 14 mV 1 mA 14 mV 1 mA 14 mV 1 mA MEASUREMENT RESOLUTION (by PC Remote Control Mode) 1 mV 1 mV 1 mV 2 mV Voltage 1 mA 2 mA 3 mA 1 mA Current 2 mV 2 mA 2 mV 3 mA 5 mV 1 mA 5 mV 1 mA 5 mV 1 mA 14 mV 1 mA 14 mV 1 mA 14 mV 1 mA 0.1% ± 20 mV 0.1% ± 40 mA 0.1% ± 20 mV 0.1% ± 50 mA 0.1% ± 200 mV 0.1% ± 5 mA 0.1% ± 200 mV 0.1% ± 10 mA 0.1% ± 200 mV 0.1% ± 20 mA 0.1% ± 400 mV 0.1% ± 2 mA 0.1% ± 400 mV 0.1% ± 4 mA 0.1% ± 400 mV 0.1% ± 6 mA READBACK ACCURACY Voltage Current RESPONSE TIME Rise Time Fall Time (full load) Fall Time (no load) Load Transient Recovery Time (load change from 50 to 100%) DC POWER SUPPLIES FRONT PANEL DISPLAY ACCURACY 0.1% ± 0.1% ± Voltage 20 mV 20 mV 0.1% ± 0.1% ± Current 40 mA 70 mA WWW.KEITHLEY.COM 0.1% ± 20 mV 0.1% ± 100 mA 0.1% ± 20 mV 0.1% ± 20 mA Series 2260B specifications Specifications (23°C ±5°C) Programmable DC Power Supplies REGULATION (CV): Load: 0.05% of setting + 5mV. Line: 0.05% of setting + 3mV. REGULATION (CC): Load: 0.1% of setting + 5mA. Line: 0.1% of setting + 5mA. VOLTAGE SLEW RATE RANGE: Rising and Falling: 0.1V/s to 60V/s (2260B-30-36, 2260B-30-72, 260B-30-108). 0.1V/s to 160V/s (2260B-80-13, 2260B-80-27, 2260B-80-40). 0.1V/s to 60V/s (2260B-250-4, 2260B-250-9, 2260B-250-13). 1V/s to 1600V/s (2260B-800-1, 2260B-800-2, 2260B-800-4). CURRENT SLEW RATE RANGE: Rising and Falling: 0.01  A/s to 72.00A/s (2260B-30-36). 0.1   A/s to 144.0A/s (2260B-30-72). 0.1   A/s to 216.0A/s (2260B-30-108). 0.01  A/s to 27.00A/s (2260B-80-13). 0.01  A/s to 54.00A/s (2260B-80-27). 0.01  A/s to 81.00A/s (2260B-80-40). 0.001A/s to 9.000A/s (2260B-250-4). 0.01  A/s to 18.00A/s (2260B-250-9). 0.01  A/s to 27.00A/s (2260B-250-13). 0.001A/s to 2.880A/s (2260B-800-1). 0.001A/s to 5.760A/s (2260B-800-2). 0.001A/s to 8.640A/s (2260B-800-4). MAXIMUM VOLTAGE DROP IN EACH LOAD WIRE WHEN USING REMOTE SENSE: 30V and 80V Models: 0.6V. 250V and 800V Models: 1V. OUTPUT DELAY TIME RANGE: On Delay and Off Delay: 0s to 99.99s. INTERNAL RESISTANCE RANGE: 0.000Ω to 0.833Ω (2260B-30-36). 0.000Ω to 0.417Ω (2260B-30-72). 0.000Ω to 5.926Ω (2260B-80-13). 0.000Ω to 2.963Ω (2260B-80-27). 0.000Ω to 0.278Ω (2260B-30-108). 0.000Ω to 1.975Ω (2260B-80-40). 0.00  Ω to 55.55Ω (2260B-250-4). 0.00  Ω to 27.77Ω (2260B-250-9). 0.00  Ω to 18.51Ω (2260B-250-13). 0.0  Ω to 555.5Ω (2260B-800-1). 0.0  Ω to 277.8Ω (2260B-800-2). 0.0  Ω to 185.4Ω (2260B-800-4). SERIES AND PARALLEL CAPABILITY: Parallel Operation: Up to 3 units including the master unit. Series Operation: Up to 2 units including the master unit (30V and 80V models only). PROTECTION FUNCTIONS: OVP: 10% to 100% of rated output voltage range. Accuracy: ±2% of rated output voltage. OCP: ~10% to 110% of rated output current range. Accuracy: ±2% of rated output current. OTP: Activated by elevated internal temperatures. ISOLATION VOLTAGE: 500VDC, output to chassis. ANALOG VOLTAGE CONTROL: Voltage Setting Accuracy: ±0.5% of rated output voltage. Current Setting Accuracy: ±1% of rated output current. ANALOG RESISTANCE CONTROL: Voltage Setting Accuracy: ±1.5% of rated output voltage. Current Setting Accuracy: ±1.5% of rated output current. ANALOG CONTROL: External voltage or resistance control of output, voltage and current monitor outputs, turn-on, turn-off control, status monitoring, 26-Pin Connector (Rear Panel). INTERFACE: USB: 1.1/2.0,Type A Host (Front Panel), Type B Control (Rear Panel). LAN: 100BASE-T (100Mb/s). GPIB: (with optional 2260B-GPIB-USB Adapter). AC INPUT RANGE: 85VAC-265VAC, 50/60Hz, single phase MAXIMUM POWER CONSUMPTION: 500VA (2260B-30-36, 2260B-80-13, 2260B-250-4, 2260B-800-1). 1000VA (2260B-30-72, 2260B-80-27, 2260B-250-9, 2260B-800-2). 1500VA (2260B-30-108, 2260B-80-40, 2260B-250-13, 2260B-800-4) POWER FACTOR: 0.97 to 0.99 (typical). FAN: With thermal sensing control ENVIRONMENT: Operating: 0° to 50°C, 20% to 85% RH. Storage: –25° to 70°C, 90% RH or less. TEMPERATURE COEFFICIENT (after 30 minutes warm-up): Voltage: 100ppm/°C. Current: 200ppm/°C. SAFETY: Complies with European Union Low Voltage Directive. ELECTROMAGNETIC COMPATIBILITY: Complies with European Union EMC Directive. DIMENSIONS, WEIGHT: 360W Models: 71mm wide × 124mm high × 350mm deep (2.80 in. × 4.88 in. × 13.78 in.). Net Weight: Approx. 3kg (6.6 lb.). Shipping Weight: 4.3kg (9.5 lb.). 720W Models: 142.5mm wide × 124mm high × 350mm deep (5.61 in. × 4.88 in. × 13.78 in.). Net Weight: Approx. 5kg (11 lb.). Shipping Weight: 6.8kg (15 lb.). 1080W Models: 214mm wide × 124mm high × 350mm deep (8.43 in × 4.88 in × 13.78in). Net Weight: Approx 7.5kg (16.5 lb.). Shipping Weight: 9.6kg (21 lb.) WARRANTY: 3 years. Series 2260B specifications GENERAL DC POWER SUPPLIES Series 2260B specifications Series 2260B WWW.KEITHLEY.COM Series 2260B Programmable DC Power Supplies Model 2260-001: Accessory Kit: Analog control mating connector, pins, cover, and ground wire. Model 2260-002: Simple IDC tool. Model 2260-004: Accessory Kit (30V and 80V models): Air filter, analog connector cover, analog control lock lever, M8-size output terminal bolts, washers and screws, and M4-size output terminal screws with washers. Model 2260-009: Test Lead Set for 250V and 800V models, two sets of red and black wires, 20AWG, 1.22m (48 in), stripped wires on one end and lugs on the other end. Model 2260-005: Cable, 0.5m (1.6 ft.), to connect two series 2260B power supplies in series. Model 2260-010: Basic Accessories Kit (250V and 800V models): Air filter, analog protection cover, analog control lock lever, output terminal cover, output terminal connector, strain relief. DC POWER SUPPLIES Model 2260-003: Contact removal tool. Model 2260-006: Cable, 0.5m (1.6 ft.), to connect two series 2260B power supplies in parallel. Model 2260B-EXTERM: Extended terminal; Test Leads, 0.7m (28 in.), and terminal box to bring outputs to the front of the instrument or another location. Magnetic base attaches to side of instrument. Model 2260-008: Test lead set with lugs, 10AWG, 1.22m (48 in), red/blue wire pair with #10 terminal lugs on each end. WWW.KEITHLEY.COM Model 2260-007: Cable, 0.5m (1.6 ft.), to connect three series 2260B power supplies in parallel. Series 2260B Accessories Series 2260B Accessories Series 2260B Accessories Model 2260B-EXTERM-HV: Extended terminal for 250V and 800V models; test leads and terminal box to bring outputs to the front of the instrument or another location. Magnetic base attached to side of instrument. Model 2260B-GPIB-USB Adapter: Provides a GPIB interface for the Series 2260B power supplies. Model 2260B-RMK-EIA: Rack mount kit (EIA racks). Programmable DC power supplies Programmable DC Power Supplies Model 2260B-RMK-JIS: Rack mount kit (JIS racks). DC POWER SUPPLIES Model 2110 specifications Series 2260B WWW.KEITHLEY.COM Contact Information: ASEAN / Australia (65) 6356 3900 Austria 00800 2255 4835 Balkans, Israel, South Africa and other ISE Countries +41 52 675 3777 Belgium 00800 2255 4835 Brazil +55 (11) 3759 7627 Canada 1 800 833 9200 Central East Europe and the Baltics +41 52 675 3777 Central Europe & Greece +41 52 675 3777 Denmark +45 80 88 1401 Finland +41 52 675 3777 France 00800 2255 4835 Germany 00800 2255 4835 Hong Kong 400 820 5835 India 000 800 650 1835 Italy 00800 2255 4835 Japan 81 (3) 6714 3010 Luxembourg +41 52 675 3777 Mexico, Central/South America & Caribbean 52 (55) 56 04 50 90 Middle East, Asia, and North Africa +41 52 675 3777 The Netherlands 00800 2255 4835 Norway 800 16098 People’s Republic of China 400 820 5835 Poland +41 52 675 3777 Portugal 80 08 12370 Republic of Korea 001 800 8255 2835 Russia & CIS +7 (495) 6647564 South Africa +41 52 675 3777 Spain 00800 2255 4835 Sweden 00800 2255 4835 Switzerland 00800 2255 4835 Taiwan 886 (2) 2656 6688 United Kingdom & Ireland 00800 2255 4835 USA 1 800 833 9200 Rev 0415 For Further Information Tektronix maintains a comprehensive, constantly expanding collection of application notes, technical briefs and other resources to help engineers working on the cutting edge of technology.Visit www.tektronix.com or www.keithley.com. Copyright © 2015, Tektronix. All rights reserved. Tektronix products are covered by U.S. and foreign patents, issued and pending. Information in this publication supersedes that in all previously published material. Specification and price change privileges reserved. TEKTRONIX and TEK are registered trademarks of Tektronix, Inc. All other trade names referenced are the service marks, trademarks or registered trademarks of their respective companies. 9.21.15 KI 1KW-60208-0 A Tektronix Company WWW.KEITHLEY.COM
2260B-800-4 价格&库存
很抱歉,暂时无法提供与“2260B-800-4”相匹配的价格&库存,您可以联系我们找货
