2380-RM
2380-RM
    KEITHLEY
    KEITHLEY - 2380-RM - Rack Mount Kit, Rack Mount Kit, Keithley 2380 Series Programmable DC Electronic...
2380-RM 数据手册
Series 2380 programmable DC electronic loads can sink a wide range of voltages and currents. The 200W Model 2380-500-15 can accept up to 500V or 15A. The 250W Model 2380-120-60 can accept up to 120V or 60A. The 750W Model 2380- 500 30 can accept up to 500V or 30A. These single-output, stand-alone electronic loads are cost-effective and self-contained. Multiple Operating Modes • 200W, 250W, and 750W models • Supports up to 500V or 60A • Constant current (CC),constant voltage (CV), constant resistance (CR), and constant power (CP) operating modes • LED simulated load test mode • Readback voltage and current resolution down to 0.1mV/0.01mA • Dynamic mode with cycle rate up to 25kHz • Voltage rise and fall time measurement • Current monitor function • List mode • Battery test mode These DC electronic loads can operate in constant current (CC), constant voltage (CV), constant resistance (CR), or constant power (CP) mode. They can also be configured to provide a dynamically changing load to the DC source with load switching times as fast as 25kHz. Versatile internal, external, and remote triggering options allow synchronizing the dynamic load behavior with other events. Comprehensive Protection Protection functions built into Series 2380 DC electronic loads ensure the reliability and safety of all tests. These functions include over temperature protection (OTP), over voltage protection (OVP), over current protection (OCP), over power protection (OPP), and local/remote reverse voltage (LRV/RRV) protection. A power-on system self-test ensures the instrument is operating properly. Programmable DC Electronic Loads Programmable DC Electronic Loads Full Complement of Settings and Controls To maximize testing efficiency, you can save test parameters into any one of 100 memory locations for quick recall. All load parameters, such as voltage, current, slew rate, and dynamic mode time intervals, can be set using the front panel controls or programmed remotely. A numeric keypad and rotary knob allow entering settings quickly and setting parameters to their full resolution easily. USB-TMC, GPIB and RS-232 interfaces are built in for remote control and communication. A current monitor interface simplifies monitoring input current waveforms by providing a connection for an oscilloscope. • Built-in GPIB,USB, and RS-232 interfaces Figure 1. Use either the rotary knob or the keypad to quickly enter settings and set parameter values using all the available resolution. A Tektronix Company DC POWER SUPPLIES Programmable DC electronic loads Series 2380 2380 Programmable DC Electronic Loads Programmable DC Electronic Loads Ordering Information 2380-500-15 Programmable DC Electronic Load, 500V, 15A, 200W 2380-120-60 Programmable DC Electronic Load, 120V, 60A, 250W 2380-500-30 Programmable DC Electronic Load, 500V, 30A, 750W 2380J-500-15 Programmable DC Electronic Load, 500V, 15A, 200W-Japan only 2380J-120-60 Programmable DC Electronic Load, 120V, 60A, 250W-Japan only 2380J-500-30 Programmable DC Electronic Load, 500V, 30A, 750W-Japan only Model 2380-500-15 rear panel Model 2380-500-30 rear panel ACCESSORIES AVAILABLE Accessories Supplied Quick Start Guide Documentation CD Power cord 2380-001 9-pin Rear Panel Mating Connector 2380-002 DUT Connection Protective Cover 7007-2 Double-Shielded Premium IEEE-488 Interface Cable, 2m (6.5 ft) KP-CL-488LPA IEEE-488.2 Interface Board for the PCI Bus USB-B-1 APPLICATIONS • Environmental test, stress test, and accelerated life testing for AC/DC power sources and DC/DC modules DC POWER SUPPLIES • LED lighting drivers and high power component testing Model 2380-500-15 front view showing the safety covers on the input terminals. USB Cable, Type A Connector to Type B Connector, 1m (3.3 ft) RACK MOUNT KITS FOR THE 2380-500-15 AND THE 2380-120-60 4299-7 Universal Fixed Rack Mount Kit RMU2U Fixed Rack Mount Kit 386759800 RMU2U Rack Mount Cosmetic Filler Panel RACK MOUNT KIT FOR THE 2380-500-30 2380-RM Full-Rack-Width Instrument Fixed Rack Mount Kit SERVICES AVAILABLE Model Number*-1-EW 3-year factory warranty from date of shipment extended 1 additional year Model Number*-5Y-EW 3-year factory warranty from date of shipment extended to 5 years C/Model Number*-3Y-STD KeithleyCare 3 YR STD Calibration Plan C/Model Number*-3Y-DAT KeithleyCare 3 YR Calibration w/Data Plan C/Model Number*-5Y-STD KeithleyCare 5 YR STD Calibration Plan C/Model Number*-5Y-DAT KeithleyCare 5 YR Calibration w/Data Plan * Replace the specific power supply model number in place of Model Number to generate the appropriate model number for a service item. Example for a 2380-500-15, a 1-year extended warranty model number would be 2380-500-15-EW. • Automotive electronics testing • Battery research and discharge testing • Production test A Tektronix Company 2380 Programmable DC Electronic Loads Specifications Constant Voltage Mode Constant Current Mode Constant Resistance Mode 1 Constant Power Mode 3 High Range 0–500 V 0–15 A 200 W 0.6 V at 3 A (maximum 0.9 V) 4.5 V at 15 A 0.1–50 V 1 mV ±(0.05% + 0.025% FS) 0–3 A 0.1 mA ±(0.05% + 0.05% FS) 0.3 Ω–10 Ω 0.001 Ω 0.01% + 0.08 S 200 W 10 mW 0.1% + 0.1% FS 0.1– 500 V 10 mV ±(0.05% + 0.025% FS) 0–15 A 1 mA ±(0.05% + 0.05% FS) 10 Ω–7.5 kΩ 0.1 Ω 0.01% + 0.0008 S 200 W 10 mW 0.1% + 0.1% FS 20 µs–3600 s; Res: 1 µs 5 µs ± 100 ppm 20 µs–3600 s; Res: 1 µs 5 µs ± 100 ppm 0.0001–0.1 A/µs 0.001–1 A/µs ~10 µs ~10 µs 0–50 V 1 mV ±(0.025% + 0.025% FS) 0–3 A 0.01 mA ±(0.05% + 0.05% FS) 200 W 10 mW ±(0.1% + 0.1% FS) 0–500 V 10 mV ±(0.025% + 0.025% FS) 0–15 A 0.1 mA ±(0.05% + 0.05% FS) 200 W 10 mW ±(0.1% + 0.1% FS) ~210 W ~3.3 A ~530 V ~85°C ~210 W ~16.5 A ~530 V ~85°C Dynamic Mode CC Mode Rated Value (0°–40°C) Constant Voltage Mode Constant Current Mode Constant Resistance Mode 1 Constant Power Mode 3 Low Range 0–120 V 0–6 A 250 W High Range 0–120 V 0–60 A 250 W 0.18 V at 6 A 1.8 V at 60 A 0–18 V 1 mV ±(0.05% + 0.025% FS) 0–6 A 0.1 mA ±(0.05% + 0.1% FS) 0.05 Ω–10 Ω 0.001 Ω 0.01% + 0.08 S 250 W 10 mW 0.2% + 0.2% FS 0–120 V 10 mV ±(0.05% + 0.025% FS) 0–60 A 1 mA ±(0.05% + 0.1% FS) 10 Ω–7.5 kΩ 0.1 Ω 0.01% + 0.0008 S 250 W 10 mW 0.2% + 0.2% FS T1 & T2 Accuracy Ascending/ Descending Slope 4 Minimum Rise Time 5 20 µs–3600 s; Res: 1 µs 5 µs ± 100 ppm 20 µs–3600 s; Res: 1 µs 5 µs ± 100 ppm 0.0001–0.25 A/µs 0.001–2.5 A/µs ~20 µs ~20 µs Range Resolution Accuracy Range Resolution Accuracy Range Resolution Accuracy 0–18 V 0.1 mV ±(0.025% + 0.025% FS) 0–6 A 0.1 mA ±(0.05% + 0.1% FS) 250 W 10m W ±(0.2% + 0.2% FS) 0–120 V 1 mV ±(0.025% + 0.025% FS) 0–60 A 1 mA ±(0.05% + 0.1% FS) 250 W 10m W ±(0.2% + 0.2% FS) ~260 W ~6.6 A ~130 V ~85°C ~260 W ~66 A ~130 V ~85°C Input Voltage Input Current Input Power Min. Operating Voltage Range Resolution Accuracy Range Resolution Accuracy Range Resolution Accuracy 2 Range Resolution Accuracy Dynamic Mode T1 & T2 Accuracy Ascending/ Descending Slope 4 Minimum Rise Time 5 Measuring Range Range Readback Voltage Resolution Accuracy Range Readback Current Resolution Accuracy Range Readback Power Resolution Accuracy Measuring Range Protection Range Overpower Protection Overcurrent Protection Overvoltage Protection Over Temperature Protection Specification Current (CC) Short Circuit Voltage (CV) Resistance (CR) Input Terminal Impedance Dimensions CC Mode Readback Voltage Readback Current Readback Power Protection Range Overpower Protection Overcurrent Protection Overvoltage Protection Over Temperature Protection Specification ~3.3 / 3 A ~16.5 / 15 A ~0 V ~0 V ~300 mΩ ~300 mΩ ~1 MΩ ~1 MΩ 214.81mm × 104.24mm × 397.03mm Current (CC) Voltage (CV) Resistance (CR) Input Terminal Impedance Dimensions Short Circuit ~6.6 / 6 A ~66 / 60 A 0V 0V ~30 mΩ ~30 mΩ ~300 kΩ ~300 kΩ 214.81mm ×104.24mm × 397.03mm NOTES* 1. 2. 3. 4. 5. The voltage/current input is no less than 10% FS (FS indicates the full scale). Accuracy is defined as: % of reading + % of full scale. The range of read-back resistance is between (1/(1/R + (1/R)*0.01% + 0.08) Ω and 1/(1/R– (1/R)*0.01%–0.08)) Ω. The voltage/current input is no less than 10% FS. Ascending/descending slope: 10%–90% current ascending slope from 0 to maximum current. Minimum rise time: 10%–90% current rise time. DC POWER SUPPLIES Programmable DC electronic loads Rated Value (0°–40°C) Input Voltage Input Current Input Power Min. Operating Voltage Range Resolution Accuracy Range Resolution Accuracy Range Resolution Accuracy 2 Range Resolution Accuracy Model 2380-120-60/2380J-120-60 Low Range 0–500 V 0–3 A 200 W Programmable DC Electronic Loads Model 2380-500-15/2380J-500-15 *Specifications are subject to change without notice. A Tektronix Company 2380 Programmable DC Electronic Loads Model 2380-500-30/2380J-500-30 Programmable DC Electronic Loads Constant Voltage Mode Constant Current Mode Constant Resistance Mode 1 Constant Power Mode 3 High Range 0–500 V 0–30 A 750 W 0.36 V / 3 A 3.6 V / 30 A 0–50 V 1 mV ±(0.025% + 0.05% FS) 0–3 A 0.1 mA ±(0.05% + 0.05% FS) 0.15 Ω–10 Ω 0.001 Ω 0.01% + 0.08 S 750 W 10 mW 0.2% + 0.2% FS 0–500 V 10 mV ±(0.025% + 0.05% FS) 0–30 A 1 mA ±(0.05% + 0.05% FS) 10 Ω–7.5 kΩ 0.1Ω 0.01% + 0.0008 S 750 W 10 mW 0.2% + 0.2% FS T1 & T2 Accuracy Ascending/ Descending Slope 4 Minimum Rise Time 5 20 µs–3600 s; Res: 1 µs 5 µs ± 100 ppm 20 µs–3600 s; Res: 1 µs 5 µs ± 100 ppm 0.0001–0.1 A/µs 0.001–1 A/µs ~20 µs ~20 µs Range Resolution Accuracy Range Resolution Accuracy Range Resolution Accuracy 0–50 V 1 mV ±(0.025% + 0.025% FS) 0–3 A 0.1 mA ±(0.05% + 0.05% FS) 750 W 10 mW ±(0.2% + 0.2% FS) 0–500 V 10 mV ±(0.025% + 0.025% FS) 0–30 A 1 mA ±(0.05% + 0.05% FS) 750 W 10 mW ±(0.2% + 0.2% FS) ~760 W ~3.3 A ~530 V ~85°C ~760 W ~33 A ~530 V ~85°C Input Voltage Input Current Input Power Min. Operating Voltage Range Resolution Accuracy Range Resolution Accuracy Range Resolution Accuracy 2 Range Resolution Accuracy Dynamic Mode CC Mode Measuring Range Readback Voltage Readback Current Readback Power Protection Range Overpower Protection Overcurrent Protection Overvoltage Protection Over Temperature Protection Specification Current (CC) Voltage (CV) Resistance (CR) Input Terminal Impedance Dimensions Short Circuit ~3.3 / 3 A ~3.3 / 30 A 0V 0V ~120 mΩ ~120 mΩ 1 MΩ 1 MΩ 482mm × 131.4mm × 580mm Memory Capacity: 100 sets of measurements and selectable parameters. Signal Connections: Front Panel: Input: Stud and threaded knob terminals for lug connectors (200W and 250W versions). Rear Panel: Input: Terrminal Bars (750W version). Current Monitor Output: BNC. Remote Sense, Analog Input, External Trigger, Voltage Fault: 9-pin terminal block. Communications: USB: USB2.0 device, type B, USB-TMC compliant. RS-232: DB-9 connector. GPIB: IEEE-488.2 compliant. Cooling Method: Fan. Fan Speed vs. Internal temperature: Temperature 40°C 50°C 70°C 85°C Temperature protection (OH) Fan status First gear Second gear Third gear and load is shut off. Power Source: AC Input: Switchable between 120VAC nominal and 240VAC nominal. “J” versions: 100VAC, nominal. Frequency: 50/60Hz. Power Consumption: 2380-500-15: 40VA. 2380-120-60: 40VA. 2380-500-30: 150VA. EMC: Conforms to European Union EMC Directive. Safety: Canadian Certification: CSA listed to UL Std. No. 61010-1(3rd Edition) and Can/CSAC22.2 No. 61010-1-12. European Union Compliance: Conforms to European Union Low Voltage Directive. Environment: Altitude: Operating: 2000m, (6562 ft) above sea level. Temperature and Relative Humidity: Operating: 0° to 40°C full accuracy with 80% relative humidity at up to 35°C, noncondensing. Storage: –20° to 70°C, 10% to 85% relative humidity up to 40°C, 5% to 60% relative humidity above 40°C. Net Weight: 200W/250W Model: 4.65kg. 750W Model: 24.95kg. Shipping Weight: 200W/250W Model: 7kg. 750W Model: 31.75kg. Recommended calibration frequency: 1 time/year. Warranty: 3 years. DC POWER SUPPLIES NOTES* 1. The voltage/current input is no less than 10% FS (FS indicates the full scale). Accuracy is defined as: % of reading + % of full scale. 2. The range of read-back resistance is between (1/(1/R + (1/R)*0.01% + 0.08) Ω and 1/(1/R– (1/R)*0.01%–0.08)) Ω. 3. The voltage/current input is no less than 10% FS. 4. Ascending/descending slope: 10%–90% current ascending slope from 0 to maximum current. 5. Minimum rise time: 10%–90% current rise time. *Specifications are subject to change without notice. A Tektronix Company Programmable DC electronic loads Rated Value (0°–40°C) General Low Range 0–500 V 0–3 A 750 W Contact Information: ASEAN / Australia (65) 6356 3900 Austria 00800 2255 4835 Balkans, Israel, South Africa and other ISE Countries +41 52 675 3777 Belgium 00800 2255 4835 Brazil +55 (11) 3759 7627 Canada 1 800 833 9200 Central East Europe and the Baltics +41 52 675 3777 Central Europe & Greece +41 52 675 3777 Denmark +45 80 88 1401 Finland +41 52 675 3777 France 00800 2255 4835 Germany 00800 2255 4835 Hong Kong 400 820 5835 India 000 800 650 1835 Italy 00800 2255 4835 Japan 81 (3) 6714 3010 Luxembourg +41 52 675 3777 Mexico, Central/South America & Caribbean 52 (55) 56 04 50 90 Middle East, Asia, and North Africa +41 52 675 3777 The Netherlands 00800 2255 4835 Norway 800 16098 People’s Republic of China 400 820 5835 Poland +41 52 675 3777 Portugal 80 08 12370 Republic of Korea 001 800 8255 2835 Russia & CIS +7 (495) 6647564 South Africa +41 52 675 3777 Spain 00800 2255 4835 Sweden 00800 2255 4835 Switzerland 00800 2255 4835 Taiwan 886 (2) 2656 6688 United Kingdom & Ireland 00800 2255 4835 USA 1 800 833 9200 Rev 0415 Copyright © 2015, Tektronix. All rights reserved. Tektronix products are covered by U.S. and foreign patents, issued and pending. Information in this publication supersedes that in all previously published material. Specification and price change privileges reserved. TEKTRONIX and TEK are registered trademarks of Tektronix, Inc. All other trade names referenced are the service marks, trademarks or registered trademarks of their respective companies. 121715.KI1KW-60327-0 A Tektronix Company DC POWER SUPPLIES For Further Information Tektronix maintains a comprehensive, constantly expanding collection of application notes, technical briefs and other resources to help engineers working on the cutting edge of technology.Visit www.tektronix.com or www.keithley.com.
2380-RM 价格&库存
很抱歉,暂时无法提供与“2380-RM”相匹配的价格&库存,您可以联系我们找货
