2110-220-GPIB
2110-220-GPIB
    KEITHLEY
    KEITHLEY - 2110-220-GPIB - Bench Digital Multimeter, 2110 Series, 1 kV, 10 A, 5.5 Digit
2110-220-GPIB 数据手册
5½-Digit Dual-Display Digital Multimeter The Model 2110 5½-Digit Dual-Display Digital Multimeter combines a compelling price with a comprehensive set of capabilities, superior measurement accuracy, and high speed for a broad range of applications. It features 15 measurement functions and 7 math functions and has dual-line display capability, which allows it to display two different measurements concurrently. The Model 2110 is an unbeatable value for production, R&D, and test engineers, scientists, and students making a wide variety of measurements in portable, bench, and system applications. High Accuracy, Abundant Capabilities, Low Cost The Model 2110 provides precision and a rich set of capabilities at a value price. It has 0.012% one-year basic DC voltage accuracy and 0.020% one-year basic resistance accuracy up to the 100kW range. • High accuracy, high speed for general purpose measurements • 15 measurement functions, including capacitance and thermocouple measurements • Dual-line display allows concurrent measurements • TMC-compliant USB 2.0 interface for use with SCPI test commands • GPIB option for use in system applications DIGITAL MULTIMETERS & SYSTEMS • Includes PC software utilities for graphing and data sharing in both Microsoft® Word and Excel • Rugged construction for durability in bench/portable applications • Includes all accessories, such as start-up software, USB cable, power cable, and safety test leads • CE compliant and listed • Three year warranty APPLICATIONS Built for Production Testing The Model 2110 Digital Multimeter is ideal for applications in manual, semi-automatic, and automatic testing of low-cost electronic devices, circuits, modules, electrical components, and semiconductor components. Key features include: • Speed: up to 50,000 readings per second • Control: GPIB (optional) and USB interfaces, accepting SCPI (IEEE488.2) commands • External BNC trigger lines • NIST traceability (with included calibration certificate) Built for General Purpose Uses The Model 2110 Digital Multimeter is also ideal for bench uses such as research, development, service, calibration, and teaching. Benchoriented features include: • Accuracy: 0.012% basic DCV accuracy • Easy-to-operate panel • Easy waveform plotting and data collection with KI-Tool and KI-Link • Store up to 2000 readings The Model 2110 provides a wide number of measurement ranges and functions: • DC voltage: 0.1V, 1V, 10V, 100V, and 1000V • AC voltage: 0.1V, 1V, 10V, 100V, and 750V • DC current: 10mA, 100mA, 1A, 3A, and 10A • AC current: 1A, 3A, and 10A • Two- and four-wire resistance: 100W, 1kW, 10kW, 100kW, 1MW, 10MW, and 100MW • Frequency: From 10Hz to 300kHz • Capacitance measurement: 1nF, 10nF, 100nF, 1µF, 10µF, 100µF • Thermocouple measurement: J-, R-, S-, T-, E-, N-, B-, C-, and K-type thermocouples • Temperature (RTD and NTC Thermistor) measurements • Diode measurement • Continuity test • Programmable A-D converter and filter settings for signal to noise optimization. Additionally, seven mathematical operations can be performed on measurement readings: percentage, average, min/max, NULL, limits, mX+b, dB, and dBm testing. Speed At 5½ digits, the Model 2110 delivers up to 200 readings/s via the USB remote interface. At the fast 4½-digit setting, it reads up to 50,000 readings/s and up to 30,000 readings/s into the buffer, making it ideal for production and monitoring applications in which speed is ­critical. 1.888.KEITHLEY (U.S. only) www.keithley.com A Greater Measure of Confidence Low-cost 5½-digit DMM for system, bench, or portable applications Low-cost 5½-digit DMM for system, bench, or portable applications 2110 2110 5½-Digit Dual-Display Digital Multimeter Accessories Supplied Reference Manual on CD, Specifications, LabVIEW® Driver, Keithley I/O Layer, USB Cable, Power Cable, Safety Test Leads, KI-Tool, and KI-Link Add-in (both Microsoft Word and Excel versions), Calibration Certificate All accessories, such as start-up software, USB cable, power cable, and safety test leads, are included with the Model 2110. Simplicity The Model 2110 is operational and intuitive to use right out of the box. The functions on the front panel are user friendly and easy to read. Its KI-Tool and KI-Link software allow users to quickly control the instrument over GPIB (if equipped) or USB, record measurements, and display time-series plots of the data. Its LabView® and IVI drivers give more-advanced customers even more control over the instrument. Both the TMC-compliant USB remote interface and the GPIB interface allow easy re-use of existing SCPI programs. Startup Software, PC Utilities Included The KI-Tool application provides charting and graphing capabilities without programming to simplify setup, checkout, and basic measurement applications requiring graphical data representation. Scale, offset, and level can be adjusted to fine-tune images for visual evaluation of signal and noise elements over time. It also includes tabular data and SCPI command prompt windows for maximum flexibility. Data sets can also be saved to disk files. Low-cost 5½-digit DMM for system, bench, or portable applications 2110-100: 5½-digit USB Digital Multimeter (100V) 2110-120: 5½-digit USB Digital Multimeter (120V) 2110-220: 5½-digit USB Digital Multimeter (220V) 2110-240: 5½-digit USB Digital Multimeter (240V) 2110-100-GPIB: 5½-digit USB and GPIB Digital Multimeter (100V) 2110-120-GPIB: 5½-digit USB and GPIB Digital Multimeter (120V) 2110-220-GPIB: 5½-digit USB and GPIB Digital Multimeter (220V) 2110-240-GPIB: 5½-digit USB and GPIB Digital Multimeter (240V) The Microsoft Excel Add-In utility is also included and provides quick data import into a standard Microsoft Excel spreadsheet, including selectable graphing, instrument settings, and number of data points collected. Data can then be analyzed through standard or optional Microsoft Excel functions, including graphical, statistical, and trend charting. A version supporting Microsoft Word is also included for direct data import into reports. LabView, IVI-C, and IVI-COM drivers are also supplied to allow for increased flexibility in integrating the Model 2110 into new and existing systems and test routines. KI-Tool simplifies basic measurement applications through every setup and graphical data representation. 1.888.KEITHLEY (U.S. only) www.keithley.com A Greater Measure of Confidence DIGITAL MULTIMETERS & SYSTEMS Low-cost 5½-digit DMM for system, bench, or portable applications Ordering Information 2110 5½-Digit Dual-Display Digital Multimeter Specifications DC CHARACTERISTICS Model 2110 specifications Range 100.000 mV 1.00000   V 10.0000   V 100.000   V 1000.00   V Accuracy1 ±(% of reading + % of range) Input Resolution Resistance 1 Year, 23° ±5°C   1 µV 0.012 + 0.004  10 µV 0.012 + 0.001 10 MW 0.1 mV 0.012 + 0.002    1 mV 0.012 + 0.002  10 mV 0.02  + 0.003 DCI (DC Current) Range 10.0000 mA 100.000 mA 1.00000   A 3.0000    A 10.0000   A Accuracy1 ±(% of reading + % of range) Shunt Resolution Resistance 1 Year, 23° ±5°C   0.1 µA 5.1 W 0.05  + 0.020    1 µA 5.1 W 0.05  + 0.010   10 µA 0.1 W 0.150 + 0.020  100 µA 0.1 W 0.200 + 0.030  100 µA 5 mW 0.250 + 0.050 Resistance 2 Range 100.000 W 1.00000 kW 10.0000 kW 100.000 kW 1.00000 MW 10.0000 MW 100.000 MW Resolution   1 mW 10 mW 100 mW   1 W 10 W 100 W   1 kW Range 1.0000V Resolution   10 µV Test Current    1 mA    1 mA  100  µA    10  µA    1  µA   0.1  µA   0.1  µA Test Current 1 mA Accuracy1 ±(% of reading + % of range) 1 Year, 23° ±5°C 0.020 + 0.030 Temperature Coefficient 0°–18°C & 28°–40°C 0.002 + 0.0005 Test Current 1 mA Accuracy1 ±(% of reading + % of range) 1 Year, 23° ±5°C 0.020 + 0.020 Temperature Coefficient 0°–18°C & 28°–40°C 0.002 + 0.0005 Continuity Range 1000W Resolution 10 mW Temperature Coefficient 0°–18°C & 28°–40°C 0.005 + 0.002 0.005 + 0.001 0.008 + 0.001 0.008 + 0.001 0.008 + 0.001 Accuracy1 ±(% of reading + % of range) 1 Year, 23° ±5°C 0.020 + 0.020 0.020 + 0.003 0.020 + 0.002 0.020 + 0.002 0.030 + 0.004 0.200 + 0.004 2.000 + 0.005 Diode Test DIGITAL MULTIMETERS & SYSTEMS TEMPERATURE (Thermocouple) CHARACTERISTICS Temperature Coefficient 0°–18°C & 28°–40°C 0.001  + 0.0005 0.0009 + 0.0005 0.0012 + 0.0005 0.0012 + 0.0005 0.002  + 0.0015 Temperature Coefficient 0°–18°C & 28°–40°C 0.003 + 0.0005 0.003 + 0.0005 0.003 + 0.0005 0.003 + 0.0005 0.005 + 0.0005 0.05  + 0.0005 0.5   + 0.0005 1. Specifications valid after two hour warm-up. a. ADC set for continuous trigger operation. b. Input bias current
2110-220-GPIB 价格&库存
很抱歉,暂时无法提供与“2110-220-GPIB”相匹配的价格&库存,您可以联系我们找货
