2280-TEST-LEAD
2280-TEST-LEAD
    KEITHLEY
    KEITHLEY - 2280-TEST-LEAD - POWER SUPPLY TEST LEAD KIT, 1KV, 20A
2280-TEST-LEAD 数据手册
The Series 2280S Precision Measurement, Low Noise, Programmable DC Power Supplies are much more than just sources of clean power; they are also precision measurement instruments. They can source stable, low noise voltages as well as monitor load currents over a wide dynamic range from amps to nanoamps. The Model 2280S-32-6 can output up to 32V at up to 6A; the Model 2280S-60-3 can output up to 60V at up to 3.2A. • Measure small load currents with 0.05% accuracy and 10nA resolution • Measure voltage and current with 6½-digit resolution • Capture the peak of a load current burst as short as 140µs using external triggering or capture load current changes using a level threshold, sampling at 2800 readings per second • Output up to 192W of low noise, linear regulated power • Programmable rise and fall times eliminate voltage overshoot and undershoot transients • Built-in graphing simplifies analyzing trends or displaying voltage or current waveforms • High resolution TFT display and soft-key/icon-based user interface simplify power supply operation • Programmable output sequences reduce test times Both supplies use linear regulation to ensure low output noise and superior load current measurement sensitivity. A high resolution color Thin Film Transistor (TFT) screen displays a wide range of information on measurements. Soft-key buttons and a navigation wheel combine with the TFT display to provide an easy-to-navigate user interface that speeds instrument setup and operation. In addition, built-in plotting functions allow monitoring trends such as drift. These supplies provide the flexibility required for both benchtop and automated test system applications. For example, they provide a list mode, triggers, and other speed optimization functions to minimize test time in automated testing applications. DMM-Quality Low Current Measurements with High Resolution Unlike conventional power supplies, Series 2280S supplies can also make measurements with up to 6½ digits of resolution. Voltage output measurements can be resolved down to 100µV. These supplies measure load currents from 100nA to amps and can resolve down to 10nA. Four load current measurement ranges (10A, 1A, 100mA, and 10mA) support measuring a device’s full load current, standby mode current, and small sleep mode currents with DMM-quality accuracy. The high resolution allows characterizing small changes in load currents with confidence. It also makes it possible to make a broad range of measurements on a single range with excellent accuracy across both low and high current values. Measure Rapidly Changing Load Currents Capture measurements with either an external control signal or an analog level threshold crossing Precision measurement, low noise, programmable DC power supplies Precision Measurement, Low Noise, Programmable DC Power Supplies To monitor fast-changing and pulse-like load currents properly, Series 2280S supplies offer the speed necessary to capture load changes that occur at intervals as short as 140µs. This capability allows designers and manufacturers of portable, battery-operated devices to monitor load currents easily in all of a device’s operating modes so they can determine the device’s total power consumption. This high speed measurement capability allows measuring each state of a power-up load sequence and a power-down sequence. Measurements can be made as fast as 2500 readings per second, making it possible to characterize and test the current draw at each of the start-up states. Delay Measure Delay Measure • Sink up to 0.45A to discharge voltage quickly • Digital I/O for direct communication with other devices and instruments • GPIB, USB, and LAN interfaces • Built-in web page allows automated control, monitoring, and data logging • Automate tests easily with KickStart start-up software Trigger Trigger Figure 1. Make time-critical measurements on fast-changing or pulse-like loads. An external trigger initiates the acquisition. Programmable delay and measure times enable measurements at a specific time on the load current pulse. In addition to the digital trigger, a level threshold setting can be used to store up to 2500 measurements at a programmed reading rate. 1.888.KEITHLEY (U.S. only) www.keithley.com A Greater Measure of Confidence A Tektronix Company DC POWER SUPPLIES Precision measurement, low noise, programmable DC power supplies Series 2280S No da enh w w t a an i t lo c e h gg d in g DC POWER SUPPLIES Precision measurement, low noise, programmable DC power supplies Ordering Information 2280S-32-6 Precision Measurement DC Power Supply, 32V, 6A 2280S-60-3 Precision Measurement DC Power Supply, 60V, 3.2A Accessories Supplied Quick Start Guide KickStart Quick Start Guide User Documentation CD LAN Crossover Cable Power Cord Rear Panel Mating Connector with Cover ACCESSORIES AVAILABLE 2280-TEST-LEAD Power Supply Test Lead Kit, 1000V, 20A Rating 2280-001 Rear Panel Mating Connector and Cover CA-180-3A LAN Crossover Cable USB-B-1 USB Cable Type A to B, 1m (3.3 ft) 2450-TLINK Trigger Link cable to connect 2280S digital I/O to Trigger Link I/O on other Keithley instruments 4299-8 Single Fixed Rack-Mount Kit 4299-9 Dual Fixed Rack-Mount Kit 4299-10 Dual Fixed Rack-Mount Kit for one 2U Graphical Display Instrument and one Series 26xx Instrument 4299-11 Dual Fixed Rack-Mount Kit for one 2U Graphical Display Instrument and one Series 24xx, Series 2000, or 2U Agilent Instrument KPCI-488LPA IEEE-488.2 Interface Board for the PCI Bus KUSB-488B IEEE-488.2 USB-GPIB Interface Adapter for USB Port with 2m (6.6 ft) cable 7007-05 Double Shielded Premium IEEE-488 Interface Cables, 0.5m (1.6 ft) 7007-1 Double Shielded Premium IEEE-488 Interface Cables, 1m (3.2 ft) 7007-2 Double Shielded Premium IEEE-488 Interface Cables, 2m (6.5 ft) 7007-3 Double Shielded Premium IEEE-488 Interface Cables, 3m (10 ft) 7007-4 Double Shielded Premium IEEE-488 Interface Cables, 4m (13 ft) Precision Measurement, Low Noise, Programmable DC Power Supplies The measurements can be captured using either of two methods. A measurement can be initiated by a digital external control signal transmitted to the external input of the digital I/O port. In addition, up to 2500 measurements can be stored at a sampling rate up to 2800 readings/s based upon a programmed threshold level. The user selects both the level and the slope of the signal, a rising signal or a falling signal. The level setting can be used to store either voltage and/or current measurements when the threshold level is crossed. When the level threshold is enabled, the supply is continuously monitoring the level of the selected parameter and buffering the measurements. Thus pre-threshold measurements can be saved along with the post-threshold measurements. External Triggers start measurements Measurement Complete signals Figure 2. Measure the start-up load currents as a device powers up. View and Control Every Parameter of the Supply for Maximum Performance The bright, 4.3-inch TFT display shows voltage and current readings, the source settings and many additional settings in large, easy-to-read characters. The icon-based main menu provides all the functions users can control and program for fast access to source setup, measurement setup, display formats, trigger options, and system settings. Menus are short, and the menu options you need are easy to find and clearly described, so that you can set up test parameters quickly by using the navigation wheel, keypad, or soft-keys. Many set-up parameters, such as for voltage and current settings, can be entered directly from the home screen; less complex tests don’t even require accessing the main menu to make adjustments. Whether your test’s requirements are uncomplicated or complex, the Series 2280S supplies provide a simple way to set up all the required parameters. Figure 3. Adjust voltage, current, the current range, the measurement mode, protection levels, and other functions from the home screen. Figure 4. Access the full functionality of the Series 2280S supplies from the main menu. 1.888.KEITHLEY (U.S. only) www.keithley.com A Greater Measure of Confidence A Tektronix Company Precision measurement, low noise, programmable DC power supplies Series 2280S Perform Semi-Automated Testing Right on Your Bench Test your design over its operating voltage range automatically or study how it responds to DC output changes by using the Series 2280S supplies’ built-in List Mode function. Create and save up to 10 lists of sequenced voltage levels with up to 99 distinct voltages in each list. The duration of each voltage level can be set as short as 1ms or as long as 60s. Create simple linear ramps or any custom configuration from either the front panel or an interface bus. A single trigger will automatically execute the list once or multiple times. Figure 5. Configure the readback measurements exactly the way you need them using a Measure Sub-screen. Controlled Rise and Fall Times Protect Devices Under Test Are you working on a device or a system with a high in-rush current? Series 2280S supplies allow programming the voltage output’s rise time to slow the voltage ramp and avoid voltage overshoot, which could potentially damage the DUT. The voltage fall time can also be controlled to prevent a fast ramp down of the output voltage. Voltage rise and fall times can be set as slow as 10V/s or as fast as 100V/s. Small voltage transitions can be programmed to rise and fall as fast as 1000V/s. Figure 7A. Create an output sequence using the List setup screen. Power supply with no slew rate control Precision measurement, low noise, programmable DC power supplies Precision Measurement, Low Noise, Programmable DC Power Supplies Model 2280S with slew rate control Figure 6. Programmable slew rates permit controlling voltage rise and fall rates, preventing undesirable transients during power up of capacitive loads. Figure 7B. Use the list mode to step the output voltage automatically through a series of levels. The voltages were created by the list shown in Fig. 7A. DC POWER SUPPLIES Precision measurement, low noise, programmable DC power supplies Series 2280S 1.888.KEITHLEY (U.S. only) www.keithley.com A Greater Measure of Confidence A Tektronix Company Precision Measurement, Low Noise, Programmable DC Power Supplies Trend Analysis and Load Current Characterization Use the built-in graphing function to monitor the stability of the load current or capture and display a dynamic load current. Or, use it to view a start-up or turn-off load current. Series 2280S supplies can take measurements quickly and store up to 2,500 measurement points. In addition to displaying a voltage or current waveform or both, they can compute statistics on the stored data. Statistical calculation options include average, maximum, minimum, peak-peak, and standard deviation. All the information you need is accessible through a few display menus. Figure 9. Web page display of the LXI-data logging function showing all parameters stored and the associated statistics. Figure 8. Monitor voltage, current, or both with the graphing function. Simple, Yet Powerful Data Logging As well as capturing 2500 data points in the internal memory and displaying it using the Series 2280S graphing function, voltage and current measurements can be collected using the LAN interface and the Series 2280S built-in web browser. The web interface home page offers a data logging option. Measurements can be taken over a programmed time interval, based on a programmed number of data points, or manually using the Start/Stop button on the webpage user interface. Using the web-based data logger, measurements can be continuously taken over multiple days. Figure 9 shows a web page display of the measurements, the time when measurements were taken, and a number of status parameters. Statistics on the logged data are displayed on the page and include maximum, minimum, and average values. The total consumed electric chage in milliamp-hours is also computed. Control buttons on the side of the display allow control of the data logging and enable copying of either selected rows or all the data. The data can be easily pasted into a report or a spreadsheet for analysis. Just interface to a Series 2280S via LAN and select the data logging option. This powerful data logging capability requires no programming. Automate a test quickly and easily with KickStart software Set up an automated test for the Series 2280S supplies in four simple steps with the KickStart start-up software. KickStart is available for installation on your PC via a free download from www.keithley.com. Once the program is open, perform these steps: create a test file, select the 2280S power supply, select the power supply application, and enter the test parameters. Run the test, and get results without having to write a line of code. KickStart provides both graph and spreadsheet displays. Data is saved to the test file, and the data can be exported to data analysis programs. Or take a screen shot of the plot for reproduction in test reports. Up to 15,000 data points can be stored. KickStart may be all the software you ever need. DC POWER SUPPLIES Figure 10. KickStart DC power main screen. 1.888.KEITHLEY (U.S. only) www.keithley.com A Greater Measure of Confidence A Tektronix Company Precision measurement, low noise, programmable DC power supplies Precision measurement, low noise, programmable DC power supplies Series 2280S Figure 12. Series 2280S rear panel showing the rear output connector with remote sense inputs, digital I/O, and the three interfaces (GPIB, USB, and LAN). Figure 11. KickStart plot with measurement table. Optimized Performance for Production Test Series 2280S supplies are as powerful in a production test system as they are flexible on the R&D benchtop. In addition to their List Mode function, several other Series 2280S features help minimize test time in automated systems. For example, an external trigger input allows hardware synchronization and control by other instruments in the test system. To eliminate many system delays, Series 2280S supplies produce a “measurement ­complete output” to signal the test system when the supplies have ­completed their required actions. To reduce measurement time, the reading speed can be increased by reducing the acquisition time from power line cycle integration times, 16ms at 60Hz (20ms at 50Hz), to 33μs (40μs). Furthermore, the Series 2280S supplies can sink up to 0.45A. Thus, these supplies can quickly discharge a voltage level and change to a different voltage. A choice of front or rear panel terminals provides enhanced connection flexibility. For maximum voltage accuracy, 4-wire remote sensing ensures that the output voltage programmed is actually the level applied to the load. In addition, the sense lines are monitored in order to detect any breaks in them. These features ensure any production problems can be quickly identified and corrected. Four additional digital I/O pins can provide fault status outputs or control an external relay or status lamp. Series 2280S supplies can be controlled via their built-in GPIB, USB, or LAN interfaces. The USB interface is test and measurement system (TMC) compliant. The LXI Core compliant LAN interface supports controlling and monitoring a Series 2280S supply remotely, so test engineers can always access the power supply and view measurements, even if they’re located on a different continent than their test systems. Series 2280S specifications Precision Measurement, Low Noise, Programmable DC Power Supplies To facilitate production test software development, native National Instruments LabVIEW™ drivers, IVI-C and IVI-COM drivers are available on the Keithley website, www.keithley.com. Series 2280S Accessories Model 2280-001: Rear Panel Mounting Connector and Cover (assembled view on the left, and connector and top and bottom cover shown separately on the right) Model 2280-TEST-LEAD: Power Supply Test Lead Kit, 1000V, 20A Rating: Contains 122cm (4ft) of cable, spade lug adapters, and alligator clips 1.888.KEITHLEY (U.S. only) www.keithley.com A Greater Measure of Confidence A Tektronix Company DC POWER SUPPLIES Series 2280 specifications Series 2280S SERVICES AVAILABLE 2280S-32-6-EW 2280S-32-6-5Y-EW C/2280S-32-6-3Y-STD C/2280S-32-6-3Y-DATA Series 2280S specifications C/2280S-32-6-3Y-1702 C/2280S-32-6-5Y-STD C/2280S-32-6-5Y-DATA C/2280S-32-6-5Y-1702 2280S-60-3-EW 2280S-60-3-5Y-EW C/2280S-60-3-3Y-STD C/2280S-60-3-3Y-DATA C/2280S-60-3-3Y-1702 C/2280S-60-3-5Y-STD C/2280S-60-3-5Y-DATA C/2280S-60-3-5Y-1702 1 Additional Year of Factory Warranty (total of 4 years) 2 additional years of factory warranty beyond the 3-Year factory warranty (total of 5 years) 3 Calibrations Within 3 Years of Purchase 3 (ANSI-Z540-1 compliant) Calibrations Within 3 Years of Purchase 3 (ISO 17025 Accredited) Calibrations within 3 Years of Purchase 5 Calibrations Within 5 Years of Purchase 5 (ANSI-Z540-1 compliant) Calibrations Within 5 Years of Purchase 5 (ISO 17025 Accredited) Calibrations within 5 Years of Purchase 1 Additional Year of Factory Warranty (total of 4 years) 2 additional years of factory warranty beyond the 3-Year factory warranty (total of 5 years) 3 Calibrations Within 3 Years of Purchase 3 (ANSI-Z540-1 compliant) Calibrations Within 3 Years of Purchase 3 (ISO 17025 Accredited) Calibrations within 3 Years of Purchase 5 Calibrations Within 5 Years of Purchase 5 (ANSI-Z540-1 compliant) Calibrations Within 5 Years of Purchase 5 (ISO 17025 Accredited) Calibrations within 5 Years of Purchase Precision Measurement, Low Noise, Programmable DC Power Supplies Specifications 23°C ±5°C with 1-hour instrument warm-up. DC OUTPUT RATINGS Voltage Current Maximum Power 2280S-32-6 0 to 32 V 0 to 6 A 192 W 2280S-60-3 0 to 60 V 0 to 3.2 A 192 W 2280S-32-6 ± (0.02% + 3 mV) 1 mV 2280S-60-3 ± (0.02% + 6 mV) 1 mV 2280S-32-6 ± (0.02% + 2 mV) 0.1 mV 2280S-60-3 ± (0.02% + 4 mV) 0.1 mV VOLTAGE 1 SOURCE SETTING Accuracy Resolution MEASUREMENT 2 (0.5V over-range) Accuracy Resolution ADDITIONAL OFFSET AT FASTER MEASUREMENT SETTINGS 2280S-32-6 0.21 mV 5½ (0.1 PLC) 1.44 mV 4½ (0.01 PLC) 7.60 mV 3½ (0.002 PLC) 2280S-60-3 0.40 mV 2.7 mV 14.25 mV REGULATION Load Line 2280S-32-6 ±(0.01% + 2 mV) ±(0.01% + 1 mV) 2280S-60-3 ±(0.01% + 2 mV) ±(0.01% + 1 mV) 2280S-32-6 < 1mV RMS < 5mV p-p 2280S-60-3 < 2mV RMS < 7mV p-p OUTPUT RIPPLE AND NOISE Bandwidth 20Hz–20MHz LOAD TRANSIENT RECOVERY TIME: Resistive load change 50% load to 100% load or 100% load to 50% load: 93°C (typical) 6 ms (typical)8 2280S-60-3 >93°C (typical) 6 ms (typical)8 Overtemperature Protection (OTP) Output turn-off Temperature Response Time OTHER TIMING DATA CV TO CC TRANSITION TIME (V-Set = 5V, I-limit = 0.5A, Resistive Load change 25Ω to 2.5Ω): 2.4ms. CC TO CV TRANSITION TIME (V-Set = 5V, I-limit = 0.5A, Resistive Load change 2.5Ω to 25Ω: 1.1ms. FUNCTION CHANGE (from detection of bus command to function change completed): 10ms (typical). OUTPUT OFF/ON (from detection of bus command to voltage beginning to decrease): 5ms (typical). REVERSE LEADS ACTUATION: 6ms (typical)8. 1. Specifications based on using remote sense connections. For 2-wire connections, add an offset of 0.5mV/A (Front terminals). 2. 6½ digit resolution, 1 PLC reading rate, filter on, autozero on. 3. 100V/s to 1000V/s rise and fall slew rates: 2280S-32-6: limited to 5V changes at a maximum of 3A; between 0V to 5V, the load current can be up to full load, 6A 2280S-60-3: limited to 10V changes at a maximum of 2A; between 0V and 10V, the load current can be up to full load, 3.2A. 4. 6 ½ digit resolution, 1PLC integration time, Autozero: on, Filter: on 10mA and 100mA ranges: Source Delay: 2ms 1A and 10A ranges: Source Delay: 1ms. 5. Settings: Autozero: off, 0.002 PLC, Arm Source: External, Trigger Source: Immediate, Filter: off 10mA and 100mA ranges: Source Delay: 2ms 1A and 10A ranges: Source Delay: 0ms or off 6. Time includes trigger detection, jitter, and 0.002PLC integration time. 7. Settings: Autozero: off, Output Delay: off, Source Delay: off, voltage output is constant, Measure Count: 1000. 8. Time defined as from detection of condition to start of output turn-off. 9. Filter on, 10mA and 100mA ranges: Source Delay: 2ms 1A and10A ranges: Source Delay: 1ms DC POWER SUPPLIES GENERAL COMMON MODE CURRENT: < 6µA peak-peak. CHASSIS ISOLATION: ±240V, any terminal to chassis. >1GΩ in parallel with 2.7V (per pin). Maximum Sink Current: –50mA @ 0.7V (per pin, solid-state fuse p­ rotected). 5V power supply, limited to 0.5A @>4V (solid-state fuse protected). Trig In minimum pulse ≥4µs, Logic Low pulse. Meter Ready Pulse, 15–30µs, Logic Low Pulse. EMC: Conforms to European Union EMC directive. SAFETY: U.S. NRTL Listing: UL61010-1 3rd ed 2012 and UL61010-2-030:2012. Canadian Certification: CAN/CSA C22.2 No. 61010-1 3rd ed 2012. European Union Compliance: Low Voltage Directive . COOLING: Forced air, side intake and rear exhaust. POWER SUPPLY: 100V/120V/220V/240V ±10%. POWER LINE FREQUENCY: 50/60Hz ±3Hz, automatically sensed at power-on. POWER CONSUMPTION: 630VA peak. OPERATING ENVIRONMENT: 0° to 40°C, ≤80% RH up to 35°C, non-condensing. Altitude: up to 2000 meters. STORAGE ENVIRONMENT: –25° to 70°C. LXI WEB BROWSER COMPATIBLE OPERATING SYSTEM AND SOFTWARE: Windows 2000, Win 7 and XP compatible, supports Web browsers with Java plug-in (requires Java plug-in 1.7 or higher). Web page served by Model 2280S. RACK DIMENSIONS: (W×H×D), without boot: 213.8 × 88.4 × 383.3mm (8.42 × 3.48 × 15.1 in.). BENCH DIMENSIONS: (W×H×D) with boot: 255.3 × 107.2 × 415.0mm (10.1 × 4.22 × 16.34 in.) SHIPPING WEIGHT: 13.29kg (29.3 lbs.). NET WEIGHT: 10.85kg (23.9 lbs.). WARRANTY: 3 years. Note: Specifications are subject to change without notice. 1.888.KEITHLEY (U.S. only) www.keithley.com A Greater Measure of Confidence A Tektronix Company Series 2280S specifications Series 2280S Specifications are subject to change without notice. All Keithley trademarks and trade names are the property of Keithley Instruments. All other trademarks and trade names are the property of their respective companies. A Tektronix Company KEITHLEY INSTRUMENTS ■ 28775 AURORA RD. ■ CLEVELAND, OH 44139-1891 ■ 440-248-0400 ■ Fax: 440-248-6168 ■ 1-888-KEITHLEY ■ www.keithley.com BENELUX +31-40-267-5506 www.keithley.nl FRANCE +33-01-69-86-83-60 www.keithley.fr ITALY +39-049-762-3950 www.keithley.it MALAYSIA 60-4-643-9679 www.keithley.com SINGAPORE 01-800-8255-2835 www.keithley.com.sg BRAZIL 55-11-4058-0229 www.keithley.com GERMANY +49-89-84-93-07-40 www.keithley.de JAPAN 81-120-441-046 www.keithley.jp MEXICO 52-55-5424-7907 www.keithley.com TAIWAN 886-3-572-9077 www.keithley.com.tw CHINA 86-10-8447-5556 www.keithley.com.cn INDIA 080-30792600 www.keithley.in KOREA 82-2-6917-5000 www.keithley.co.kr RUSSIA +7-495-664-7564 www.keithley.ru UNITED KINGDOM +44-1344-39-2450 www.keithley.co.uk For further information on how to purchase or to locate a sales partner please visit www.keithley.com/buy © Copyright 2015 Keithley Instruments Printed in the U.S.A 4.22.15 DC POWER SUPPLIES A Greater Measure of Confidence
2280-TEST-LEAD 价格&库存
很抱歉,暂时无法提供与“2280-TEST-LEAD”相匹配的价格&库存,您可以联系我们找货
