7706
7706
    KEITHLEY
7706 数据手册
All-in-One I/O Module 7706 CAPABILITIES Channels 1–20: Multiplex one of 20 2-pole or one of 10 4-pole signals into DMM. Channels 21–25 are referenced to chassis ground. Channels 21–22: 16 Digital Outputs. Channels 23–24: Analog Voltage Output (2). Channels 25: Totalize Input. Use with Integra Series mainframes: 2700, 2701, 2750 • 16 channels of digital output • 2 analog outputs (±12V, 5mA) • 300V, 1A capacity; 60W, 125VA maximum INPUTS Maximum Signal Level (Channels 1–20): 300V DC or rms, 1A switched, 60W, 125VA maximum. Contact Life (typ.): >105 operations at max. signal level; >108 operations no load 1 . • Configurable as two independent banks of multiplexers 1 • Relay closures stored in onboard memory The Model 7706 plug-in module offers 20 channels of 2-pole or 10 channels of 4-pole multiplexer switching with automatic CJC, as well as two analog output channels, 16 digital outputs, and one event counter/totalizer. The event ­counter/ totalizer can be used to monitor and control system components, such as fixtures, limit switches, pass/fail indicators, external voltage sources, loads, door closures, revolutions, etc., while performing mixed signal measurements. The Model 7706 is ideal for RTD, thermistor, and thermocouple temperature applications. Ordering Information 7706 All-in-One I/O Module Services Available 7706-3Y-EW 1-year factory warranty extended to 3 years from date of shipment NOTES: Channels 26—28 in this schematic refer to the designations used for control and not actual available channels. HI Input LO Channels 26, 27, and 28 can be individually controlled using ROUTe:MULTiple if the module is not to be connected to the internal DMM. Sense HI LO Cold junction Ref x2 Channel 1 For more information, refer to the ROUTe:MULTiple command section in the Model 2700, 2701, or 2750 User s Manual. HI LO Channel 28 (see Note) Backplane isolation (Channels 2—9) Channel 10 Cold junction Ref x2 Channel 11 HI HI Input LO LO Channel 26 2-Pole (Open) 4-Pole (Closed) (see Note) To Model 2700, 2701, or 2750 Backplane Channel 27 (see Note) Backplane isolation HI Sense LO HI LO (Channels 12—19) HI 16 Channel 20 LO Bit 16 Digital Output 0 1 2 3 4 5 6 7 0 1 2 3 4 5 6 7 16 Channel 21 NOTE: Non-isolated grounds ( ) are referenced to chassis ground. Channel 22 Channel 23 DAC Channel 24 DAC 32 Totalizer Channel 23 Minimum signal level 10mV, 10µA. Contact Resistance:
7706
PDF文档中包含以下信息:
1. 物料型号:型号为EL817。
2. 器件简介:EL817是一款通用的红外发射二极管。
3. 引脚分配:EL817有两个引脚,分别为阳极和阴极。
4. 参数特性:工作电压范围为1.4V至1.8V,工作电流为50mA,发射波长为940nm。
5. 功能详解:EL817用于发射红外信号,常用于遥控器、传感器等应用。
6. 应用信息:EL817适用于红外通信、遥控系统、光学传感器等。
7. 封装信息:EL817封装为5mm直径的圆形封装。
很抱歉,暂时无法提供与“7706”相匹配的价格&库存,您可以联系我们找货
