FLUKE 715
FLUKE 715
    FLUKE(福禄克)
    FLUKE 715
FLUKE 715 数据手册
Fluke 715 mA Loop Calibrators Technical Data Fluke 715 Volt/mA Calibrator Volt Milliamp Calibrator to troubleshoot process loops The Fluke 715 Volt/mA Calibrator delivers outstanding performance, durability and reliability. Offered in the rugged Fluke 80 Series DMM package, the calibrator is compact, lightweight and easy to carry. With a push button interface similar to the multifunction Fluke 740 Series Documenting Process Calibrators, the 715 is easy to use. It is EMI tolerant, dust/splash resistant and features a removable battery door for quick battery changes. It features: • Measure loop current (0 mA to 20 mA, 4 mA to 20 mA) signals with 0.01 % accuracy and 0.001 mA resolution • Source precision voltage signals up to 20 V with 0.01 % accuracy • Measure voltage output process signals from PLCs, transmitters • Source or simulate 24 mA loop current • 24 V loop supply with simultaneous current measurement Fluke 707 Loop Calibrator The fastest, one-handed tool for loop checks The Fluke 707 Loop Calibrator is a high performance solution for calibration, repair and maintenance of current loops. The “Quick Click” knob makes it extremely fast and easy to use. It features: • One handed user interface with “Quick Click” detented knob • mA sourcing, simulation and measurement • 0.015 % accuracy and 0.001 mA resolution • Simultaneous mA and % of span display • Selectable step or ramp outputs • 24 V Loop supply with mA measure, including 250 Ω HART resistor • 0 V dc to 28 V dc measurement to check Loop Voltage • Removable battery door for quick battery replacement • Compact case with protective holster • Three year warranty Fluke 705 Loop Calibrator Low cost calibration muscle The Fluke 705 Loop Calibrator is a cost-effective, integrated solution for calibration, repair and maintenance of current loops. It features: • mA sourcing, simulation and measurement • 0.02 % accuracy and 0.001 mA resolution • Simultaneous mA and % of span display • Selectable step or ramp outputs • 24 V Loop supply with mA measure • 0 V dc to 28 V dc measurement to check Loop Voltage • Removable battery door for quick battery replacement • Compact case with protective holster • Three-year warranty General Specifications: Maximum voltage: 30 volts: Non-operating temperature: –4 °C to 60 °C Operating temperature: –10 °C to 55 °C Relative humidity: 95 % (10 °C to 30 °C); 75 % (30 °C to 40 °C); 45 % (40 °C to 50 °C); 35 % (50 °C to 55 °C) Operating altitude: 3,000 m max Shock: 1 m drop test Vibration: Random, 2 g, 5 Hz to 500 Hz Safety: CSA C22.2 No. 1010.1:1992 EMC: EN50082-1:1992 and EN55022:1994 Class B Power: 9 V battery ANSI/NEDA 1604A or IEC 6LR619V alkaline; two batteries in 718 Warranty: Three-years Functional Specifications: Fluke 705 and 707 Fluke 715 0 V to 28 V 0 mV to 200 mV / 0 V to 25 V Voltage measurement Range Resolution 1 mV 10 µV / 1 mV Accuracy 705: 0.025 % Rdg + 1 counts 707, 707Ex: 0.015 % Rdg + 2 counts 0.01 % Rdg + 2 counts Range 0 mA to 24 mA 0 mA to 24 mA Resolution 0.001 mA 0.001 mA Accuracy 705: 0.02 % Rdg + 2 counts 707, 707Ex: 0.015 % Rdg + 2 counts 0.01 % + 2 counts Current measurement Current sourcing Range 0 mA to 20 mA or 4 mA to 20 mA 0 mA to 20 mA or 4 mA to 20 mA Accuracy 705: 0.02 % Rdg + 2 counts 707, 707Ex: 0.015 % Rdg + 2 counts 0.01 % Rdg + 2 counts Drive capability 705: 1000 Ω @ 24 mA 707: 1200 Ω @ 24 mA 707Ex: 700 Ω @ 20 mA 1000 Ω @ 24 mA Loop power while measuring mA 24 V 24 V Voltage sourcing n/a 0 mV to 200 mV or 0 V to 20 V Display current and % of span Yes mA or % Auto step, auto ramp Yes Yes Span Check Yes Yes Battery life 18 hours typical, at 12 mA 18 hours typical, at 12 mA Fluke. Keeping your world up and running. Fluke Corporation PO Box 9090, Everett, WA USA 98206 Fluke Europe B.V. PO Box 1186, 5602 BD Eindhoven, The Netherlands For more information call: In the U.S.A. (800) 443-5853 or Fax (425) 446-5116 In Europe/M-East/Africa (31 40) 2 675 200 or Fax (31 40) 2 675 222 In Canada (800) 36-FLUKE or Fax (905) 890-6866 From other countries +1 (425) 446-5500 or Fax +1 (425) 446-5116 Web access: http://www.fluke.com ©2006 Fluke Corporation. All rights reserved. Printed in U.S.A. 2/2006 2574106 D-EN-N Rev A
FLUKE 715
物料型号: - Fluke 715 - Fluke 707 - Fluke 705
器件简介: - Fluke 715是一款Volt/mA校准器,具有出色的性能、耐用性和可靠性。 - Fluke 707是一款高性能的环路校准器,具有快速、单手操作的特点。 - Fluke 705是一款成本效益高的环路校准器,用于校准、维修和维护电流环路。
引脚分配参数特性功能详解: - 这些校准器可以测量和源电流信号,测量电压输出过程信号,具有高精度和分辨率。 - 它们还具有24V环路供电和电流测量功能,以及0V直流到28V直流的测量范围。
应用信息: - 这些校准器适用于校准、维修和维护电流环路。
封装信息: - 文档中未明确提供封装信息,但提到了它们具有紧凑的外壳和保护性皮套。
FLUKE 715 价格&库存
很抱歉,暂时无法提供与“FLUKE 715”相匹配的价格&库存,您可以联系我们找货
