2601B-PULSE-CA1
2601B-PULSE-CA1
    KEITHLEY
    KEITHLEY - 2601B-PULSE-CA1 - Test Accessory, BNC to BNC Cable Kit-1.2m, 50 Ohm, Keithley 2601B-PULSE...
2601B-PULSE-CA1 数据手册
2601B-PULSE System SourceMeter 10 µs Pulser/SMU Instrument ® Datasheet through highly automated pulsed I-V production test. For automated system applications, the 2601B-PULSE’s Test Script Processor (TSP®) runs complete test programs from inside the instrument for industry-best throughput. In larger, multi-channel applications, the Keithley TSP-Link® technology works together with TSP technology to enable high-speed, pulser/SMU-per-pin parallel testing. Because the 2601B-PULSE offers full isolation that does not require a mainframe, it can be easily reconfigured and re-deployed as your test applications evolve. The new 2601B-PULSE System SourceMeter 10 µs Pulser/SMU Instrument with PulseMeter™ technology is an industry-leading high current/high speed pulser with measure plus the full functionality of a traditional SMU. This new pulser offers leading 10 A current pulse output at 10 V with a pulse width minimum of 10 µs, perfect for testing vertical cavity surface emitting lasers (VCSEL) used in LIDAR and facial recognition, LEDs for lighting and displays, semiconductor device characterization, surge protection testing, and so much more. The pulser’s built-in dual 1 Megasample/second (MS/s), 18-bit digitizers make it possible to acquire both pulse current and voltage waveforms simultaneously without the need to use a separate instrument. The 2601B-PULSE is a powerful solution that significantly boosts productivity in applications ranging from benchtop characterization Key Features • Industry leading 10 A @ 10 V, 10 microsecond pulse output • No tuning required; works with inductive loads up to 3 μH • Dual 1 Megasample/second digitizers for high speed I/V pulse measurements (pulser function only) • DC capability up to ±40 V @ ±1.0 A, 40 Watt • TSP technology embeds complete test programs inside the instrument for best-in-class system-level throughput • TSP-Link expansion technology for multi-channel parallel test without a mainframe • USB 2.0, LXI Core, GPIB, RS-232, and digital I/O interfaces • Supported in the Keithley KickStart non-programming software tool SMU (I or V Source) Full DC Operation Pulse Operation: Pulse Width >150 µs, typical Dual Integrating ADCs: One each for V and I PULSER (I Source only) DC Bias Pulse Operation: 10 µs ≤ Pulse Width ≤ 500 µs Dual 1 MS/s High-speed ADCs: One each for V and I External Interlock/Connector box included with 2601B-PULSE Datasheet Pulsed Testing for Device Characterization Testing real device operation and minimizing the heating effects with on-wafer testing just got easier with the 2601B-PULSE SMU. Thermal management is critical during the testing of many devices, especially those at the semiconductor wafer level, such as VCSELs, laser diodes, and LEDs. Pulsed I-V testing minimizes the heating effects of the current in the device, especially if tested at the wafer level when devices have no temperature control circuitry. Testing with DC would either change their characteristics, or at worst, destroy them. Later on, in production, when they have been assembled into modules with temperature controls, the devices can be DC tested and the results compared to those from the pulsed test. Some devices will pass a DC test and fail a pulsed test due to device characteristic changes resulting from temperature shift. The 10 V / 10 A / 10 µs output of the 2601B-PULSE ensures that you get a proper output pulse into your device and an accurate measurement when it is required. Pulse output performance of the 2610B-PULSE SMU. 2 TEK.COM No Tuning Required When outputting current pulses, cabling and inductance can be a problem. Inductance can have a limiting effect and could even be damaging. Quite often, the inductance can be different from device to device, even when testing laser diodes on a wafer. The effect of inductance on a current source is that inductance resists changes in current. This can cause the current source to increase the output voltage. The result is overshoot and ringing as the pulse settles. This may not be acceptable in your test. Some solutions require tuning to compensate for these behaviors, which can be time consuming. The 2601B-PULSE’s control loop system eliminates the need to tune for load changes up to 3 μH so that your pulse has no overshoot and ringing when outputting pulses from 10 μs up to 500 μs at a current up to 10 amps. This ensures a fast rise time, so your devices are sourced with a current pulse to properly characterize the device or circuit. The images on the next page show the performance of the 2601B-PULSE with PulseMeter technology compared to a competitive modular SMU outputting a 5 A, 50 μs pulse on a device with an impedance of 3 µH. 2601B-PULSE System SourceMeter 10 µs Pulser/SMU Instrument Unmatched Throughput for Automated Test with TSP Technology For test applications that demand the highest levels of automation and throughput, the 2601B-PULSE’s TSP technology delivers industry-best performance. TSP technology goes far beyond traditional test command sequencers — it fully embeds, then executes, complete test programs from within the SMU instrument itself. This virtually eliminates the timeconsuming bus communications to and from the PC controller, and thus dramatically improves overall test times. • Conditional branching • Advanced calculations and flow control • Variables • Pass/Fail test • Prober/Handler control • Datalogging/ Formatting Test Script DUT Typical pulse output from a competitive SMU with overshoot and 6.47 μs rise time. TSP technology executes complete test programs from the non-volatile memory of the 2601B-PULSE.
2601B-PULSE-CA1 价格&库存
很抱歉,暂时无法提供与“2601B-PULSE-CA1”相匹配的价格&库存,您可以联系我们找货
