3706A
3706A
    KEITHLEY
    3706A
3706A 数据手册
Series 3700A System Switch/Multimeter and Plug-In Cards Datasheet Key Features • Six-slot system switch mainframe with optional high performance multimeter • Multi-processor architecture optimized for high throughput scanning and pattern switching applications • Remote PC control via Ethernet, USB, and GPIB interfaces • Up to 576 two-wire or 720 one-wire multiplexer channels in one mainframe • Up to 2,688 one-pole matrix crosspoints in one mainframe A Tektronix Company The Series 3700A offers scalable, instrument grade switching and multi-channel measurement solutions that are optimized for automated testing of electronic products and components. The Series 3700A includes four versions of the 3706A system switch mainframe along with a growing family of plug-in switch and control cards. When the 3706A mainframe is ordered with the high performance multimeter, you receive a tightly integrated switch and measurement system that can meet the demanding application requirements in a functional test system or provide the flexibility needed in stand-alone data acquisition and measurement applications. • Embedded Test Script Processor (TSP®) offering unparalleled system automation, throughput, and flexibility • TSP-Link Technology master/slave connection provides easy system expansion and seamless connection to Series 2600 and 2600B SourceMeter® SMU instruments • Capable of over 14,000 readings per second to memory with optional high performance multimeter • LXI interface with embedded Web browser interface for test setup, maintenance, and basic application control Maximizes System Control and Flexibility To provide users with greater versatility when designing test systems, the Series 3700A mainframes are equipped with many standard features. For example, easy connectivity is supported with three remote interfaces: LXI/Ethernet, General Purpose Interface Bus (GPIB), and Universal Serial Bus (USB). Fourteen digital I/O lines are also included, which are programmable and can be used to control external devices such as component handlers or other instruments. Additionally, system control can be greatly enhanced by using our Test Script Processor (TSP) technology. This technology provides “smart” instruments with the ability to perform distributed processing and control at the instrument level versus a central PC. Datasheet High Quality Switching at a Value Price This flexible resolution supplies a DC reading rate from >14,000 readings/second at 3½ digits to 60 readings/ second at 7½ digits to accommodate a greater span of applications. The multimeter does not use a card slot, so you maintain all six slots in your mainframe. In addition, the multimeter is wired to the mainframe’s analog backplane, ensuring a high quality signal path from each card channel to the multimeter. The Series 3700A builds upon Keithley’s tradition of producing innovative, high quality, precise signal switching. This series offers a growing family of high density and general purpose plug-in cards that accommodates a broad range of signals at very competitive pricing. The Series 3700A supports applica­tions as diverse as design validation, accelerated stress testing, data acquisition, and functional ­testing. Single Channel Reading Rates 3706A Mainframe DCV/ 2 Wire Ohms NPLC The Series 3700A includes the base 3706A system switch/multimeter mainframe with three options for added flexibility. This mainframe contains six slots for plug-in cards in a compact 2U high (3.5 inches/89 mm) enclosure that easily accommodates the needs of medium to high channel count applications. When fully loaded, a mainframe can support up to 576 two-wire multiplexer channels or 2,688 one-pole matrix crosspoints for unrivaled density and economical per channel costs. 4 Wire Ohms 1.0 60 29 0.2 295 120 0.06 935 285 0.006 6,200 580 0.0005 14,100 650 The multimeter supports 13 built-in measurement functions, including: DCV, ACV, DCI, ACI, frequency, period, two-wire ohms, four-wire ohms, three-wire RTD temperature, four-wire RTD temperature, thermocouple temperature, thermistor temperature, and continuity. In addition, the multimeter offers extended low ohms (1 W) and low current (10 µA) ranges. In-rack calibration is ­supported, which reduces both maintenance and calibration time. High Performance, 7½-digit Multimeter (DMM) The high performance multimeter option provides up to 7½-digit measurements, offering 26-bit resolution to support your ever-increasing test accuracy requirements. Measurement Capability 1p DC Voltage AC Voltage DC Current AC Current Frequency 1µ 1n 1m 1 1k 1 pA 3A 3A 1 nA 500 kHz 3 Hz 2 µs 1 µΩ 100 nΩ Dry Circuit Resistance 1G 300 V 300 V 10 nV 100 nV Period Resistance (2-Wire) Resistance (4-Wire) 1M 330 ms 120 MΩ 120 MΩ 2 kΩ 1 µΩ Logarithmic scale –500 Temperature–RTD Temperature–TC Temperature–Thermistor Linear scale Measurement capabilities of the high performance multimeter 2 TEK.COM 0 500 –200°C –200°C –80°C 1000 1500 2000 630°C 1820°C 150°C Series 3700A System Switch/Multimeter and Plug-In Cards TSP Distributed Control Increases Test Speed and Lowers Test Cost TSP technology enhances instrument control by allowing users the choice of using standard PC control or of creating embedded test scripts that are executed on microprocessors within the instrument. By using TSP test scripts instead of a PC for instrument control, you avoid communication delays between the PC controller and instrument, which results in improved test throughput. Test scripts can contain math and decision-­making rules that further reduce the interaction between a host PC and the instrument. This form of distributed control supports the autonomous operation of individual instruments or groups of instruments and can possibly remove the need for a high level PC controller, which lowers test and ownership costs. This is the same proven TSP technology found in our innovative Series 2600B System SourceMeter® SMU instruments. TSP-Link Technology for Easy and Seamless System Coordination and Expansion If your channel density requirements grow or if you need to process more signal types, use TSP-Link to expand your system. The TSP-Link master/slave connection offers easy system expansion between Series 3700A mainframes. You can also use TSP-Link to connect to other TSP-Link enabled instruments such as Series 2600B SourceMeter SMU instruments. Everything connected with TSP-Link can be controlled by the master unit, just as if they were all housed in the same chassis. This high speed system expansion interface lets users avoid the complex and time-consuming task of expanding their remote interfaces to another mainframe. There is no need to add external triggers and remote communication cables to individual instruments, since all TSP-Link connected devices can be controlled from a single master unit. Test Script Builder Software Suite Test Script Builder is a software tool that is provided with all Series 3700A instruments to help users easily create, modify, debug, and store TSP test scripts. It supplies a project/file manager window to store and organize test scripts, a context-sensitive program editor to create and modify test TSP code, and an immediate instrument control window to send Ethernet, GPIB, and USB commands and to receive data from the instrument. The immediate window also allows users to see the output of a given test script and simplifies d ­ ebugging. Create and modify test TSP code in the context-sensitive editor window. Store and organize test scripts in the file manager window. The immediate window ­displays test script output and assists in debugging. Test Script Builder Software Suite Version 1.4 LXI Core 2011 with LXI Clock Synchronization, LXI Timestamped Data, LXI Event Messaging, LXI Event Log. Transportable Memory, USB 2.0 Device Port All 3706A mainframes contain a USB device port for easy transfer of readings, configurations, and test scripts to memory sticks. This port, which is located on the front panel, provides you with easy access to and portability of measurement results. Simply plug in a memory stick and, with a few simple keystrokes, gain access to virtually unlimited memory storage. Additional capabilities include saving and recalling system configurations and storage for TSP scripts. TEK.COM 3 Datasheet Embedded Web Server The built-in Web interface offers a quick and easy method to control and analyze measurement results. Interactive schematics of each card in the mainframe support pointand-click control for opening and closing switches. A scan list builder is provided to guide users through the requirements of a scan list (such as trigger and looping definitions) for more advanced applications. When the mainframe is ordered with the multimeter, additional Web pages are included for measurement configuration and viewing, including a graphing toolkit. Built-in Web Server Interface 3. Analyze your data. View your results in real-time or historical mode with point-and-click simplicity. Data can be exported directly to your PC in either numerical or graphical formats for presentation or other applications. 3706A front panel 1. Configure your switch channels and measurement functions. Configure the DMM to make your measurements at the desired speed, resolution, etc. and assign them to the desired channels. 3706A-S front panel 3706A-NFP and 3706A-SNFP front panel 2. Build and run your automated scan list. The toolkit makes it easy to build and execute an automated sequence of channel-open and channel-close commands and triggered multimeter measurements. 3706A rear panel 4 TEK.COM Series 3700A System Switch/Multimeter and Plug-In Cards High Performance Multimeter Specifications (Rev. A) DC Specifications 1 PLC or 5 PLC. For 10 GΩ or 10 MΩ ±1% 10 + 9 25 + 9 30 + 9 (1 + 5)/°C 1.0000 000 V 19 0.1 µV >10 GΩ or 10 MΩ ±1% 7+2 25 + 2 30 + 2 (1 + 1)/°C 10.000000 V 1 µV >10 GΩ or 10 MΩ ±1% 7+2 20 + 2 25 + 2 (1 + 1)/°C 100.00000 V 10 µV 10 MΩ ±1% 15 + 6 35 + 6 40 + 6 (5 + 1)/°C 300.00000 V 100 µV 10 MΩ ±1% 20 + 6 35 + 6 40 + 6 (5 + 1)/°C 1.0000000 Ω 0.1 µΩ 10 mA 8.2 V 15 + 80 40 + 80 60 + 80 (8 + 1)/°C 10.000000 Ω 1 µΩ 10 mA 8.2 V 15 + 9 40 + 9 60 + 9 (8 + 1)/°C 100.00000 Ω 10 µΩ 1 mA 13.9 V 15 + 9 45 + 9 65 + 9 (8 + 1)/°C 1.0000000 kΩ 100 µΩ 1 mA 13.9 V 20 + 4 45 + 4 65 + 4 (8 + 1)/°C 10.000000 kΩ 1 mΩ 100 µA 9.1 V 15 + 4 40 + 4 60 + 4 (8 + 1)/°C 100.00000 kΩ 10 mΩ 10 µA 14.7 V 20 + 4 45 + 5 65 + 5 (8 + 1)/°C 1.0000000 MΩ 100 mΩ 10 µA 14.7 V 25 + 4 50 + 5 70 + 5 (8 + 1)/°C 10.000000 MΩ 1Ω 0.64 µA//10 MΩ 6.4 V 150 + 6 200 + 10 400 + 10 (70 + 1)/°C 100.00000 MΩ 10 Ω 0.64 µA//10 MΩ 6.4 V 800 + 30 2000 + 30 2000 + 30 (385 + 1)/°C 1.0000000 Ω 1 µΩ 10 mA 27 mV 25 + 80 50 + 80 70 + 80 (8 + 1)/°C 10.000000 Ω 10 µΩ 1 mA 20 mV 25 + 80 50 + 80 70 + 80 (8 + 1)/°C 100.00000 Ω 100 µΩ 100 µA 20 mV 25 + 80 90 + 80 140 + 80 (8 + 1)/°C (8 + 1)/°C 1.0000000 kΩ 1 mΩ 10 µA 20 mV 25 + 80 180 + 80 400 + 80 2.0000000 kΩ 10 mΩ 5 µA 20 mV 25 + 80 320 + 80 800 + 80 (8 + 1)/°C 1.000 kΩ 100 mΩ 1 mA 13.9 V 40 + 100 100 + 100 100 + 100 (8 + 1)/°C (35 + 9)/°C 10.000000 µA 1 pA
3706A 价格&库存
很抱歉,暂时无法提供与“3706A”相匹配的价格&库存,您可以联系我们找货
