803293
803293
    FLUKE(福禄克)
803293 数据手册
Fluke holsters and fuses Take care of your test tools— inside and out Protective meter holsters C10 Meter Holster • Snap on yellow holster absorbs shocks and protects meter from rough handling Fits Fluke 10 Series DMMs • C70Y Meter Holster • Snap on yellow holster absorbs shocks and protects meter from rough handling Flex-Stand™ allows meter to hang, lean or stand for convenience and best viewing For Fluke 70 and 73 Meters • ToolPak™ Magnetic Meter Hanging Solution • Free both hands to make measurements • Hang your meter from metallic surfaces like panels and pipes • Kit includes universal hanger clips (two), hook and loop straps (two lengths), adapter and strong magnet • Attaches to back of many Fluke meters, including 110, 170, 180 Series, 87V and 83V DMMs, 724, 725 and 789 Process Calibrators, 70 Series III DMMs, 1503, 1507, 1577 and 1587 Insulation Multimeters and 50 Series II Digital Thermometers IntelliTone 200 Kit • IntelliTone digital processing H80M Protective Holster with magnetic strap • • Snap on holster absorbs • shocks and protects meter from rough handling Magnetic strap solution makes it easy to hang your meter for hands free work For Fluke 80 Series DMMs, 710 Series and 787 calibration tools • • • • Fuse selection guide Replacement fuses for Fluke DMMs are available from your distributor in 440 mA, 500 mA, 630 mA, 1 A, 2 A, 3 A, 11 A, and 15 A values. To order direct from Fluke call 1-888-99-FLUKE (U.S.) or contact your distributor. 21-III/75-III 73-III 76/29/79-II 83/85/87/88 (S/N < 65650001) 25/27 (S/N < 7247001) 27 (S/N >7247001) 45 (S/N < 7211001) 45 (S/N > 7211001) 73 and 73-II 863/865/867/867B 83/85/87 (S/N > 65650001) 87-IV/89-IV/187/189/ 83-III/85-III/87-III/87E-III/83V/87V 23-III/77-III/26-III/79-III/175/177/179 111/112 712/713/714/715/716/717/718 724/725 1577/1587 1503/1507 formula removes surface dirt, oil and grease • Safe on rubber • Safe to the environment • Comes in two sizes: 6-pack (MC6) and 50-pack (MC50) Verification tools • Model 21/23/75/77-II New! MeterCleaner Wipes • Industrial strength cleaning Fuse requirements P/N 871173; 630 mA 250V fuse P/N 892583; 15 A 600 V fuse P/N 871173; 630 mA 250 V fuse P/N 803293 11 A 1000 V fuse P/N 871207; 1 A 600 V fuse P/N 892583; 15 A 600 V fuse P/N 871173; 630 mA 250 V fuse P/N 871202; 3A 600 V fuse P/N 892583; 15A 600 V fuse P/N 943121; 440 mA 1000 V fuse P/N 803293; 11A 1000 V fuse P/N 871181; 500 mA 250 V fuse P/N 892583; 15 A 600 V fuse P/N 871181; 500 mA 250 V fuse P/N 943121; 440 mA 1000 V fuse P/N 803293; 11 A 1000 V fuse P/N 892583; 15 A 600 V fuse P/N 943121; 440 mA 1000 V fuse P/N 803293; 11 A 1000 V fuse P/N P/N P/N P/N P/N 803293; 11 A 1000 V fuse 686527; 125 mA 250 V fuse 2002234 (qty. 1); 50 mA 250 V fuse 943121; 440 mA 1000 V fuse 2279339; 315 mA, 1000 V fuse For more information and detailed specifications, go to www.fluke.com/accessories eliminates noise and false signals New SmartTone™ analog toning precisely isolates individual wire pairs Locates cables safely and effectively on active networks Verifies twisted-pair installation with visual end-to-end continuity test Identifies, diagnoses, and troubleshoots datacom/telecom services Test the integrity of UTP, Coax, phone and security cabling using known standards. MicroScanner Pro • The essential cable verification tester • Measures length and distance to • • • • • fault via true TDR (Time Domain Reflectometry) Pinpoints opens, shorts, reversed, crossed and split pairs Tests UTP, STP and coax cables Flashes hub and switch port lights Identifies active networking hubs and detects speed/duplex settings Analog tone generator with four song selections MicroMapper • The fast, comprehensive LAN wiremap checker • Tests twisted-pair cables for opens, shorts, crossed pairs, split pairs, or any miswires Verifies correct pin outs, wiremap • For more information and detailed specifications, go to www.flukenetworks.com Accessories 71
803293 价格&库存
很抱歉,暂时无法提供与“803293”相匹配的价格&库存,您可以联系我们找货
