7705-MTC-2
7705-MTC-2
    KEITHLEY
    KEITHLEY - 7705-MTC-2 - Test Cable Assembly, D-Sub Cable Assembly
7705-MTC-2 数据手册
Model 7705-MTC-2 Cable Packing List Keithley Instruments, Inc. 28775 Aurora Road Cleveland, Ohio 44139 (440) 248-0400 Fax: (440) 248-6168 www.keithley.com General information The Model 7705-MTC-2 cable is a 50-pin cable assembly (2 meters in length) terminated with a male D-sub connector on one end and a female D-sub connector on the other end. This cable mates to the 50-pin D-sub connectors on the Models 7701, 7703, 7705, and 7707 switching modules. 7705-MTC-2 cable WARNING To prevent electric shock, adhere to the following safety precautions: • • • • Both ends of the cable must be connected before applying any power to the system. Remove all power in the system before connecting the cable to a switching module or external circuitry. Both D-sub connector shells of this cable must be connected to a safety earth ground if any hazardous voltages are present. A shock hazard exists when voltage levels greater than 30VRMS, 42.4V peak, or 60VDC are present. Do not exceed the maximum signal levels for the cable or the switching module(s). Cable maximum signal levels The Model 7705-MTC-2 cable is rated for 300VDC or RMS maximum voltage, and 2A maximum current. Pin number identification Pin number identification for the D-sub connectors of the 7705-MTC-2 cable are shown as follows: Male D-sub connector: 1 17 18 33 34 50 Female D-sub connector: 17 33 1 18 50 34 PA-806 Rev. A / 10-01 NOTE The Model 7705-MTC-2 cable is a one-to- one connection (pin 1 of male D-Sub connects to pin 1 of female D-Sub). Switching modules terminal identification Refer to the individual switching module packing list for specific hookup information.
7705-MTC-2 价格&库存
很抱歉,暂时无法提供与“7705-MTC-2”相匹配的价格&库存,您可以联系我们找货
7705-MTC-2
    库存:1
