2000/E
2000/E
    KEITHLEY
    KEITHLEY - 2000/E - DMM, BENCH, 6.5 DIGIT, 3A, 1KV
2000/E 数据手册
The Model 2000 6½-Digit Multimeter is part of Keithley’s family of high performance DMMs. Based on the same high speed, low noise A/D converter technology as the Model 2001 and 2002, the 2000 is a fast, accurate, and highly stable instrument that’s as easy to operate as it is to afford. It combines broad measurement ranges with superior accuracy specifications — DC voltage from 100nV to 1kV (with 0.002% 90-day basic accuracy) and DC resistance from 100µW to 100MW (with 0.008% 90-day basic accuracy). Optional switch cards enable multiplexing up to 20 different input signals for multipoint measurement applications. • 13 built-in measurement functions • 2000 readings/second at 4½ digits • Optional scanner cards for multipoint measurements • GPIB and RS-232 interfaces • Fluke 8840/42 command set Ordering Information 2000 6½-Digit DMM 2000/2000-SCAN 6½-Digit DMM/ Scanner Combination Accessories Supplied Instruction Manual and Model 1751 Safety Test Leads DIGITAL MULTIMETERS & SYSTEMS 6½-Digit Multimeter ACCESSORIES AVAILABLE 2000-SCAN 2001-SCAN 2001-TCSCAN 10-channel, General-Purpose Scanner Card 10-channel Scanner Card with two high-speed ­channels 9-channel, Thermocouple Scanner Card with built-in cold junction Cables/Adapters 7007-1 Shielded IEEE-488 Cable, 1m (3.3 ft) 7007-2 Shielded IEEE-488 Cable, 2m (6.6 ft) 7009-5 RS-232 Cable Rack Mount Kits 4288-1 Single Fixed Rack Mount Kit 4288-2 Dual Fixed Rack Mount Kit GPIB Interfaces KPCI-488LPA IEEE-488 Interface/Controller for the PCI Bus KUSB-488B IEEE-488 USB-to-GPIB Interface Adapter High Throughput The 2000 offers exceptional measurement speed at any reso­lution. At 6½ digits, it delivers 50 triggered rdgs/s over the IEEE-488 bus. At 4½ digits, it can read up to 2000 rdgs/s into its internal 1024 reading buf­fer, making it an excellent choice for applications where throughput is ­critical. For benchtop or stand-alone applications, the 2000 has a front panel design that’s simple to understand and easy to use. The 2000 has 13 built-in measurement functions, including DCV, ACV, DCI, ACI, 2WW, 4WW, temper­ature, frequency, period, dB, dBm, continuity mea­sure­ ment, and diode testing. A built-in RS-232 inter­ face con­­nects to a notebook or full-sized PC’s serial port to take, store, process, and dis­­play meas­­ure­­­ments auto­matically. Services Available 2000-SCAN-3Y-EW 1-year factory warranty extended to 3 years from date of shipment 2000-3Y-EW 1-year factory warranty extended to 3 years from date of shipment 2001-TCSCAN-3Y-EW 1-year factory warranty extended to 3 years from date of shipment C/2000-3Y-ISO 3 (ISO-17025 accredited) calibrations within 3 years of purchase for Models 2000, 2000-SCAN* C/2001-3Y-ISO 3 (ISO-17025 accredited) calibrations within 3 years of purchase for Model 2001-TCSCAN* *Not available in all countries 1.888.KEITHLEY (U.S. only) www.keithley.com A Greater Measure of Confidence General-purpose instrument that’s as easy to operate as it is to afford General-purpose instrument that’s as easy to operate as it is to afford 2000 6½-Digit Multimeter Optional Multiplexer Cards Creating a self-contained multipoint measurement solution is as simple as plugging a scanner card into the option slot on the 2000’s back panel. This ap­proach eliminates the complexities of triggering, timing, and processing issues and helps reduce test time significantly. For applications involving more than 10 measurement points, the 2000 is com­patible with Keithley’s Series 7000 switch matrices and cards. Model 2000-SCAN Scanner Card • Ten analog input channels (2-pole) • Configurable as 4-pole, 5-channel Model 2001-SCAN Scanner Card • Ten analog input channels GENERAL: 10 channels of 2-pole relay input. All channels configurable to 4-pole. CAPABILITIES: Multiplex one of ten 2-pole or one of five 4-pole signals into DMM. INPUTS Maximum Signal Level: DC Signals: 110V DC, 1A switched, 30VA maximum (resistive load). AC Signals: 125V AC rms or 175V AC peak, 100kHz maximum, 1A switched, 62.5VA maximum (resistive load). Contact Life: >105 operations at maximum signal level; >108 operations cold switch­ing. Contact Resistance: 10 GW 10 MW ±1% 10 MW ±1% 1 mA 1 mA 100 µA 10 µA 10 µA 700 nA // 10MW 700 nA // 10MW < 0.15 V < 0.03 V < 0.3 V
2000/E 价格&库存
很抱歉,暂时无法提供与“2000/E”相匹配的价格&库存,您可以联系我们找货
