3706A-S
3706A-S
    KEITHLEY
    KEITHLEY - 3706A-S - Bench Digital Multimeter, Current, Voltage, Frequency, Resistance, Temperature,...
3706A-S 数据手册
The Series 3700A offers scalable, instrument grade switching and multi-channel measurement solutions that are optimized for automated testing of electronic products and components. The Series 3700A includes four versions of the Model 3706A system switch mainframe along with a growing family of plug-in switch and control cards. When the Model 3706A mainframe is ordered with the high performance multimeter, you receive a tightly integrated switch and measurement system that can meet the demanding application requirements in a functional test system or provide the flexibility needed in stand-alone data acquisition and measurement applications. • Six-slot system switch mainframe with optional high performance multimeter • Multi-processor architecture optimized for high throughput scanning and pattern switching applications • Remote PC control via Ethernet, USB, and GPIB interfaces • Up to 576 two-wire or 720 onewire multiplexer channels in one mainframe • Up to 2,688 one-pole matrix crosspoints in one mainframe • Embedded Test Script Processor (TSP®) offering unparalleled system automation, throughput, and flexibility SWITCHING AND CONTROL System Switch/Multimeter and Plug-In Cards • TSP-Link Technology master/ slave connection provides easy system expansion and seamless connection to Series 2600 and 2600B SourceMeter® SMU instruments • Capable of over 14,000 readings per second to memory with optional high performance multimeter • LXI interface with embedded Web browser interface for test setup, maintenance, and basic application control Maximizes System Control and Flexibility To provide users with greater versatility when designing test systems, the Series 3700A mainframes are equipped with many standard features. For example, easy connectivity is supported with three remote interfaces: LXI/Ethernet, General Purpose Interface Bus (GPIB), and Universal Serial Bus (USB). Fourteen digital I/O lines are also included, which are programmable and can be used to control external devices such as component handlers or other instruments. Additionally, system control can be greatly enhanced by using our Test Script Processor (TSP) technology. This technology provides “smart” instruments with the ability to perform distributed processing and control at the instrument level versus a central PC. High Quality Switching at a Value Price The Series 3700A builds upon Keithley’s tradition of producing innovative, high quality, precise signal switching. This series offers a growing family of high density and general purpose plug-in cards that accommodates a broad range of signals at very competitive pricing. The Series 3700A supports applica­ tions as diverse as design validation, accelerated stress testing, data acquisition, and functional t­esting. Model 3706A Mainframe The Series 3700A includes the base Model 3706A system switch/multimeter mainframe with three options for added flexibility. This mainframe contains six slots for plug-in cards in a compact 2U high (3.5 inches/89mm) enclosure that easily accommodates the needs of medium to high channel count applications. When fully loaded, a mainframe can support up to 576 two-wire multiplexer channels or 2,688 one-pole matrix crosspoints for unrivaled density and economical per channel costs. High Performance, 7½-digit Multimeter (DMM) The high performance multimeter option provides up to 7½-digit measurements, offering 26-bit resolution to support your ever-increasing test accuracy requirements. This flexible resolution supplies a DC reading rate from >14,000 readings/second at 3½ digits to 60 readings/second at 7½ digits to accommodate a greater span of applications. Single Channel Reading Rates The multimeter does not use a card slot, so DCV/ 4 Wire you maintain all six slots in your mainframe. Ohms NPLC 2 Wire Ohms In addition, the multimeter is wired to the 60 29 1.0 mainframe’s analog backplane, ensuring a high 295 120 0.2 quality signal path from each card channel to 935 285 0.06 the multimeter. 0.006 6,200 580 The multimeter supports 13 built-in measure14,100 650 0.0005 ment functions, including: DCV, ACV, DCI, ACI, frequency, period, two-wire ohms, four-wire ohms, three-wire RTD temperature, four-wire RTD temperature, thermocouple temperature, thermistor temperature, and continuity. In addition, the multimeter offers extended low ohms (1W) and low current (10µA) ranges. In-rack calibration is ­supported, which reduces both maintenance and calibration time. A Tektronix Company System switch with high performance multimeter System switch with high performance multimeter Series 3700A System Switch/Multimeter and Plug-In Cards Mainframes 3706A Six-slot system switch with high performance DMM 3706A-NFP Six-slot system switch with high performance DMM, without front panel display and keypad 3706A-S Six-slot system switch 3706A-SNFP Six-slot system switch, without front panel display and keypad Plug-in Cards 3720 Dual 1×30 multiplexer card (auto CJC when used with 3720-ST) 3721 Dual 1×20 multiplexer card (auto CJC when used with 3721-ST) 3722 Dual 1×48, high density, multiplexer card 3723 Dual 1×30, high speed, reed relay multiplexer card 3724 Dual 1×30 FET multiplexer card 3730 6×16, high density, matrix card 3731 6×16 high speed, reed relay matrix card 3732 Quad 4×28, ultrahigh density, reed relay matrix card 3740 32 channel isolated switch card 3750 Multifunction control card Accessories Supplied Test Script Builder Software Suite CD Ethernet Crossover Cable (CA-180-3A) Series 3700A Product CD (includes LabVIEW®, IVI C, and IVI.COM drivers) Measurement Capability 1p 1µ 1n 1m 1 1k DC Voltage AC Voltage DC Current AC Current Frequency 1M 1G 500kHz Period Resistance (2-Wire) Resistance (4-Wire) 2µs 330ms Dry Circuit Resistance Logarithmic scale Temperature–RTD Temperature–TC Temperature–Thermistor Linear scale Measurement capabilities of the high performance multimeter ACCESSORIES AVAILABLE GPIB INTERFACES AND CABLES 7007-1 Shielded GPIB Cable, 1m (3.5ft) 7007-2 Shielded GPIB Cable, 2m (6.6ft) KPCI-488LPA IEEE-488 Interface/Controller for the PCI Bus KUSB-488B IEEE-488 USB-to-GPIB Interface Adapter DIGITAL I/O, TRIGGER LINK, AND TSP-LINK 2600-TLINK Trigger I/O to Trigger Link Interface Cable, 1m (3.3 ft) CA-126-1 Digital I/O and Trigger Cable, 1.5m (4.9 ft) CA-180-3A CAT5 Crossover Cable for TSP-Link MULTIMETER CONNECTORS 3706-BAN DMM Adapter Cable, 15-pin D-sub to banana jacks, 1.4m (4.6 ft) 3706-BKPL Analog Backplane Extender Board, 15-pin D-sub to terminal block 3706-TLK Test Lead Kit, includes 3706-BAN and plug-in test lead accessories 8620 Shorting Plug SERVICES AVAILABLE Mainframe Models 3706A and 3706A-NFP 3706A-3Y-EW 1 Year Factory Warranty Extended to 3 Years 1 Year Factory Warranty Extended to 5 Years 3706A-5Y-EW C/3706A-3Y-STD Calibration Contract, 3 Years, Standard Calibration* C/3706A-3Y-DATA Calibration Contract, 3 Years, Z540 Compliant Calibration with Data* C/3706A-3Y-ISO Calibration Contract, 3 Years, ISO 17025 Accredited Calibration* C/3706A-5Y-STD Calibration Contract, 5 Years, Standard Calibration* C/3706A-5Y-DATA Calibration Contract, 5 Years, Z540 Compliant Calibration with Data* C/3706A-5Y-ISO Calibration Contract, 5 Years, ISO 17025 Accredited Calibration* Mainframe Models 3706A-S and 3706A-SNFP 3706A-S-3Y-EW 1 Year Factory Warranty Extended to 3 Years 3706A-S-5Y-EW 1 Year Factory Warranty Extended to 5 Years RACK MOUNT KIT SOFTWARE SERVICES SYSTEM DEVELOPMENT OR IMPLEMENTATION Other service contracts are available; please contact us for details. 4288-10 *Not available in all countries. Fixed Rear Rack Mount Kit A Tektronix Company System switch with high performance multimeter System switch with high performance multimeter Ordering Information SWITCHING AND CONTROL Series 3700A System Switch/Multimeter and Plug-In Cards TSP Distributed Control Increases Test Speed and Lowers Test Cost TSP technology enhances instrument control by allowing users the choice of using standard PC control or of creating embedded test scripts that are executed on microprocessors within the instrument. By using TSP test scripts instead of a PC for instrument control, you avoid communication delays between the PC controller and instrument, which results in improved test throughput. Test scripts can contain math and decision-­ making rules that further reduce the interaction between a host PC and the instrument. Test Script Builder Software Suite Test Script Builder is a software tool that is provided with all Series 3700A instruments to help users easily create, modify, debug, and store TSP test scripts. It supplies a project/file manager window to store and organize test scripts, a text-sensitive program editor to create and modify test TSP code, and an immediate instrument control window to send Ethernet, GPIB, and USB commands and to receive data from the instrument. The immediate window also allows users to see the output of a given test script and simplifies d­ ebugging. This form of distributed control supports the autonomous operation of individual instruments or groups of instruments and can possibly remove the need for a high level PC controller, which lowers test and ownership costs. This is the same proven TSP technology found in our innovative Series 2600B System SourceMeter® SMU instruments. TSP-Link Technology for Easy and Seamless System Coordination and Expansion If your channel density requirements grow or if you need to process more signal types, use TSP-Link Technology to expand your system. The TSPLink master/slave connection offers easy system expansion between Series 3700A mainframes. You can also use TSP-Link Technology to connect to other TSP-Link enabled instruments such as Series 2600B SourceMeter SMU instruments. Everything connected with TSP-Link can be controlled by the master unit, just as if they were all housed in the same chassis. This high speed system expansion interface lets users avoid the complex and time consuming task of expanding their remote interfaces to another mainframe. There is no need to add external triggers and remote communication cables to individual instruments, since all TSP-Link connected devices can be controlled from a single master unit. Create and modify test TSP code in the context sensitive editor window. Store and organize test scripts in the file manager window. The immediate window ­displays test script output and assists in debugging. Test Script Builder Software Suite SWITCHING AND CONTROL Version 1.4 LXI Core 2011 with LXI Clock Synchronization, LXI Timestamped Data, LXI Event Messaging, LXI Event Log. Transportable Memory, USB 2.0 Device Port All Model 3706A mainframes contain a USB device port for easy transfer of readings, configurations, and test scripts to memory sticks. This port, which is located on the front panel, provides you with easy access to and portability of measurement results. Simply plug in a memory stick and, with a few simple keystrokes, gain access to virtually unlimited memory storage. Additional capabilities include: saving and recalling system configurations and storage for TSP scripts. A Tektronix Company System switch with high performance multimeter System switch with high performance multimeter Series 3700A Embedded Web Server The built-in Web interface offers a quick and easy method to control and analyze measurement results. Interactive schematics of each card in the mainframe support point-and-click control for opening and closing switches. A scan list builder is provided to guide users through the requirements of a scan list (such as trigger and looping definitions) for more advanced applications. When the mainframe is ordered with the multimeter, additional Web pages are included for measurement configuration and viewing, including a graphing toolkit. Built-in Web Server Interface 3. Analyze your data. View your results in real-time or historical mode with point-and-click simplicity. Data can be exported directly to your PC in either numerical or graphical formats for presentation or other applications. 1. Configure your switch channels and measurement functions. Configure the DMM to make your measurements at the desired speed, resolution, etc. and assign them to the desired channels. System switch with high performance multimeter System Switch/Multimeter and Plug-In Cards Model 3706A front panel Model 3706A-S front panel 2. Build and run your automated scan list. The toolkit makes it easy to build and execute an automated sequence of channel-open and channel-close commands and triggered multimeter measurements. Model 3706A-NFP and Model 3706A-SNFP front panel Model 3706A rear panel A Tektronix Company SWITCHING AND CONTROL System switch with high performance multimeter Series 3700A Series 3700A System Switch/Multimeter and Plug-In Cards High Performance Multimeter Specifications (Rev. A) DC Specifications Series 3700A specifications Function Voltage4 Resistance 4, 5, 6, 7 Dry Circuit Resistance 6, 8 Continuity (2W) Current 9 Range 100.00000 mV 19 1.0000000 V 19 10.000000 V 100.00000 V 300.00000 V 1.0000000 W 10.000000 W 100.00000 W 1.0000000 kW 10.000000 kW 100.00000 kW 1.0000000 MW 10.000000 MW 100.00000 MW 1.0000000 W 10.000000 W 100.00000 W 1.0000000 kW 2.0000000 kW 1.000 kW 10.000000 µA 100.00000 µA 1.0000000 mA 10.000000 mA 100.00000 mA 1.0000000 A 3.0000000 A 1 Resolution 0.01 µV 0.1 µV 1 µV 10 µV 100 µV 0.1 µW 1 µW 10 µW 100 µW 1 mW 10 mW 100 mW 1 W 10 W 1 µW 10 µW 100 µW 1 mW 10 mW 100 mW 1 pA 10 pA 100 pA 1 nA 10 nA 100 nA 1 µA Test Current or Burden Voltage 10 mA 10 mA 1 mA 1 mA 100 µA 10 µA 10 µA 0.64 µA//10 MW 0.64 µA//10 MW 10 mA 1 mA 100 µA 10 µA 5 µA 1 mA
3706A-S 价格&库存
很抱歉,暂时无法提供与“3706A-S”相匹配的价格&库存,您可以联系我们找货
3706A-S
    库存:1
