2010/E
2010/E
    KEITHLEY
    KEITHLEY - 2010/E - Bench Digital Multimeter, Keithley 2000 Series, True RMS, Auto Range, 750 V, 3 A...
2010/E 数据手册
The 7½-digit Model 2010 Low Noise Multi­meter ­combines high resolution with the high speed and accuracy needed for production applications such as testing precision sensors, transducers, A/D and D/A con­verters, regulators, references, connectors, switches, and relays. It is based on the same high speed, low noise A/D converter technology as the Models 2000, 2001, and 2002. High Measurement Flexibility The 2010 has 15 built-in measurement functions, including DCV, ACV, DCI, ACI, 2WW, 4WW, dry circuit resistance, temperature (with either thermocouples or RTDs), frequency, period, ratio, continuity meas­­ure­ment, and diode testing. This multi-functional design minimizes added equip­ment costs. • 7½-digit resolution • 100nV rms noise floor • 7ppm DCV repeatability • Built-in 10-channel scanner mainframe • Dry circuit and low power measurement mode • 15 measurement functions including support for RTD and thermocouple temperature measurements • Built-in ratio measurement function • GPIB and RS-232 interfaces Ordering Information 2010 Autoranging DMM Accessories Supplied Model 1751 Safety Test Leads, User Manual, Service Manual Services Available 2000-SCAN-3Y-EW 1-year factory warranty extended to 3 years from date of shipment 2001-TCSCAN-3Y-EW 1-year factory warranty extended to 3 years from date of shipment 2010-3Y-EW 1-year factory warranty extended to 3 years from date of shipment C/2000-3Y-ISO 3 (ISO-17025 accredited) calibrations within 3 years of purchase for Model 2000-SCAN* C/2001-3Y-ISO 3 (ISO-17025 accredited) calibrations within 3 years of purchase for Model 2001-TCSCAN* C/2010-3Y-ISO 3 (ISO-17025 accredited) calibrations within 3 years of purchase for Model 2010* *Not available in all countries Creating a self-contained multipoint measurement solution is as simple as plugging a 2000-SCAN or 2001-TCSCAN scanner card into the option slot in the 2010’s back panel. This “plug-in” approach ­eliminates the need for a separate scanner and significantly reduces programming and setup time in a­ pplications involving a limited number of test points. For larger applications, the 2010 is compatible with Keithley’s Series 7000 switch matrices and cards. Unique Resistance Measurement Functions Characterizing the resistance, linearity, or isolation of contacts, connectors, switches, or relays complete­ly and efficiently demands an uncommon combination of ohms measurement capa­bilities. The 2010 offers: • Low-power ohms measurement mode. Low-level resistance measurements can be made with source current as low as 100µA, an order of magnitude lower than is possible with other DMMs, so device self-heating is minimized. Among other benefits, this low-power measurement capability makes the 2010 suitable for end-of-life contact testing per ASTM B539-90. • Dry circuit test function. When measuring contact and connector resistances, it is important to control the test voltage carefully in order to avoid puncturing any oxides or films that may have formed. A built-in clamp limits the open circuit test voltage to 20mV to ensure dry circuit conditions. • Offset compensated ohms function. This function eliminates thermal effects that can create errors in low-level resistance measurements in system environments. • Extended ohms measurement capability. The 2010 provides a 10W range for more precise measurements of low resistances. Optional Multiplexer Cards Creating a self-contained multipoint measurement solution is as simple as plugging a scanner card into the option slot on the 2010’s back panel. This ap­proach eliminates the complexities of triggering, timing, and processing issues and helps reduce test time significantly. For applications involving more than 10 measurement points, the 2010 is com­patible with Keithley’s Series 7000 switch matrices and cards. Model 2000-SCAN Scanner Card • Ten analog input channels (2-pole) • Configurable as 4-pole, 5-channel DMM optimized for resistance measurement applications Low Noise 7½-Digit Autoranging Multimeter ACCESSORIES AVAILABLE Test Leads 5804/5 4-Wire/Kelvin Test Lead Sets Switch/Scanner Cards 2000-SCAN 10-channel Scanner 2001-TCSCAN 9-channel Thermocouple Scanner CABLES/ADAPTERS 7007-1 Shielded IEEE-488 Cable, 1m (3.3 ft) 7007-2 Shielded IEEE-488 Cable, 2m (6.6 ft) 7009-5 RS-232 Cable RACK MOUNT KITS 4288-1 Single Fixed Rack Mount Kit 4288-2 Dual Fixed Rack Mount Kit GPIB Interfaces KPCI-488LPA IEEE-488 Interface/Controller for the PCI Bus KUSB-488B IEEE-488 USB-to-GPIB Interface Adapter 1.888.KEITHLEY (U.S. only) www.keithley.com A Greater Measure of Confidence DIGITAL MULTIMETERS & SYSTEMS DMM optimized for resistance measurement applications 2010 2010 Low Noise 7½-Digit Autoranging Multimeter Resolution 10 nV 100 nV 1 µV 10 µV 100 µV Resolution 1 µW 10 µW 100 µW 1 mW 10 mW 100 mW 1 W 10 W Accuracy 23°C ± 5°C ±(ppm of rdg. + ppm of range) 90 Day 1 Year 40 + 9 60 + 9 36 + 9 52 + 9 33 + 2 50 + 2 32 + 2 50 + 2 40 + 4 70 + 4 50 + 4 70 + 4 400 + 4 200 + 4 1500 + 4 1500 + 4 Test Current   10 mA   1 mA   1 mA 100  µA 10  µA 10  µA 640 nA//10 MW 640 nA//10 MW Resolution 1 nA 10 nA 100 nA 1 µA Accuracy 23°C ± 5°C ±(ppm of rdg. + ppm of range) 90 Day 1 Year 300 + 80 500 + 80 300 + 800 500 + 800 500 + 80 800 + 80 1200 + 40 1200 + 40 Burden Voltage < 0.15 V < 0.18 V < 0.35 V 10 GW > 10 GW > 10 GW 10 MW ±1% 10 MW ±1% DIGITAL MULTIMETERS & SYSTEMS DCV (all ranges), DCI (all ranges), and Ohms (
2010/E 价格&库存
很抱歉,暂时无法提供与“2010/E”相匹配的价格&库存,您可以联系我们找货
2010/E
    • 1+73675.06602
    库存:2
