3730-ST
3730-ST
    KEITHLEY
    KEITHLEY - 3730-ST - Test Accessory, Screw Terminal Block, Keithley 3730 Plug-in Cards, 3700
3730-ST 数据手册
Model 3730 Keithley Instruments, Inc. 28775 Aurora Road Cleveland, Ohio 44139 1-888-KEITHLEY www.keithley.com 6x16 Matrix Specifications 96 two-pole crosspoints with column expansion relays MATRIX CONFIGURATION: 6 row by 16 column matrix. Columns can be expanded using the backplane or isolated by relays. CONTACT CONFIGURATION: 2 pole form A. CONNECTOR TYPE: Two 50 pin male D-shells. MODEL 3730-ST SCREW TERMINAL OPTION: #22 AWG typical wire size with .062 inch O.D. 88 conductors maximum. #16 AWG maximum wire size with .092inch O.D. 44 conductors per card maximum. MAXIMUM SIGNAL LEVEL: 300V DC or RMS, 1A switched (2A carry), 60W, 125VA. COMMON MODE VOLTAGE: 300V DC or RMS between any terminal and chassis. VOLT-HERTZ LIMIT: 8x107 CONTACT LIFE: > 105 operations at max signal level. >108 operations no load. 1 6x16 Channel Resistance (end of contact life) Contact Potential (differential) Offset Current Isolation Differential CH –CH Common mode Crosstalk CH-CH 300KHz: 1MHz: 20MHz: Bandwidth 1 2 3 2, 3
3730-ST 价格&库存
很抱歉,暂时无法提供与“3730-ST”相匹配的价格&库存,您可以联系我们找货
3730-ST
    库存:1
