CS-1616-3
CS-1616-3
    KEITHLEY
    KEITHLEY - CS-1616-3 - Test Accessory, Safety Interlock Mating Connector, Keithley 2450 & 2460 Sourc...
CS-1616-3 数据手册
2460 SourceMeter® SMU Instrument • One tightly coupled instrument that combines capabilities from analyzers, curve tracers, and I-V systems at a fraction of their cost • Wide coverage up to 105V, 7A DC/7A pulse, 100W max. • Five-inch, high resolution capacitive touchscreen GUI Learn Faster, Work Smarter, Invent Easier The Model 2460 features a five-inch, full-color, high resolution touchscreen that supports intuitive operation, helps operators become familiar with the instrument quickly, and optimizes overall speed and productivity. A simple icon-based menu structure reduces the number of steps required to configure a test by as much as 50 percent and eliminates the cumbersome multi-­layer menu structures typically used on soft-key instruments. Built-in, context-sensitive help supports intuitive operation and minimizes the need to review a separate manual. These capabilities, combined with the Model 2460’s high versatility, simplify its operation in both basic and advanced measurement applications, regardless of the user’s previous experience in working with SMU instruments. • 0.012% basic measure accuracy with 6½-digit resolution Model 2460 SourceMeter® SMU Instrument The Model 2460 High Current SourceMeter® Source Measure Unit (SMU) Instrument brings advanced Touch, Test, Invent® technology right to your fingertips. It combines an innovative graphical user interface (GUI) with capacitive touchscreen technology to make testing intuitive and minimize the learning curve to help engineers and scientists learn faster, work smarter, and invent easier. With its 7A DC and pulse current capability, the Model 2460 is optimized for characterizing and testing high power materials, devices, and modules such as silicon carbide (SiC), gallium nitride (GaN), DC-DC converters, power MOSFETs, solar cells and panels, LEDs and lighting systems, electrochemical cells and batteries, and much more. These new capabilities, combined with Keithley’s decades of expertise in developing high precision, high accuracy SMU instruments, will make the Model 2460 a “go-to instrument” for high current applications in the lab and in the rack for years to come. • Source and sink (4-quadrant) operation • Four “Quickset” modes for fast setup and measurements • Context-sensitive help function 2460 main home screen The Model 2460’s icon-based menu structure helps even novice users configure tests quickly and confidently. • Front panel input banana jacks; rear panel input mass termination screw connections +7A • 2460 SCPI and TSP® scripting programming modes • Front-panel USB 2.0 memory I/O port for transferring data, test scripts, or test configurations +5A +4A Quadrant II – Sink Quadrant I + Source Quadrant III – Source Quadrant IV + Sink +1A 0A –1A –4A –5A –7A –100V –20V –10V 0V +10V +20V DC or Pulsed Model 2460 power envelope. +100V All-in-One SMU Instrument The Model 2460, built on the fourth generation of the award-winning SourceMeter SMU platform, leverages the proven capabilities of previously introduced high current SMU instruments from Keithley, including the Models 2420, 2425, and 2440. It offers a highly flexible, four-­quadrant voltage and current source/load coupled with precision voltage and current measurements. This all-in-one instrument can be used as a: • Precision power supply with V and I readback • True current source • Digital multimeter (DCV, DCI, ohms, and power with 6½-digit resolution) • Precision electronic load • Trigger controller 1.888.KEITHLEY (U.S. only) www.keithley.com A Greater Measure of Confidence SMU INSTRUMENTS Model 2460 SourceMeter® SMU Instrument 100 Watts, 7 Amps 2460 SourceMeter® SMU Instrument Ordering Information Model 2460 SourceMeter® SMU Instrument 2460 100V, 7A, 100W SourceMeter Instrument 2460-NFP 100V, 7A, 100W SourceMeter Instrument, with No Front Panel 2460-RACK 100V, 7A, 100W SourceMeter Instrument, without Handle 2460-NFP-RACK 100V, 7A, 100W SourceMeter Instrument, with No Front Panel and No Handle Accessories Supplied 2460-KIT Rear Panel Mating Mass Terminated Screw Connector 8608 Model 2420/2425/2440 Max Voltage: 60V/100V/40V Max Current: 3A/3A/5A DC Power: 60W/100W/50W Wideband Noise: 10mVrms ttyp. Sweep Types: Linear, Log, Custom, Source-Memory 5000 Point Reading Buffer >2000 Readings/second SCPI Programming GPIB, RS-232 Front/Rear Banana Jacks Model 2460 Max Voltage: 100V Max Current: 7A DC Power: 100W Wideband Noise: 2mVrms typ. Sweep Types: Linear, Log, Dual Linear, Dual Log, Custom >250,000 Point Reading Buffer >3000 Readings/second SCPI Programming + TSP Scripting GPIB, USB, Ethernet (LXI) Front: Banana Jacks Rear: Mass Screw Terminal Connection Comparison of Models 2420, 2425, and 2440 with Model 2460. Ease of Use Beyond the Touchscreen In addition to its advanced touchscreen, the Model 2460’s front panel offers a variety of features that enhance its speed, user-friendliness, and learnability, including a USB 2.0 memory I/O port, a HELP key, a rotary navigation/control knob, a front/rear input selector button, and banana jacks for basic bench applications. The USB 2.0 memory port simplifies storing test results and instrument configurations, uploading test scripts into the instrument, and installing system upgrades. All front-panel buttons are backlit to enhance visibility in low-light environments. High Performance Test Leads 5˝ color graphical touchscreen display USB-B-1 USB Cable, Type A to Type B, 1m (3.3 ft) CS-1616-3 Safety Interlock Mating Connector CA-180-3A TSP-Link/Ethernet Cable Documentation CD Rotary navigation/ control knob Online HELP key USB 2.0 memory I/O Front/rear input selector 2460 QuickStart Guide Test Script Builder Software (available at www.keithley.com) KickStart Startup Software (available at www.keithley.com) SMU INSTRUMENTS LabVIEW and IVI Drivers (available at www.keithley.com) The Model 2460’s high resolution, capacitive touchscreen and front panel controls allow for intuitive operation, even by novice users. Four “Quickset” modes simplify instrument setup. With one touch, the instrument can be quickly configured for various operating modes without the need to configure the instrument indirectly for this operation. One-touch Quickset modes speed measurement setups and minimize the time to measurements. 1.888.KEITHLEY (U.S. only) www.keithley.com A Greater Measure of Confidence Model 2460 SourceMeter® SMU Instrument 100 Watts, 7 Amps 2460 SourceMeter® SMU Instrument 100 Watts, 7 Amps Model 2460 SourceMeter® SMU Instrument Mass screw terminal connections Interlock Ethernet USB Digital I/O TSP-Link GPIB Model 2460 rear panel connections are optimized to maintain signal integrity and speed system setup. Convert Raw Data to Information A full graphical plotting window converts raw data and displays it immediately as useful information, such as semiconductor I-V curves and voltammograms. Using the Model 2460’s Sheet view, test data can also be displayed in tabular form. The instrument supports exporting data to a spreadsheet for further analysis, dramatically improving productivity for research, benchtop testing, device qualification, and debugging. TriggerFlow Building Blocks for Instrument Control and Execution The Model 2460 incorporates Keithley’s TriggerFlow triggering system, which provides user control over instrument execution. TriggerFlow diagrams are created in much the same way that flow charts are developed, using four fundamental building block types: • Wait – Waits for an event to occur before the flow continues • Branch – Branches when a condition has been satisfied • Action – Initiates an action in the instrument, for example, measure, source, delay, set digital I/O, etc. • Notify – Notifies other equipment that an event has occurred A TriggerFlow model using a combination of these building blocks can be created from the front panel or by sending remote commands. With the TriggerFlow system, users can build triggering models from very simple to complex with up to 255 block levels. The Model 2460 also includes basic triggering functions, including immediate, timer, and manual triggering. ® Built-in data display, charting, and spreadsheet export functions simplify converting test results into useful information. TriggerFlow building blocks allow creating triggering models that range from very simple to highly complex. 1.888.KEITHLEY (U.S. only) www.keithley.com A Greater Measure of Confidence SMU INSTRUMENTS Model 2460 SourceMeter® SMU Instrument Comprehensive Built-in Connectivity Rear panel access to rear-input mass termination connector, remote control interfaces (GPIB, USB 2.0, and LXI/Ethernet), D-sub 9-pin digital I/O port (for internal/external trigger signals and handler control), instrument interlock control, and TSP-Link® jacks make it simple to configure multiple instrument test solutions and eliminate the need to invest in additional adapter accessories. 2460 SourceMeter® SMU Instrument SMU INSTRUMENTS Unmatched System Integration and Programming Flexibility When a Model 2460 is configured into a multi-channel I-V test system, its embedded Test Script Processor (TSP®) allows it to run test scripts, so users can create powerful measurement applications with significantly reduced development times. TSP technology also offers channel expansion without a mainframe. Keithley’s TSP-Link® channel expansion bus, which uses a 100 Base T Ethernet cable, can connect multiple Model 2460s and other TSP instruments such as Keithley’s Model 2450 SourceMeter SMU Instruments, Series 2600B System SourceMeter SMU instruments, and Series 3700A Switch/Multimeter systems in a master-slave configuration that operates as one integrated system. The TSP-Link expansion bus supports up to 32 units per GPIB or IP address, making it easy to scale a system to fit an application’s particular requirements. The Model 2460 also includes a SCPI programming mode that takes advantage of all of the instrument’s capabilities. Parallel Test Capability The TSP technology in the Model 2460 supports testing multiple devices in parallel to meet the needs of device research, advanced semiconductor lab applications, and even high throughput production test. This parallel testing capability allows each instrument in the system to run its own complete test sequence, creating a fully multi-threaded test environment. The number of tests that can be run in parallel on a Model 2460 can be as high as the number of instruments in the system. Free Instrument Control Start-up Software The Model 2460 comes with KickStart instrument control/start-up software, which lets users start taking measurements in minutes without programming. In most cases, users merely need to make some quick measurements, graph the data, and store the data to disk for later analysis in software environments such as Excel. KickStart offers: • Instrument configuration control to perform I-V characterization • Native X-Y graphing, panning, and zooming • Spreadsheet/tabular viewing of data • Saving and exporting data for further analysis • Saving of test setups • Screenshot capturing of graph • Annotation of tests • Command line dialog for sending and receiving data • HTML help • GPIB, USB 2.0, Ethernet compliance Simplified Programming with Ready-to-Use Instrument Drivers For those who prefer to create their own customized application software, native National Instruments LabVIEW® drivers, as well as IVI-C and IVICOM drivers are available at www.keithley.com. TYPICAL APPLICATIONS Ideal for current/voltage characterization and functional test of a wide range of modern electronic devices: • Power semiconductors and materials –– SiC, GaN –– IBGTs –– Power MOSFETs –– Thyristors • Power devices –– Telecom power management chipsets –– DC-DC converters • Electrochemistry –– Galvanic cycling –– Cyclic voltammetry –– Electro-deposition • Energy generation –– Solar cells –– Batteries • Efficient energy consumption –– LEDs/AMOLEDs –– Automotive modules –– Power management modules KickStart start-up software lets users be ready to take measurements in minutes. 1.888.KEITHLEY (U.S. only) www.keithley.com A Greater Measure of Confidence Model 2460 SourceMeter® SMU Instrument Model 2460 SourceMeter® SMU Instrument 100 Watt, 7 Amps 2460 SourceMeter® SMU Instrument 100 Watt, 7 Amps CABLES, CONNECTORS, ADAPTERS 2460-BAN Screw Terminal Connector to Banana Cable 2460-KIT Mating Mass Termination Connector 8607 2-Wire, 1000V Banana Cables, 1m (3.3 ft.) CS-1616-3 Safety Interlock Mating Connector COMMUNICATION INTERFACES & CABLES 7007-1 Shielded GPIB Cable, 1m (3.3 ft) 7007-2 Shielded GPIB Cable, 1m (6.6 ft) CA-180-3A CAT5 Crossover Cable for TSP-Link/Ethernet KPCI-488LPA IEEE-488 Interface for PCI Bus KUSB-488B IEEE-488 USB-to-GPIB Interface Adapter USB-B-1 USB Cable, Type A to Type B, 1m (3.3 ft) TRIGGERING 2450-TLINK 8501-1 8501-2 AND CONTROL DB-9 to Trigger Link Connector Adapter. Trigger Link Cable, DIN-to-DIN, 1m (3.3 ft) Trigger Link Cable, DIN-to-DIN, 2m (6.6 ft) RACK MOUNT KITS 4299-8 Single Fixed Rack Mount Kit 4299-9 Dual Fixed Rack Mount Kit 4299-10 Dual Fixed Rack Mount Kit. Mount one 2460 and one Series 26xxB 4299-11 Dual Fixed Rack Mount Kit. Mount one 2460 and one Series 2400, Series 2000, etc. 2450-BenchKit Ears and Handle for 2460-NFP-RACK and 2460-RACK models Source Range   200.0000 mV   2.000000   V   7.000000   V   10.00000   V   20.00000   V   100.0000   V Max. ResoCurrent lution 7.35 A 5 μV 7.35 A 50 µV 7.35 A 250 µV 5.25 A 500 µV 4.20 A 500 µV 1.05 A 2.5 mV 1 Year Factory Warranty extended to 3 years from date of shipment 2460-5Y-EW 1 Year Factory Warranty extended to 5 years from date of shipment C/2460-3Y-17025 KeithleyCare® 3 Year ISO 17025 Calibration Plan C/2460-3Y-DATA KeithleyCare 3 Year Calibration w/Data Plan C/2460-3Y-STD KeithleyCare 3 Year Std. Calibration Plan C/2460-5Y-17025 KeithleyCare 5 Year ISO 17025 Calibration Plan C/2460-5Y-DATA KeithleyCare 5 Year Calibration w/Data Plan C/2460-5Y-STD KeithleyCare 5 Year Std. Calibration Plan C/NEW DATA Calibration Data for New Units C/NEW DATA ISO ISO-17025 Calibration Data for New Units Noise (RMS) (10 GW 1 µV >10 GW 1 µV >10 GW 10 µV >10 GW 10 µV >10 GW 100 µV >10 GW Accuracy (23° ±5°C), 1 Year ±(% rdg. + volts) 0.012 % + 200 µV 0.012 % + 300 µV 0.015 % + 1 mV 0.015 % + 1 mV 0.015 % + 1 mV 0.015 % + 5 mV Current Specifications 1, 2, 5 Source Range 1.000000 μA 10.00000 μA 100.0000 μA 1.000000 mA 10.00000 mA 100.0000 mA 1.000000 A 4.000000 A 5.000000 A 7.000000 A Max. Voltage 105 V 105 V 105 V 105 V 105 V 105 V 105 V 21 V 10.5 V 7.35 V Resolution 50 pA 500 pA 5 nA 50 nA 500 nA 5 μA 50 μA 250 μA 250 μA 500 μA Measure 3 Accuracy (23° ±5°C), 1 Year ±(% setting + amps) 0.025 % + 1 nA 0.025 % + 1.5 nA 0.020 % + 15 nA 0.020 % + 150 nA 0.020 % + 1.5 μA 0.020 % + 15 μA 0.050 % + 750 μA 0.100 % + 3 mA 0.100 % + 3 mA 0.150 % + 6 mA Noise (RMS) (
CS-1616-3 价格&库存
很抱歉,暂时无法提供与“CS-1616-3”相匹配的价格&库存,您可以联系我们找货
CS-1616-3
库存:16
