871223
871223
    FLUKE(福禄克)
871223 数据手册
® Fluke 78 Automotive Multimeter with RPM, Dwell, Temp Features Volts, amps, continuity and resistance Frequency for “pulsed-DC” and AC frequency tests Duty Cycle to verify operation of feedback carburetors, and other variable duty cycle signals ● Direct Reading Dwell for 3, 4, 5, 6 and 8-cylinder engines ● Temperature in °F or °C up to 980°F or 980°C; thermocouple bead probe and adapter plug accessories included ● Min/Max Recording work with all meter functions ● Precision Analog Bar Graph ● RPM80 Inductive Pickup (optional accessory) for both conventional and distributorless (DIS) ignitions) ● 10 Megohm Input Impedance ● Sleep Mode ● Protective Holster with Flex-Stand™ ● ● ● Specifications Basic Accuracy (± % of reading) Function DC Voltage AC Voltage DC Current AC Current Resistance Ranges 400 mV - 500V 4V - 500V 4A -10A 10A 400Ω - 40 MΩ Accuracy 0.3% 2.5% 1.0% 2.5% 0.5% Best Resolution 0.1 mV 0.001V 0.001A 0.01A 0.1Ω Frequency Temperature 99.99 Hz - 99.99 kHz -40 °F to 1839 °F (-40°C to 999°C) 0 - 120 0.0% - 99.9% 60 - 7000 RPM 0.01% 0.3% 0.3% 2° .02%/kHz 0.2% 0.01Hz 1° 1° 1° 0.1% 1 RPM Dwell Angle Duty Cycle RPM Safety Designed to protection Class II per IEC 1010 overvoltage category II, CSA C22.2 No. 231, ANSI/ISA-S82, IEC 348 and UL 1244. Shock and vibration per MIL-T-28800 for a Class 2 instrument. Fuse information Uses a 15A (892583, 871223 or 847793) replaceable internal fuse Warranty Lifetime (Meter) 1 year (Accessories) Included with Your Fluke 78 Automotive Meter The Fluke 78 gives you the automotive features you need, at the price you want. Fluke 78 Automotive Meter Holster with Flex-Stand™ 9V Battery (installed) TL75 Test Leads AC70 Alligator Clips 80PK-1 Bead Thermocouple Probe 80AK Thermocouple Adapter User’s Manual for automotive use Quick Reference Guide 13
871223 价格&库存
很抱歉,暂时无法提供与“871223”相匹配的价格&库存,您可以联系我们找货
