FLUKE C25
FLUKE C25
    FLUKE(福禄克)
FLUKE C25 数据手册
Fluke C25 Large Soft Case for DMMs Features and Specification:  Dimensions (HxWxD) 218 mm x 128 mm x 64mm 8.6 in x 5 in x 2.52 in Product Description: Get the right case for your Fluke tools. The C25 carrying case is a durable, zippered carrying case with padding and inside pocket, and high quality polyester exterior. It includes a convenient hand strap and carries most of Fluke’s popular digital multimeters. It is available with a 1 year warranty. Compatible with: Model Name Description Fluke 1503 Insulation Resistance Tester Fluke 1507 Insulation Resistance Tester Fluke 1577 Insulation Multimeter Fluke 1587 Insulation Multimeter Fluke 175 True-rms Digital Multimeter Fluke 177 True-rms Digital Multimeter Fluke 179 True-rms Digital Multimeter Fluke 179/TPAK Multimeter and ToolPak™ Combo Kit Fluke 705 Loop Calibrator Fluke 707 Loop Calibrator Fluke 707Ex Intrinsically Safe Loop Calibrator Fluke 707Ex Intrinsically Safe Loop Calibrator Fluke 709 Precision Loop Calibrator Fluke 709H Precision Loop Calibrator with HART Communications/Diagnostics Fluke 709H Precision Loop Calibrator with HART Communications/Diagnostics Fluke 709H Precision Loop Calibrator with HART Communications/Diagnostics Fluke 709H Precision Loop Calibrator with HART Communications/Diagnostics Fluke 714 Fluke 714 Thermocouple Calibrator Fluke 715 Fluke 715 Volt/mA Calibrator Fluke 717 10,000G Pressure Calibrator Fluke 717 10,000G Pressure Calibrator Fluke 717 1000G Pressure Calibrator 0 to 1000 PSI, (0 mbar to 69 bar, 0 to 6894.8 kPa ) Fluke 717 100G Pressure Calibrator -12 to 100 PSI, (-850 mbar to 7 bar, -85 to 689.48 kPa) Fluke 717 1500G Pressure Calibrator 0 to 1500 PSI, (0 bar to 103.4 bar, 0 to 10342 kPa ) Fluke 717 15G Pressure Calibrator -12 to 15 psi (-850 mbar to 1 bar, -85 to 103 kPa) Fluke 717 1G Pressure Calibrator Fluke 717 3000G Pressure Calibrator 0 to 3000 PSI, (0 bar to 207 bar, 0 to 20684 kPa) Fluke 717 300G Pressure Calibrator -12 to 300 PSI, (-850 mbar to 20 bar, -85 to 2068.4 kPa ) Fluke 717 30G Pressure Calibrator -12 to 30 psi (-850 mbar to 2 bar, -85 to 207 kPa) Fluke 717 5000G Pressure Calibrator 0 to 5000 PSI, (0 bar to 345 bar, 0 to 34474 kPa) Fluke 717 500G Fluke 717 500G Pressure Calibrator 0 to 500 PSI, (0 mbar to 34.7 bar, 0 to 3447.4 kPa ) Fluke 725 Multifunction Process Calibrator Fluke 726 Precision Multifunction Process Calibrator Fluke 726 Precision Multifunction Process Calibrator Fluke 77 IV Digital Multimeter Fluke 77 IV Digital Multimeter Fluke 787 Fluke 787 ProcessMeter™ Fluke 789 ProcessMeter™ with 250 Ohm HART resistor Fluke 83V Average Responding Industrial Multimeter Fluke 87V Digital Multimeter Fluke 88V/A Kit Automotive Multimeter Combo Kit Contact Information: www.Farnell.co.uk www.Fluke.com
FLUKE C25 价格&库存
很抱歉,暂时无法提供与“FLUKE C25”相匹配的价格&库存,您可以联系我们找货
