2290-5-SHVBH
2290-5-SHVBH
    KEITHLEY
    KEITHLEY - 2290-5-SHVBH - Test Accessory, SHV Male Bulkhead Connector, Keithley 2290-5 5kV Power Sup...
2290-5-SHVBH 数据手册
Model 2290-5-SHVBH SHV Male Bulkehead Connector Keithley Instruments, Inc. 28775 Aurora Road Cleveland, Ohio 44139 1-888-KEITHLEY http://www.keithley.com Description The Model 2290-5 can contain hazardous voltages. Be certain that the high voltage is completely discharged before removing or connecting the high-voltage cable. High-voltage cables can store charge if they are disconnected from the supply while high voltage is turned on and can cause personal injury or death if not handled properly. Do not connect the HIGH-VOLTAGE output to exposed circuitry. Any load connected to the HIGH-VOLTAGE output should be enclosed in a metal shield that is connected to safety earth ground using #18AWG or larger wire. The high-voltage 5 kV SHV male bulkhead connector is used to connect external equipment. High-voltage installation: 1. Turn off power and allow all voltage to discharge. 2. Install the Model 2290-5-SHVBH SHV male bulkhead connector (see next figures). Figure 1: Model 2290-5 SHV male bulkhead connector Figure 2: Model 2290-5 SHV male bulkhead connector mounting dimensions 077084400 *077084400* 1 Model 2290-5-SHVBH Connector Characteristics Nominal impedance non-constant Maximum operating voltage (RMS) 3500 RMS 5000 V DC Insulation resistance 10E6 MΩ Temperature range -65° C to 165° C (-85° F to +329° F) Materials A. B. C. D. E. F. G. 2 Bodies and fittings: brass, QQ-B-626, alloy 360, 1/2 hard Crimp sleeves: commercial bronze, alloy 220 Male center contact: brass, QQ-B-626, alloy 360, 1/2 hard Outer contact: beryllium copper, ASTM-B-196 Insulator: PTFE, ASTM D1457 Gaskets and seals: silicone rubber, ZZ-R-765A, class IIA, grade 50 Contact finish: .0001 inch minimum, hard gold plate, MIL-G-45204B 077084400
2290-5-SHVBH 价格&库存
很抱歉,暂时无法提供与“2290-5-SHVBH”相匹配的价格&库存,您可以联系我们找货
