DMM7510
DMM7510
    KEITHLEY
    KEITHLEY - DMM7510 - Bench Digital Multimeter, DMM7500 Series, 7.5 Digit, 10 A, 1 KV
DMM7510 数据手册
Datasheet DMM7510 7½-Digit Graphical Sampling Multimeter The DMM7510 combines all the advantages of a precision digital multimeter, a graphical touchscreen display, and a high speed, high resolution digitizer to create an industry first: a graphical sampling multimeter. The digitizer gives the DMM7510 unprecedented signal analysis flexibility; the five-inch capacitive touchscreen display makes it easy to observe, interact with, and explore measurements with “pinch and zoom” simplicity. This combination of high performance and high ease of use offers unparalleled insight into your test results. A Tektronix Company Key Features • Precision multimeter with 3½- to 7½-digit resolution • Capture and display waveforms or transients with 1 MS/sec digitizer • Large internal memory buffer; store over 11 million readings in standard mode or 27.5 million in compact mode • 14 PPM basic one-year DCV accuracy • 100 mV, 1 Ω, and 10 µA ranges offer the sensitivity needed for measuring low level signals such as portable device sleep mode currents Capture Waveforms with the Built-in 1 MS/sec Digitizer Capturing and displaying waveforms and transient events just got easier with the DMM7510’s voltage or current digitizing function. The built-in 1 MS/sec, 18-bit digitizer makes it possible to acquire waveforms without the need to use a separate instrument. The digitizing functions employ the same ranges that the DC voltage and current functions use to deliver exceptional dynamic measurement range. In addition, the voltage digitizing function uses the same DC voltage input impedance (10 GΩ or 10 MΩ) levels to reduce loading significantly on the DUT. • Make accurate low resistance measurements with offset compensated ohms, four-wire, and dry circuit functions • Auto-calibration feature improves accuracy and stability by minimizing temperature and time drift • Display more with five-inch, high resolution touchscreen interface • Readings and screen images can be saved quickly via the front panel USB memory port • Multiple connectivity options: GPIB, USB, and LXIcompliant LAN interfaces • Two-year specifications enable longer calibration cycles The built-in graphing utility supports displaying and comparing measurements or waveforms from up to four reading buffers at once. Advanced triggering options make it possible to capture a signal at precisely the right point. Datasheet Determine the current drain of the components such as the microcontroller (MCU) in your lowpower, battery-operated product as well as the product’s total current draw. In addition, profile the current drain in all of the product’s operating states from its sleep mode to its transmit mode. Using the enhanced accuracy DC current function, the DMM7510 can measure a 1 µA sleep mode current with 1 pA resolution and with 0.375 nA tolerance. Furthermore, using the digitizing current function, the DMM7510 can capture the current wave shapes as the product transitions from sleep mode to transmit mode. Make Demanding Measurements with Confidence The DMM7510’s design makes the most of Keithley’s low level measurement expertise. Features like the low noise input stage and the 32-bit A-to-D converter allow this instrument to deliver DC accuracies typically only found in metrologygrade instrumentation—but at about half the price of those solutions. The DMM7510’s 100 mV, 10 Ω, and 10 µA ranges deliver the sensitivity needed to measure low signals with confidence when characterizing today’s demanding electronic designs. In addition to one- and two-year accuracy specifications, an auto-calibration function ensures greater accuracy between calibration cycles. One Power Line Cycle Noise Performance The DMM7510 provides noise performance equivalent to or better than many 8½-digit DMMs. 2µV 1µV Volts Accurately Measure and Visualize Ultra-Low Current Drain Levels 0µV –1µV –2µV 6½ Digit 8½ Digit DMM7510 Comparison of the DMM7510’s 1 VDC noise performance with that of typical 6½- and 8½-digit multimeters. All data was taken at 1 NPLC with a low thermal short applied to the input. Capture the current drain from all the operating states – sleep mode to active transmit mode – of a component or a product with the DMM7510’s digitizing function. Focus in on characteristics of the wave shapes with the touchscreen pinch and zoom features. 15 Measurement Functions The DMM7510 provides 15 basic measurement functions. In addition to the digitizing voltage and current functions, it includes capacitance, ACV and ACI, temperature (RTD, thermistor, and thermocouple), 2- and 4-wire resistance, dry circuit ohms, period, frequency, diode test, and DC voltage ratio. The instrument’s flat menu structure allows for fast configuration and improves usability. Its intuitive design lets you to learn how to operate the instrument and begin making device measurements faster and with greater confidence. RTD, Thermistor, Thermocouple 2 TEK.COM DMM7510 7½-Digit Graphical Sampling Multimeter Five-inch touchscreen displays more information simultaneously Rotary control knob offers an alternative to touchscreen navigation Online HELP is just a button press away Store test results and screen images quickly via the USB 2.0 memory port Front/rear input selector Lower swipe screen speeds access to often-used features Designed for Higher Testing Productivity In addition to its advanced touchscreen, the DMM7510’s front panel offers a variety of features that enhance its speed, user-friendliness, and learnability, including a USB 2.0 memory I/O port, a HELP key, a rotary navigation/control knob, and front/ rear input selector button. All frontpanel buttons are backlit to enhance visibility. The rear panel of the DMM7510 provides connections and controls that simplify configuring multiinstrument test solutions, including input connectors, remote control interfaces (GPIB, USB 2.0 and LXI/ Ethernet), a D-sub 9-pin digital I/O port (for internal/external trigger signals and handler control), and TSPLink® jacks for connecting to other TSP-enabled instruments. DMM7510 Measurement Capabilities 1f Logarithmic Scale DC Voltage AC Voltage DC Current AC Current Resistance (2-wire) Resistance (4-wire) Dry Circuit Resistance Capacitance Period Frequency 1p 1n 1µ 1m 1 1k 10nV 100nV 1G 1010V 707VRMS 10.1A 10.1A 1pA 1nA 1µΩ 100nΩ 1µΩ 1.2GΩ 1.2GΩ 2.4kΩ 1.2mF 0.1pF 2µs Digitize Voltage Digitize Current 1M 330ms 3Hz 1µV 500kHz 1010V 0.1nA 10.1A Linear Scale Thermocouple Thermistor 3-Wire RTD 4-Wire RTD –200°C –80°C –200°C –200°C –500° 1820°C 150°C 850°C 850°C 0° 500° Easily accessible current fuses LAN/LXI interface USB 2.0 interface Six user-defined digital I/Os 1000° 1500° 2000° Measure Complete and External Trigger (8503 BNC Accessory Available) GPIB interface TEK.COM 3 Datasheet Flexible System Integration and Programming To offer users maximum programming flexibility and simplify configuring multi-instrument test systems, the DMM7510 includes Keithley’s powerful Test Script Processor (TSP®) system and SCPI programming mode. The embedded scripting capability allows running powerful test scripts directly on the instrument, without the need for an external PC controller. These test scripts are complete test programs based on an easy-to-use yet highly efficient and compact scripting language, Lua (www.lua.org). Scripts are a collection of instrument control commands and/or program statements. Program statements control script execution and provide facilities such as variables, f­unctions, branching, and loop control. This allows you to create powerful measurement applications with significantly reduced development times. Test scripts can contain any sequence of routines that are executable by conventional programming languages (including decision-making algorithms), so the instrument can manage every facet of the test without the need to communicate with a PC for decisionmaking. This eliminates delays due to GPIB, Ethernet or USB traffic congestion and greatly improves overall test times. TSP technology also offers “mainframe-less channel expansion.” The TSP-Link® channel expansion bus and a 100 Base T Ethernet cable allow connecting multiple DMM7510s with other TSP-enabled instruments in a master-slave configuration so they operate as a single integrated system. These instruments include the 2450 and 2460 Graphical SourceMeter® SMU instruments, Series 2600B 4 TEK.COM SourceMeter SMU instruments, and the Series 3700A Switch/Multimeter systems. TSP-Link supports up to 32 units per GPIB or IP address, so it’s easy to scale a system to fit the requirements of an a ­ pplication. A standard SCPI programming mode supports taking advantage of all of the DMM7510’s new features when programming remotely. In addition, the instrument is code-compatible with the SCPI language, which many other DMMs use. This code compatibility avoids the need to rewrite code that is normally associated with upgrading to a new instrument with new ­capabilities. Instrument Control Software Keithley’s KickStart instrument control software lets you begin taking measurements in minutes. KickStart combines a wide range of functions to enhance testing productivity: • Instrument-specific UI panel • Manual instrument configuration • Basic reading display and tabular viewing of data • Datalogging • Native X-Y data graphing • Panning and zooming • Basic statistics (native to instrument, mX+b) • Saving/exporting data • Connect using any remote interface (GPIB, USB, LAN) • Saving instrument setups • Screenshot capture • Command line dialog box Ready-to-use Instrument Drivers Simplify Programming Need to create your own customized application software? Native National Instruments LabVIEW®, IVI-C, and IVI-COM drivers are available for downloading at www.tek.com to simplify the programming process. DMM7510 7½-Digit Graphical Sampling Multimeter Specification Conditions This document contains specifications and supplemental information for the DMM7510 7½-Digit Graphical Sampling Multimeter instrument. Specifications are the standards against which the DMM7510 is tested. Upon leaving the factory, the Model DMM7510 meets these specifications. Supplemental and typical values are nonwarranted, apply at 23°C (73°F), and are provided solely as useful information. Measurement accuracies are specified at the DMM7510 terminals under these conditions: • Temperature 23° ±5°C, 5% to 80% relative humidity, noncondensing. • After a 90-minute warmup period. • 1 PLC or 5 PLC; for NPLC settings less than 1 PLC, add appropriate ppm of range for peak noise uncertainty from the RMS noise table. • Autozero enabled unless otherwise noted. • Remote sense operation or properly zeroed local operation. • Calibration period: One year or two years (calibration period may vary depending on customer requirements). • TACAL = Ambient temperature of last automatic calibration. • TCAL = Ambient temperature of last external calibration; factory calibration performed at 23° ±1°C. DC Voltage Accuracy (Input impedance AUTO) Accuracy ±(ppm of reading + ppm of range) Input Impedance 2 24 Hour TCAL ±1°C 2 90 Day TCAL ±5°C 1 Year TCAL ±5°C 2 Year TCAL ±5°C Temperature Coefficient 3 Range 1 Resolution 100.00000 mV 4 10 nV >10 GΩ or 10 MΩ ±1 % 6+9 12 + 9 18 + 9 29 + 9 0.1 + 2.5 1.0000000 V 4 100 nV >10 GΩ or 10 MΩ ±1 % 4+1 9+2 15+ 2 26 + 2 0.1 + 0.5 10.000000 V 4 1 µV >10 GΩ or 10 MΩ ±1 % 2 + 0.7 9 + 1.2 100.00000 V 4 1000.0000 V 4, 6 10 µV 100 µV 10 MΩ ±1 % 10 MΩ ±1 % 8+3 8+3 (18 + 5) 5 14 + 1.2 22 + 1.2 0.1 + 0.05 (22 + 5) (30 + 5) 5 (0.15 + 0.05) 5 5 35 + 5 40 + 5 45 + 5 2.0 + 0.5 (19 + 5) 5 (23 + 5) 5 (31 + 5) 5 (0.15 + 0.05) 5 35 + 5 40 + 5 45 + 4 2.0 + 0.5 RMS Noise (additional peak noise uncertainty) 7 Applies to ±ppm of range. Peak noise uncertainty is included in DC specifications for ≥1 PLC. Add peak noise uncertainty to measurements for 10 GΩ ||
DMM7510
PDF文档中包含以下信息:
1. 物料型号:型号为EL817,是一款光隔离型光电晶体管。
2. 器件简介:EL817是一种光隔离型光电晶体管,具有高输入阻抗和低输出阻抗,适用于高速光耦应用。
3. 引脚分配:EL817共有3个引脚,分别为阳极、阴极和发射极。
4. 参数特性:EL817的主要参数包括工作电压、工作电流、响应时间和隔离电压等。
5. 功能详解:EL817通过光电效应实现电信号的传输,具有抗干扰能力强、响应速度快等优点。
6. 应用信息:EL817广泛应用于通信、工业控制、医疗设备等领域。
7. 封装信息:EL817采用DIP-6封装,具有较好的散热性能和机械强度。
DMM7510 价格&库存
很抱歉,暂时无法提供与“DMM7510”相匹配的价格&库存,您可以联系我们找货
