HV-CA-554-3
HV-CA-554-3
    KEITHLEY
    KEITHLEY - HV-CA-554-3 - Test Cable Assembly, High Voltage Triax Cable, Keithley 2657A, 8010 Series ...
HV-CA-554-3 数据手册
Cables ACCESSORIES LENGTH Description Type From To m ft USE WITH: 236-ILC-3 Safety Interlock Shielded twisted pair 3-pin round 3-pin round 3 10 237-ALG-2 Low Noise Input Triax 3-slot male triax Alligator clips (3) 2 6.6 237-ALG-15 Low Noise Input Triax 3-slot male triax Alligator clips (3) 15 50 4200-SCS, 8007, 8008 Series 2200, Series 2600B, 4200-PA, 6220, 6221, 6482, 6487, 6514, 6517A, 6517B Series 2200, Series 2600B, 4200-PA, 6220, 6221, 6482, 6487, 6514, 6517A, 6517B 2000-MTC-2 Cable Assembly DB44 female Unterminated 2 6.6 2000-20 2000-MTCD-2 Cable Assembly DB44 female DB50 male 2 6.6 2000-SCAN-20 2107-4 Input Cable Shielded twisted pair Shielded multiple conductors Shielded twisted pair LEMO Copper spade lugs (4) 1.2 4 2107-30 Input Cable Shielded twisted pair LEMO Copper spade lugs (4) 9.1 30 2182A, Series 2200 2107-50 Input Cable Shielded twisted pair LEMO Copper spade lugs (4) 15 50 2182A, Series 2200 2260-005 Input Cable 0.5 1.6 Series 2260B 2260-006 Input Cable 0.5 1.6 Series 2260B 2260-007 Input Cable 0.5 1.6 Series 2260B 2290-5-SHV Input Cable 3 10 2290-5-MHV Input Cable 3 10 2290-10-SHV 2290-10-SHVUC 2290-INT-CABLE 2450-TRX-BAN 2600-ALG-2 2651A-KIT-1 2651A-KIT-2 2651A-KIT-3 3720-MTC-1.5 3720-MTC-3 3721-MTC-1.5 3721-MTC-3 3722-MTC-1.5 3722-MTC-1.5/MM 3722-MTC-3 3722-MTC-3/MM 3732-MTC-1.5 3732-MTC-3 4200-MTRX-1 4200-MTRX-2 4200-MTRX-3 4200-PRB-C 4200-RPC-0.3 4200-RPC-2 4200-RPC-3 4200-RPC-6 4200-TRX-0.3 4200-TRX-1 4200-TRX-2 4200-TRX-3 4801 4802-10 4803 6011 6011-10 6517-ILC-3 6517B-ILC-3 7009-5 7011-MTC-1 7011-MTC-2 Input Cable 3 10 3 10 3.05 10 0.3 2 1 2 3 1.5 3 1.5 3 1.5 1.5 3 3 1.5 3 1 2 3 1 6.6 3.3 6.6 10 5 10 5 10 5 5 10 10 5 10 3.2 6.5 9.8 0.3 2 3 6 0.3 1 2 3 1.2 3 15.2 1.5 3 1 1 1.5 1 2 1 6.5 9.8 19.6 1ft 3.2 6.5 9.8 4 10 50 5 10 3.3 3.3 5 3.3 6.6 2290-5, 2290-5-SHVBH 2290-5 2290-10, 2290-10-SHVBH 2290-10 2290-5, 2290-10 2450 2635B, 2636B, 4200-PA 2651A, 8011 2651A, 8011 2651A, 8011 3720, 3723, 3724 3720, 3723, 3724 3721, 3730, 3731, 3740, 3750 3721, 3730, 3731, 3740, 3750 3722 3722 3722 3722 3732 3732 4200-SCS 4200-SCS 4200-SCS 4200-PIV, 4210-CVU 4200-PA 4200-PA 4200-PA 4200-PA 4200-PA 4200-PA 4200-PA 4200-PA 6482, 6485, 7158 6482, 6485, 7158 6482, 6485, 7158 Instruments with 2-slot triax connectors Instruments with 2-slot triax connectors 6517A, 8009 6517B, 8009 All RS-232 capable instruments 7011-C, 7012-C, 7013-C, 7015-C, 7018-C 7011-C, 7012-C, 7013-C, 7015-C, 7018-C 7019C-MTCI-2 2 6.6 Series 2400 Interlock Cable Adapter Cable Low Noise Input Cable Assembly Cable Assembly Cable Assembly Mass Terminated Assembly Mass Terminated Assembly Mass Terminated Assembly Mass Terminated Assembly Mass Terminated Assembly Mass Terminated Assembly Mass Terminated Assembly Mass Terminated Assembly Mass Terminated Assembly Mass Terminated Assembly Ultra Low Noise Ultra Low Noise Ultra Low Noise Cable Assembly Cable Assembly Cable Assembly Cable Assembly Cable Assembly Ultra Low Noise Ultra Low Noise Ultra Low Noise Ultra Low Noise Low Noise Input Low Noise Input Low Noise Cable Kit Input Leads Input Leads 4-pin Interlock Cable Interlock Cable Shielded RS-232 Mass Terminated Assembly Mass Terminated Assembly Coax Coax Coax Coax 3-conductor Triax Triax Coax Coax Coax Twisted pair Twisted pair Twisted pair Twisted pair Twisted pair Twisted pair Twisted pair Twisted pair Twisted pair Twisted pair SMU triax SMU triax SMU triax Y adapter cable Remote PreAmp Remote PreAmp Remote PreAmp Remote PreAmp PreAmp triax PreAmp triax PreAmp triax PreAmp triax Coax Coax Coax Triax Triax Shielded Shielded Shielded Twisted pair (45) Twisted pair (45) SHV Female SHV Female SHV Male SHV Male 3-pin 3-slot male triax 3-slot male triax 2-pin plug 2-pin plug 2-pin plug D-sub female D-sub female D-sub female D-sub female D-sub male D-sub male D-sub male D-sub male D-sub female D-sub female Miniature male Miniature male Miniature male Female SMA DB15 DB15 DB15 DB15 3-slot male 3-slot male 3-slot male 3-slot male Male BNC Male BNC Male BNC (10) 2-slot male triax 2-slot male triax 4-pin female DIN 4-pin Phoenix Male DB-9 96-pin female 96-pin female Kelvin Instrument Cable Shielded twisted pair Card connector Input Cable SHV Female MHV Male SHV Male Unterminated Unterminated Banana input jack Alligator clips (3) 2-pin plug 2-pin plug 2-pin plug 78-pin D-sub male 78-pin D-sub male 50-pin D-sub male 50-pin D-sub male 104-pin D-sub female 104-pin D-sub male 104-pin D-sub female 104-pin D-sub male 78-pin D-sub male 78-pin D-sub male 3-slot male 3-slot male 3-slot male 2 female SSMC DB15 DB15 DB15 DB15 3-slot male 3-slot male 3-slot male 3-slot male Male BNC Unterminated Female BNC (5) Alligator clips (3) Alligator clips (3) 4-pin female DIN 4-pin DIN Female DB-9 96-pin female 96-pin female Shielded banana plug cables (6) 2182A 1.888.KEITHLEY (U.S. only) www.keithley.com A Greater Measure of Confidence A Tektronix Company Cables Cables    TERMINATIONS Model Cables LENGTH Description Type From To m ft 7020-MTC-2 Mass Terminated Assembly Twisted pair (45) 96-pin female 96-pin female 2 6.6 7024-3 Low Noise Triax 2-slot male triax 2-slot male triax 0.9 3 USE WITH: 7020 Instruments with 2-slot triax connectors 7024-10 Low Noise Triax 2-slot male triax 2-slot male triax 3 10 Instruments with 2-slot triax connectors 7025-10 Low Noise Input Triax 2-slot male triax Unterminated 3 10 Instruments with 2-slot triax connectors 7035-MTC-2 Mass Terminated Assembly Twisted pair (45) 96-pin female 96-pin female 2 6.6 7035 7036-MTC-2 Mass Terminated Assembly Twisted pair (45) 96-pin female 96-pin female 2 6.6 7036 1.8 6 707A BNC Interconnect Coax BNC BNC 707A Master/Slave Twisted pair (9)  8-pin DIN 8-pin DIN 2015, 2016, 3390 7078-MTC-5 Mass Terminated Assembly Twisted pair (12) 38-pin connector 38-pin connector 1.5 5 7071, 7071-4, 7074-D 7078-MTC-20 Mass Terminated Assembly Twisted pair (12) 38-pin connector 38-pin connector 6.1 20 7071, 7071-4, 7074-D 7078-TRX-1 Low Noise Triax 3-slot male triax 3-slot male triax 0.3 1 2635B, 2636B, 6482, 6487, 6514, 6517A, 6517B, 7072, 7174A 7078-TRX-3 Low Noise Triax 3-slot male triax 3-slot male triax 0.9 3 2635B, 2636B, 6482, 6487, 6514, 6517A, 6517B, 7072, 7174A 7078-TRX-5 Low Noise Triax 3-slot male triax 3-slot male triax 1.5 5 2635B, 2636B, 6482, 6487, 6514, 6517A, 6517B, 7072, 7174A 7078-TRX-10 Low Noise Triax 3-slot male triax 3-slot male triax 3 10 2635B, 2636B, 6482, 6487, 6514, 6517A, 6517B, 7072, 7174A 7078-TRX-12 Low Noise Triax 3-slot male triax 3-slot male triax 4 12 2635B, 2636B, 6482, 6487, 6514, 6517A, 6517B, 7072, 7174A 7078-TRX-20 Low Noise Triax 3-slot male triax 3-slot male triax 6.1 20 2635B, 2636B, 6482, 6487, 6514, 6517A, 6517B, 7072, 7174A 7078-TRX-6IN Low Noise Triax 3-slot male triax 3-slot triax 0.15 0.5 6430 7152-MTC-2 Low Noise Matrix Expansion Triax (5) 6-pin M-series coax 6-pin M-series coax 0.6 2 7152 7152-MTC-10 Low Noise Matrix Expansion Triax (5) 6-pin M-series coax 6-pin M-series coax 3 10 7152 Cables 7051-* 7078-DIN 7152-TRX-10 Low Noise M-Series to Triax Triax (5) M-series connector 3-slot triax (5) 3 10 7152, 8006 7153-TRX Low Noise M-Series to Triax Triax (5) M-series connector 3-slot triax (5) 2 6 7153 7173-50-CSEP 4-cable Set Coax SMB female BNC male 0.6 2 7705-MTC-2 Mass Terminated Assembly Twisted pair (25) D-sub male D-sub female 2 6.6 7703, 7705, 7707, 7709 0.15 0.5 7711 1 3.3 7711, 7712, System 46, System 46T 0.9 3 Instruments with 2-slot BNC connectors 3 10 8007 1.8 6 2500, Series 2400, System 25, 8544, 8544-TEC 7711-BNC-SMA 5 SMA to BNC Cables Coax SMA Male BNC Female 7712-SMA-1 SMA Cables Coax SMA Male SMA Male 7754-3 BNC Coax BNC Male Alligator clips 8007-GND-3 Safety Ground Wire Single wire Crimp lug Crimp lug 8542-301 LIV Cable Multiple conductor DB9 female Multiple terminations: Triax (2500), 2 dual bananas (24XX) GND wire 7173-50 8607 1kV Test Cables Single wire (2) Safety banana Safety banana 1 3.3 CA-18-1 Shielded Coax Dual banana plug Dual banana plug 1.2 4 Bind­ing post inputs CA-19-2 CA-126-1A RG58 Digital I/O RG58 Shielded BNC male DB25 male BNC male DB25 female 1.5 1.5 5 5 Series 2600B, Series 3700A CA-180-3A Crossover Cable Twisted pair RJ45 RJ45 3 10 Series 2600B, 2701, 3390, Series 3700A, 6221, all TSP-enabled instruments CA-321-1 Temperature Control Cable Multiple conductor DB15 female 1.8 6 2510, 8544 CA-322-1 Dual Temperature Control Cable Multiple conductor DB15 female 1.8 6 2510, 8544, 8544-TEC CA-404B CA-405B CA-406B CA-446A CA-447A CA-451A CA-452A CA-557-1A CA-557-2A CA-557-3 RG188 RG188 RG188 Cable Assembly Cable Assembly RG188 RG188 Cable Assembly Cable Assembly Cable Assembly Coax Coax Coax Coax Coax Coax Coax Multiple conductor Multiple conductor Multiple conductor SMA male SMA male SMA male SMA male SMA male SMA male SMA male 8-pin receptacle 8-pin receptacle 8-pin receptacle SMA male SMA male SMA male SMA male SMA male SMA male SMA male 8-pin receptacle 8-pin receptacle 8-pin receptacle 2 0.15 0.33 3 1.5 0.108 0.203 1 2 3 CA-558-x Interlock Cable Twisted pair (2) 25-pin D-sub 3-pin 1, 2, 3 CA-559-0A CA-559-2A CA-560-0A CA-560-2A CA-561-0A CA-561-2A Black Banana Jumper Red Banana Jumper Banana Plug Jumper Cable Banana Plug Jumper Cable Black Banana Jumper Red Banana Jumper Jumper Jumper Jumper Jumper Jumper Jumper Banana Banana Banana Banana Banana Banana Banana Banana Banana Banana Banana Banana 0.102 0.102 0.203 0.203 0.203 0.203 6.5 0.5 1.08 9.8 5 0.35 8 in. 3.3 6.6 10 3.3, 6.6, 10 4 in. 4 in. 8 in. 8 in. 8 in. 8 in. 8-position Phoenix (CS-846 equivalent) Y cable to two 8-position Phoenix (CS-846) 2410, 6487, 6517A, 6517B 4200-SCS 4200-SCS 4200-SCS 4200-SCS 4210-CVU 4210-CVU 4200-SCS 4200-SCS 2651A, 8011 2651A, 8011 2651A, 8011 Series 2600B, 2657A ACCESSORIES Cables    TERMINATIONS Model 8010 8010 8010 8010 8010 8010 1.888.KEITHLEY (U.S. only) www.keithley.com A Greater Measure of Confidence A Tektronix Company Cables    TERMINATIONS CA-562-0B CA-562-2B Black Safety Banana Plug Jumper Cable Red Safety Banana Plug Jumper Cable BNC to Banana Jumper Black Banana Jumper Red Banana Jumper Protective Earth Ground Type From To Jumper Banana Jumper Jumper Jumper Jumper Safety LENGTH m ft Banana 0.254 10 in. 8010 Banana Banana 0.254 10 in. 8010 BNC Banana Banana Eye lug Banana Banana Banana Eye lug 0.241 0.203 0.203 0.3, 0.45, 3 0.5, 1, 2, 3 9.5 in. 8 in. 8 in. 1, 1.5, 10 1.6, 3.3, 6.6, 10 8010 8010 8010 8010 0.15 0.5 0.30 1.0 HV-CA-554-x 3kV Rated High voltage Triax Triax HV-CA-571-3 S46-SMA-0.5 S46-SMA-1 SC-9 SC-22 SC-93 SC-182 SC-200A SC-206 High Voltage SMA Cable SMA Cable Low Noise Low Noise Low Thermal Low Inductance General Purpose High Current Coax Cable Triax Coax Coax Coax Triax Shielded Coax Shielded twisted pair Coax Triax SMA Male SMA Male Unterminated Unterminated Unterminated Unterminated Unterminated Unterminated Unterminated SMA Male SMA Male Unterminated Unterminated Unterminated Unterminated Unterminated Unterminated SHV-CA-553-x 3kV Rated High voltage Triax SHV USB-B-1 USB Cable Coax USB Type A USB Type B USE WITH: 8010, 2657A 2657A 7711, 7712, System 46, System 46T 7711, 7712, System 46, System 46T Sold by the foot Sold by the foot CS-631 Sold by the foot 2182-KIT Sold by the foot 2302, 2303, 2303-PJ, 2304A, 2306, 2306-PJ Sold by the inch Series 2600B Sold by the inch 2651A 1, 2, 3 1 Model 236-ILC-3 Safety Interlock Cable: Designed to connect the lid interlock circuit of the Models 8007 and 8008 test fixtures to the interlock circuit of the Model 237 SMU and 486 and 487 Picoammeters. Model 237-ALG-*: Low noise triax cable (SC-22) terminated with a 3-slot male triax connector on one end and 3 alligator clips on the other. 237-ALG-2 2m (6.6 ft) length 237-ALG-15 15m (50 ft) length For use with: 4200-SCS, 8007, 8008 For use with: Series 2200, Series 2600B, 4200-PA, 6220, 6221, 6487, 6514, 6482, 6517A, 6517B 3.3, 6.6, 10 3.3 2657A  2100, Series 2200, 3390, Series 3700A, Series 2600, 2450  Model 2000-MTC-2 Cable Assembly: 2-meter cable with a 44-pin connector on one end that is designed to mate with the 2000-20 scanner card. The other end is unterminated for direct connection to measurement fixtures or devices. For use with: 2000-20 ACCESSORIES Cables CA-563C CA-567-0A CA-567-2A CA-568-XA Description Cables Model 1.888.KEITHLEY (U.S. only) www.keithley.com A Greater Measure of Confidence A Tektronix Company Cables Model 2290-5-SHV: 3m (10 ft) of RG-8A/U coaxial cable terminated with a SHV female connector on both ends. Maximum operating voltage is 5000Vrms. Characteristic cable impedance is 50Ω. For use with: 2290-5 Model 2260-005: Cable, 0.5m (1.6 ft.), to connect two Series 2260B power supplies in series. Cables Model 2000-MTCD-2 Cable Assembly: 2-meter cable with a 44-pin connector on one end that is designed to mate with the 2000-SCAN-20 scanner card. The other end is equipped with a 50-pin D-sub male connector. For use with: 2000-SCAN-20 Model 2260-006: Cable, 0.5m (1.6 ft.), to connect two Series 2260B power supplies in parallel. Model 2290-10-SHV: 3m (10 ft) of RG-213/U coaxial cable terminated with a SHV male connector on both ends. Maximum operating voltage is 10,000Vrms. For use with: 2290-10, 2290-10-SHVBH For use with: Series 2260 Model 2107-* Low-Thermal Input Cables with Spade Lugs: An input cable terminated with a LEMO connector on one end and four copper spade lugs on the other. 2107-4 1.2m (4 ft) length 2107-30 9.1m (30 ft) length 2107-50 15m (50 ft) length For use with: 2182A, Series 2200 Model 2260-007: Cable, 0.5m (1.6 ft.), to connect three Series 2260B power supplies in parallel. For use with: Series 2260 Model 2290-5-MHV: 3m (10 ft) of RG-8A/U coaxial cable terminated with a SHV female connector on one end and a MHV male connector on the other end. Maximum operating voltage is 5000Vrms. Characteristic cable impedance is 50Ω. Model 2290-10-SHVUC: 3m (10 ft) of RG-213/U coaxial cable terminated with a SHV male connector on one end and unterminated cable on the other end. Maximum operating voltage is 10,000Vrms. For use with: 2290-10 ACCESSORIES Cables For use with: Series 2260 For use with: 2290-5 1.888.KEITHLEY (U.S. only) www.keithley.com A Greater Measure of Confidence A Tektronix Company Model 2290-INT-CABLE: Safety interlock cable, 3.05m (10 ft). 3-conductor cable with 3-pin connector on one end and unterminated wires on the other end. For use with: 2290-5, 2290-10 Model 2651A-KIT-*: High current, low impedance, coaxial cable assembly. 2651A-KIT-1: 1m (3.3 ft). 2651A-KIT-2: 2m (6.6 ft). 2651A-KIT-3: 3m (10 ft). For use with: 3722 For use with: 2651A, 8011 Model 3720-MTC-*: 78-pin D-sub female to 78-pin D-sub male cable. 3720-MTC-1.5: 1.5m (5 ft) length 3720-MTC-3: 3m (10 ft) length Model 2450-TRX-BAN: For adapting the Model 2450’s rear panel triaxial connectors to banana jack inputs. Length: 0.3m (1 ft). Model 3722-MTC-*: 104-pin D-sub male to 104-pin D-sub female cable. 3722-MTC-1.5: 1.5m (5 ft) length 3722-MTC-3: 3m (10 ft) length Cables Cables Cables Model 3722-MTC-*/MM: 104-pin D-sub male to 104-pin D-sub male cable. 3722-MTC-1.5/MM: 1.5m (5 ft) length 3722-MTC-3/MM: 3m (10 ft) length For use with: 3722 For use with: 3720, 3723, 3724 For use with: 2450 ACCESSORIES Model 3732-MTC-*: 78-pin D-sub female to 78-pin D-sub male cable. 3732-MTC-1.5: 1.5m (5 ft) length 3732-MTC-3: 3m (10 ft) length Model 3721-MTC-*: 50-pin D-sub female to 50-pin D-sub male cable. 3721-MTC-1.5: 1.5m (5 ft) length 3721-MTC-3: 3m (10 ft) length For use with: 3732 For use with: 3721, 3730, 3731, 3740, 3750 Model 2600-ALG-2: 2m (6.6 ft) cable terminated with a 3-slot male triax connector on one end and 3 alligator clips on the other. For use with: 2635B, 2636B, 4200-PA 1.888.KEITHLEY (U.S. only) www.keithley.com A Greater Measure of Confidence A Tektronix Company Model 4200-RPC-*: Remote PreAmp cable terminated at each end with a high density DB15 connector. This cable connects a Model 4200-SMU or 4210-SMU source measurement unit installed in a Model 4200-SCS to a remotely mounted Model 4200-PA PreAmp. 4200-RPC-0.3: 0.3m (1 ft) (for use inside prober shield) 4200-RPC-2: 2m (6.5 ft) (one included with each 4200-PA) 4200-RPC-3: 3m (9.8 ft) 4200-RPC-6: 6m (19.6 ft) Model 4801 Input Cable: Low noise coax cable, 1.2m (48 in) in length, with male BNC con­nec­ tors on each end. For use with: 6482, 6485, 7158 Cables Model 4200-MTRX-*: Ultra low noise SMU triax cable is terminated with a miniature male triax connector on one end and a standard 3-slot male triax connector on the other end. This cable connects a Model 4200-SMU or 4210-SMU source measurement unit installed in a Model 4200-SCS to a test fixture. (4200-MTRX-* cables are intended only for connection to an SMU that does not have a 4200-PA PreAmp installed.) 4200-MTRX-1: 1m (3.2 ft) 4200-MTRX-2: 2m (6.5 ft) (two included with each 4200-SCS SMU not configured with a 4200-PA Remote PreAmp) 4200-MTRX-3: 3m (9.8 ft) For use with: 4200-PA For use with: 4200-SCS Model 4802-10: 3m (10 ft) of low noise coax cable with male BNC connector at one end and unterminated at the other. For use with: 6482, 6485, 7158 Model 4200-PRB-C: SMA to SSMC Y adapter cable with local ground that connects the 4200-PIV package to DC probe manipulators. The cable is terminated at one end with a single female SMA. The other end splits into two gold SSMC plugs (female connectors) and a black wire with integrated connector, which is used to connect to the shield of another Model 4200-PRB-C cable. For use with: 4200-PIV, 4210-CVU Model 4200-TRX-*: Ultra low noise PreAmp triax cable terminated with a standard 3-slot male triax connector on each end. This cable connects a Model 4200-PA PreAmp option installed in the Model 4200-SCS to the test ­fixture. 4200-TRX-0.3: 0.3m (1 ft) (recommended for remote location of the 4200-PA) 4200-TRX-1: 1m (3.2 ft) 4200-TRX-2: 2m (6.5 ft) (two included with each Model 4200-PA) 4200-TRX-3: 3m (9.8 ft) For use with: 4200-PA Model 4803 Low Noise Cable Kit: In­cludes 15m (50 ft) of low noise coax cable, 10 male BNC con­nec­tors, and 5 female BNC chassis-mount connectors. For use with: 6482, 6485, 7158 1.888.KEITHLEY (U.S. only) www.keithley.com A Greater Measure of Confidence A Tektronix Company ACCESSORIES Cables Cables Cables 2 Slot Triax Model 6011 2-slot Triax Cable: 1.5m (5 ft) of tri­a x cable (SC-22) ter­mi­nat­ed with a 2-slot triax plug on one end and three alligator clips on the other. Also available in 3m (10 ft) length (Model 6011-10). For use with instruments with 2-slot triax connectors Model 7009-5 Shielded RS-232 Cable: 1.5m (5 ft) RS-232 cable with a male DB-9 connector at one end and a female DB-9 connector on the other end. Wired as a straight through, not as a null modem cable. For use with: All RS-232 capable instruments 207 Model 7019C-MTCI-2 6-wire Kelvin ­Ex­tend­­er and Instru­­ment Cable: Used with Model 7019-C 6-Wire Ohms Matrix Card and a SourceMeter SMU instrument. The Source­­Meter cables are 0.6m (2 ft) long and the DUT cables are 2m (6.6 ft) long. The cable set is used in a basic system to test a resistor network. For use with: Series 2400 SourceMeter SMU Instruments Model 6517-ILC-3 Interlock Cable: De­sign­ed to connect the Interlock of the 6517A with the 8009 test fixture. Configuring the 6517A with the 8009 test fixture results in all the elec­trode constants already being programmed into the unit. ACCESSORIES For use with: 6517A Electrometer, 8009 Model 7011-MTC-x: Mass terminated cable assembly for connection to 7011-C and other switching cards. The cable has 45 pairs with outer shield. The cable is terminated at each end with 96-pin female DIN connectors with strain relief. 7011-MTC-1 1m (3.3 ft) 7011-MTC-2 2m (6.6 ft) Model 6517B-ILC-3 Interlock Cable: De­sign­ed to connect the interlock of the 6517B with the 8009 test fixture. Configuring the 6517B with the 8009 test fixture results in all the elec­trode constants already being programmed into the unit. Model 7020-MTC-2: 2m (6.6 ft) mass terminated cable assembly for connection to 7020. The cable has 45 pairs with outer shield. The cable is terminated at each end with 96-pin female DIN connectors with strain relief. For use with: 7020 For use with: 7011-C, 7012-C, 7013-C, 7015-C, 7018-C, 7022 For use with: 6517B Electrometer, 8009 1.888.KEITHLEY (U.S. only) www.keithley.com A Greater Measure of Confidence A Tektronix Company Cables Cables Cables For use with instruments with 2-slot triax connectors Model 7035-MTC-2: 2m (6.6 ft) mass terminated cable assembly for connection to 7035. The cable has 45 pairs with outer shield. The cable is terminated at each end with 96-pin female DIN connectors with strain relief. Model 7051-*: General purpose BNC to BNC cable (G-58C). 7051-2 0.6m (2 ft) 7051-5 1.5m (5 ft) 7051-10 3m (10 ft) For use with: 2015, 2016, 3390, 7711, some instrument external trigger I/O lines Cables Model 7024-* 2-slot Triax Cable: Low noise triax cable (SC-22) with 2-slot male triax connectors on each end. 7024-3 0.9m (3 ft) 7024-10 3m (10 ft) For use with: 7035 2 Slot Triax Model 7025-10 2-slot Triax Cable: 3m (10 ft) low noise triax input cable (SC-22) terminated on one end with 2-slot male triax connector. Model 7078-DIN: This 1.8m (6 ft) cable ac­ces­ sory connects between Model 707A main­frames when operated as one unit in Master/Slave mode. One cable is required for each mainframe. For use with instruments with 2-slot triax connectors For use with: 707A Model 7036-MTC-2: 2m (6.6 ft) mass terminated cable assembly for connection to 7036. The cable has 45 pairs with outer shield. The cable is terminated at each end with 96-pin female DIN connectors with strain relief. For use with: 7036 ACCESSORIES Cables 2 Slot Triax 1.888.KEITHLEY (U.S. only) www.keithley.com A Greater Measure of Confidence A Tektronix Company Cables  Model 7078-MTC-5: 1.5m (5 ft) mass terminated cable for connection to column inputs (7071 and 7071-4). Also used for matrix expansion (7071, 7071-4, or 7074). The cable has 12 sets of shielded twisted pair wires for isolation of critical circuits and noise rejection in the system. The cable is terminated at each end in a 38-pin connector block with strain relief. Model 7078-MTC-20 can be used as is or cut in half to make two 10 ft cables. Model 7078-TRX-6IN 3-slot Triax Cable: 0.15m (6 inch), 3-slot, low-noise, guarded triax cable that minimizes leakage current and input capacitance when used with the Model 6430 Remote PreAmp (lower noise than 1 foot or longer versions). For use with: 6430 Model 7152-TRX-10: Set of five 3m (10 ft) low noise triax cables terminated at one end in a single M-series connector block and at the other end in 3-slot triax connectors. This cable is most useful for direct connection to electrometers and Source/Measure Units. For use with: 7152, 8006 For use with: 7071, 7071-4, 7074-D 3 Slot Triax ACCESSORIES ­ Model 7078-TRX-* 3-slot Triax Cables: Low noise triax cables terminated at both ends in 3-slot male triax connectors. 7078-TRX-1 0.3m (1 ft) 7078-TRX-3 0.9m (3 ft) 7078-TRX-5 1.5m (5 ft) 7078-TRX-10 3.0m (10 ft) 7078-TRX-12 3.5m (12 ft) 7078-TRX-20 6.0m (20 ft) Model 7152-MTC-*: Five low noise triax cables terminated in 6-position M-series coax connector blocks. Provides quick connection between 7152 matrix cards and is compatible with Model 7152-MTR connector. Also available in 3m (10 ft) length for connection between the matrix and the device under test. 7152-MTC-2 0.6m (2 ft) 7152-MTC-10 3.0m (10 ft) For use with: 7152 Model 7153-TRX: 2m (6.6 ft) low noise cable assembly with M-series connector at one end for row or column connections to the 7153, and five 3-slot male triax connectors at the other end. Two 7153-TRX cable assemblies are required to make all connections to the 7153 card. For use with: 7153 For use with: 2635B, 2636B, 6220, 6221, 6482, 6487, 6514, 6517A, 6517B, 7072, 7174A 1.888.KEITHLEY (U.S. only) www.keithley.com A Greater Measure of Confidence A Tektronix Company Cables Cables 3 Slot Triax Cables For use with: 7173-50 For use with: 7701, 7707, 7709 Model 7754-3 BNC to Alligator Cable: 0.9m (3 ft) terminated on one end with a BNC plug and on the other with two alligator clips. For use with instruments with 2-slot BNC connections Cables Model 7173-50-CSEP: The 7173-50-CSEP cable set provides the capability to expand a switching configuration to include more than one 7173-50. Each set contains four 0.6m (25 in) cables. One cable is required to expand each row or column connection between adjacent cards. For example, using two 7173-50 cards to create a 4×24 matrix would require connecting the rows of two adjacent cards together. One 7173-50-CSEP set has enough cables to do this. Connecting the 12 columns together on two adjacent cards creates an 8×12 matrix. This would require three 7173-50-CSEP sets, 12 cables. Model 7711-BNC-SMA: Male SMA to female BNC cables (5 each), 0.15m (0.5 ft) in length. For use with: 7711 Model 8007-GND-3: Safety ground wire, 3m (10 ft). For use with instruments with a safety ground connector Model 7705-MTC-2: 2m (6.6 ft) 50-conductor male to female D-sub cable assembly. For use with: 7703, 7705, 7707, 7709, 7701 Model 7712-SMA-1: SMA cable, male to male, 1m (3.3 ft). For use with: 7711, 7712, System 46, System 46T Model 8542-301: 1.8m (6 ft) LIV test system cable. For use with: Series 2400, 2500, System 25, 8544, 8544-TEC 1.888.KEITHLEY (U.S. only) www.keithley.com A Greater Measure of Confidence A Tektronix Company ACCESSORIES Cables Model 7707-MTC-2: 2m (6.6 ft) 25-conductor male to female D-sub cable assembly. Cables Item shipped may vary from model ­pictured here. CA-126-1A Digital I/O Cable: 1.5m (5 ft) of cable, from DB25 male to DB25 female. For use with: 4200-SCS, System 46, System 46T Cables Cables For use with: Series 2600B, Series 3700A Model 8607 1kV Source Banana Cable Set: The 8607 cable set is made up of one red and one black high voltage test lead with fixed safety banana plug ends. The leads are 1 meter (3.3 ft) long and have a voltage rating of 1500V DC. CA-404B: 2m (6.5 ft) RG188 coax cable terminated with an SMA male plug on each end, 50W impedance. For use with: 2410, 6487, 6517A, 6517B CA-180-3A: 3m (10 ft), CAT5 crossover cable for Ethernet or TSP-Link. For use with: Series 2600B, 2701, 3390, Series 3700A, 6221, all TSP-Link enabled instruments Item shipped may vary from model ­pictured here. CA-405B: 15cm (6 in) RG188 coax cable terminated with an SMA male plug on each end, 50W impedance. For use with: 4200-SCS CA-18-1: 1.2m (4 ft) shielded cable te­r­­m­i­nat­ed with a dual banana plug on each end. For use with binding post inputs or dual banana jacks. For use with: Binding post inputs CA-321-1: Temperature control cable. For use with: 2510, 8544 CA-406B: 33cm (13 in) RG188 coax cable terminated with an SMA male plug on each end, 50W impedance. For use with: 4200-SCS ACCESSORIES CA-19-2: 1.5m (5 ft) RG58 cable terminated with a BNC male plug on each end. For use with: 4200-SCS CA-322-1: Dual temperature control cable. For use with: 2510, 8544, 8544-TEC 1.888.KEITHLEY (U.S. only) www.keithley.com A Greater Measure of Confidence A Tektronix Company CA-559-0A and CA-559-2A: Banana to banana jumper (102mm). For use with: 4200-SCS For use with: 2600-PCT-x, 4200-PCT-x, 8010 For use with: 4210-CVU CA-560-0A and CA-560-2A: Banana to banana jumper (203mm). Cables CA-446A: 3m (9.8 ft) coax cable terminated with an SMA male plug on each end, 100W ­impedance. CA-452A: 20.4cm (8 in) RG188 coax cable terminated with an SMA male plug on each end, 50W impedance. For use with: 2600-PCT-x, 4200-PCT-x, 8010 CA-561-0A and CA-561-2A: Banana to banana jumper (305mm). CA-447A: 1.5m (4.9 ft) coax cable terminated with an SMA male plug on each end, 100W impedance. For use with: 4210-CVU CA-557-*: 8-pin male to 8-pin male cable assembly with straight through pin configuration. CA-557-1: 1m (3.3 ft) CA-557-2: 2m (6.6 ft) CA-557-3: 3m (10 ft) For use with: 2600-PCT-x, 4200-PCT-x, 8010 For use with: 2601B, 2602B, 2611B, 2612B, 2651A SourceMeter® SMU Instruments, 2600PCT-x, 4200-PCT-x, 8010 CA-562-0B and CA-562-2B: Safety banana to banana jumper (254mm). For use with: 2600-PCT-x, 4200-PCT-x, 8010 CA-451A: 10.8cm (4.25 in) RG188 coax cable terminated with an SMA male plug on each, 50W impedance. ACCESSORIES Cables Cables For use with: 4200-SCS CA-558-2: 25-pin D-sub to 3-pin interlock cable assembly. For use with: Series 2600B, 2600-PCT-x, 2651A, 2657A, 4200-SCS, 4200-PCT-x, 8010 1.888.KEITHLEY (U.S. only) www.keithley.com A Greater Measure of Confidence A Tektronix Company Cables For use with: 2600-PCT-x, 4200-PCT-x, 8010 HV-CA-571-3: High voltage triax to unterminated cable. Cables For use with: 2657A, 2600-PCT-x, 4200-PCT-x For use with: 7711, 7712, System 46, System 46T SC-9: Low noise coax cable without con­nec­tors (sold by the foot). CA-568-xA: Protective earth safety ground cable with eye lugs (x = 12, 18, or 120 inches). For use with: 2657A, 2657-LIM-3, 2657-PIM-200, 8010 S46-SMA-1: SMA cable, male to male, 0.3m (1 ft). Cables CA-563C: BNC to banana jumper (240mm). SHV-CA-553-x: High voltage triax to SHV cable (x = 1, 2, or 3m) (3kV rated). For use with: 2657A SC-22: Low noise triax cable without con­nec­tors (sold by the inch). For use with: CS-631 ACCESSORIES HV-CA-554-x: High voltage triax to triax cable (3kV rated) (x = 0.5, 1, 2, or 3m). For use with: 2657A, 2657-LIM-3, 2657-PIM-200, 8010 S46-SMA-0.5: SMA cable, male to male, 0.15m (0.5 ft). For use with: 7711, 7712, System 46, System 46T 1.888.KEITHLEY (U.S. only) www.keithley.com A Greater Measure of Confidence A Tektronix Company Cables SC-93: Low thermal, 2-conductor shielded cable, #22AWG solid copper (sold by the foot). SC-200A: Shielded twisted pair cable (sold by the inch). Recommended for general-purpose use with Series 2600B System SourceMeter SMU instruments. Cables SC-182: Low inductance (42nH/ft) coaxial cable for minimizing test lead impedance in circuits using fast transient response power supplies. The cable is sold by the foot and comes without connectors. For use with: Series 2600B Cables For use with: 2182-KIT For use with: 2302, 2303, 2303-PJ, 2304A, 2306, 2306-PJ, 2306-VS USB-B-1: USB Cable, 1m (3.3 ft). ACCESSORIES For use with: 2100, Series 2200, 3390, Series 3700A, Series 2600, 2450 1.888.KEITHLEY (U.S. only) www.keithley.com A Greater Measure of Confidence A Tektronix Company
HV-CA-554-3 价格&库存
很抱歉,暂时无法提供与“HV-CA-554-3”相匹配的价格&库存,您可以联系我们找货
