2290-5-MHV
2290-5-MHV
    KEITHLEY
    KEITHLEY - 2290-5-MHV - Test Cable Assembly, SHV Female-MHV Male Cable, Keithley 2290 Series High Vo...
2290-5-MHV 数据手册
Model 2290-5-MHV Keithley Instruments, Inc. 28775 Aurora Road Cleveland, Ohio 44139 1-888-KEITHLEY http://www.keithley.com SHV Plug to MHV Male Cable Description The Model 2290-5 can contain hazardous voltages. Be certain that the high voltage is completely discharged before removing or connecting the high-voltage cable. High-voltage cables can store charge if they are disconnected from the supply while high voltage is turned on and can cause personal injury or death if not handled properly. Do not connect the HIGH-VOLTAGE output to exposed circuitry. Any load connected to the HIGH-VOLTAGE output should be enclosed in a metal shield that is connected to safety earth ground using #18AWG or larger wire. The high-voltage output cable connects the Model 2290-5 source output to external equipment. High-voltage cable installation: 1. Turn off power and allow all voltage to discharge. 2. Install the Model 2290-5-MHV high-voltage cable (see next figure). Figure 1: Model 2290-5 MHV cable 077084200 *077084200* 1 Model 2290-5-MHV SHV plug to MHV male cable Characteristics 2 Length 10 feet (3.05 meters) Type RG-8A/U coax Maximum operating voltage (RMS) 5,000 volts Impedance 50 Ohms 077084200
2290-5-MHV 价格&库存
很抱歉,暂时无法提供与“2290-5-MHV”相匹配的价格&库存,您可以联系我们找货
