2460-KIT
2460-KIT
    KEITHLEY
    KEITHLEY - 2460-KIT - Test Connector Kit, 8-pin Connector, Cable Housing, 2x Outlet Covers, Strain R...
2460-KIT 数据手册
Model 2460-KIT Keithley Instruments 28775 Aurora Road Cleveland, Ohio 44139 1-800-935-5595 http://www.keithley.com Screw Terminal Connector Kit Description The Model 2460-KIT Screw Terminal Connector Kit contains a cable housing, an inverted plug, and a cable tie for strain relief. The cable housing is made up of two half-shells with cable outlets on three sides so that you can select which direction to wire your connections to the Model 2600-KIT rear-panel screw terminal. The inverted plug secures cables to pins for quick connection to the rear panel. Figure 1: Model 2460-KIT 071335400 / September 2014 *P071335400* 1 Model 2460-KIT Screw Terminal Connector Kit The maximum floating (common mode) voltage for a source-measure unit (SMU) is ±250 V. Exceeding this level may cause damage to the instrument and create a shock hazard. Using an external source to float a SMU could create a shock hazard in the test circuit. A shock hazard exists whenever >42 V peak is present in the test circuit. Appropriately rated cables or insulators must be provided for all connections to prevent access to live parts. When >42 V is present, the test circuit must be insulated for the voltage used or surrounded by a metal safety shield that is connected to a known protective earth (safety ground) and chassis ground. Each screw in the screw terminal connector can accommodate from 26 AWG (0.2 mm2) to 12 AWG (2.5 mm2) conductors. Parts list Model 2460-KIT parts list Quantity Part 1 8-pin connector 1 Cable housing (2 half-shells) 2 Cable outlet covers 1 Cable strain relief tie 2 Screws Characteristics Plug specifications Characteristic Specification Insulation material group I Nominal current/cross section 14 A / 2.5 mm2 Maximum load current/cross section 14 A / 2.5 mm2 Connection capacity 26 AWG to 12 AWG UL and CSA approval data: 2 Nominal voltage 300 V Current 14 A Conductor sizes 26 AWG to 12 AWG 071335400 / September 2014 Model 2460-KIT Screw Terminal Connector Kit Assembly Turn off instrument power before installing the screw terminal connector to the instrument. Failure to remove power before installation may cause personal injury or death from electrical shock. To assemble the kit: 1. Determine your wiring requirements and pinouts. 2. Split the cable housing into upper and lower halves. 3. Thread wire and cabling into housing through one of the cable outlets. 4. Connect wires to the inverted plug. 5. Insert the cable tie through the strain relief slots and fasten around the cables. 6. Install the cable outlet covers in the unused cable outlets. 7. Snap housing halves together. 8. Insert the and tighten screws in the screw holes on the other side of the cable housing. 9. Plug assembled Model 2460-KIT into the Model 2460 rear-panel screw terminal. The following figure shows the pin connections for the Model 2460 rear-panel screw terminal. Figure 2: Model 2460 screw terminal pinouts 071335400 / September 2014 3 Safety precautions The following safety precautions should be observed before using this product and any associated instrumentation. Although some instruments and accessories would normally be used with nonhazardous voltages, there are situations where hazardous conditions may be present. This product is intended for use by qualified personnel who recognize shock hazards and are familiar with the safety precautions required to avoid possible injury. Read and follow all installation, operation, and maintenance information carefully before using the product. Refer to the user documentation for complete product specifications. If the product is used in a manner not specified, the protection provided by the product warranty may be impaired. The types of product users are: Responsible body is the individual or group responsible for the use and maintenance of equipment, for ensuring that the equipment is operated within its specifications and operating limits, and for ensuring that operators are adequately trained. Operators use the product for its intended function. They must be trained in electrical safety procedures and proper use of the instrument. They must be protected from electric shock and contact with hazardous live circuits. Maintenance personnel perform routine procedures on the product to keep it operating properly, for example, setting the line voltage or replacing consumable materials. Maintenance procedures are described in the user documentation. The procedures explicitly state if the operator may perform them. Otherwise, they should be performed only by service personnel. Service personnel are trained to work on live circuits, perform safe installations, and repair products. Only properly trained service personnel may perform installation and service procedures. Keithley Instruments products are designed for use with electrical signals that are measurement, control, and data I/O connections, with low transient overvoltages, and must not be directly connected to mains voltage or to voltage sources with high transient overvoltages. Measurement Category II (as referenced in IEC 60664) connections require protection for high transient overvoltages often associated with local AC mains connections. Certain Keithley measuring instruments may be connected to mains. These instruments will be marked as category II or higher. Unless explicitly allowed in the specifications, operating manual, and instrument labels, do not connect any instrument to mains. Exercise extreme caution when a shock hazard is present. Lethal voltage may be present on cable connector jacks or test fixtures. The American National Standards Institute (ANSI) states that a shock hazard exists when voltage levels greater than 30 V RMS, 42.4 V peak, or 60 VDC are present. A good safety practice is to expect that hazardous voltage is present in any unknown circuit before measuring. Operators of this product must be protected from electric shock at all times. The responsible body must ensure that operators are prevented access and/or insulated from every connection point. In some cases, connections must be exposed to potential human contact. Product operators in these circumstances must be trained to protect themselves from the risk of electric shock. If the circuit is capable of operating at or above 1000 V, no conductive part of the circuit may be exposed. Do not connect switching cards directly to unlimited power circuits. They are intended to be used with impedance-limited sources. NEVER connect switching cards directly to AC mains. When connecting sources to switching cards, install protective devices to limit fault current and voltage to the card. Before operating an instrument, ensure that the line cord is connected to a properly-grounded power receptacle. Inspect the connecting cables, test leads, and jumpers for possible wear, cracks, or breaks before each use. When installing equipment where access to the main power cord is restricted, such as rack mounting, a separate main input power disconnect device must be provided in close proximity to the equipment and within easy reach of the operator. For maximum safety, do not touch the product, test cables, or any other instruments while power is applied to the circuit under test. ALWAYS remove power from the entire test system and discharge any capacitors before: connecting or disconnecting cables or jumpers, installing or removing switching cards, or making internal changes, such as installing or removing jumpers. Do not touch any object that could provide a current path to the common side of the circuit under test or power line (earth) ground. Always make measurements with dry hands while standing on a dry, insulated surface capable of withstanding the voltage being measured. 4 071335400 / September 2014 For safety, instruments and accessories must be used in accordance with the operating instructions. If the instruments or accessories are used in a manner not specified in the operating instructions, the protection provided by the equipment may be impaired. Do not exceed the maximum signal levels of the instruments and accessories, as defined in the specifications and operating information, and as shown on the instrument or test fixture panels, or switching card. When fuses are used in a product, replace with the same type and rating for continued protection against fire hazard. Chassis connections must only be used as shield connections for measuring circuits, NOT as protective earth (safety ground) connections. If you are using a test fixture, keep the lid closed while power is applied to the device under test. Safe operation requires the use of a lid interlock. If a screw is present, connect it to protective earth (safety ground) using the wire recommended in the user documentation. symbol on an instrument means caution, risk of danger. The user must refer to the operating instructions located in the The user documentation in all cases where the symbol is marked on the instrument. symbol on an instrument means caution, risk of electric shock. Use standard safety precautions to avoid personal The contact with these voltages. The symbol on an instrument shows that the surface may be hot. Avoid personal contact to prevent burns. The symbol indicates a connection terminal to the equipment frame. symbol is on a product, it indicates that mercury is present in the display lamp. Please note that the lamp must be If this properly disposed of according to federal, state, and local laws. The WARNING heading in the user documentation explains dangers that might result in personal injury or death. Always read the associated information very carefully before performing the indicated procedure. The CAUTION heading in the user documentation explains hazards that could damage the instrument. Such damage may invalidate the warranty. Instrumentation and accessories shall not be connected to humans. Before performing any maintenance, disconnect the line cord and all test cables. To maintain protection from electric shock and fire, replacement components in mains circuits — including the power transformer, test leads, and input jacks — must be purchased from Keithley Instruments. Standard fuses with applicable national safety approvals may be used if the rating and type are the same. Other components that are not safety-related may be purchased from other suppliers as long as they are equivalent to the original component (note that selected parts should be purchased only through Keithley Instruments to maintain accuracy and functionality of the product). If you are unsure about the applicability of a replacement component, call a Keithley Instruments office for information. To clean an instrument, use a damp cloth or mild, water-based cleaner. Clean the exterior of the instrument only. Do not apply cleaner directly to the instrument or allow liquids to enter or spill on the instrument. Products that consist of a circuit board with no case or chassis (e.g., a data acquisition board for installation into a computer) should never require cleaning if handled according to instructions. If the board becomes contaminated and operation is affected, the board should be returned to the factory for proper cleaning/servicing. Safety precaution revision as of January 2013. 071335400 / September 2014 5
2460-KIT 价格&库存
很抱歉,暂时无法提供与“2460-KIT”相匹配的价格&库存,您可以联系我们找货
