3720-ST
3720-ST
    KEITHLEY
    KEITHLEY - 3720-ST - Test Accessory, Screw Terminal Block, Keithley 3720 Multiplexer Card
3720-ST 数据手册
Plug-in Cards for Series 3700 Mainframes 1.888.KEITHLEY (U.S. only) w w w.keithley.com SWITCHING AND CONTROL Plug-in cards for Series 3700 mainframes Series 3700 A G R E A T E R M E A S U R E O F C O N F I D E N C E Series 3700 Plug-in Cards for Series 3700 Mainframes • Multiplexer, matrix, and I/O cards Specifications for Plug-In Cards Plug-in cards for Series 3700 mainframes • Relay closures automatically counted and stored in each card’s onboard memory Additional Series 3700 cards are currently in development. For a current list of cards and specifications, visit www.keithley.com. • Unlimited contact life with solid-state relay (Model 3724) Page • Automatic CJC for temperature measurements when used with screw terminal accessory (Models 3720, 3721, 3724) No. of Channels Card Config. Type of Relay Ordering Information Contact Configuration 3720 Dual 1×30 Multiplexer Card4 Max. Voltage 3721 Dual 1×20 Multiplexer Card6 3722 Dual 1×48, High Density, Multiplexer Card . . . . . . . . 8 Max. Current Switched Comments 3723 Dual 1×30, High Speed, Reed Relay, Multiplexer Card . . . . . . . 10 3724 Dual 1×30 FET Multiplexer Card . . . . . . . 12 3720 3721 3722 4 6 8 60 (Dual 1×30) 40 (dual 1×20) 96 (dual 1×48) Multiplexer Latching electromechanical 2 Form A Multiplexer Latching electromechanical 2 Form A 300 V (ch 1–40), 300 V 60 V (ch 41–42) 2 A (ch 1–40), 1A 3 A (ch 41–42) 2 independent 1×20 2 independent 1×30 multiplexers. Automatic multiplexers. Automatic temperature reference temperature reference when used with screw when used with screw terminal accessory terminal accessory (Model 3721-ST) (Model 3720-ST) Multiplexer Latching electromechanical 2 Form A 300 V 1A 2 independent 1×48 multiplexers 3730 6×16, High Density, Matrix Card . . . . . . . . . . . . 15 3731 6×16, High Speed, Reed Relay, Matrix Card . . . . . . 17 3732 Quad 4×28, Ultra-High Density, Reed Relay, Matrix Card . . . . . . . . . . . . 19 3740 General Purpose Card with 32 Independent Channels . . . . . . . . . . . . . . 23 Plug-in Card Accessories 3750 Multifunction Control Card25 SWITCHING AND CONTROL Cables 2 Screw Terminal Block Connector Kits 3721 3722 3720-MTC-1.5, 3720-MTC-3 3721-MTC-1.5, 3721-MTC-3 3722-MTC-1.5, 3722-MTC-1.5/MM, 3722-MTC-3, 3722-MTC-3/MM 3720-ST 3721-ST 3791-KIT78-R 3790-KIT50-R 3791-CIT Tools 1.888.KEITHLEY (U.S. only) w w w.keithley.com 3720 A G R E A T E R M E A S U R E 3792-KIT104-R, 3792-KIT104-R/F 3791-CIT O F C O N F I D E N C E 3723 3724 3730 3731 3732 3740 3750 10 12 15 17 19 23 60 (dual 1×30) or 120 single pole (dual 1×60) 60 (dual 1×30) 6×16 6×16 448 crosspoints (Quad 4×28) 32 Multiplexer Multiplexer Matrix Matrix Dry reed FET solid-state Dry reed Dry reed 1 Form A 2 Form A Matrix Latching electromechanical 2 Form A 25 40 digital I/O, 4 counter/totalizers, and 2 isolated analog outputs Independent 2 Form A 1 Form A 200 V 200 V 300 V 200 V 200 V 1A 0.1 A 1A 1A 0.75 A 2 independent 1×30 multiplexers 2 independent 1×30 multiplexers. Automatic temperature reference when used with screw terminal accessory (Model 3724-ST) Columns can be expanded through the backplane or isolated by relays 3723 3724 3730 3731 3732 3740 3750 3720-MTC-1.5, 3720-MTC-3 3720-MTC-1.5, 3720-MTC-3 3721-MTC-1.5, 3721-MTC-3 3721-MTC-1.5, 3721-MTC-3 3720-MTC-1.5, 3720-MTC-3 3721-MTC-1.5, 3721-MTC-3 3721-MTC-1.5, 3721-MTC-3 3723-ST, 3723-ST-1 3724-ST 3730-ST 3731-ST 3732-ST-C, 3732-ST-R 3740-ST 3750-ST 3791-KIT78-R 3791-KIT78-R 3790-KIT50-R 3790-KIT50-R 3791-KIT78-R 3790-KIT50-R 3790-KIT50-R 3791-CIT 3791-CIT 1.888.KEITHLEY (U.S. only) w w w.keithley.com Banks can be Relay actuation time connected of 0.5ms. Columns together via bank can be expanded configuration relays through the backplane or isolated to create a single 4×112 or dual 4×56 by relays matrix. Analog backplane relays also included for card to card expansion. Row expansion with 3732-ST-R accessory to create a dual 8×28 or single 16×28 matrix. Independent Latching electromechanical 28 Form C, 4 Form A 300 VDC/250 VAC (Form A) 2 A (Form C), 7 A (Form A) 32 general purpose independent channels. 3791-CIT A G R E A T E R M E A S U R E O F N/A N/A N/A N/A All-in-one card design. 40 bidirectional I/O. Four 32-bit counter/totalizers. 2 programmable analog (V or I) outputs. Plug-in cards for Series 3700 mainframes Plug-in Cards for Series 3700 Mainframes SWITCHING AND CONTROL Series 3700 C O N F I D E N C E 3 3720 Dual 1×30 Multiplexer Card 60 differential channels, automatic CJC w/3720-ST accessory • 60 two-pole channels or 30 four-pole channels for general purpose switching • Automatic CJC for temperature measurements when used with 3720-ST accessory Dual 1×30 multiplexer card • Analog backplane connection relays provide easy bank and card interconnections • 300V, 1A switched or 2A carry signal capacity; 60W, 125VA • Screw terminal connections provided with removable 3720-ST accessory • Relay closures stored in onboard memory • Latching electromechanical relays The Model 3720 offers two independent banks of 1×30 two-pole multiplexers. It is ideal for general purpose switching, including temperature measurements. The two banks can automatically be connected to the Series 3700 mainframe backplane and optional DMM through the analog backplane connection relays. This connection allows the mainframe to reconfigure the card to a single 1×60 two-pole multiplexer or to enable card-to-card expansion for even larger configurations. Other features of the Model 3720 include its ability to be reconfigured to coordinated four-pole operation for additional measurement flexibility. Furthermore, the Model 3720 supports thermo­ couple-type temperature measurements when used with the Model 3720-ST (screw terminal) ­accessory providing automatic cold junction compensation (CJC). The Model 3720 uses two 78-pin male D-sub connectors for signal connections. For screw terminal or automatic CJC, use the detachable Model 3720-ST accessory. Accessories Available Ordering Information 3720 Dual 1×30 Multiplexer Card 3720-MTC-1.5 3720-MTC-3 3720-ST 3791-CIT 3791-KIT78-R SWITCHING AND CONTROL 7401 4 1.888.KEITHLEY (U.S. only) w w w.keithley.com 78 Pin D-sub Female to Male Cable, 1.5m (5 ft.) 78 Pin D-sub Female to Male Cable, 3m (10 ft.) Screw Terminal Block (required for auto CJC thermocouple measurements) Contact Insertion and Extraction Tool 78 Pin Female D-sub Connector Kit (contains 2 female D-sub connectors and 156 solder-cup contacts) Type K Thermocouple Wire (100 ft.) A G R E A T E R Services Available 3720-3Y-EW-STD 1-year factory warranty extended to 3 years from date of shipment 3720-5Y-EW-STD 1-year factory warranty extended to 5 years from date of shipment C/3720-3Y-STD 3 (Z540-1 compliant) calibrations within 3 years of purchase* *Not available in all countries M E A S U R E O F C O N F I D E N C E 3720 Dual 1×30 Multiplexer Card 60 differential channels, automatic CJC w/3720-ST accessory HI LO HI Analog Backplane 1 LO (DMM Input) HI Analog Backplane 2 LO (DMM Sense) Channel 1 HI LO HI Analog LO Backplane 3 Channels 2–29 Channel 30 HI Analog LO Backplane 5 HI LO HI Analog LO Backplane 6 Multiplexer Bank 2 Output 2 Channel 31 HI LO HI Analog Backplane 1 LO (DMM Input) HI Analog Backplane 2 LO (DMM Sense) HI LO HI Analog LO Backplane 3 Maximum Carrying Current for Pulses Maximum Carrying Current (A) 20 100% duty 50% duty 25% duty 10% duty 5% duty 1 shot 1 0.1 1 10 100 Pulse Width (ms) 1000
3720-ST 价格&库存
很抱歉,暂时无法提供与“3720-ST”相匹配的价格&库存,您可以联系我们找货
3720-ST
    库存:1
    3720-ST
      库存:3
