7011-C
7011-C
    KEITHLEY
    KEITHLEY - 7011-C - Test Accessory, Multiplexer Card, Keithley 7001 & 7002 Switch Mainframes, 7011
7011-C 数据手册
7011-C, 7011-S, 40-channel Multiplexer Cards 7111-S Quad 1×10 Multiplexer Configuration Each of the four multiplexer outputs on this card connects to the 7001/7002 analog back­plane through removable jumpers for even greater flexibility. Two 7011 cards can be used to make a single 1×80 multiplexer with all intercard connections through the backplane. The 7011 mul­ti­plex­er outputs can also be connected to the rows of the 7012 via the backplane for row expansion. The Model 7111-S is a form C version of the 7011-S. The 7111-S is a low-­voltage, quad 1×10, single-pole form C multiplexer card. The 7111-S assembly consists of a screw terminal connector card and a relay card. External test circuits are wired directly to the screw terminals of the connector card. • Quad 1×10 multiplexer for 2-, 4-, or 8-pole operation • Connects to 7001/7002 backplane for easy expandability • 500nV, 100pA offsets Ordering Information 7011-C 7011-S 7111-S Quad 1×10 Multiplexer with 96-pin Mass Terminated Connector Board Quad 1×10 Multiplexer with Screw Terminal Connector Board Quad 1×10 Form C Multiplexer with Screw Terminal Connector Board Accessories Available SWITCHING AND CONTROL For 7011-C: 7011-KIT-R 7011-MTC-1 7011-MTC-2 96-pin Female Connector Kit 96-pin Mass Terminated Cable, Female to Female, 1m 96-pin Mass Terminated Cable, Female to Female, 2m For 7011-S and 7111-S: 7011-ST Extra Screw Terminal Connection Board Services Available 7011-C-3Y-EW 7011-S-3Y-EW 7111-S-3Y-EW 1-year factory warranty extended to 3 years from date of shipment 1-year factory warranty extended to 3 years from date of shipment 1-year factory warranty extended to 3 years from date of shipment These cards automatically configure the 7001 or 7002 mainframe. Two con­­nec­ tion options are available, screw terminal for maximum flex­i­­bil­i­t y or a single 96-pin quick disconnect con­nector. MULTIPLEX CONFIGURATION: Four in­de­pen­dent 1×10 2-pole multiplex banks or two ­in­de­pen­dent 1×10 4-pole multiplex banks. Ad­ja­cent banks can be connected together. Jump­ers can be removed to isolate any bank from the backplane. CONTACT CONFIGURATION: 2-pole Form A (Hi, Lo) (1-pole form C for 7111-S). CONNECTOR TYPE: 7011-C: 96-pin male DIN connector. 7011-S and 7111-S: Screw terminal, #16AWG maximum wire size, with 0.092 inch O.D. 28 conductors per card maximum. #22AWG typical wire size with 0.062 inch O.D. 88 conductors per card maximum. MAXIMUM SIGNAL LEVEL: DC Signals: 110V DC between any two pins, 1A switched. 30VA (re­sis­tive load). AC Signals: 125V rms and 175V AC peak, between any two pins, 1A switched, 60VA (resistive load). COMMON MODE VOLTAGE: 175V peak, any pin to chassis. CONTACT LIFE: Cold Switching: 108 closures. At Maximum Signal Levels: 105 closures. CHANNEL RESISTANCE (per conductor):
7011-C 价格&库存
很抱歉,暂时无法提供与“7011-C”相匹配的价格&库存,您可以联系我们找货
