237-BNC-TRX
237-BNC-TRX
    KEITHLEY
    KEITHLEY - 237-BNC-TRX - Test Accessory, 3 Lug Female Triax to Male BNC Connector with Guard Disconn...
237-BNC-TRX 数据手册
Model ACCESSORIES Connectors, adapters, and tools 213-CON Name Use With: Model Name Use With: Rear Panel Mating Connector 2200-20-5, 2200-30-5, 2200-32-3, 2200-60-2, 2200-72-1 4851 BNC Shorting Plug Instruments with BNC connectors 6171 3-slot Male to 2-Lug Female Triax Adapter 2-lug triax connectors 6172 2-slot Male to 3-Lug Female Triax Adapter 7065, 2500INT 7001-PNL Metal Plate 7001 7011-KIT-R Female 96-pin Connector Kit 7011-C, 7012-C, 7013-C, 7015-C, 7018-C 237-BAN-3A Triax to Banana Plug 4200-SCS, 7072, 7072-HV, DMMs 237-BNC-TRX 3-Lug Female Triax to Male BNC Connector with guard disconnected 4200-SCS, 6517A, 6517B, 7078-TRX cables 237-TRX-BAR 3-Lug Triax Female to Female Barrel Adapter 2635B, 2636B, 4200-SCS, 6482, triax interconnect 237-TRX-NG Triax Male-Female Adapter with guard 6517A, 6517B, 7072, 7072-HV disconnected 7011-ST Extra Screw Terminal Board 7011-S 237-TRX-T 3-slot Male to Dual 3-Lug Female Triax 4200-SCS, 7072, 7072-HV, Tee Adapter 7078-TRX cables 7012-ST Extra Screw Terminal Board 7012-S 7013-ST Extra Screw Terminal Board 7013-S 237-TRX-TBC 3-Lug Female Triax Bulkhead Connector 7072, 7072-HV, 7078-TRX cables 7015-ST Extra Screw Terminal Board 7015-S 7018-ST Extra Screw Terminal Board 7018-S 2182-325A Silver Solder for use with 2182-KIT 2182A 7072-TRT 707B, 708B 2182-KIT Low-Thermal Connector with Strain Relief (LEMO) Triax Removal Tool 2182A, SC-93 7074-CIT Contact Extraction Tool 7152-KIT, 7152-MTR 7078-CIT Contact Insertion/Extraction Tool 7078-KIT, 7078-MTR, 7152-KIT, 7152-MTR 7078-HCT Hand Crimping Tool for 7078-KIT, 7169-KIT 7078-KIT 7078-KIT Connector Kit 7071, 7071-4, 7074-D, 7078-MTR 7078-MTR Mass Terminated Receptacle, Bulkhead Mount 7071, 7071-4, 7078-KIT, 7078MTC 7078-TRX-BNC 3-slot Male Triax to BNC Adapter 4210-CVU, 4801, 6482, 6487, 6514, 6517A, 6517B, 7072, 7072-HV 7078-TRX-GND 3-slot Male Triax to BNC Adapter (guard removed) 4200-SCS, 4801, 6517A, 6517B, 7072, 7072-HV, Series 2600B 7078-TRX-TBC 3-Lug Female Triax Bulkhead Connector w/Cap 7078-TRX cables 2188 Low-Thermal Calibration Shorting Plug 2182A 2230G-30-1-JUMPER Shorting Jumper Series 2200 Power Supplies 2230GJ-30-1-JUMPER Shorting Jumper Series 2230 Power Supplies 2260-001 Accessory Kit Series 2260B 2260-002 IDC Tool Series 2260B 2260-003 Contact Removal Tool Series 2260B 2260-004 Accessory Kit Series 2260B 2260B-GPIB-USB GPIB-USB Adapter Series 2260B 2290-5-SHVBH 5kV SHV Male Bulkhead Connector 2290-5 2290-10-SHVBH 10kV SHV Female Bulkhead Connector 2290-10 2499-DIGIO Digital I/O Expansion Module SourceMeter SMU instruments 2500INT-SMA SMA Connector 2500INT integrating sphere 2500INT-FC/PC FP/PC Connector 2500INT integrating sphere 7152-HCT Hand Crimp Tool for 7152-KIT, 7152-MTR 7152-KIT, 7152-MTR 2500INT-FC/APC FP/APC Connector 2500INT integrating sphere 7152-KIT 6-Position M-Series Plug w/Contacts 7152, 7152-MTR 2600-KIT Screw Terminal Connector with Strain 2601B, 2602B (2 needed), 2611B, Relief and Cover 2612B (2 needed) 7152-MTR 6-Position M-Series Receptacle w/Sockets 7152, 7152-KIT, 7152-MTC-2, 7152-MTC-10 2600-TRIAX 3-Lug Triax Adapter 2601B, 2602B (2 needed), 2604B, 2611B, 2612B (2 needed), 2614B 7703-306A DB50 Male Connector Kit 7701, 7703, 7705, 7709 7709-308A DB25 Male Connector Kit 7701, 7707, 7709, Series 2600B 7712-SMA-N Female SMA to Male N-Type Adapter 7711, 7712 7755 50W Feed-Through Terminator RG 58 cable, 776, 3390 7788 50-pin D Subconnector Kit 7703, 7705, 77XX, modules with D sub connectors 7789 50-pin Male and 25-pin Male D-Shell Connector Kit 7701, 7709 7790 50-pin Male, 50-pin Female, and 25-pin 7701, 7703, 7705, 7707, 7709 Male IDC D-Shell Connector Kit 8610 Low Thermal Shorting Plug 2000, 2001, 2002, 2010 8620 4-Wire DMM Shorting Plug 2000, 2001, 2002, 2010, 2015, 2016, 2100, 2110, Series 2400, Series 2700, Series 3700A 8680 RTD Probe Adapter 2001, 2002, 2010, 2110 BG-18 Dual Banana to BNC Coaxial Adapter Series 2000, 2100, 2110, Series 2400, 2700, 2750 CAP-18 Protective Shield/Cap BNC, 2-lug triax connectors CAP-31 Protective Shield/Cap 3-lug triax connectors CA-573-3A1 4-Pin Round Interlock Cable, Unterminated 2657A-LIM-3 2657A-LIM-3 Low Interconnect Module 2657A 2657A-PM-200 200V Protection Module 2657A 3706-BKPL Analog Backplane Extender Board Series 3700A 3720-ST Screw Terminal Block 3720 3721-ST Screw Terminal Block 3721 3723-ST Screw Terminal Block 3723 3723-ST-1 Screw Terminal Block 3723 3724-ST Screw Terminal Block 3724 3730-ST Screw Terminal Block 3730 3731-ST Screw Terminal Block 3731 3740-ST Screw Terminal Block 3740 3750-ST Screw Terminal Block 3750 3790-KIT50-R 50-pin Female D-sub Connector Kit 3721, 3730, 3731, 3740, 3750 3791-CIT Contact Insertion and Extraction Tool 3720, 3722, 3723 3791-KIT78-R 78-pin Female D-sub Connector Kit 3720, 3723, 3724, 3732 3792-KIT104-R 104-pin Male D-sub Connector Kit 3722 3792-KIT104-R/F 104-pin Female D-sub Connector Kit 3722 1.888.KEITHLEY (U.S. only) www.keithley.com A Greater Measure of Confidence A Tektronix Company Connectors, adapters, and tools Connectors, Adapters, and Tools Name Use With: Model Name Use With: CS-400 DB25 Male Solder Cup CA-126-1 cable, 213 CS-1305 Interlock Connector 6517B CS-458 Interlock Connector Kit 6517-ILC-3 CS-1390 BNC Barrel, 4200-SCS BNC interconnect Male LEMO Triax to Female SMA Adapter 4200-SCS CS-565 CS-630 3-Lug Female Triax Bulkhead Connector 6487, 6517A, 6517B CS-1391 SMA Tee Adapter (Female-Male-Female) 4200-SCS CS-1423-3 Miniature Mating Connector 2635B, 2636B CS-631 3-Lug Male Triax Cable Mount Connector 4200-SCS, SC-22 cable CS-1479 SMA Male to BNC Male Adapter 4200-SCS CS-1592-2 Screw Terminal Plug 2651A CS-1626-2 Screw Terminal Receptacle 2651A CS-1629-8 Screw Terminal Connector 2651A CS-1638-12 Rear Panel Mounting Connector 2200-20-5, 2200-30-5, 2200-323, 2200-60-2, 2200-72-1 CS-1655-15 Rear Panel Mating Connector 2220-30-1, 2220J-30-1, 2230-30-1, 2230J-30-1 HV-CS-1613 High Voltage Triax Feed Through Connector/Barrel (female to female) 2657A, 2600-PCT-x, 4200-PCT-x TL-24 SMA Torque Wrench 4200-SCS, System 46, System 46T CS-701 BNC Tee Adapter (Female-Male-Female) 4200-SCS CS-719 3-Lug Triax Jack Receptacle 4200-SCS CS-846 Screw Terminal Test Lead Connector 230X, 2510, 2510-AT CS-1247 SMA Female to BNC Male Adapter 4200-SCS CS-1249 SMA Female to SMB Plug Adapter 4200-SCS CS-1251 BNC Female to SMB Plug Adapter 4200-SCS CS-1252 SMA Male to BNC Female Adapter 4200-SCS CS-1281 SMA Female to SMA Female Adapter 4200-SCS Model 213-CON Rear Panel Mating Connector: Quick disconnect, 12-screw terminal connector with handle. Model 237-BNC-TRX: Male BNC to 3-lug female triax adapter (guard dis­con­nect­ed). Terminates triax cable in BNC plug. High voltage rating for use with 7072-HV. Model 237-TRX-NG: 3-slot triax to 3-lug female triax adapter (guard removed) for non-guarded mea­sure­ments. High voltage rating for use with 7072-HV, etc. For use with: 2200-20-5, 2200-30-5, 2200-32-3, 2200-60-2, 2200-72-1 For use with: 4200-SCS, 6517A, 6517B, 7078TRX cables For use with: 6517A, 6517B, 7072, 7072-HV Connectors, adapters, and tools Model Item shipped may vary from model ­pictured here. Model 237-BAN-3A Triax to Banana Plug: Triax cable center conductor ter­mi­nat­ed in a safety banana plug (guard and shield open). For connecting DMMs and other banana jack instruments to a matrix or fixture. For use with: 4200-SCS, 7072, 7072-HV, DMMs Model 237-TRX-BAR: 3-lug triax barrel (female to female) for use with triax interconnect. For use with: 2635B, 2636B, 4200-SCS, triax interconnect Model 237-TRX-T: 3-slot male to dual 3-lug female triax tee adapter for use with 7078-TRX cables and 7072/7072-HV Semi­con­duc­­t­or Matrix Cards. High voltage rating for use with Model 6517B Electrometer. For use with: 4200-SCS, 6517A, 6517B, 7072, 7072-HV, 7078-TRX cables 1.888.KEITHLEY (U.S. only) www.keithley.com A Greater Measure of Confidence A Tektronix Company ACCESSORIES Connectors, adapters, and tools Connectors, Adapters, and Tools Model 237-TRX-TBC: 3-lug female triax bulk­ head connector with cap for assembly of custom panels and interface connections. High voltage rating for use with 7072-HV, etc. Uses miniature coax cable, not triax cable, at soldered end. Bulkhead is outer shield. For use with: 7072, 7072-HV, 7078-TRX cables Model 2188 Low-Thermal Calibration Shorting Plug: A low-resistance, low-­thermal shorting plug required to calibrate the Model 2182A Nanovoltmeter. Made of a LEMO connector with its pin connectors shorted together using copper wire and Sn/Ag4 silver solder. Model 2260-002: Simple IDC tool. For use with: Series 2260B For use with: 2182A Model 2182-325A: Silver solder for making ­connections in experiments with the Model 2182A. 20 ft roll. For use with: 2182A Model 2260-003: Contact removal tool. Model 2230G-30-1-JUMPER Shorting Jumper for CS-1655-15 Connector: Used to short a source and sense output when using a 2-wire output configuration. For use with: Series 2260B For use with: Series 2200 Power Supplies Model 2230GJ-30-1-JUMPER Shorting Jumper for CS-1655-15 Connector: Used to short a source and sense output when using a 2-wire output configuration. Model 2182-KIT Low-Thermal Connector with Strain Relief: Connector kit for building a custom input cable for the Model 2182A Nano­volt­ meter. Includes a low-thermal (LEMO) connector and a strain relief. For use with: Series 2200 Power Supplies Model 2260-004 Accessory Kit: Air filter, analog connector cover, analog control lock lever, M8-size output terminal bolts, washers and screws, and M4-size output terminal screws with washers. For use with: 2182A, SC-93 ACCESSORIES For use with: Series 2260B Model 2260-001: Accessory Kit: Analog control mating connector, pins, cover, and ground wire. For use with: Series 2260B 1.888.KEITHLEY (U.S. only) www.keithley.com A Greater Measure of Confidence A Tektronix Company Connectors, adapters, and tools Connectors, adapters, and tools Connectors, Adapters, and Tools For use with: Series 2260B Model 2499-DIGIO: Digital I/O expansion ­module that plugs onto the DB-9 connector of a SourceMeter® SMU instrument. Expands the three digital I/O lines of the SourceMeter to 16 lines. The SOT, EOT/BUSY, 5V, GND, and Interlock s­ ignals are passed through. Services Available: 1-year factory warranty extended to 3 years from date of shipment Model 2600-KIT: Screw terminal connector kit with extra screw terminal connector, strain relief, and cover for a single SourceMeter channel (two needed for use with Models 2602B, 2612B, and 2614B). For use with: 2601B, 2602B, 2604B, 2611B, 2612B, 2614B, 2651A For use with: SourceMeter SMU Instruments Model 2500INT-FC/ APC: FC/APC connector for 2500-INT Integrating Sphere. Model 2290-5-SHVBH: Panel mount connector for connecting a Model 2290-5 through a 2290-5SHV cable to an enclosure. For use with: 2290-5 Connectors, adapters, and tools Model 2260B-GPIB-USB Adapter: Provides a GPIB interface for the Series 2260B power supplies. For use with:  2500-INT Model 2500INT-FC/ PC: FC/PC connector for 2500-INT Integrating Sphere. For use with: 2500-INT Model 2600-TRIAX: Triax adapter for a single Series 2600B SourceMeter channel (two needed for use with Models 2602B and 2612B). For use with standard 3-lug triax cables. For use with: 2601B, 2602B, 2611B, 2612B Model 2500INTSMA: SMA connector for 2500-INT Integrating Sphere. For use with: 2500-INT Model 2290-10-SHVBH 10kV SHV Female Bulkhead Connector: Panel mount connector for connecting a Model 2290-10 through a 229010-SHV cable to an enclosure. Model 2657A-LIM-3: Low Interconnect Module for use with 2657A, HV triax cables (3kV rated). For use with: Series 2657A ACCESSORIES Connectors, adapters, and tools Connectors, Adapters, and Tools For use with: 2290-10 1.888.KEITHLEY (U.S. only) www.keithley.com A Greater Measure of Confidence A Tektronix Company 2657A-PM-200: 200V protection module to protect standard triax instruments from 2657A, standard and HV triax cables (3kV rated). Model 3721-ST: Screw Terminal Block. Required with the Model 3721 for automatic CJC thermocouple measurements. For use with: Series 2657A For use with: 3721 Model 3706-BKPL: Analog backplane extender board, 15-pin D-sub to terminal block. For use with: Series 3700A Model 3724-ST: Screw Terminal Block. For use with: 3724 Model 3730-ST: Screw Terminal Block. Model 3723-ST: Screw Terminal Block. Accessory for Model 3723 for two-pole applications. For use with: 3730 For use with: 3723 ACCESSORIES Model 3731-ST: Screw Terminal Block. Model 3720-ST: Screw Terminal Block. Required with the Model 3720 for automatic CJC thermocouple measurements. For use with: 3720 For use with: 3731 Model 3723-ST-1: Screw Terminal Block. Accessory for the Model 3723 for single-pole applications. For use with: 3723 1.888.KEITHLEY (U.S. only) www.keithley.com A Greater Measure of Confidence A Tektronix Company Connectors, adapters, and tools Connectors, adapters, and tools Connectors, Adapters, and Tools Model 3750-ST: Screw Terminal Block. For use with: 3750 For use with: 3720, 3723, 3724, 3732 For use with: 3732 Model 3790-KIT50-R: 50-pin female D-sub connector kit that contains two female D-sub connectors and 100 solder cup contacts. Use for assembly of custom cable and harnesses compatible with Series 3700A plug-in cards. Model 3732-ST-R: Screw Terminal Block. Enables screw terminal access and additional matrix sizes including: dual 8×28 (1W), single 8×28 (2W), and single 16×28 (1W). Model 3791-KIT78-R: 78-pin female D-sub connector kit that contains two female D-sub connectors and 156 solder-cup contacts. Use for assembly of custom cable and harnesses compatible with Series 3700A plug-in cards. For use with: 3721, 3730, 3731, 3740, 3750 Connectors, adapters, and tools Model 3732-ST-C: Screw Terminal Block. Enables screw terminal access and additional matrix sizes including: quad 4×28 (1W), dual 4×28 (2W), single 4×56 (2W), dual 4×56 (1W), and single 4×112 (1W). Model 3792-KIT104-R: 104-pin male D-sub connector kit that contains two male D-sub connectors with housings and 208 solder-cup contacts. Use for assembly of custom cable and harnesses compatible with Series 3700A plug-in cards. For use with: 3722 For use with: 3732 Model 3791-CIT: Contact insertion and extraction tool for assembly and maintenance of Series 3700A D-sub Connector kits. For use with: 3791-KIT78-R, 3791-KIT104-R Model 3740-ST: Screw Terminal Block. For use with: 3740 Model 3792-KIT104-R/F: 104-pin female D-sub connector kit that contains two female D-sub connectors with housings and 208 solder-cup contacts. Use for assembly of custom cables, harnesses, and DUT interface compatible with Series 3700A plug-in cards. For use with: 3722 1.888.KEITHLEY (U.S. only) www.keithley.com A Greater Measure of Confidence A Tektronix Company ACCESSORIES Connectors, adapters, and tools Connectors, Adapters, and Tools Connectors, Adapters, and Tools For use with: Instruments with BNC connectors Model 7001-PNL: Metal plate used to cover an empty card slot on the rear panel of a Model 7001. For use with: 7001 Model 7012-ST: Extra quick disconnect screw terminal board. One 7012-ST is included with each 7012-S. For use with: 7012-S Model 6171: 3-slot male to 2-lug female triax adapter. For use with: 2-lug triax connectors Model 7011-KIT-R: 96-pin female DIN con­nec­ tor with solder eyelets and strain relief. This kit can be used for assembly of custom cables to connect with the con­nec­tors on the 7011-C, 7012-C, 7013-C, 7015-C, and 7018-C switch cards. Also con­nects with the 7011-MTR bulkhead mount male connector. Model 7013-ST: Extra quick disconnect screw terminal board. One 7013-ST is included with each 7013-S. For use with: 7013-S For use with: 7011-C, 7012-C, 7013-C, 7015-C, 7018-C Model 6172: 2-slot male to 3-lug female triax adapter. For use in adapting Models 7065 and 250INT inputs to 3-slot triax plugs. Model 7015-ST: Extra quick disconnect screw terminal board. One 7015-ST is included with each 7015-S. For use with: 2500INT, 7065 ACCESSORIES For use with: 7015-S Model 7011-ST: Extra quick disconnect screw terminal board. One 7011-ST is included with each 7011-S. For use with: 7011-S 1.888.KEITHLEY (U.S. only) www.keithley.com A Greater Measure of Confidence A Tektronix Company Connectors, adapters, and tools Connectors, adapters, and tools Model 4851: BNC shorting plug. For use with: 7018-S Model 7078-CIT: Contact insertion and ex­trac­ tion tool for assembly and main­te­nance of 7078-MTC cables and connec­tors. For use with: 7078-KIT, 7078-MTR, 7152-KIT, 7152-MTR Model 7078-MTR: 38-pin female bulkhead mount re­cep­ta­cle with 40 contacts for custom interface and patch panels compatible with 7078-MTC and 7078-KIT. Requires 7078-HCT; recommend 7078-CIT. For use with: 7078-KIT, 7078-MTC, 7071, 7071-4 Connectors, adapters, and tools Model 7018-ST: Extra quick disconnect screw terminal board. One 7018-ST is included with each 7018-S. Model 7072-TRT: Triax removal tool used to connect or disconnect triax style connectors when clearance is limited making it difficult to mate or unmate a connector with your fingers. For use with: 707B, 708B Model 7078-HCT: Contact crimping pliers for as­sem­bly of cables and connectors using 7078-MTR or 7078-KIT. For use with: 7078-KIT Model 7078-TRX-BNC: 3-slot male triax to BNC adapter for use with 7072 Semi­con­duc­tor Matrix Card and 4801 cables. For use with: 4210-CVU, 4801, 6482, 6487, 6514, 6517A, 6517B, 7072, 7072-HV Model 7074-CIT: Contact extraction tool for removal of contacts from cables and con­nec­tors. For use with: 7152-KIT, 7152-MTR Model 7078-KIT: 38-pin male plug assembly with strain relief and 40 con­tacts for assembly of custom cable and harnesses compatible with Model 7071 8×12 Matrix Card, Model 7071-­ ­­ 4 Dual 4×12 Matrix Card, and 7078-MTR Mass Ter­ mi­nat­ed Receptacle. Re­quires 7078-HCT; recom­ mend 7078-CIT. For use with: 7071, 7071-4, 7074-D, 7078-MTR Model 7078-TRX-GND: 3-slot male triax to female BNC adapter (guard removed) for adapting non-guarded measurements to the Model 7072 or 7072-HV Semi­con­duc­tor Matrix Cards or 8006 or 8008 Test Fixtures. For use with: Series 2600B, 4801, 6517A, 6517B, 7072, 7072-HV 1.888.KEITHLEY (U.S. only) www.keithley.com A Greater Measure of Confidence A Tektronix Company ACCESSORIES Connectors, adapters, and tools Connectors, Adapters, and Tools Model 7078-TRX-TBC: 3-lug female triax bulkhead connector with cap for assembly of custom panels and in­ter­face connections. For use with: 7078-TRX Cables Model 7152-MTR: 6-pin bulkhead mount re­cep­ta­cle with contacts for custom in­ter­face and patch panels com­pat­i­­ble with 7152-MTC and 7152-KIT. Re­quires 7152 HCT; re­commend 7074-CIT and 7074-HCT. For use with: 7152, 7152-KIT, 7152-MTC-2, 7152-MTC-10 Model 7152-HCT: Contact crimping pliers for as­sem­bly of cables and con­nec­tor using 7152-MTR or 7152-KIT. Model 7709-308A: DB25 male connector kit ­(solder cup) with shell. For use with: 7701, 7707, 7709, Series 2600B Model 7712-SMA-N: Female SMA to male N-type adapter. For use with: 7152-KIT, 7152-MTR For use with: 7711, 7712 Model 7703-306A: DB50 male connector kit (solder cup) with shell. ACCESSORIES For use with: 7701, 7703, 7705, 7709 Model 7152-KIT: 6-pin plug assembly with strain relief and contacts for assembly of custom cable and harnesses compatible with Model 7152 4×5 Low Current Matrix Card and 7152-MTR Mass Ter­mi­nat­ed Re­cept­acle. Requires 7152-HCT recommend 7074-CIT and 7074-HCT. Model 7755 50W Feed-Through Ter­mi­na­tor: BNC-to-BNC adapter for ter­mi­nat­ing RG58 cable in its characteristic impedance. VSWR
237-BNC-TRX 价格&库存
很抱歉,暂时无法提供与“237-BNC-TRX”相匹配的价格&库存,您可以联系我们找货
237-BNC-TRX
    • 1+2644.57310
    库存:11
