2600-TLINK
2600-TLINK
    KEITHLEY
    2600-TLINK
2600-TLINK 数据手册
Model 2600-TLINK Digital I/O to TLink Adapter Cable Keithley Instruments, Inc. 28775 Aurora Road Cleveland, Ohio 44139 (440) 248-0400 www.keithley.com Introduction This document contains information on the Model 2600-TLINK Digital I/O to TLink adapter cable. Use this cable to connect the Model 260x SourceMeter® Instrument trigger link to digital I/O. Cable description As shown in Figure 1, the length of the cable is 3 feet. One connector is an 8-pin locking Micro-din connector, and the other connector is a 25 Pin D-Sub connector. Figure 2 contains the connector pinouts. Table 1 Cable specifications Characteristic Shield effectiveness (minimum) Temperature range Voltage rating Amperage rating Range/Value Specification 70–500MHZ 500–1000MHZ 20dB 10dB Operating -20° to 80°C Peak 42V Maximum 1.0 Amp Figure 1 Cable features 3 feet 8 Pin Male Micro-din Connector (Locking) 25 Pin D-Sub Connector (Male) PA-906 Rev. A / 04-05 Figure 2 Cable pinouts Schematic 3 4 1 2 6 7 5 8 1 2 3 4 5 6 7 8 NC NC NC NC NC NC NC NC NC NC NC NC NC NC 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 13 25 14 1 Connection Refer to Figure 3 for the typical instrument connector location. Refer to the specific instrument’s User’s Manual for additional connection information. WARNING Do not exceed the voltage rating for this cable. This cable is intended for use to transfer digital I/O information as a trigger link and is not intended as a power supply. Make sure both connections do not exceed the cables specifications. Failure to follow this warning may result in injury from electrical shock as well as damage to the equipment. Figure 3 Typical instrument connector WARNING:NO INTERNAL OPERATOR SERVICABLE PARTS,SERVICE BY QUALIFIED PERSONNEL ONLY. UL C S G HI CHANNEL A US LISTED SourceMeter 4ZA4 G G HI G S LO LO ! CAT I CHANNEL B ! S CAT I LO LO G HI G G ! DIGITAL I/O LINE FUSE SLOWBLOW 3.15A, 250V RS-232 MADE IN U.S.A. IEEE-488 (CHANGE IEEE ADDRESS WITH FRONT PANEL MENU) ! TSP-Link R CAUTION:FOR CONTINUED PROTECTION AGAINST FIRE HAZARD,REPLACE FUSE WITH SAME TYPE AND RATING. Model 2602 Digital I/O connection (25-pin D-sub Female) 2 S G HI LINE RATING 100-240VAC 50, 60Hz 240VA MAX.
2600-TLINK 价格&库存
很抱歉,暂时无法提供与“2600-TLINK”相匹配的价格&库存,您可以联系我们找货
