5805-12
5805-12
    KEITHLEY
    KEITHLEY - 5805-12 - Test Lead Set, Kelvin Clip, 4mm Banana Plugs x 2, Black, Red, 3.6 m
5805-12 数据手册
Test Leads and Probes Model 1600A 1651 1681 1751 1752 1754 2187-4 2260-008 2260B-EXTERM 2600-BAN 3706-BAN 3706-TLK 5804 5805 5805-12 5806 5807-7 5808 5809 6517-RH 6517-TP 7401 8605 8606 8608 8681 CA-109A Name High Voltage Probe 50-Ampere Shunt Clip-On Test Lead Set Safety Test Leads Premium Safety Test Lead Kit Safety Universal Test Lead Kit Low Thermal Test Lead Kit Test Lead Set Extended Terminal Test Leads Banana Test Leads/Adapter Cable Banana Test Leads/Adapter Cable Test Lead Kit General-Purpose, 4-Terminal Test Lead Set Kelvin Probes, 0.9m (3 ft) Kelvin Probes, 3.6m (12 ft) Kelvin Clip Lead Set, 0.9m (3 ft) Helical Spring Point Test Leads, 2.1m (7 ft) Single-pin Kelvin Probe Kelvin Clip Lead Set Humidity Probe with Extension Cable Thermocouple Bead Probe Thermocouple Wire Kit, 30m (100 ft), Type K High Performance Modular Test Leads High Performance Modular Probe Kit High Performance Clip Lead Set Low Cost RTD Test Lead Set for Output Connections Use With: DMMs DMMs DMMs All DMMs, Series 2400 All DMMs, Series 2400 All DMMs, Series 2400 2182A, 622x Current Sources Series 2260B Series 2260B 2601B, 2602B, 2611B, 2612B Series 3700A Mainframes Series 3700A Mainframes Series 2400, 2750, DMMs Series 2400, 2750, DMMs Series 2400, 2750, DMMs Series 2400, 2750, DMMs Series 2400, 2750, DMMs 2700, 2701, 2750, Series 2400, DMMs 2700, 2701, 2750, Series 2400, DMMs 6517A, 6517B 6517A, 6517B 2001-TCSCAN, 2110, 3720, 3721, 3724, 7057A, 7700, 7706, 7708 All DMMs, Series 2400 All DMMs, Series 2400, Series 2600B, Series 3700A 2450, Series 2400, DMMs 2001, 2002, 2010 DMMs (with 8680) 2000-SCAN, 2001-SCAN, 2001-TCSCAN ACCESSORIES MAXIMUM INPUT: 40kV DC or 28kV AC, 50/60Hz. INPUT RESISTANCE: 1000MW. DIVISION RATIO: 1000:1 (into 10MW). For use with: DMMs Model 1681 Clip-On Test Lead Set: Two 1.2m (48 in) leads terminated with banana plugs and spring action clip-on probes. For use with: DMMs Item shipped may vary from model ­pictured here. Model 1751 Safety Test Leads: 91.4cm (36 in) test lead set supplied with each Model 175A and 197A. Finger guards and shroud­ed banana plugs help minimize the chance of making contact with live circuitry. For use with: All DMMs, Series 2400 SourceMeter® SMU Instruments Item shipped may vary from model ­pictured here. Model 1600A High Voltage Probe Item shipped may vary from model ­pictured here. Model 1651 50 Ampere Shunt: ­External 0.001W ± 1%, 4-terminal shunt; extends current mea­sur­ing capability of Keithley DMMs to 50A. CABLE LENGTH: 1.4m (56 in). For use with: DMMs Model 1752 Premium Safety Test Lead Kit: Includes two banana leads with safety shrouds on both ends, two fully insulated alligator clips, two fully insulated needle probes, and two spring-action clip-on probes with safety blocks. Carrying case not included. For use with: All DMMs, Series 2400 SourceMeter SMU Instruments 1.888.KEITHLEY (U.S. only) www.keithley.com A Greater Measure of Confidence A Tektronix Company Technical information: Source Measurement Unit (SMU) Instruments Test leads and probes TEST LEADS AND PROBES SELECTOR GUIDE Model 1754 Universal Test Lead Kit: 10-piece test lead kit with interchangeable plug-in accessories. Kit includes: 1 set of test leads, 91.4cm (36 in), 1 red and black; 2 spade lugs, 2 standard banana plugs, 2 hooks, and 2 min­ia­ture alligator clips with boots. For use with: All DMMs, Series 2400 SourceMeter SMU Instruments Model 2600-BAN: 1m (3.3 ft) banana test leads/adapter cable for a single Series 2600B SourceMeter channel (two needed for use with Model 2602B and 2612B). Provides safety banana connections to Hi, Sense Hi, Lo, Sense Lo, and guard. Model 3706-BAN: 1.4m (4.6 ft) banana test leads/adapter cable for Model 3706A mainframe with high performance multimeter option. Provides direct connection to high performance multimeter utilizing rear panel backplane connector. Safety banana connections to HI, LO, Sense HI, Sense LO, and AMP. For use with: Series 3700A mainframes For use with: 2601B, 2602B, 2611B, 2612B Test leads and probes Item shipped may vary from model ­pictured here. Model 3706-TLK Test Lead Kit: Includes 3706BAN banana test leads/adapter cable and plugin test lead accessories. Test lead accessories include: 4 spring hook probes, 2 needle test probes, 4 safety plug adapters, and carrying case. Model 2260-008: Test lead set with lugs, 10AWG, 122m (48 in), red/blue wire pair with #10 terminal lugs on each end. Model 2187-4 Low Thermal Test Lead Kit: Includes an input cable with banana terminations, banana extensions, sprung-hook clips, alligator clips, needle probes, and spade lugs to connect the Model 2182A to virtually any DUT. The kit is also used to connect the Model 2182A directly to the Model 622X guard to improve response time for pulsed measurements or to reduce errors when measuring high impedance devices. For use with: 2182A, 6220, 6221, 6220/2182A, 6221/2182A For use with: Series 3700A mainframes For use with: Series 2260B Item shipped may vary from model ­pictured here. Model 2260B-EXTERM: Extended Terminal Test Leads, 0.7m (28 in.), and terminal box to bring outputs to the front of the instrument or another location. Magnetic base attaches to side of the instrument. For use with: Series 2260B Model 5804 Test Lead Set: Designed to be used with Keithley instruments that measure 4-terminal resistance. Contains: 2 test leads, 0.9m (36 in), red and black; 2 test clips, red and black; 2 plunger clip adapters, red and black; 2 alligator clips with boots (accept standard test probe tip); 2 alligator clips with boots (barrels accept standard banana plugs). For use with: Series 2400 SourceMeter® SMU Instruments, 2750, DMMs 1.888.KEITHLEY (U.S. only) www.keithley.com A Greater Measure of Confidence A Tektronix Company ACCESSORIES Technical information: Source Measurement Unit (SMU) Instruments Test Leads and Probes Model 5805 Kelvin Probes: 2 spring-loaded test probes, red and black, 0.9m (36 in) with banana plug termination. De­signed to be used with Keithley in­stru­ments that measure 4-terminal re­sis­tance and in-circuit current. 1⁄8 -in spacing between pin tips. A package of 8 re­place­ment contacts (P/N CS-551) is available. Model 5805-12: Similar to 5805 but 3.6m (12 ft) in length. For use with: Series 2400 SourceMeter SMU Instruments, 2750, DMMs Model 5806 Kelvin Clip Lead Set: 2 clip test leads, red and black, 0.9m (36 in) with banana plug ter­mi­na­tion. Designed to be used with Keithley instruments that meas­ure 4-terminal re­sis­tance. Maximum jaw opening ½ in. A package of 8 r­ eplace­ment elastic bands (P/N 5806-306B) is ­available. ACCESSORIES For use with: Series 2400 SourceMeter SMU Instruments, 2750, DMMs Model 5807-7 Helical Spring Point Test Leads: Two excellent Kelvin test probes for Keithley in­stru­ments that measure 4-terminal re­sis­tance. The probes have point­ed tips that rotate when pressure is exerted on the handle. Good contact is assured, and the handle can be held at any angle to the mea­sure­ment surface. The lead wires ter­mi­nate in banana plugs. Lead wire length: 2m (7 ft). Model 5809 Low Cost, Kelvin Clip Lead Set: Two 0.94m (37 in) long probes with alligator style clips, each with opposing blade source and sense connections to color coded standard safety banana plugs. Designed for applications requiring Kelvin connection to wires, axial leaded components, and other terminals able to be clipped onto. The miniature blade design accommodates narrow available width applications as well as general lighter duty applications. The maximum jaw opening is 9.14mm (0.36 in) and the blade width is 2.92mmm (0.115 in). For use with: Series 2400 SourceMeter SMU Instruments, 2750, DMMs For use with: 2700, 2701, 2750, Series 2400, DMMs Model 5808 Low Cost, Single Pin, Kelvin Probes: Two 1.17m (46 in) long, single fixed pin probes with source and sense leads per probe and color coded standard safety banana plugs. Designed for applications requiring Kelvin resistance measurements with the convenience of a single point of circuit contact. The Kelvin connection at the base of each probe pin results in very low resistance errors, eliminating all wire and probe body resistance. For the highest precision sensing applications, use the Model 5805, 5806, or 5809 for complete control over sensing point placement. Model 6517-RH Humidity Probe: The 6517-RH comes with a 3m (10 ft) extension cable and is designed to be used with the 6517B Electrom­ eter. The 6517-RH measures the relative humidity of the testing environment. OPERATING TEMPERATURE RANGE: –10°C to +60°C OPERATING HUMIDITY RANGE: 0 to 100% RH MEASURING RANGE: 10 to 90% RH TEMPERATURE DEPENDENCE:
5805-12 价格&库存
很抱歉,暂时无法提供与“5805-12”相匹配的价格&库存,您可以联系我们找货
    • 1+6556.11443
    库存:2
