7078-TRX-10
7078-TRX-10
    KEITHLEY
    KEITHLEY - 7078-TRX-10 - Test Cable Assembly, Triax Cable
7078-TRX-10 数据手册
Cables LENGTH Description Type From To m ft USE WITH: 7078-DIN 707A Master/Slave Twisted pair (9)  8-pin DIN 8-pin DIN 1.8 6 707A 7078-MTC-5 Mass Terminated Assembly Twisted pair (12) 38-pin connector 38-pin connector 1.5 5 7071, 7071-4, 7074-D 7078-MTC-20 Mass Terminated Assembly Twisted pair (12) 38-pin connector 38-pin connector 6.1 20 7071, 7071-4, 7074-D 7078-TRX-1 Low Noise Triax 3-slot male triax 3-slot male triax 0.3 1 2635B, 2636B, 6482, 6487, 6514, 6517A, 6517B, 7072, 7174A 7078-TRX-3 Low Noise Triax 3-slot male triax 3-slot male triax 0.9 3 2635B, 2636B, 6482, 6487, 6514, 6517A, 6517B, 7072, 7174A 7078-TRX-5 Low Noise Triax 3-slot male triax 3-slot male triax 1.5 5 2635B, 2636B, 6482, 6487, 6514, 6517A, 6517B, 7072, 7174A 7078-TRX-10 Low Noise Triax 3-slot male triax 3-slot male triax 3 10 2635B, 2636B, 6482, 6487, 6514, 6517A, 6517B, 7072, 7174A 7078-TRX-12 Low Noise Triax 3-slot male triax 3-slot male triax 4 12 2635B, 2636B, 6482, 6487, 6514, 6517A, 6517B, 7072, 7174A 7078-TRX-20 Low Noise Triax 20 2635B, 2636B, 6482, 6487, 6514, 6517A, 6517B, 7072, 7174A Low Noise Triax 3-slot male triax 3-slot triax 6.1 7078-TRX-6IN 3-slot male triax 3-slot male triax 0.15 0.5 6430 7152-MTC-2 Low Noise Matrix Expansion Triax (5) 6-pin M-series coax 6-pin M-series coax 0.6 2 7152 7152-MTC-10 Low Noise Matrix Expansion Triax (5) 6-pin M-series coax 6-pin M-series coax 3 10 7152 7152-TRX-10 Low Noise M-Series to Triax Triax (5) M-series connector 3-slot triax (5) 3 10 7152, 8006 7153-TRX Low Noise M-Series to Triax Triax (5) M-series connector 3-slot triax (5) 2 6 7153 7173-50-CSEP 4-cable Set Coax SMB female BNC male 0.6 2 7705-MTC-2 Mass Terminated Assembly Twisted pair (25) D-sub male D-sub female 2 6.6 7711-BNC-SMA 5 SMA to BNC Cables Coax SMA Male BNC Female 0.15 0.5 7711 7712-SMA-1 SMA Cables Coax SMA Male SMA Male 1 3.3 7711, 7712, System 46, System 46T 7754-3 BNC Coax BNC Male Alligator clips 8007-GND-3 Safety Ground Wire Single wire Crimp lug Crimp lug 8542-301 LIV Cable Multiple conductor DB9 female Multiple terminations: Triax (2500), 2 dual bananas (24XX) GND wire 7173-50 0.9 3 Instruments with 2-slot BNC connectors 3 10 8007 1.8 6 2500, Series 2400, System 25, 8544, 8544-TEC 8607 1kV Test Cables Single wire (2) Safety banana Safety banana 1 3.3 CA-18-1 Shielded Coax Dual banana plug Dual banana plug 1.2 4 Bind­ing post inputs CA-19-2 CA-126-1A RG58 Digital I/O RG58 Shielded BNC male DB25 male BNC male DB25 female 1.5 1.5 5 5 Series 2600B, Series 3700A CA-180-3A Crossover Cable Twisted pair RJ45 RJ45 3 10 Series 2600B, 2701, 3390, Series 3700A, 6221, all TSP-enabled instruments CA-321-1 Temperature Control Cable Multiple conductor DB15 female 1.8 6 2510, 8544 CA-322-1 Dual Temperature Control Cable Multiple conductor DB15 female 1.8 6 2510, 8544, 8544-TEC CA-404B CA-405B CA-406B CA-446A CA-447A CA-451A CA-452A CA-557-1A CA-557-2A CA-557-3 RG188 RG188 RG188 Cable Assembly Cable Assembly RG188 RG188 Cable Assembly Cable Assembly Cable Assembly Coax Coax Coax Coax Coax Coax Coax Multiple conductor Multiple conductor Multiple conductor SMA male SMA male SMA male SMA male SMA male SMA male SMA male 8-pin receptacle 8-pin receptacle 8-pin receptacle SMA male SMA male SMA male SMA male SMA male SMA male SMA male 8-pin receptacle 8-pin receptacle 8-pin receptacle 2 0.15 0.33 3 1.5 0.108 0.203 1 2 3 CA-558-x Interlock Cable Twisted pair (2) 25-pin D-sub 3-pin 1, 2, 3 CA-559-0A CA-559-2A CA-560-0A CA-560-2A CA-561-0A CA-561-2A Black Banana Jumper Red Banana Jumper Banana Plug Jumper Cable Banana Plug Jumper Cable Black Banana Jumper Red Banana Jumper Black Safety Banana Plug Jumper Cable Red Safety Banana Plug Jumper Cable BNC to Banana Jumper Black Banana Jumper Red Banana Jumper Protective Earth Ground Jumper Jumper Jumper Jumper Jumper Jumper Banana Banana Banana Banana Banana Banana Banana Banana Banana Banana Banana Banana 0.102 0.102 0.203 0.203 0.203 0.203 6.5 0.5 1.08 9.8 5 0.35 8 in. 3.3 6.6 10 3.3, 6.6, 10 4 in. 4 in. 8 in. 8 in. 8 in. 8 in. Jumper Banana Banana 0.254 10 in. 8010 Jumper Banana Banana 0.254 10 in. 8010 Jumper Jumper Jumper Safety Bnc Banana Banana Eye lug Banana Banana Banana Eye lug CA-562-0B CA-562-2B CA-563C CA-567-0A CA-567-2A CA-568-xA 8-position Phoenix (CS-846 equivalent) Y cable to two 8-position Phoenix (CS-846) 0.241 9.5 in. 0.203 8 in. 0.203 8 in. 0.3, 0.45, 3 1, 1.5, 10 Cables 7703, 7705, 7707, 7709 2410, 6487, 6517A, 6517B 4200-SCS 4200-SCS 4200-SCS 4200-SCS 4210-CVU 4210-CVU 4200-SCS 4200-SCS 2651A, 8011 2651A, 8011 2651A, 8011 Series 2600B, 2657A 8010 8010 8010 8010 8010 8010 8010 8010 8010 8010 1.888.KEITHLEY (U.S. only) www.keithley.com A Greater Measure of Confidence ACCESSORIES Cables    TERMINATIONS Model
7078-TRX-10 价格&库存
很抱歉,暂时无法提供与“7078-TRX-10”相匹配的价格&库存,您可以联系我们找货
