09075.0601-00
09075.0601-00
    MARQUARDT(马夸特)
    MARQUARDT - 09075.0601-00 - Slide Switch, DPDT, On-On, Through Hole, 9075
09075.0601-00 数据手册
Slide switches 9075.0601 Product number Business unit Product family Actuation type Output Switching function Material fixed contact Contact system Number of poles connections Rating IEC Contact resistance (new condition) Insulation resistance (new condition) Voltage strength at 250 V Ambient temperature Actuators and additional actuators Housing description Connection surface Contact material Contact type Miscellaneous Type of fastening 9075.0601 Switches, Sensors & Controls Slide switches direct catalogue miniature switch Changeover switch (SPDT) CuZn gold-plated Electrical life 2 - pole PCB terminal, sealed with epoxy resin, angled ≤ 0.4V A 28 V 50000 < 50 mOhm > 500 MOhm small contact distance -25 °C ... +70 °C > 500 V slide: PA, light grey cover: PA, black base plate: PA glass fiber-reinforced, gray, with additional fastening bracket of CuSn bearing connection gold plated external connection gold plated CuSn gold-plated slide contact actuating travel 2.5 mm pcb assembly Technical changes reserved. Dimensions are not binding. Detailed specifications available on request.
09075.0601-00 价格&库存
很抱歉,暂时无法提供与“09075.0601-00”相匹配的价格&库存,您可以联系我们找货
