1881.1105-00
1881.1105-00
    MARQUARDT(马夸特)
1881.1105-00 数据手册
SERIES 1881 - SINGLE-POLE ROUND ROCKER SWITCHES SLIDE SWITCHES TOGGLE SWITCHES PUSHBUTTON SWITCHES ROCKER SWITCHES TO 12 (4) A 250 V AC ON REQUEST PRODUCT FE ATURES Attractive round rocker switch Other colors High mechanical rating with at least 100 000 switching cycles Other printing variants Variants with IP 51 Cable assembly Low depth with 18.7 mm Gold-plated contacts for low voltages Appliance cut-out with 20 mm Other switching functions (e.g. 1888 - middle off) Other terminal variants (e.g. PCB) SENSORS MICRO-SIGNAL SWITCHES SNAP-ACTION SWITCHES TACT AND KEY SWITCHES FOOT SWITCHES ROTARY SWITCHES Painted variants | 40 PVC-protection cap Mechanical life endurance 10E4 Operating force 3N Inrush current (capacitive) 70 A Contact resistance (new condition) < 100 mOhm (1 A 12 V DC) Insulation resistance (new condition) > 100 MOhm (500 V DC) Proof tracking 250 PTI Protection type IP 40 and IP 51 (product-dependent) Ambient temperature terminal side -20 °C ... +100 °C actuating side -20 °C ... +55 °C Flammability UL 94 V-2 UL 94 V-0 (product-dependent) Glow wire test temperature 850 °C Material PA PA silver plated actuator housing terminals Plug force of the terminals < Approval marks 3/ 1 80 N Suitable for appliances of protection class II / 1US C / 2US C SERIES 1881 - SINGLE-POLE ROUND ROCKER SWITCHES ROCKER SWITCHES IP 40 1881.1104 4.8 > 3 Ag IP 40 1881.1105 4.8 > 3 Ag IP 40 1881.1106 4.8 > 3 Ag IP 40 1881.1108 4.8 > 3 Ag IP 51 1881.1109 4.8 > 3 Ag IP 40 1881.1111 4.8 > 3 Ag IP 40 1881.1112 1 mm longer 4.8 > 3 Ag IP 51 with swtiching system cover 4.8 > 3 Ag IP 51 with swtiching system cover opening terminal 1b closed 1883.1105 4.8 > 3 Ag IP 40 1883.1106 4.8 > 3 Ag IP 40 TOGGLE SWITCHES SLIDE SWITCHES ROTARY SWITCHES with swtiching system cover Normally open contact (SPNO) 1881.1209 PUSHBUTTON SWITCHES Ag ON / OFF switch (SPST) Stock version Actuator 3 Miscellaneous Contact material EN 60335 cap. 30 conform “G” Contact distance in mm > Terminal type 4.8 Housing color 1881.1103 single-pole Actuator color / printing Terminal description 12 (4) A 250 V AC 1E4 10 (4) A 250 V AC 1E4 8 (8) A 250 V AC 5E4 6 (4) A 250 V AV 5E4 15 A 250 V AC 1 1/2 HP 15 A 125 V AC 3/4 HP 10 A 250 V AC 1/2 HP 10 A 125 V AC 1/3 HP TO 12 (4) A 250 V AC SENSORS MICRO-SIGNAL SWITCHES SNAP-ACTION SWITCHES TACT AND KEY SWITCHES FOOT SWITCHES Changeover switch (SPDT) 41 | SERIES 1881 - SINGLE-POLE ROUND ROCKER SWITCHES ø 23 19.7 7.8 11.7 18.7 11.6 2 2 15.4 3.5 15.4 3.4 ROCKER SWITCHES TO 12 (4) A 250 V AC 7 DIN 46 244-A4.8-0.8 SLIDE SWITCHES 4.8 11.8 ø19.8 ø 19.8 Quick-connect terminal 4.8 x 0.8 Basic type 1881 Quick-connect terminal 4.8 x 0.8 1 mm longer X = wall thickness X 0.75 ... 1.25 1.25 ... 2 2 ... 3 Ø 20.3 20.8 21.1 Transparent PVC-protection cap. Serves as dust and water protection of the actuation side. ROTARY SWITCHES Protection cap on request 4.2 18.2 8 Ø 24.5 11.2 FOOT SWITCHES TACT AND KEY SWITCHES SNAP-ACTION SWITCHES MICRO-SIGNAL SWITCHES SENSORS | 42 7 11.8 TOGGLE SWITCHES PUSHBUTTON SWITCHES 4.8 18.6 SERIES 1855 - MINIATURE DOUBLE-POLE ROCKER SWITCHES ON REQUEST Illuminated rocker switches Other colors Different lamp variants Other printing variants Powerful with 50 000 mechanical switching cycles Other terminal types Caulked terminals for reliable plugging of the receptacles Other lamp variants ROTARY SWITCHES Cable assembly SLIDE SWITCHES PRODUCT FE ATURES TOGGLE SWITCHES PUSHBUTTON SWITCHES ROCKER SWITCHES TO 4 (1) A 250 V AC Mechanical life endurance 5E4 Contact resistance (new condition) < 100 mOhm (1 A 12 V DC) terminal side -20 °C ... +85 °C actuating side -20 °C ... +55 °C Flammability UL 94 V-2 Glow wire test temperature 850 °C Material PA PA silver plated actuator housing terminals Plug force of the terminals < Approval marks 3/ 1 80 N Suitable for appliances of protection class II /2 TACT AND KEY SWITCHES IP 40 Ambient temperature SNAP-ACTION SWITCHES Protection type MICRO-SIGNAL SWITCHES 250 PTI SENSORS Proof tracking FOOT SWITCHES Insulation resistance (new condition) > 100 MOhm (500 V DC) 43 |
1881.1105-00 价格&库存
很抱歉,暂时无法提供与“1881.1105-00”相匹配的价格&库存,您可以联系我们找货
