5000.0101-01
5000.0101-01
    MARQUARDT(马夸特)
5000.0101-01 数据手册
SERIES 5000 - ROUND PUSHBUT TON SWITCHES ON REQUEST Attractive, round pushbutton switch Other colors Efficient contact system at least 200 000 mechanical switching cycles Actuator printing Variants with sealing cap for IP 54 dust and water protection Cable assembly Snap-on for greater wall thickness 20E4 Proof tracking 250 PTI Protection type IP 40 IP 54 (in variants with sealing cap) Ambient temperature terminal side -20 °C ... +85 °C actuating side -20 °C ... +55 °C Flammability UL 94 V-2 Glow wire test temperature 850 °C Material PA glass fiber-reinforced PA glass fiber-reinforced silver plated Approval marks 3/ 1 64 N Suitable for appliances of protection class II /2 SNAP-ACTION SWITCHES < MICRO-SIGNAL SWITCHES Plug force of the terminals SENSORS actuator housing terminals TACT AND KEY SWITCHES Mechanical life endurance FOOT SWITCHES ROTARY SWITCHES Appliance cut-out with diameter 16 mm, alternatively with fixing pin SLIDE SWITCHES PRODUCT FE ATURES TOGGLE SWITCHES PUSHBUTTON SWITCHES ROCKER SWITCHES FOR AT LE AST 200 000 MECHANICAL SWITCHING CYCLES 99 | SERIES 5000 - ROUND PUSHBUT TON SWITCHES Contact material Pretravel max. in mm Total travel / stroke in mm 2.0 + 0.4 4.0 5000.0103 2.8 > 3 Ag 2.0 + 0.4 4.0 5000.0104 2.8 > 3 Ag 2.0 + 0.4 4.0 5000.0211 2.8 > 3 Ag 2.0 + 0.4 4.0 fixing pin 5000.0212 2.8 > 3 Ag 2.0 + 0.4 4.0 fixing pin 5000.0501 2.8 > 3 Ag 2.0 + 0.4 4.0 fixing pin with IP 54 sealing cap 7.2 7.2 ø21 Quick-connect terminal 2.8 x 0.8 Basic type 5000 SENSORS MICRO-SIGNAL SWITCHES 7.2 SNAP-ACTION SWITCHES R 4 8 2.4+0.1 ø16+0.05 10 Ø 16.0 +0.05 21.5 X 1.4 ... 1-7 11±0.05 6.2 ø17 17.8±0.1 ø21 Quick-connect terminal 2.8 x 0.8 (with fixing pin) 5000.0211 and 5000.0212 ø16+0.05 R 12.2 ø21 Quick-connect terminal 2.8 x 0.8 (with fixing pin and IP 54 sealing cap) 5000.0501 ø20 X = wall thickness 17.8±0.1 4 1.3-0.15 TACT AND KEY SWITCHES FOOT SWITCHES 8 2.4±0.1 10 ø16+0.05 6.2 11±0.05 21.5 10 6.2 ø17 21.5 ø20 ø11 ø20 4 | 100 Stock version Terminal type PUSHBUTTON SWITCHES TOGGLE SWITCHES Normally open contact (SPNO) ROTARY SWITCHES SLIDE SWITCHES Miscellaneous Contact distance in mm Ag 2 A 250 V AC 1/10 HP 3 4 A 125 V AC 1/10 HP > 4 (2) A 250 V AC 5E4 2.8 single-pole Housing color 5000.0101 Actuator color / printing Terminal description ROCKER SWITCHES FOR AT LE AST 200 000 MECHANICAL SWITCHING CYCLES
5000.0101-01 价格&库存
很抱歉,暂时无法提供与“5000.0101-01”相匹配的价格&库存,您可以联系我们找货
