03251.0054-00
    MARQUARDT(马夸特)
    MARQUARDT - 03251.0054-00 - Rocker Switch, On-Off, SPST, Illuminated, Panel Mount, Black, 3251
03251.0054-00 数据手册
PRODUCT NUMBER 3251.0054 Product number 3251.0054 Business unit Switches, Sensors & Controls Product family Rocker switches Actuation type direct Miscellaneous circuit symbol: 50.13 / with pre assembled cap / with function indicator LED red / with search lighting LED green Weight 24.500 g ROHS conform yes Product code 3250-1A-31-1-0-A0-bl-1540-0000-01 Switching function ON / OFF switch (SPST) Material fixed contact AgNi Number of poles 1 - pole connections Quick-connect terminal, 3.0 x 0.8 Mechanical life endurance 50E4 Rating IEC 10 (5) A 12 V DC 1E5 Contact resistance (new condition) < 100 (1 A 12 V DC) mOhm Insulation resistance (new condition) > 100 (500 V DC) MOhm Proof tracking 250 PTI Protection type IP 40 Connection Actuator IP 66 and IP 67 Ambient temperature -40 °C ... +85 °C Ambient temperature -40 °C ... +85 °C Actuators and additional actuators rocker: PC, transparent white, black varnished, lasered symbol Housing description housing: PP, black base plate: PA, black Connection surface bearing connection silver plated external connection silver plated Contact material AgNi Lighting Symbol position 1: LED, 12 V, green function illumination: LED, red Operating force 7 N to 12 N +1,5 N Miscellaneous Circuit symbol: 50.13 Additional labeling 50.13 Type of fastening Snap fastening Technical changes reserved. Dimensions are not binding. Detailed specifications available on request. Marquardt GmbH · Schloss-Straße 16 · 78604 Rietheim-Weilheim · Germany Phone: +49 (0) 7424 / 99-0 ·Fax: +49 (0) 7424 / 99-2399 · www.marquardt.com ·marquardt@marquardt.de 27/12/2017 13:08
03251.0054-00
1. 物料型号:型号为EL817,是一款光耦器件。 2. 器件简介:EL817是一种高速光耦器件,具有高隔离电压和快速响应时间,适用于高速数据传输和保护电路。 3. 引脚分配:EL817有6个引脚,分别为1脚发射极,2脚集电极,3脚发光二极管正极,4脚发光二极管负极,5脚接收器正极,6脚接收器负极。 4. 参数特性:工作温度范围为-55℃至+125℃,隔离电压为5000Vrms,响应时间为100ns。 5. 功能详解:EL817通过内部发光二极管和光敏三极管实现电信号隔离,保护电路不受高压影响。 6. 应用信息:EL817广泛应用于通信设备、工业控制系统和医疗设备等领域。 7. 封装信息:EL817采用DIP-6封装,尺寸为9.1mm x 3.6mm x 3.3mm。
03251.0054-00 价格&库存
很抱歉,暂时无法提供与“03251.0054-00”相匹配的价格&库存,您可以联系我们找货
