09041.0201-00
    MARQUARDT(马夸特)
    MARQUARDT - 09041.0201-00 - Toggle Switch, On-Off-On, DPDT, Non Illuminated, Panel Mount, 5 A
09041.0201-00 数据手册
Toggle switches 9041.0201 Product number Business unit Product family Actuation type Packing unit ROHS conform Output Switching function Material fixed contact Contact system Number of poles connections Mechanical life endurance Rating IEC Contact resistance (new condition) Insulation resistance (new condition) Voltage strength at 250 V Ambient temperature Actuators and additional actuators Housing description Connection surface Contact material Contact type Miscellaneous Type of fastening 9041.0201 Switches, Sensors & Controls Toggle switches direct 100 yes catalogue miniature switch Changeover switch with OFF position in the center (DPDT - Center OFF) Ag Electrical life 50000 2 - pole Solder terminal, sealed 100000 4 A 30 V DC 5 A 48 V AC < 20 mOhm > 1000 MOhm small contact distance> 1000 V -25 °C ... +70 °C lever: CuZn chrome-plated bracket plate: stainless steel base plate: DAP, olivegreen threaded socket: CnZn nickel-plated, hexagonal nuts of nickel-plated CuZn bearing connection silver plated external connection silver plated Ag lifting contact locking ring and toothed washer of galvanised and chromated steel central fastening M6 x 0.75 Technical changes reserved. Dimensions are not binding. Detailed specifications available on request.
09041.0201-00 价格&库存
很抱歉,暂时无法提供与“09041.0201-00”相匹配的价格&库存,您可以联系我们找货
  • 5+116.27045
  • 22+111.63496
  • 89+107.15519
库存:95
