09051.0100-00
09051.0100-00
    MARQUARDT(马夸特)
    MARQUARDT - 09051.0100-00 - Pushbutton Switch, SPDT, Momentary
09051.0100-00 数据手册
Pushbutton switches 9051.0100 Product number Business unit Product family Packing unit Output Switching function Material fixed contact Contact system Number of poles connections Mechanical life endurance Rating IEC Contact resistance (new condition) Insulation resistance (new condition) Voltage strength at 250 V Ambient temperature Actuators and additional actuators 9051.0100 Switches, Sensors & Controls Pushbutton switches 100 catalogue miniature switch Changeover switch (SPDT) Ag Electrical life 1 - pole Solder terminal, sealed 25000 100000 4 A 30 V DC 5 A 48 V AC < 20 mOhm > 1000 MOhm small contact distance -25 °C ... +70 °C > 1000 V actuator: CurZn nickel-plated threaded socket: CnZn nickel-plated, hexagonal nuts of nickelplated CuZn toothed disc: Duroplast (base) / chromated galvanized steel Housing description (bracket plate) bracket plate: stainless steel base plate: DAP, olivegreen bearing connection silver plated Connection surface external connection silver plated Contact material Ag Contact type lifting contact Operating force 6.0 N stroke 3.8 mm / corresponding pushbuttons 9090.03.. see Miscellaneous additional parts Type of fastening central fastening M6 x 0.75 Technical changes reserved. Dimensions are not binding. Detailed specifications available on request.
09051.0100-00 价格&库存
很抱歉,暂时无法提供与“09051.0100-00”相匹配的价格&库存,您可以联系我们找货
  • 8+57.30874
  • 20+55.02094
  • 84+52.82298
库存:97
