4021.0512
    MARQUARDT(马夸特)
4021.0512 数据手册
Marquardt SERIES 4021 Double Pole DT-Switches with marking with marking 230 V / 115 V 4021.0512 4021.0203 with marking 230 V / 115 V 4021.4620 4021.4723 Quick-connect 2,8 mm PCB terminal Drawing as . pdf Drawing as . pdf Technical data Technical data http://www.marquardt.de/docs/ProduktKatalog/deutsch/pr...dex.asp?seite=vargruppe.asp&vargruid=410&bauid=38&sp=E (1 of 2)7/20/2006 12:25:54 PM Marquardt Angled PCB terminal Solder terminal Drawing as . pdf Drawing as . pdf Technical data Technical data http://www.marquardt.de/docs/ProduktKatalog/deutsch/pr...dex.asp?seite=vargruppe.asp&vargruid=410&bauid=38&sp=E (2 of 2)7/20/2006 12:25:54 PM Marquardt SERIES 4021 - Technical Data Double Pole DT-Switches with marking Electrical rating 2 (0,5) A 250 V~ for currentless switching 5 A 250 V~ for currentless switching 10 A 125 V~ Mechanical life endurance 1E4 Contact resistance (new state) < 100 (12 V, 1A DC) Insulation resistance (new state) > 100 500 V DC between the open contacts High voltage resistance (new state) 1250 V eff. between the open contacts 3750 V eff. reinforced insulation Resistance to tracking PTI 250 Contact gap 3 mm Insulation spacing http://www.marquardt.de/docs/ProduktKatalog/deutsch/pr...ndex.asp?seite=techdata.asp&vargruid=410&bauid=38&sp=E (1 of 3)7/20/2006 12:26:02 PM Marquardt 8 mm Protection type IP 40 Ambient temperature Terminal side -20 ... +85 °C no condensation Actuating side -20 °C ... +55 °C no condensation Storage temperature -40°C ... +80 °C Flammability Push button and housing UL 94 V-2 Heat and fire-resistant 850 °C category D Material Push button and housing PA Contacts CuAg Terminals silver-plated Temperature rise at the terminals according to el. life endurance max. 30 K UL 1054 according to el. life endurance max. 55 K EN 61058-1 Push-on force of connectors 60 N Approval marks http://www.marquardt.de/docs/ProduktKatalog/deutsch/pr...ndex.asp?seite=techdata.asp&vargruid=410&bauid=38&sp=E (2 of 3)7/20/2006 12:26:02 PM Marquardt These switches are suitable for appliances of class II The test conditions comply with EN 61058-1 and UL 1054 http://www.marquardt.de/docs/ProduktKatalog/deutsch/pr...ndex.asp?seite=techdata.asp&vargruid=410&bauid=38&sp=E (3 of 3)7/20/2006 12:26:02 PM
4021.0512 价格&库存
很抱歉,暂时无法提供与“4021.0512”相匹配的价格&库存,您可以联系我们找货
