H
Series 1550 - Single and double-pole rocker switches
to 16 (4) A 250 V AC
Sensors
Micro-signal switches
Snap-Action switches
Tact and key switches
Foot switches
Rotary Switches
Slide Switches
Toggle Switches
Pushbutton Switches
Rocker Switches
Product features
Inrush currents (capacitive) up to 100 A
Two housing variants (with flange or lower lying)
With mechanical forced opening
Illuminated window with lens effect
Eco
Push‘n‘Drive
Other colors
Other rocker labelings
Other lamp variants
Conformity IEC 60065 chap. 14.6
Special rockers
Cable assembly
Mechanical life endurance
5E4
Inrush current (capacitive)
100 A
Contact distance
≥ 3 mm
Contact resistance (new condition)
< 100 mOhm (1 A 12 V DC)
Insulation resistance (new condition)
> 100 MOhm (500 V DC)
Proof tracking
250 PTI
Protection type
IP 40
Ambient temperature
terminal side -20 °C ... +100 °C
actuating side -20 °C ... +55 °C
Flammability
UL 94 V-2
UL 94 V-0 (product-dependent)
Glow wire test temperature
850 °C
Material actuator
housing
PA
PA
Plug force of the terminals
≤ 80 N
Approval marks
7/1/4/5
Suitable for appliances of protection class II
50
On request
Toggle Switches
Contact material
Ag
1551.3102
6.3
Ag
1551.3103
6.3
Ag
1551.3106
6.3
Ag
6.3
Ag
6.3
Ag
1551.3202
6.3
Ag
1551.3702
6.3
Ag
Au
lower lying flange
lower lying flange
approvals KEMA
lower lying flange
increased life endurance
at a high electrical rating
Slide switches
Pushbutton switches
Rocker switches
Stock version
Miscellaneous
EN 60335 cap. 30 conform “G”
Terminal description
Terminal type
16 A 125 V AC 1 HP
16 A 250 V AC 2 HP
20 A 125 V AC 1 HP
20 A 250 V AC 2 HP
20 mA 250 V AC 5E4
10 A 12 V DC
10 (4) A 250 V AC 25E3
6.3
Rotary switches
16 (4) A 250 V AC 5E4
7 A 250 V AC 5E4
Housing color
Ag
Foot switches
1551.1303
6.3
Tact and Key switches
1551.2654
Snap-action switches
1581.1303
micro-Signal switches
12
Sensors
1550.3609
10 (4) A 250 V AC 5E4
230
Eco
ON / OFF switch (SPST)
16 (4) A 250 V AC 1E4
1550.3102
Actuator color / printing
Push‘n‘Drive
single-pole
Lighting voltage (V)
H
Normally closed contact (SPNC)
Normally open contact (SPNO)
51
H
Ag
230
6.3
Ag
lower lying flange
1555.4608
230
Ag
lower lying flange
1555.8104
230
6.3
Ag
flange dimension
31.5 x 17 mm
1555.3125
115
6.3
Ag
1555.3109
110
6.3
Ag
1555.3120
110
6.3
Ag
1555.3111
12
6.3
Ag
Housing color
ON / OFF switch (DPST)
Ag
1552.2601
Ag
1552.2602
Ag
1552.3102
6.3
Ag
1552.3104
6.3
Ag
1552.3112
6.3
Ag
1552.3117
6.3
Ag
1552.3602
6.3
1552.4602
1552.4702
1552.4802
Push‘n‘Drive
Eco
Sensors
1552.0102
52
Foot switches
Rotary Switches
Slide Switches
Toggle Switches
Pushbutton Switches
Rocker Switches
1555.3604
Stock version
6.3
Miscellaneous
230
Terminal type
1555.3108
16 A 125 V AC 1 HP
16 A 250 V AC 2 HP
230
20 A 125 V AC 1 HP
Ag
1555.3104
20 A 250 V AC 2 HP
6.3
20 mA 250 V AC 5E4
10 A 12 V DC
230
Ag
1555.3102
double-pole
7 A 250 V AC 5E4
6.3
Contact material
lower lying flange
lower lying flange
conformant with
EN 60065 par. 14.6
Ag
lower lying flange
Ag
lower lying flange
Ag
2 PCB holders
lower lying flange
Ag
lower lying flange
H
6.5
17.8
28.3
Basic types 1550 and 1555
single and double-pole
12
6
23.4
12
29.8
2
10
Pushbutton switches
15
30
27
Rocker switches
Toggle Switches
Quick-connect terminal 6.3 x 0.8
y
z
27.2 +-0.1
12.2 +0.2
cover frame 31.5 x 17 mm
X = Wall thickness
x
y
z
0.8 ... 5.0
28.6 +-0.1
14 +0.2
1555.8104
double-pole
14
Sensors
17.8
28.3
6
12
29.8
2
12
23.4
Eco
6.5
17
10
Push‘n‘Drive
31.5
28.4
Foot switches
Rotary switches
x
0.8 ... 5.0
Slide switches
X = Wall thickness
53
H
12.8
5
21
12
6
6
23.4
12
24.8
4.5
10
23.7
2
23.2
12.8
4.5
5
2
12
Solder terminal
X = Wall thickness
26.8 -0.1
12.4 +0.1
2 ... 3
26.8
-0.1
12.4 +0.1
26.4 -0.1
12.4 +0.1
1.25 ... 2
30
15
30
10
27
17.8
29.8
28.3
12
23.4
Basic type 1551 and 1552
12
X = Wall thickness
x
y
z
0.8 ... 5.0
27.2 +-0.1
12.2 +0.2
15
10
2
2
27
17.8
2 ... 3
12
6
23.4
12
Solder terminal
29.8
z
12.4 +0.1
6.5
y
26.2 -0.1
26
x
0.75 ... 1.25
6.5
Pushbutton Switches
Toggle Switches
Slide Switches
lower lying flange
Foot switches
Rotary Switches
12
13
29.5
10
23.4
Sensors
Eco
Push‘n‘Drive
54
13
29.5
23.7
24.8
Rocker Switches
H
12.8
6
3.5
12.3
12.4 +0.1
Dummy piece for series 1550 made
of PA
17.8
15
23.4
12
29.8
2
30
27
PCB terminal
angled mirror-inverted
Rotary switches
23.4
Foot switches
3.5
12.3
23.4
12
6
5
1.3x0.8
12
Toggle Switches
Slide switches
12.8
17
4.5
5
2
12.8
17
4.5
10
23.7
1.3x0.8
+0.1
PCB terminal
angled
Dummy piece
203.103.013
13
29.5
10
23.7
Sensors
26.8 -0.1
PCB terminal
Eco
12.4
3.5
12
Push‘n‘Drive
26.4
2 ... 3
4.5
5
23.4
5
z
12.4 +0.1
1.25 ... 2
2
12.8
6
12
13
29.5
5
y
26.2 -0.1
-0.1
24.8
4.5
5
2
23.3
12
2
x
0.75 ... 1.25
0.8
6
X = Wall thickness
10
23.7
1.3
12
23.4
Basic types 1551 and 1552
lower lying flange
13
29.5
10
23.7
Pushbutton switches
13
29.5
Rocker switches
17
55
很抱歉,暂时无法提供与“1552.3119”相匹配的价格&库存,您可以联系我们找货
