01839.3512-02
01839.3512-02
    MARQUARDT(马夸特)
    MARQUARDT - 01839.3512-02 - Rocker Switch, On-Off-On, DPDT, Non Illuminated, Panel Mount, Black, 183...
01839.3512-02 数据手册
SERIES 1830 - HIGH INRUSH SINGLE POLE AND DOUBLE POLE ROCKER SWITCHES UP TO 20 (4) A 250 V~ SINGLE POLE ST-SWITCHES illuminated 20 (4) A 250 V~ 10 (8) A 250 V~ 5E4 5/120 A 250 V~ T 85/55 16 A (1 HP) 250 V AC 6.3 1830.3111 6.3 1830.3112* 6.3 1830.3118* 6.3 1830.8112* Switches for 125 V AC on request quick-connect terminal 6.3 quick-connect terminal 6.3 6.3 1835.3114 6.3 1835.3111 6.3 1835.3118* 6.3 1831.3933* 1831.0114* 6.3 1831.8112* DOUBLE POLE ST-SWITCHES illuminated 20 (4) A 250 V~ 10 (8) A 250 V~ 5E4 5/120 A 250 V~ T 85/55 16 A (1 HP) 250 V AC 6.3 1835.3112* Switches for 125 V AC or 400 V AC on request quick-connect terminal 6.3 SINGLE POLE ST-SWITCHES 20 (4) A 250 V~ 10 (8) A 250 V~ 5E4 5/120 A 250 V~ T 105/55 16 A (1/3 HP) 125 V AC 16 A (1 HP) 250 V AC 6.3 1831.3312* 6.3 1831.3313* 1831.0115 quick-connect terminal 6.3 2.14 * Version on stock quick-connect terminal 6.3 DOUBLE POLE ST-SWITCHES 20 (4) A 250 V~ 10 (8) A 250 V~ 5E4 5/120 A 250 V~ T 105/55 16 A (1/3 HP) 125 V AC 16 A (1 HP) 250 V AC 6.3 1832.3312* 6.3 1832.3311* 6.3 1832.8112* quick-connect terminal 6.3 quick-connect terminal 6.3 6.3 1833.3302* 6.3 1833.8102 SINGLE POLE DT-SWITCHES 10 (4) A 250 V~ 6 (4) A 250 V~ 5E4 T 105/55 6 A (1/4 HP) 125 V AC 6 A (1/2 HP) 250 V AC 16 (4) A 250 V~ T 105/55 16 A (1/3 HP) 125 V AC 16 A (1/2 HP) 250 V AC 6.3 1833.3305* 6.3 1833.3312 quick-connect terminal 6.3 quick-connect terminal 6.3 6.3 1834.3302* quick-connect terminal 6.3 DOUBLE POLE DT-SWITCHES 10 (4) A 250 V~ 6 (4) A 250 V~ 5E4 T 105/55 6 A (1/4 HP) 125 V AC 6 A (1/2 HP) 250 V AC 16 (4) A 250 V~ T 105/55 16 A (1/3 HP) 125 V AC 16 A (1/2 HP) 250 V AC 6.3 1834.3309* 6.3 1834.3312 * Version on stock 2.15 SERIES 1830 - HIGH INRUSH SINGLE POLE AND DOUBLE POLE ROCKER SWITCHES UP TO 20 (4) A 250 V~ SINGLE POLE DT-SWITCHES with centre-OFF 6 (4) A 250 V~ T 105/55 6 A (1/8 HP) 125-250 V AC without momentary 6.3 1838.3502* 4.8 1838.1502* 16 (4) A 250 V~ T 105/55 16 A (1/3 HP) 125 V AC 16 A (1/2 HP) 250 V AC 6.3 1838.3512 momentary on both sides without momentary 6.3 1838.3402* 4.8 1838.1402* 4.8 1838.1509* 6.3 1838.3412 Momentary function on one side on request quick-connect terminal 6.3 quick-connect terminal 4.8 DOUBLE POLE DT-SWITCHES with centre-OFF 6 (4) A 250 V~ T 105/55 6 A (1/8 HP) 125-250 V AC without momentary 6.3 1839.3502* 4.8 1839.1502 16 (4) A 250 V~ T 105/55 16 A (1/3 HP) 125 V AC 16 A (1/2 HP) 250 V AC 6.3 1839.3512 momentary on both sides momentary on both sides 6.3 1839.3402* 4.8 1839.1402* 4.8 1839.1407* 6.3 1839.3412 Momentary function on one side on request quick-connect terminal 6.3 quick-connect terminal 4.8 SWITCHES WITH MOMENTARY FUNCTION 4 (2) A 250 V~ T 105/55 6 A (1/10 HP) 125 V AC 4 A (1/10 HP) 250 V AC normally open 6.3 1831.3402 2.16 * Version on stock DT momentary 6.3 1833.3402 quick-connect terminal 6.3 DOUBLE POLE WITH MOMENTARY FUNCTION 4 (2) A 250 V~ T 105/55 6 A (1/10 HP) 125 V AC 4 A (1/10 HP) 250 V AC normally open 6.3 1832.3407 DT momentary 6.3 1834.3402* quick-connect terminal 6.3 PILOT LIGHTS Pilot lights with neon lamp and resistor for 230 V~ v Pilot light for 125 V AC according to UL and other colours on request. 6.3 1837.3102* 6.3 1837.8102* quick-connect terminal 6.3 resp. 4.8 6.3 1837.8108 quick-connect terminal 6.3 SERIES 1830 - ROCKER SWITCHES WITH INTEGRATED DUST PROTECTION Several double pole versions with integrated dust protection are available in the 1830 series. The diagram opposite shows how the seal in the switch offers a better protection for the contact system against dust penetration. On request we will supply the switch versions with this dust protection. dust protection * Version on stock 2.17
01839.3512-02 价格&库存
很抱歉,暂时无法提供与“01839.3512-02”相匹配的价格&库存,您可以联系我们找货
