1939.3119-04
1939.3119-04
    MARQUARDT(马夸特)
1939.3119-04 数据手册
SERIES 1930 - DOUBLE-POLE ROCKER SWITCHES IP 65 FOOT SWITCHES ROTARY SWITCHES SLIDE SWITCHES TOGGLE SWITCHES PUSHBUTTON SWITCHES ROCKER SWITCHES TO 20 (4) A 250 V AC PRODUCT FE ATURES ON REQUEST Illuminated and non-illuminated variants with various switching functions Other switching functions (e.g. Changeover switch) IP 65 with integrated gasket for high dust and water protection Other terminal types Inrush current (capacitive) up to 120 A Other printing variants Approval for 400 V Other lamp variants 100 million times proven switching principle Cable assembly Other colors (e.g. red) Modern rocker design High, flexible variety Mechanical life endurance 5E4 Operating force 3-8N Inrush current (capacitive) 120 A 100 A (basic type 1939) 50 A (basic type 1934) Contact resistance (new condition) < 100 mOhm (1 A 12 V DC) SENSORS MICRO-SIGNAL SWITCHES SNAP-ACTION SWITCHES TACT AND KEY SWITCHES Insulation resistance (new condition) > 100 MOhm (500 V DC) | 70 Proof tracking 250 PTI Protection type IP 65 (recessed installation) Ambient temperature terminal side -30 °C ... +105 °C actuating side -30 °C ... +55 °C Flammability UL 94 V-2 UL 94 V-0 (housing and socket only) Glow wire test temperature 850 °C Material PC / TPU (bellows) PA silver plated actuator housing terminals Plug force of the terminals < Approval marks 3/ 1 80 N Suitable for appliances of protection class II / 2US C SERIES 1930 - DOUBLE-POLE ROCKER SWITCHES IP 65 ROCKER SWITCHES 1935.3138 12 1935.3133 24 1935.3131 125 1935.3128 125 1935.3134 125 - 250 ON / OFF switch (DPST) 1935.3218 250 TOGGLE SWITCHES Housing color PUSHBUTTON SWITCHES Actuator color / printing Normally open contact (DPNO) 1935.3129 250 1935.3119 250 1935.3118 250 1935.3114 250 1935.3113 250 1935.3112 250 1935.3135 1935.3137 400 Lighting voltage in V 400 double-pole ON / OFF switch (DPST) TO 20 (4) A 250 V AC 20 (4) A 250 V AC 1E4 12 (4) A 250 V AC 1E4 10 (8) A 400 V AC 5E4 SLIDE SWITCHES 10 (8) A 250 V AC 5E4 10 A 24 V DC 10 A 12 V DC 6 (4) A 250 V AC 5E4 16 A 250 V AC 1 HP ROTARY SWITCHES 16 A 125 V AC 3/4 HP 16 A 125 V AC 1/3 HP 14 A 250 V AC 3/4 HP 14 A 250 V AC 1/2 HP 14 A 125 V AC 1/3 HP FOOT SWITCHES 14 A 125 V AC 1/4 HP 12 A 250 V AC 1 HP 12 A 125 V AC 1/2 HP SENSORS MICRO-SIGNAL SWITCHES SNAP-ACTION SWITCHES TACT AND KEY SWITCHES 6.3 > Ag 3 6.3 > Ag 3 6.3 > Ag 3 6.3 > Ag 3 6.3 > Ag 3 6.3 > Ag 3 6.3 > Ag bellow anthracite EN 60335 cap. 30 conform “G” Miscellaneous 3 6.3 3 > Ag 6.3 3 > Ag 6.3 3 > Ag 6.3 3 > Ag 6.3 > Ag 3 > Contact material Ag 6.3 3 > 3 Contact distance in mm Ag Terminal description 6.3 Terminal type Stock version 71 | SERIES 1930 - DOUBLE-POLE ROCKER SWITCHES IP 65 TOGGLE SWITCHES 1932.3413 1932.3314 Normally open contact (DPNO) Housing color 1932.3312 1932.3412 1932.3132 1932.3131 1932.3130 1932.3118 1932.3116 1932.3114 1932.3113 1932.3112 Actuator color / printing Normally closed contact (DPNC) Lighting voltage in V 1932.1113 double-pole ON / OFF switch (DPST) PUSHBUTTON SWITCHES ROCKER SWITCHES TO 20 (4) A 250 V AC 20 (4) A 250 V AC 1E4 12 (4) A 250 V AC 1E4 10 (8) A 400 V AC 5E4 SLIDE SWITCHES 10 (8) A 250 V AC 5E4 10 A 24 V DC 10 A 12 V DC 6 (4) A 250 V AC 5E4 ROTARY SWITCHES 16 A 250 V AC 1 HP 16 A 125 V AC 3/4 HP 16 A 125 V AC 1/3 HP 14 A 250 V AC 3/4 HP 14 A 250 V AC 1/2 HP FOOT SWITCHES 14 A 125 V AC 1/3 HP 14 A 125 V AC 1/4 HP 12 A 250 V AC 1 HP 12 A 125 V AC 1/2 HP 6.3 > Ag 3 6.3 > Ag 3 6.3 > Ag single-pole occupied EN 60335 cap. 30 conform “G” Miscellaneous 3 6.3 3 > Ag 6.3 3 > Ag 6.3 3 > Ag 6.3 3 > Ag 6.3 3 > Ag 6.3 3 > Ag 6.3 3 > Ag 6.3 3 > Ag 6.3 > Ag 3 3 > Contact material Stock version | 72 4.8 Contact distance in mm Ag Terminal description SENSORS MICRO-SIGNAL SWITCHES SNAP-ACTION SWITCHES TACT AND KEY SWITCHES Terminal type SERIES 1930 - DOUBLE-POLE ROCKER SWITCHES IP 65 10 (8) A 400 V AC 5E4 10 (8) A 250 V AC 5E4 10 A 24 V DC 10 A 12 V DC 6 (4) A 250 V AC 5E4 16 A 250 V AC 1 HP 16 A 125 V AC 3/4 HP 16 A 125 V AC 1/3 HP 14 A 250 V AC 3/4 HP ROCKER SWITCHES PUSHBUTTON SWITCHES 1939.0454 1939.3318 1939.3314 1939.3312 TOGGLE SWITCHES 12 (4) A 250 V AC 1E4 SLIDE SWITCHES 20 (4) A 250 V AC 1E4 1939.3119 1934.2114 1934.3114 Housing color ROTARY SWITCHES Actuator color / printing Changeover switch with OFF position in the center (DPDT - Center OFF) Lighting voltage in V 1934.3112 double-pole Changeover switch (DPDT) TO 20 (4) A 250 V AC 14 A 250 V AC 1/2 HP 14 A 125 V AC 1/3 HP FOOT SWITCHES 14 A 125 V AC 1/4 HP 12 A 250 V AC 1 HP 12 A 125 V AC 1/2 HP EN 60335 cap. 30 conform “G” TACT AND KEY SWITCHES SENSORS Miscellaneous MICRO-SIGNAL SWITCHES SNAP-ACTION SWITCHES Au single-pole occupied momentary function both sides 3 Contact distance in mm Ag Terminal description 6.3 Terminal type Stock version 73 | SERIES 1930 - DOUBLE-POLE ROCKER SWITCHES IP 65 TO 20 (4) A 250 V AC 27.6 3 ROCKER SWITCHES 36.4 3 26.65 26.65 8.64 .7 R3 22 10.2 22 Basic types 1932, 1934, 1935 and 1939 double-pole Quick-connect terminal 4.8 x 0.8 basic type 1932 36.4 Quick-connect terminal 6.3 x 0.8 basic type 1939 27.6 3 TOGGLE SWITCHES X = wall thickness 13.55 3 26.65 Z 22 +0.2 22 +0.2 27.6 .7 Y 30 -0.1 30.2 -0.1 22 22 SLIDE SWITCHES X 0.75 ... 1.25 1.25 ... 3 26.65 8.64 36.4 R3 3 ROTARY SWITCHES Quick-connect terminal 6.3 x 0.8 basic types 1932, 1934 and 1935 Solder terminal basic type 1939 13.55 PUSHBUTTON SWITCHES 27.6 13.55 36.4 0.8x0.8 FOOT SWITCHES 36.4 ø1.3+0.1 10 PCB terminal basic type 1934 A correct assembly and examination on tightness according to IP 65 in the equipment must be ensured by the customer. TACT AND KEY SWITCHES SNAP-ACTION SWITCHES MICRO-SIGNAL SWITCHES SENSORS | 74 10.2 27.6 10.2 Sunken installation recommended for IP 65
1939.3119-04 价格&库存
很抱歉,暂时无法提供与“1939.3119-04”相匹配的价格&库存,您可以联系我们找货
