2709.5101
2709.5101
    MARQUARDT(马夸特)
    Electromechanical Switch ON OFF SPST Trigger Switch 25A
2709.5101 数据手册
POWER TOOL SWITCHES VARIETY. QUALITY. INNOVATION POWER TOOL SWITCHES BY MARQUARDT THE PROGRAM This catalog covers our wide range of power tool switches. The standard versions are listed with their part numbers. Sample switches and installation drawings with tolerance specifications are available on request. Use of these products requires application specific knowledge. Our engineers will be glad to give their guidance in selection as well as product-oriented application indications. Our entire program is distinguished by one common feature: The consistently high quality level which has made us the favorite supplier to leading manufacturers worldwide. We are certified according to ISO TS 16949:2002, the actual QM-standard of the automotive industry. Quality is the most important part of our program. CONTENTS SWITCHES FOR CORDLESS POWER TOOLS DC ON/OFF trigger switches with integrated brake contact :: Page: 13 - 14 Series 2700 and 2704 DC trigger switches with integrated electronic speed control, reversing switch and brake contact :: Page: 15 - 18 Series 2701, 2707, 2711 and 2709 SWITCHES FOR CORDED POWER TOOLS Trigger switches in different electronic versions electrical ratings up to 8 (8) A 250 V~ 5E4 / 13 A 125 V AC :: Page: 20 - 23 Series 1298, 2504 and 1299 Reversing module (for series 1298, 1299, 2504) :: Page: 24 Series 1201, 1202 and 1203 FOR AN INDEX OF ALL PART NUMBERS SEE PAGE 51. 4 CONTENTS Double pole trigger switches with different electronic versions Electrical rating 10 (10) A 250 V~ 5E4 / 16 A 125 V AC :: Page: 25 Series 2602 Single pole ON/OFF trigger switches in US-shape Electrical rating 8 (8) A 250 V~ 5E4 / 13 A 125 V AC / 6 A 250 V AC :: Page: 27 Series 1276 Double pole ON/OFF trigger switches Electrical rating 5 (5) A 250 V~ 5E4 :: Page: 28 Series 1277 Double pole ON/OFF trigger switches Electrical rating up to 8 (8) A 250 V~ 5E4 / 12 A 125 V AC :: Page: 29 Series 2100 5 CONTENTS SWITCHES FOR CORDED POWER TOOLS Double pole ON/OFF trigger switches – electrical rating 8 (8) A 250 V~ 5E4 up to 17,5 A 125 -250 V AC, 3/4HP 125 V AC, 1 1/2 HP 250 V AC :: Page: 30 Series 1281 Double pole ON/OFF trigger switches – electrical rating 10 (10) A 250 V~ 5E4 22 A 125 V AC/DC, 1 1/2 HP, 10 A 250 V AC/DC, 1 HP :: Page: 31 - 32 Series 1269 Double pole ON/OFF trigger switches with additional time delayed NO – electrical rating 10 (10) A 250 V~ 5E4 :: Page: 33 Series 1369 Double pole ON/OFF trigger switches with suppression capacitor – electrical rating up to 12 (12) A 250 V~ 5E4, 20 A 125 -250 V AC, 1 1/2 HP 125 V AC / 2 HP 250 V AC :: Page: 34 Series 1267 FOR AN INDEX OF ALL PART NUMBERS SEE PAGE 51. 6 CONTENTS Double pole ON/OFF trigger switches with additional time delayed NO – electrical rating up to 2,6 kW 250 V~ for inrush current limitation :: Page: 35 Series 1362 Double pole ON/OFF trigger switches with suppression capacitor – electrical rating up to 12 (12) A 250 V~ 5E4, 20 A 125 -250 V AC, 1 1/2 HP 125 V AC / 2 HP 250 V AC :: Page: 36 Series 2200 Double pole ON/OFF trigger switches with suppression capacitor – electrical rating up to 12 (12) A 250 V~ 5E4, 20 A 125 -250 V AC, 1 1/2 HP 125 V AC / 2 HP 250 V AC :: Page: 37 Series 1257 Double pole DT switches electrical rating 10 (6) A 250 V~ :: Page: 38 Series 1205 7 CONTENTS SWITCHES FOR CORDED POWER TOOLS ON/OFF slide switches for direct and indirect actuation – electrical rating 8 (8) A 250 V~ 5E4, 15 A 125 V AC / 8 A 250 V AC 25 A 12-36 V DC :: Page: 39 Series 1206 Single pole and double pole push button switches for indirect actuation – electrical rating 7 (7) A 250 V~ 5E4, 10 A 125 V AC / 5 A 250 V AC :: Page: 41 Series 1247 Double pole push button switches for indirect actuation – electrical rating 8 (8) A 250 V~ 5E4, 14 A 125 V AC / 8 A 125 V DC, 8 A 250 V AC :: Page: 42 Series 1246 Double pole push button switches for indirect actuation – electrical rating 8 (8) A 250 V~ 5E4, 15 A 125 V AC 1 HP / 15 A 125 V DC 1 HP, 25 A 24 V DC :: Page: 43 Series 1249 FOR AN INDEX OF ALL PART NUMBERS SEE PAGE 51. 8 CONTENTS Double pole push button switches for indirect actuation – electrical rating up to 12 (12) A 250 V~ 5E4, 20 A 125 -250 V AC, 1 1/2 HP 125 V AC / 2 HP 250 V AC :: Page: 44 Series 1267 Rotary potentiometers with and without NO electrical rating NO 4 (2) A 250 V~ µ :: Page: 46 Series 2075 Customized power tool switches, brushrings and speed-control units :: Page: 47 - 48 Solid state control units, Robust appliance and snap action switches :: Page: 49 - 50 9 9 HINTS FOR TECHNICAL INFORMATION Approvals Nearly all Marquardt-power tool switches are approved according to IEC 61058-1 (EN 61058-1) and with the ENEC mark and approved by UL and CSA as special use switches according to UL 1054 resp. C 22.2 - 55. Approval marks Europe  USA  Canada Electrical rating According to the European standard, the rated current for motor load is indicated in brackets. According to the regulations of the approval authorities of USA (UL) and of Canada (CSA), the permissible motor load is indicated by means of the HP-Value (horse-power). This HP-rating refers to the mechanical power of the machine. Unless specified otherwise, the rating for the electronics is normally equal to the rated power of the mechanical contacts (depending on the installation and cooling conditions). Endurance The mechanical endurance is the number of possible cycles of operations without electrical load, while the electrical endurance is the number of cycles of operating at maximum electrical load. The lower the electrical rating, the more the electrical endurance approaches the mechanical endurance. Due to the parallel circuit paths with the integrated electronics, the electrical endurance approaches the mechanical endurance when the switch is used in the power tool. Operating cycles Switches that are expected to be actuated more than 2,000 times per year must be approved for frequent operation ≥ 50,000 operating cycles). Most of our switches for electric power tools meet this requirement and are marked with the symbol 5E4. Switches not marked with this symbol are approved for 10,000 operating cycles. Protection against dust The actuating side on most of the power tool switches shown in this catalog is dust protected. You will find a corresponding note in the individual description. The dust protection indicated in our documents refers according to IEC 61058-1 (EN 61058-1) to the actuating side of the switch. The sealing between switch and customer equipment as well as the examination on tightness have to be realized by the customer. Ambient temperature The switches for electric power tools shown in this catalog are mainly approved for an ambient temperature of 55 °C max. Versions for 85 °C max. are marked with T 85. 10 HINTS FOR TECHNICAL INFORMATION EMC – interference suppression Requirements for the appliance interference suppression can be found in EN 61058-1:2002 and in the appliancerespective EMC regulations. Contact gap Switches having a contact gap < 3 mm are not recommended as the only means of disconnecting an appliance from the supply. These switches are marked with µ. Please pay attention to the appliance requirements. Regulations for protection of machines We recommend the use of switches with approval marks IEC 61058-1 (EN 61058-1) if you have to meet the regulations of the standard institutions for protection of power tools. Switches without approval marks have to be tested by your approval authority together with the appliance. Regulations for machines Please consult specific tool safety requirements for additional specifications. CE identification Our power tool switches comply as electrical accessories with the requirements of the low voltage regulation 73/23/EWG. The CE mark is shown on the smallest package unit of the switch. The appliance must satisfy the requirements of the EMC regulations. Minimum order amounts The minimum order amounts of individual switches depend on the respective packing units and the production batch sizes. Please ask for information. Changes We reserve the right to alter switches in accordance with technical improvements. The data specified in the catalog (e.g. dimensions, photos, drawings) are not binding. Ask for samples and outline drawings with tolerance specifications for new projects. Application indications / Liability Since all data in this catalog refer exclusively to the switches supplied by us, the customers themselves are responsible for the examination whether our switches are suitable for the individual case planned by them. Please contact us for further information. Our liability exclusively depends on our terms of payment and delivery, which we send you on request. 11 SWITCHES FOR CORDLESS DC POWER TOOLS 12 SERIES 2700 – ON/OFF TRIGGER SWITCHES FOR CORDLESS DC POWER TOOLS Product description :: SPNO with integrated brake contact :: Optional integrated reversing module :: Lock-off in mid-position of lever :: Dust protected Te c h n i c a l d a t a 1 15 41.2 42 39.5 35.4 2a 1+ 8.5 2- 2.3 24.4 28 2700.0101 :: Electrical rating 25 A / 18 V :: Mechanical endurance SPNO 1E5 cycles DPDT 5E4 cycles :: Electrical endurance SPNO 1E5 cycles DPDT 5E4 cycles :: Contacts Ag :: Volume resistance < 4 mΩ 30 29 Te r m i n a l s 17 15 23.4 :: Solder lugs on the motor and battery side 10.7 22.2 61.3 1 Special versions on request 15 41.2 42 41.7 39.5 35.4 2a 1+ 8.5 24.4 28 23.4 :: Switches with battery clamps :: Switches for higher battery voltages up to 24 V :: Switches without brake contact 17 7 29 15 with reversing module 2.3 74 10° 2700.5101 2- 10° 10.7 22.2 30 61.3 2a 1 Switching function 1+ 13 2- SERIES 2704 – ON/OFF TRIGGER SWITCHES FOR CORDLESS DC POWER TOOLS Product description :: SPNO with integrated brake contact :: Locking ring which couples with customized actuator :: Dust protected Te c h n i c a l d a t a :: :: :: :: :: Electrical rating 30 A / 36 V Mechanical endurance 1E5 cycles Electrical endurance 5E4 cycles Contacts Ag Volume resistance < 4 mΩ 28.5 7 39 14.4 39.8 31.8 Te r m i n a l s 2704.0401 :: Solder lugs on the motor and battery side resp. flat connectors 6.3 x 0.8 2.2 18.9 15.9 10.4 Ø2.5 25.4 27.8 Special version on request 7.85 65.4 20.7 28 :: Version with additional terminals for external resistance braking M+ brake Switching function B+ B- 14 M- SERIES 2701-2711 – SWITCHES WITH ELECTRONICS FOR CORDLESS DC POWER TOOLS Product description :: SPNO with integrated PWM (Pulse Width Modulated) electronics in various dimensions optional with: - Integrated reversing module - Lock-off in mid-position of lever - Integrated brake contact :: Dust protected :: Average duty cycle of motor voltage 15 - 80 % (depending on series), then by-pass to battery voltage Te c h n i c a l d a t a 1 2a 2701/2707 Electronics 1+ 2- 2711 :: Electrical ratings: Series 2707: 20 A / up to 18 V Series 2701: 25 A / up to 24 V Series 2711: 25 A / up to 24 V Series 2709: 25 A / up to 36 V :: Mechanical endurance SPNO 1E5 cycles DPDT 5E4 cycles :: Electrical endurance SPNO 1E5 cycles DPDT 5E4 cycles :: Contacts Ag :: Volume resistance with by-pass contact closed Series 2701, 2707, 2711: < 4 mΩ Series 2709: < 7 mΩ Electronics Te r m i n a l s M- 2709 M+ Electronics M+ B+ B- S 15 Diese Unterlage ist geistiges Eigentum der Marquardt GmbH. Schutzvermerk nach DIN 34 beachten. Copyright reserved. :: Series 2701, 2707 and 2711: Solder lugs on the motor and battery side :: Series 2709: flat connectors 6.3 x 0.8 on the motor and battery side SERIES 2701/2707 – SWITCHES WITH ELECTRONICS FOR CORDLESS DC POWER TOOLS Ø4 2a Product description 15 40.7 38.4 30.4 41.2 42 4 1 8.5 1+ 22.3 2701.5201 24.4 28 :: :: :: :: Electrical rating 25 A/12 V Rated battery voltage 7,2 V-14,4 V With integrated brake contact Copper heat sink 45 30 29 17 21.7 22.3 16 6 10° 10° with reversing module 10.7 22.2 Special versions on request :: Switches with battery clamps :: Switches for higher battery voltages up to 24 V :: Versions with torque control 15 41.2 42 41.7 39.5 35.4 62.9 8.5 2.3 24.4 28 2701.5101 74 30 29 15 7 21.7 22.3 10° with reversing module 10.7 22.2 10° 23.4 61.3 Ø4 Product description 1 15 41.2 42 40.7 38.4 30.4 4 2a 8.5 1+ 2- :: Electrical rating 20 A/12 V :: Rated battery voltage 7,2 V-12 V :: Aluminium heat sink 2.3 2707.5301 24.4 28 45 30 29 17 20.6 22.3 16 6 10° 10° with reversing module 10.7 22.2 15 41.2 42 41.7 39.5 35.4 62.9 8.5 2.3 24.4 28 2707.5101 74 30 29 10° 15 7 17 20.6 22.3 10° with reversing module 10.7 22.2 61.3 16 Special versions on request :: Switches with battery clamps :: Switches with brake contact :: Switches for higher battery voltages up to 18 V SERIES 2709/2711 – SWITCHES WITH ELECTRONICS FOR CORDLESS DC POWER TOOLS 23.5 .5) (R2 R9 :: :: :: :: M+ M- 62 64.55 28 R1 .5 Product description 20.5 10.8 R4 15.4 M1- Neue Zeichnung 2709.5301 10 16.95 S Electrical rating 25 A/36 V Rated battery voltage 24 V-36 V With integrated brake contact Copper heat sink 21.6 24.5 29 31.2 with reversing module 45 14.5 Special versions on request 7 16.6 19 15.9 9° .2 R6 9° 10.5 25.3 :: Switches with solder lugs :: Switches with two parallel MOSFETs for higher currents :: Switches with integrated passive linear potentiometer :: Switches with one-finger and two-finger trigger :: Switches with long lever for direct actuation :: ON-OFF versions without Electronics 20.5 10.8 10 16.95 57.05 62 64.5 .5) (R2 (12) 2709.5101 21.6 24.5 29 31 with reversing module 45 14.5 7 34.2 24 22.4 Product description Ø4 8.75 32.5 41.2 49.4 17 21.6 8.5 2711.5602 3.1 5.8 9° 14 16.6 19 20.3 9° .3 R6 18 Special versions on request 4.5 with reversing module 13.5 27.8 15.9 18.25 19.25 10° 12.6 8 10° 17.7 2711.5101 with reversing module 17 :: Electrical rating 25 A/12 V :: Rated battery voltage 7,2 V-12 V :: Switches with battery clamps :: Switches without brake contact :: Switches for higher battery voltages up to 24 V CUSTOMIZED VERSIONS FOR CORDLESS DC POWER TOOLS Series 2701 Series 2705 Series 2711 Series 2713 18 SWITCHES WITH ELECTRONICS FOR CORDED POWER TOOLS SERIES 1298/1299/2504 - SWITCHES WITH/WITHOUT ELECTRONICS FOR CORDED POWER TOOLS Product description :: SPNO with by-pass contact in different electronic versions, such as half-wave speed control with or without feed-back, full-wave speed control, diode or passive linear potentiometer optional with: - Reversing module - Thumbwheel for limiting actuator travel - Lock-on Te c h n i c a l d a t a 2a 2 1 1 1298/2504 2 6 1 7 2a 3 5 4 1 1 1299 with passive linear potentiometer 2 ON/OFF 20 6 1 8 5 7 8 Te r m i n a l s 2 1299 5 :: Electrical rating mechanical contact system SPNO 8 (8) A 250 V~ 5E4 / 13 A 125 V AC :: Mechanical endurance SPNO 1E5 cycles DPDT 1E4 cycles :: Electrical endurance SPNO 1 E5 cycles DPDT 5 E4 cycles :: Contacts Ag  :: The electronics are to be tested together with the corresponding appliance :: Suitable for appliances of class II 2 1 1 :: Line side: pillar terminals M3 :: Motor side: push-in terminals for soldered strands, strands with end sleeves or strands with end claws :: Versions with reversing module additional 4 x plug-in terminals 2,8 x 0,8 mm SERIES 1298/2504 - SWITCHES WITH ELECTRONICS FOR CORDED POWER TOOLS 32.8 26 8 Series 1298 11 18 28.8 45 20.1 :: Half-wave electronic speed control with by-pass contact :: Electrical rating mechanical contact system SPNO 6 (6) A 250 V~ 5E4 / 10 A 125 V AC 24 2.3 45.7 Ø11.5 26 :: With longer heat sink for higher currents :: For special voltages, special frequencies and special functions :: Without lock-button 32.8 11 4 18 Ø19.5 28.8 45 8 1298.2401 2504.2401 Special versions 1298 on request 13.5 20.2 20 15.9 6 4 M3 14.3 3 20° 1298.5401 2504.5401 14.3 2.3 13.5 20 15.9 M3 Ø11.5 33.5 Series 2504 32.8 8 1 28.8 34 4 18.2 1298.0101 2504.0101 :: Half-wave electronic speed control with by-pass contact :: Electrical rating mechanical contact system SPNO 6 (6) A 250 V~ 5E4 :: Electrical rating Electronics 3,5 A 250 V~ M3 2.3 13.3 11 15.9 20.7 Ø11.5 31 32.8 20.1 28.8 Ø12.1 M3 4 20.6 55 Ø11.5 21 2.3 13.3 24 20.2 11 20° 8 3 15.9 1298.7101 2504.7101 11 18.3 34.25 8 SERIES 1298/2504 - SWITCHES WITH ELECTRONICS FOR CORDED POWER TOOLS 27.7 Series 1298 32.8 11 28.8 36.5 16 1298.5201 2504.5201 :: Electrical rating mechanical contact system SPNO 6 (6) A 250 V~ 5E4 / 10 A 125 V AC :: Electrical rating electronics depending on the application 20.1 8 4 19.9 13.5 24 20.2 20° 12.7 15.9 3 2.3 42 Ø11.5 28.4 11 4 28.8 Ø13.7 36.5 16 1298.2201 2504.2201 :: With extended heat sink for higher currents :: For special voltages, special frequencies and special functions 32.8 8 Special versions 1298 on request M3 2.3 13.5 15.9 12.7 19.6 Ø11.5 Series 2504 32.8 18.3 11 1298.0301 2504.0301 28.8 19.9 8 2.3 9.5 11 15.9 4 M3 Ø 5.9 18.3 8 32,8 8 6 16 18 49.5 22 4 M3 22.9 20° 1298.7312 2504.7312 28,8 19.9 11.8 28 :: Electrical rating mechanical contact system SPNO 6 (6) A 250 V~ 5E4 :: Electrical rating electronics 3,5 A 250 V~ SERIES 1299 - SWITCHES WITH/WITHOUT ELECTRONICS FOR CORDED POWER TOOLS 32.8 26 8 Series 1299 11 18 28.8 45 20.1 :: Electrical rating mechanical contact system SPNO 8 (8) A 250 V~ 5E4 / 13 A 125 V AC :: SPNO optional with integrated passive linear potentiometer M3 14.3 3 13.5 24 20.2 20 15.9 20° 6 ON/OFF with reversing module 4 1299.5431 Ø11.5 :: With integrated diode :: Different actuator designs 32.8 33.5 8 Special versions 1299 on request 2.3 45.7 1299.0101 4 9 18.2 34 28.8 11 20.7 M3 2.3 13.3 11 15.9 with passive linear potentiometer Ø11.5 32.8 31.5 8 28.8 1299.5101 20.7 M3 55 Ø11.5 2.3 13.3 24 20.2 11 15.9 8 3 20° with passive linear potentiometer and reversing module 4 9 18.2 34.1 20.1 11 Customized versions series 1298/2504/1299 23 SERIES 1201/1202/1203 - DPDT REVERSING SWITCH FOR SERIES 1298/1299/2504 Product description :: Double pole change-over for reversing direction :: Additional switch for series 1298, 1299 and 2504 :: Various lever designs Te c h n i c a l d a t a :: Mechanical endurance 1E4 cycles :: Electrical endurance 5E4 cycles Te r m i n a l s :: 4 x plug-in terminals 2,8 x 0,8 mm or 4 x clamped connection without screws 55 25 11 1201 20° 24.5 Special versions on request 8 3 23 33 :: With short lever for slide actuation 13.8 20° 1202 24.5 24.4 55 Switching function 8 3 16.2 32.8 6 5 28.6 17 10.6 10 8 2.6 20° 8 16 18 20° 7 49.5 1203 24 8.5 13.5 22.9 5.6 22 8 SERIES 2602 - SWITCHES WITH ELECTRONICS FOR CORDED POWER TOOLS Product description :: DPNO with by-pass contact, optional with: - integrated half-wave electronic speed control or full-wave electronic speed control - passive linear potentiometer - Lock-on :: Dust protected Te c h n i c a l d a t a :: Electrical rating 10 (10) A 250 V~ 5E4 / 16 A 125 V AC :: Mechanical endurance 1E5 cycles :: Electrical endurance 5E4 cycles :: Contacts Ag  :: :: Suitable for appliances of class II 13 54 27,5 7 A 4,8-0,8 A 2.8-0.8 23 9,8 2602.0101 R4 Te r m i n a l s Ø3,8 M 3,5 A 4.8-0.8 110 23 14 20,4 52.5 :: Line side: pillar terminals M3,5 with screw locking :: Motor side: flat connector 4,8 x 0,8 mm resp. additional 2,8 x 0,8 mm Special versions on request 54 36 27.5 13 7 with lock-on A 2.8-0.8 :: ON/OFF version 23 9.8 2602.0201 R4 Ø3.8 M 3.5 A4.8-0.8 A 4.8-0.8 110 52.5 23 14 20.4 Switching function 1 1 28 13.5 54 23 9.8 25 A 2.8-0.8 M 3.5 A 4.8-0.8 110 52.5 20.4 with passive linear potentiometer Ø 3,8 23 14 2602.5101 A 2.8-0.8 1 2602.0201 2 2a 2 1 2 2 2602.5101 4 5 6 ON/OFF TRIGGER SWITCHES F0R AC AND DC POWER TOOLS SERIES 1276 - ON/OFF TRIGGER SWITCHES in US-SHAPE FOR CORDED POWER TOOLS Product description :: SPNO optional with: - Lock-on - Lock-off Te c h n i c a l d a t a :: Electrical rating 8 (8) A 250 V~ 5E4 / 13 A 125 V AC / 6 A 250 V AC :: Mechanical endurance 1E5 cycles :: Electrical endurance 5E4 cycles :: Contacts Ag  :: :: Suitable for appliances of class II Te r m i n a l s 29.3 28.5 14.6 27 4.7 52.5 :: Line side: 2 x pillar terminals M3 :: Motor side: 4 x push-in terminals for soldered strands, strands with end sleeves or strands with end claws 6 1276.0101 M3 28.9 2.3 15.5 17 11 11.7 with lock-on Special versions on request 5.5 :: SPNO with 2 x push-in terminals for soldered strands for line side and 2 x pushin terminals for soldered strands, strands with end sleeves or strands with end claws for motor side 28.3 29.3 12 47.6 1276.0601 6 M3 11.7 16.6 11 28.9 Switching function Customized versions 27 1 2 1 2 SERIES 1277 - ON/OFF TRIGGER SWITCHES FOR CORDED POWER TOOLS Product description :: DPNO optional with: - Lock-on - Lock-off Te c h n i c a l d a t a :: Electrical rating 5 (5) A 250 V~ 5E4 :: Mechanical endurance 1E5 cycles :: Electrical endurance 5E4 cycles :: Contacts Ag :: :: Suitable for appliances of class II Te r m i n a l s 1277.0101 with lock-on :: Line side: 2 x pillar terminals M3 :: Motor side: 4 x push-in terminals for soldered strands, strands with end sleeves or strands with end claws 1277.0201 Switching function 1 2 1 2 Customized versions 28 SERIES 2100 - ON/OFF TRIGGER SWITCHES FOR CORDED POWER TOOLS Product description :: DPNO optional with: - Lock-on - Lock-off Te c h n i c a l d a t a :: Electrical rating up to 8 (8) A 250 V~ 5E4 / 12 A 125 V AC :: Mechanical endurance 1E5 cycles :: Electrical endurance 5E4 cycles :: Contacts Ag  :: :: Suitable for appliances of class II 47 33 11 2 29 Te r m i n a l s 14.5 24 20 1 1 (2) 2100.0101 2 29 M3 with lock-on 3 5 with lock-off 13.5 16 11 2100.0301 :: Line side: pillar terminals M3 with screw locking :: Motor side: plug-in terminals 4,8 x 0,8 mm resp. additional 2,8 x 0,8 mm Ø11.5 47 33 2 24 29 1 2 (2) 2100.0201 20 1 29 M3 4.8-0.8 16 11 Switching function 2.8-0.8 1 2 1 2 Customized version 29 SERIES 1281 - ON/OFF TRIGGER SWITCHES FOR CORDED POWER TOOLS Product description :: DPNO optional with: - Lock-on - Lock-off :: High dust protection for hardest application conditions Te c h n i c a l d a t a 47 33 -0.3 14.1 M3 19.8 29 -0.3 2 1 1 Ø9 20 24 -0.2 2 13.7 :: Electrical rating 8 (8) A 250 V~ 5E4 10 A 125 -250 V AC 3/4HP 125 V AC 1 1/2 HP 250 V AC :: Mechanical endurance 1E5 cycles :: Electrical endurance 5E4 cycles :: Contacts Ag  :: :: Suitable for appliances of class II 4 +0.3 1281.0101 Te r m i n a l s 11 Ø3.5 :: Pillar terminals M3 6.5 6 11 16 with Lock-on Ø6 Special versions on request 47 33 14.1 M3 19.8 :: DPNO for higher electrical rating up to 17,5 A 125 V AC :: Lock-on and lock-off 1 1 29 2 20 24 2 13.7 1281.0201 4 16 11 Switching function Ø3.5 Customized versions 30 SERIES 1269 - DOUBLE POLE ON/OFF TRIGGER SWITCHES FOR CORDED AND CORDLESS POWER TOOLS Product description :: DPNO optional with: - Lock-on - Lock-off :: Dust protected Te c h n i c a l d a t a :: Electrical rating 10 (10) A 250 V~ 5E4 22 A 125 V AC/DC, 1 1/2 HP 10 A 250 V AC/DC, 1 HP :: Mechanical endurance 1E5 cycles :: Electrical endurance 5E4 cycles :: Contacts Ag  :: :: Suitable for appliances of class II 43.35 23.2 Te r m i n a l s 4.4 11.7 18° 10.3 14.3 5 R5 :: Screw terminals M3,5 12.7 67.7 Special versions on request 10 22.3 14 7.8 1269.0101 3 22.2 16 24.4 32.5 47.5 3 1269.0201 R5 10.3 14.3 5 43.35 23.2 :: SPDT change-over braking version :: Upgraded version with arc extinguishing shield :: Examples on page 35 4.4 22.2 11.7 18° 13.5 16 24.4 32.5 7.2 12.7 67.7 10 22.3 14 7.8 with lock-on 47.5 Ø 6.3 Switching function 1 2 1 2 1 2 43.35 2 12.7 67.7 with lock-off 10 22.3 14 7.8 DPNO with lock-on 47.5 Ø 6.3 31 23.2 13.5 3 1269.0501 R5 10.3 14.3 5 1 4.4 22.2 11.7 18° 16 24.4 32.5 7.2 DPNO with lock-off SERIES 1269 - DOUBLE POLE ON/OFF/ SINGLE POLE CHANGE-OVER SWITCHES Product description 41.95 :: DPNO :: Electrical rating 10 (10) A 250 V~ 5E4 22 A 125 V AC/DC, 1 1/2 HP 10 A 250 V AC/DC, 1 HP 4.4 10 3.6 22.2 14.7 7.5 18° 26.2 16 4.4 10.2 5 12.7 14.3 1269.0602 22.3 14 7.8 10.3 67.7 47.5 3.6 4.4 22.2 22.9 11.7 18° 23.2 16 37 40.2 5 10.2 1269.0801 12.7 67.7 18.6 22.3 14 7.8 17.3 47.5 32.5 Product description 30.2 43.35 10.3 14.3 5 3.6 1269.1001 4.4 22.2 11.7 18° 16 24.4 7.2 12.7 67.7 10 22.3 14 7.8 single pole change-over 47.5 :: SPDT change-over, e.g. for braking power tools with additional auxiliary coil :: Electrical rating 10 (10) A 250 V~ 5E4 22 A 125 V AC, 1 1/2 HP 15 A 125 V DC, 1 1/2 HP :: Upgraded SPDT with arc extinguishing shield and higher DC-rating 31.85 4.4 18° 7.2 3.6 22.2 14.7 1269.5601 2 1 2 12.7 10. 67.7 47.5 Change-over Customized versions 32 1 10.2 14.3 4.4 5 22.3 14 7.8 single pole change-over with arc shield 31.85 41.95 Switching function 16 SERIES 1369 - DOUBLE POLE ON/OFF TRIGGER SWITCHES WITH TIME-DELAYED CONTACT FOR LIMITATION OF STARTING CURRENT Product description :: DPNO with additional time-delayed contact, e.g. for soft starting over protective resistor optional with: - Lock-on - Lock-off :: Delay time 0,4 ... 0,8 sec at 20 °C ± 5 °C :: Dust protected Te c h n i c a l d a t a Electrical rating 10 (10) A 250 V~ = 5E4 Mechanical endurance 1E5 cycles Electrical endurance 5E4 cycles Contacts Ag Suitable for appliances of class II 4.4 3.6 1369.0601 10.2 41.95 26.2 28.4 15.3 22.2 11.7 8.5 31.85 :: :: :: :: :: :: 5 Te r m i n a l s 12.7 14.3 73.3 98 77.8 10.3 22.3 14 7.8 :: Screw terminals M3,5 Special versions on request :: DPNO with additional normally closed contact e.g. for braking power tools with additional auxiliary coil :: UL-Version Switching function M 2c 2 1 2 ~mains 1 (2b) 33 SERIES 1267 - DOUBLE POLE ON/OFF TRIGGER SWITCHES FOR CORDED POWER TOOLS Product description :: DPNO optional with: - Lock-off - Lock-on :: Preparation for strain relief for power cord :: Suppression capacitor C=0,22 µF/275 V AC :: Dust protected Te c h n i c a l d a t a :: Electrical rating 10(10) A 250 V~ 5E4 16 A 125 -250 V AC 1 HP 125 V AC / 2 HP 250 V AC :: Mechanical endurance 1E5 cycles :: Electrical endurance 5E4 cycles :: Contacts Ag  :: :: Suitable for appliances of class II 1267.0101 Te r m i n a l s with lock-on and lock-off 104 31.5 :: Line side: pillar terminals M4 with screw locking :: Motor side: plug-in terminals 6,3 x 0,8 mm 26.2 2 1.5 38.5 15.9 M4 A6.3-0.8 77 20.5 37.5 127 Special versions on request 15 28 :: DPNO for higher electrical ratings up to 12 (12) A 250 V~ 5E4, 20 A 125 -250 V AC :: Without suppression capacitor Switching function 1 1 2 2 mains Customized versions 34 SERIES 1362 - DOUBLE POLE ON/OFF TRIGGER SWITCHES WITH TIME-DELAYED CONTACT FOR LIMITATION OF STARTING CURRENT Product description :: DPNO with additional time-delayed contact, e.g. for soft start-up over protective resistor, optional with: - Lock-off - Lock-on :: Preparation for strain relief for power cord :: Delay time 0,3 up to 0,9 sec :: Suppression capacitor C=0,22 µF/275 VAC :: Dust protected Te c h n i c a l d a t a :: Electrical rating 2,6 kW 250 V~ with limitation of starting current :: Mechanical endurance 1E5 cycles :: Electrical endurance 5E4 cycles :: Contacts Ag :: Suitable for appliances of class II 1362.0101 Te r m i n a l s 31.5 with lock-on and lock-off 104 :: Line side: pillar terminals M4 with screw locking :: Motor side: plug-in terminals 6,3 x 0,8 mm 28.5 26.2 2 1.5 38.5 15.9 M4 A 6.3 - 0.8 20.5 37.5 77 127 5 15 Special versions on request 28 :: DPNO without lock-off :: Without lock-on :: Without suppression capacitor Switching function ~ 1 protective resistor/ electronic device 2 5 mains 1 ~ 2 :: We can help you in the choice of the protective resistor/ electronics. Customized versions 35 SERIES 2200 - DOUBLE POLE ON/OFF TRIGGER SWITCHES FOR CORDED POWER TOOLS Product description :: DPNO optional with: - Lock-off - Lock-on :: Suppression capacitor C=0,22 µF/275 VAC :: Dust protected Te c h n i c a l d a t a :: Electrical rating 8 (8) A 250 V~ 5E4 16 A 125 -250 V AC / 14 A 125 -250 V AC 3/4 HP 125 V AC 1 1/2 HP 250 V AC :: Mechanical endurance 1E5 cycles :: Electrical endurance 5E4 cycles :: Contacts Ag  :: :: Suitable for appliances of class II 2200.0101 Te r m i n a l s with lock-on and lock-off :: Line side: pillar terminals M4 :: Motor side: plug-in terminals 6,3 x 0,8 mm Special versions on request 20.3 with lock-on 2.5 2 Ø4.1 30.2 62.4 85.5 19 19 10.5 11.7 2200.0301 :: DPNO for higher electrical ratings up to 12 (12) A 250 V~ 5E4, 20 A 125 -250 V AC 36.9 72 17.5 5 4.2 6.3-0.8 12.4 26 Switching function 1 1 2 2 ~mains Customized versions 36 SERIES 1257 - DOUBLE POLE ON/OFF ROCKER SWITCHES FOR CORDED POWER TOOLS Product description :: DPST :: Suppression capacitor C=0,22 µF/275 VAC :: Dust protected Te c h n i c a l d a t a 15.9 :: Electrical rating 8 (8) A 250 V~ 5E4 14 A 125 -250 V AC 3/4 HP 125 V AC 1 1/2 HP 250 V AC :: Mechanical endurance 1E5 cycles :: Electrical endurance 5E4 cycles :: Contacts Ag  :: :: Suitable for appliances of class II 8 8 14.5 14 19.6 R 1. 5 45 19.4 1257.0101 62.6 72.5 28 3.2 94 75 Flachstecker A 6.3 - 0.8 Te r m i n a l s :: Line side: pillar terminals M 4 :: Motor side: plug-in terminals 6,3 x 0,8 mm Special versions on request 1257.0101 Elektrowerkzeugschalter :: DPST for higher electrical ratings up to 12 (12) A 250 V~ 5E4, 20 A 125 -250 V AC Switching function 1 2 2 1 ~ Customized version 37 mains SERIES 1205 - DOUBLE POLE SLIDE SWITCHES FOR REVERSING FUNCTIONS Product description :: DPDT :: Dust protected Te c h n i c a l d a t a :: :: :: :: :: :: Electrical rating 10 (6) A 250 V~ Mechanical endurance 5E4 cycles Electrical endurance 1E4 cycles Contacts Ag Suitable for appliances of class II Te r m i n a l s 1205.0101 :: Line side: screw terminals M3,5 :: Motor side: screw terminals M3,5 Switching function 1a 1b 2a 2b 1 38 2 SERIES 1206 - SINGLE POLE SLIDE SWITCHES FOR DIRECT/INDIRECT ACTUATION FOR AC AND DC POWER TOOLS Product description :: :: :: :: SPST optional with fixing barrier For direct and indirect actuation Dust protected Optional sealing from actuation side 5 Schiebeweg 3.4 3.5 :: Electrical rating 8 (8) A 250 V~ 5E4 15 A 125 V AC / 8 A 250 V AC 25 A 12-36 V DC :: Mechanical endurance 1E5 cycles :: Electrical endurance 5E4 cycles :: Contacts Ag  :: :: Suitable for appliances of class II 2 R1 3.5 12.5 Te c h n i c a l d a t a 1.3 1206.2501 Ø 1.5 Te r m i n a l s 20 .5 Ø2 1.6 Ø 1.6 19.4 11 3.7 R0 for indirect actuation 25.3 :: Plug-in terminals 6,3 x 0,8 mm :: PCB terminals straight Ø 1.8 (4x) 12.4 5 Special versions on request 13.2 2 3.7 Ø 1.5 20 17.5 23.3 25.3 2 Ø 1.8 (4x) 12.4 5 1 13 3.7 8.9 2 1 12.5 R2 5.9 5 Schiebeweg 17.5 6.3-0.8 15.6 18.3 19.4 1206.3201 23.3 25.3 39 Switching function Ø 1.6 11 1.6 3.7 15.6 Ø2 19.4 for snap-on of customized sliders, with fixing barrier 3.5 1.3 1206.2701 :: Other solder lugs :: Momentary function R1 1 12.5 5 Schiebeweg R1 SWITCHES FOR INDIRECT ACTUATION FOR CORDED POWER TOOLS SERIES 1247 - SINGLE AND DOUBLE POLE SWITCHES FOR INDIRECT ACTUATION FOR CORDED POWER TOOLS Product description :: SPNO and DPNO optional with: - Mounting ribs - Suppression capacitor :: SPNO (second path bridged) :: Dust protected Te c h n i c a l d a t a :: Electrical rating 7 (7) A 250 V~ 5E4 10 A 125 V AC / 5 A 250 V AC :: Mechanical endurance 1E5 cycles :: Electrical endurance 5E4 cycles :: Contacts Ag  :: :: Suitable for appliances of class II 24 9.4 1 27 2.8-0.8 M3.5 2 29.2 1 2 19.5 1247.0301 SPNO 1247.2301 DPNO Ø5 Te r m i n a l s 25 :: Line side: screw terminals M3,5 :: Motor side and suppression device: plug-in terminals 2,8 x 0,8 mm Special version on request Ø5 1247.0501 SPNO with suppression capacitor 1247.2501 DPNO with suppression 1 1 1.5 2 19.5 29.2 2 2 9.4 :: Non-momentary function (push/pull) M3.5 25.5 33.8 25 Switching function capacitor 1 2 1 single pole 1 2 1 2 2 double pole 1247.0102 SPNO 1247.2102 DPNO 41 SERIES 1246 - DOUBLE POLE PUSH BUTTON SWITCHES FOR INDIRECT ACTUATION FOR CORDED POWER TOOLS Product description :: DPNO optional with: - Mounting ribs - Suppression capacitor :: Dust protected Te c h n i c a l d a t a :: Electrical rating 8 (8) A 250 V~ 5E4 14 A 125 V AC / 8 A 125 V DC 8 A 125 V AC :: Mechanical endurance 1E5 cycles :: Electrical endurance 5E4 cycles :: Contacts Ag  :: :: Suitable for appliances of class II 1246.3201 Te r m i n a l s DPNO :: Line side: screw terminals M3,5 :: Motor side: plug-in terminals 4,8 x 0,8 mm, additional 2,8 x 0,8 mm Special version on request :: DPDT for 6 (6) A 250 V~ 1246.3101 DPNO with suppression capacitor Switching function 1 1246.3201 42 2 1 1246.3101 2 SERIES 1249 - DOUBLE POLE AC/DC PUSH BUTTON SWITCHES FOR INDIRECT ACTUATION FOR AC AND DC POWER TOOLS Product description :: DPNO optional with: - Suppression capacitor - Mounting ribs :: Dust protected Te c h n i c a l d a t a :: Electrical rating 8 (8) A 250 V~ 5E4 15 A 125 V AC 1 HP / 15 A 125 V DC 1 HP 25 A 24 V DC :: Mechanical endurance 1E5 cycles :: Electrical endurance 5E4 cycles :: Contacts Ag  :: :: Suitable for appliances of class II Ø5 22 4 Te r m i n a l s 3 1249.0101 22.5 25.5 15 2 6 11.1 10 10.7 21.1 21 2.8 x 0.8 4.8 x 0.8 :: Line side: screw terminals M3,5 :: Motor side: plug-in terminals 4,8 x 0,8 mm resp. additional 2,8 x 0,8 mm M3.5 Ø5 26 8.3 citor 11.1 22.5 25.5 3 1249.0201 with suppression capa- 15 2 6 10 10.7 23.9 4.8 x 0.8 21 M3.5 Switching function 1 1249.0101 43 2 1 1249.0201 2 SERIES 1267 - DOUBLE POLE PUSH BUTTON SWITCHES FOR INDIRECT ACTUATION FOR CORDED POWER TOOLS Product description :: DPNO :: Dust protected Te c h n i c a l d a t a 4 14.5 12.3 1.5 :: Electrical rating 8 (8) A 250 V~ 5E4 14 A 125 V AC 3/4 HP 14 A 250 V AC 1 1/2 HP :: Mechanical endurance 1E5 cycles :: Electrical endurance 5E4 cycles :: Contacts Ag  :: :: Suitable for appliances of class II 19 Te r m i n a l s 6.3 - 0.8 62.6 72.5 :: Line side: screw terminals M4 :: Motor side: plug-in terminals 6,3 x 0,8 mm 15 9 12.5 28 1267.7101 M3.5 7 55.6 1.5 :: DPNO for higher electrical ratings up to 12 (12) A 250 V~ 5E4, 20 A 125 -250 V AC 19 4 14.5 12.3 6.3 - 0.8 62.6 72.5 15 9 12.5 28 1267.7121 non-momentary function Special versions on request M3.5 7 Switching function 1 2 55.6 1 44 2 ROTARY POTENTIOMETERS SERIES 2075 - ROTARY POTENTIOMETER FOR PCB ASSEMBLIES Product description :: Rotary potentiometer, optional with NO contact Te c h n i c a l d a t a :: Electrical rating SPNO 4 (2) A 250 V~ µ :: Mechanical endurance 1E5 cycles :: Electrical endurance 5E4 cycles :: Contacts Ag :: Resistance value RN = 220 kΩ Tolerance on request :: Rotation angle of switch 30°, rotation angle of resistor 270° Te r m i n a l s 2075.1501 :: Silver-plated PCB with switch 2075.1801 without switch Switching function 3.85 11.8 1.35 7 G 5.8 32.0 B C D without switch, with print A-G, white 18.15 10 1.8 3.1 2075.2421 Ø 23.1 A E Ø 30.9 F 7.5 12.5 46 with switch without switch CUSTOMIZED POWER TOOL SWITCHES AND BRUSHRINGS 47 CUSTOMIZED SPEED-CONTROL UNITS WITH AND WITHOUT FEEDBACK 48 SOLID STATE CONTROL UNITS 49 ROBUST APPLIANCE AND SNAP ACTION SWITCHES FOR USE IN POWER TOOLS For further information about these switches please request our standard switches catalog. 50 INDEX OF PART NUMBERS Part Number 51 Page 1205.0101 38 1206.2501 1206.2701 1206.3201 39 39 39 1246.3101 1246.3201 42 42 1247.0102 1247.0301 1247.0501 1247.2102 1247.2301 1247.2501 41 41 41 41 41 41 1249.0101 1249.0201 Part Number Page 1299.0101 1299.5101 1299.5431 23 23 23 1362.0101 35 1369.0601 33 2075.1501 2075.1801 2075.2421 46 46 46 2100.0101 2100.0201 2100.0301 29 29 29 43 43 2200.0101 2200.0301 36 36 1257.0101 37 1267.0101 1267.7101 1267.7121 34 44 44 1269.0101 1269.0201 1269.0501 1269.0602 1269.0801 1269.1001 1269.5601 31 31 31 32 32 32 32 2504.0101 2504.0301 2504.2201 2504.2401 2504.5201 2504.5401 2504.7101 2504.7312 21 22 22 21 22 21 21 22 2602.0101 2602.0201 2602.5101 25 25 25 1276.0101 1276.0601 27 27 2700.0101 2700.5101 13 13 1277.0101 1277.0201 28 28 2701.5101 2701.5201 16 16 2704.0401 14 1281.0101 1281.0201 30 30 2707.5101 2707.5301 16 16 1298.0101 1298.0301 1298.2201 1298.2401 1298.5201 1298.5401 1298.7101 1298.7312 21 22 22 21 22 21 21 22 2709.5101 2709.5301 17 17 2711.5101 2711.5602 17 17 51
2709.5101 价格&库存
很抱歉,暂时无法提供与“2709.5101”相匹配的价格&库存,您可以联系我们找货
