09050.4200-00
09050.4200-00
    MARQUARDT(马夸特)
    MARQUARDT - 09050.4200-00 - Pushbutton Switch, DPDT, Momentary
09050.4200-00 数据手册
Pushbutton switches 9050.4200 Product number Business unit Product family Actuation type Packing unit Weight ROHS conform Output Switching function Material fixed contact Contact system Number of poles connections Mechanical life endurance Rating IEC Contact resistance (new condition) Insulation resistance (new condition) Voltage strength at 250 V Ambient temperature Actuators and additional actuators 9050.4200 Switches, Sensors & Controls Pushbutton switches direct 100 6.300 g yes catalogue miniature switch Changeover switch (DPDT momentary) Ag Electrical life 2 - pole Solder terminal, sealed 25000 100000 4 A 30 V DC 5 A 48 V AC < 20 mOhm > 1000 MOhm small contact distance -25 °C ... +70 °C > 1000 V actuator: CurZn nickel-plated threaded socket: CnZn nickel-plated, hexagonal nuts of nickel-plated CuZn toothed disc: Duroplast (base) / chromated galvanized steel (bracket plate) Housing description bracket plate: stainless steel base plate: DAP, olivegreen bearing connection silver plated Connection surface external connection silver plated Contact material Ag Contact type lifting contact Operating force ≤ 3.6 N smooth action version / stroke 1.1 mm / corresponding pushbuttons 9090.16.. Miscellaneous see additional parts Type of fastening central fastening M6 x 0.75 Technical changes reserved. Dimensions are not binding. Detailed specifications available on request.
09050.4200-00
- 物料型号:9050.4200 - 器件简介:该产品属于Marquardt的按钮开关产品系列,是直接操作的切换功能开关。 - 引脚分配:2极(2-pole),提供焊接端子和密封连接。 - 参数特性: - 电气寿命:25000次 - 机械寿命:100000次 - 额定IEC:4A30VDC或5A48VAC - 接触电阻(新状态):<20毫欧姆 - 绝缘电阻(新状态):>1000 MOhm - 250V电压强度(小接触距离):>1000V - 环境温度范围:-25°C至+70°C - 功能详解:提供切换开关(DPDT瞬时)功能,具有平滑操作版本,行程为1.1毫米。 - 应用信息:适用于需要高电气和机械寿命的应用。 - 封装信息:包括带螺纹的插座、六角螺母、固定接触材料为银(Ag),连接表面为银镀层。
09050.4200-00 价格&库存
很抱歉,暂时无法提供与“09050.4200-00”相匹配的价格&库存,您可以联系我们找货
