1813.1102-00
1813.1102-00
    MARQUARDT(马夸特)
1813.1102-00 数据手册
SERIES 1810 - SINGLE AND DOUBLE-POLE TOGGLE SWITCHES SENSORS MICRO-SIGNAL SWITCHES SNAP-ACTION SWITCHES TACT AND KEY SWITCHES FOOT SWITCHES ROTARY SWITCHES SLIDE SWITCHES TOGGLE SWITCHES PUSHBUTTON SWITCHES ROCKER SWITCHES TO 10 (4) A 250 V AC | 118 PRODUCT FE ATURES ON REQUEST Attractive toggle switches Other colors 100 million times proven switching principle Other printing variants Long life endurance with 100 000 mechanical switching cycles Other switching functions Excellent actuating characteristic Cable assembly Other terminal variants Mechanical life endurance 5E4 (changeover switch with OFF position in center) 10E4 Contact resistance (new condition) < 100 mOhm (1 A 12 V DC) Insulation resistance (new condition) > 100 MOhm (500 V DC) Proof tracking 250 PTI Protection type IP 40 Ambient temperature terminal side -20 °C ... +100 °C actuating side -20 °C ... +55 °C Flammability UL 94 V-2 Glow wire test temperature 850 °C Material PA PA silver plated actuator housing terminals Plug force of the terminals < Approval marks 3/ 1 80 N Suitable for appliances of protection class II /2 1814.2102 Changeover switch with OFF position in the center (DPDT - Center OFF) > 3 Ag > 3 Ag 1819.1102 4.8 < 3 Ag 1819.1302 4.8 < 3 Ag FOOT SWITCHES 3 Ag 4.8 > 3 Ag 1818.1102 4.8 < 3 Ag 1818.1202 4.8 < 3 Ag momentary function one side 1818.1302 4.8 < 3 Ag momentary function one side 1818.2302 SLIDE SWITCHES 4.8 momentary function both sides ROTARY SWITCHES Ag TACT AND KEY SWITCHES 3 PUSHBUTTON SWITCHES Stock version Miscellaneous Terminal type ROCKER SWITCHES 4 A 250 V AC 1/10 HP 6 A 125 V AC 1/10 HP 6 A 125 - 250 V AC 1/8 HP 6 A 125 V AC 1/4 HP 6 A 250 V AC 1/2 HP 4 (2) A 250 V AC 1E4 6 (2) A 250 V AC 1E4 6 (4) A 250 V AC 5E4 10 (4) A 250 V AC 1E4 Housing color Actuator color / printing > MICRO-SIGNAL SWITCHES Changeover switch with OFF position in the center (SPDT - Center OFF) 4.8 Stock version 1813.1102 Contact material Changeover switch (SPDT) Contact distance in mm Normally open contact (SPNO) Terminal description 1811.1202 Miscellaneous Terminal type 4 A 250 V AC 1/10 HP 6 A 125 V AC 1/10 HP 6 A 125 - 250 V AC 1/8 HP 6 A 125 V AC 1/4 HP 6 A 250 V AC 1/2 HP 4 (2) A 250 V AC 1E4 6 (2) A 250 V AC 1E4 6 (4) A 250 V AC 5E4 1811.1102 SNAP-ACTION SWITCHES 4.8 10 (4) A 250 V AC 1E4 ON / OFF switch (SPST) SENSORS Changeover switch (DPDT) Contact material 1812.1102 Contact distance in mm ON / OFF switch (DPST) Terminal description double-pole Housing color single-pole Actuator color / printing SERIES 1810 - SINGLE AND DOUBLE-POLE TOGGLE SWITCHES TO 10 (4) A 250 V AC 119 | SERIES 1810 - SINGLE AND DOUBLE-POLE TOGGLE SWITCHES ROCKER SWITCHES TO 10 (4) A 250 V AC 21 21 15 3.6 9.8 3.6 9 2 2 7 13 18.6 Quick-connect terminal 4.8 x 0.8 basic type 1818 Quick-connect terminal 4.8 x 0.8 basic type 1813 and 1811 without third terminal 15 21 3.6 9.8 2 9 Y 19.2 -0.1 19.4 -0.1 19.8 -0.1 Z 12.9 +0.1 12.9 +0.1 12.9 +0.1 13.2 X 0.75 ... 1.25 1.25 ... 2 2 ... 3 3.5 14 X = wall thickness 7 13 18.5 Basic types 1811, 1813 and 1818 single-pole 11.7 18 2 20.5 19.5 7 2 0.8 7.5 0.8 7.5 13 18.5 PCB terminal basic type 1818 ROTARY SWITCHES 21 24 21 3.6 2 15 2 24 15 SENSORS MICRO-SIGNAL SWITCHES SNAP-ACTION SWITCHES | 120 20.5 18 7 7 10.2 10.2 18.6 18.6 22 Quick-connect terminal 4.8 x 0.8 basic type 1812 Basic types 1812, 1814 and 1819 double-pole 3.6 2 X = wall thickness 24 15 Z 21.9 +0.1 21.9 +0.1 21.9 +0.1 11.7 Y 19.2 -0.1 19.4 -0.1 19.8 -0.1 3.5 14 X 0.75 ... 1.25 1.25 ... 2 2 ... 3 0.8 7.5 10.2 18.6 PCB terminal basic type 1814 22 22 Quick-connect terminal 4.8 x 0.8 basic type 1819 21 2 TACT AND KEY SWITCHES FOOT SWITCHES 2 11.7 2 14 14 13.2 PUSHBUTTON SWITCHES 2 13.2 14 14 9 TOGGLE SWITCHES SLIDE SWITCHES 15
1813.1102-00 价格&库存
很抱歉,暂时无法提供与“1813.1102-00”相匹配的价格&库存,您可以联系我们找货
