1838.1509-01
1838.1509-01
    MARQUARDT(马夸特)
1838.1509-01 数据手册
SERIES 1830 - SINGLE AND DOUBLE-POLE ROCKER SWITCHES ON REQUEST 100 million times proven switching principle Other colors mechanical life endurance up to 1 million switching cycles Other rocker printings Wide variety Snap-on customized actuators Variants with IP 67 or dust protection insert Cable assembly Other printing variants SLIDE SWITCHES PRODUCT FE ATURES TOGGLE SWITCHES PUSHBUTTON SWITCHES ROCKER SWITCHES TO 20 (4) A 250 V AC Two housing variants Actuating characteristic Approval for 400 V (product-dependent) Mechanical life endurance 10E4 5E4 (basic type 1839) 1E6 (product-dependent) Inrush current (capacitive) 120 A / 50 A (contact pair Ag / Cu and basic type 1834) Contact resistance (new condition) < 100 mOhm (1 A 12 V DC) FOOT SWITCHES ROTARY SWITCHES Illuminated and non-illuminated variants 250 PTI Protection type IP 40 / IP 67 (product-dependent) Ambient temperature terminal side -20 °C ... +105 °C / ... +85 °C / ... +100 °C actuating side -20 °C ... +55 °C Flammability UL 94 V-2 UL 94 V-0 Glow wire test temperature 850 °C Material PA / PC PA silver plated / tinned Plug force of the terminals < Approval marks 3/ 1 Suitable for appliances of protection class II /2/ MICRO-SIGNAL SWITCHES 80 N SENSORS actuator housing terminals SNAP-ACTION SWITCHES Proof tracking TACT AND KEY SWITCHES Insulation resistance (new condition) > 100 MOhm (500 V DC) 57 | SERIES 1830 - SINGLE AND DOUBLE-POLE ROCKER SWITCHES Actuator color / printing TOGGLE SWITCHES Housing color 20 (4) A 250 V AC 1E4 20 (4) A 250 V AC 16 (4) A 250 V AC 1E4 1831.3607 1831.3606 1831.3317 1831.3313 1831.3312 1831.0114 ON / OFF switch (SPST) 1835.3902 230 Changeover switch (SPDT momentary) 1830.6103 230 1830.0102 230 1830.8112 230 1830.3119 230 1830.3118 230 1830.3111 1830.3112 230 Lighting voltage in V 230 single-pole ON / OFF switch (SPST) PUSHBUTTON SWITCHES ROCKER SWITCHES TO 20 (4) A 250 V AC 10 (8) A 400 V AC 5E4 SLIDE SWITCHES 10 (8) A 250 V AC 5E4 10 (4) A 250 V AC 1E4 10 A 12 V DC 6 (4) A 250 V AC 5E4 6 (4) A 250 V AC 1E4 ROTARY SWITCHES 6 (4) A 250 V AC 4 (2) A 250 V AC 1E4 30 mA 12 V DC 16 A 250 V AC 1 HP 16 A 125 V AC 1 HP FOOT SWITCHES 16 A 250 V AC 1/2 HP 16 A 125 V AC 1/3 HP 16 A 125 V AC 1/4 HP 6 A 250 V AC 1/2 HP 6 A 125 V AC 1/4 HP 6 A 125 V AC 1/10 HP 4 A 250 V AC 1/10 HP 6.3 3 Ag housing with 2 separating gates > 6.3 3 > Ag housing with 2 separating gates 6.3 > Ag 3 6.3 > Ag 3 6.3 > Ag 3 > Ag 3 6.3 3 > Ag external lamp connection two-pole size 3 > Ag lower lying flange > Ag 3 4.8 6.3 3 > Ag Ag 6.3 > Ag 3 > Ag 6.3 > Ag 3 3 > Contact material Miscellaneous lower lying flange EN 60335 cap. 30 conform “G” Stock version | 58 3 Contact distance in mm SENSORS MICRO-SIGNAL SWITCHES SNAP-ACTION SWITCHES Terminal description 6.3 Terminal type 6.3 TACT AND KEY SWITCHES 6 A 125 - 250 V AC 1/8 HP SERIES 1830 - SINGLE AND DOUBLE-POLE ROCKER SWITCHES Housing color ROCKER SWITCHES PUSHBUTTON SWITCHES 1833.7102 1833.3307 1833.1102 1833.3312 Changeover switch (SPDT) 1831.1253 1831.8202 1831.3402 1831.1202 1831.1107 1831.3311 1832.3508 1831.8112 1831.3933 Actuator color / printing Normally open contact (SPNO) Lighting voltage in V 1831.3815 single-pole ON / OFF switch (SPST) TO 20 (4) A 250 V AC TOGGLE SWITCHES 20 (4) A 250 V AC 1E4 20 (4) A 250 V AC 16 (4) A 250 V AC 1E4 10 (8) A 400 V AC 5E4 10 (8) A 250 V AC 5E4 SLIDE SWITCHES 10 (4) A 250 V AC 1E4 10 A 12 V DC 6 (4) A 250 V AC 5E4 6 (4) A 250 V AC 1E4 6 (4) A 250 V AC ROTARY SWITCHES 4 (2) A 250 V AC 1E4 30 mA 12 V DC 16 A 250 V AC 1 HP 16 A 125 V AC 1 HP 16 A 250 V AC 1/2 HP FOOT SWITCHES 16 A 125 V AC 1/3 HP 16 A 125 V AC 1/4 HP 6 A 250 V AC 1/2 HP 6 A 125 V AC 1/4 HP TACT AND KEY SWITCHES 6 A 125 - 250 V AC 1/8 HP 6 A 125 V AC 1/10 HP 4 A 250 V AC 1/10 HP SNAP-ACTION SWITCHES SENSORS lower lying flange lower lying flange Miscellaneous 1E6 mechanical life endurance IP 67 EN 60335 cap. 30 conform “G” MICRO-SIGNAL SWITCHES Ag > 3 6.3 > Ag 3 4.8 > Ag 3 6.3 > Ag 3 4.8 > Au 3 6.3 3 > Ag 6.3 > Ag 3 4.8 > Ag 3 4.8 > Ag 3 6.3 > Ag 3 6.3 > Ag two-pole size 3 6.3 3 > Ag lower lying flange 6.3 3 > 3 Ag Contact material > Contact distance in mm Ag Terminal description 6.3 Terminal type Stock version 59 | SENSORS MICRO-SIGNAL SWITCHES SNAP-ACTION SWITCHES | 60 Contact material EN 60335 cap. 30 conform “G” Miscellaneous Stock version > Contact distance in mm Ag > > Ag Ag Ag Ag > Ag momentary function both sides lower lying flange > Ag momentary function both sides lower lying flange > > > Ag momentary function one side > Ag momentary function one side 3 3 3 3 3 3 3 3 3 Terminal description 3 4.8 6.3 4.8 6.3 6.3 6.3 2.8 4.8 4.8 4.8 16 A 250 V AC 1 HP > 30 mA 12 V DC Ag 4 (2) A 250 V AC 1E4 4.8 6 (4) A 250 V AC 3 6 (4) A 250 V AC 1E4 > 6 (4) A 250 V AC 5E4 Ag 10 A 12 V DC momentary function both sides 10 (4) A 250 V AC 1E4 6.3 10 (8) A 250 V AC 5E4 3 10 (8) A 400 V AC 5E4 > 16 (4) A 250 V AC 1E4 Ag 20 (4) A 250 V AC PUSHBUTTON SWITCHES ROCKER SWITCHES 1833.6202 1833.3402 1833.1202 Changeover switch (SPDT momentary) 1838.3502 1838.3402 1838.8302 1838.4307 1838.1602 1838.1509 1838.1502 1838.1402 1838.3901 1838.0305 Changeover switch with OFF position in the center (SPDT - Center OFF) 20 (4) A 250 V AC 1E4 1E6 mechanical life endurance IP 67 TOGGLE SWITCHES Housing color 3 SLIDE SWITCHES Actuator color / printing > ROTARY SWITCHES Lighting voltage in V Ag FOOT SWITCHES single-pole momentary function both sides TACT AND KEY SWITCHES SERIES 1830 - SINGLE AND DOUBLE-POLE ROCKER SWITCHES TO 20 (4) A 250 V AC 16 A 125 V AC 1 HP 16 A 250 V AC 1/2 HP 16 A 125 V AC 1/3 HP 16 A 125 V AC 1/4 HP 6 A 250 V AC 1/2 HP 6 A 125 V AC 1/4 HP 6 A 125 - 250 V AC 1/8 HP 6 A 125 V AC 1/10 HP 4 A 250 V AC 1/10 HP Terminal type SERIES 1830 - SINGLE AND DOUBLE-POLE ROCKER SWITCHES ROCKER SWITCHES 1832.1612 1835.3107 12 1835.3116 115 - 230 ON / OFF switch (DPST) 1835.3802 230 PUSHBUTTON SWITCHES Actuator color / printing Changeover switch (DPDT) 1835.7108 230 1835.3108 230 1835.3105 230 1835.3102 230 1835.9413 230 1835.3118 230 1835.3114 230 1835.3112 230 1835.3419 1835.3111 230 Lighting voltage in V 400 double-pole ON / OFF switch (DPST) TO 20 (4) A 250 V AC Housing color TOGGLE SWITCHES 20 (4) A 250 V AC 1E4 20 (4) A 250 V AC 16 (4) A 250 V AC 1E4 10 (8) A 400 V AC 5E4 10 (8) A 250 V AC 5E4 SLIDE SWITCHES 10 (4) A 250 V AC 1E4 10 A 12 V DC 6 (4) A 250 V AC 5E4 6 (4) A 250 V AC 1E4 6 (4) A 250 V AC ROTARY SWITCHES 4 (2) A 250 V AC 1E4 30 mA 12 V DC 16 A 250 V AC 1 HP 16 A 125 V AC 1 HP 16 A 250 V AC 1/2 HP FOOT SWITCHES 16 A 125 V AC 1/3 HP 16 A 125 V AC 1/4 HP 6 A 250 V AC 1/2 HP 6 A 125 V AC 1/4 HP TACT AND KEY SWITCHES 6 A 125 - 250 V AC 1/8 HP 6 A 125 V AC 1/10 HP 4 A 250 V AC 1/10 HP MICRO-SIGNAL SWITCHES SENSORS cover frame 33.2 long lower lying flange PCB holder 248.103.011 mounted lower lying flange Miscellaneous cover frame 33.2 long EN 60335 cap. 30 conform “G” SNAP-ACTION SWITCHES 4.8 3 > Ag 6.3 > Ag 3 6.3 > Ag 3 6.3 > Ag 3 > Ag 3 6.3 > Ag 3 6.3 > Ag 3 6.3 > Ag 3 > Ag 3 6.3 > Ag 3 6.3 > Ag 3 6.3 > Ag 3 6.3 3 > 3 Ag Contact material > Contact distance in mm Ag Terminal description 6.3 Terminal type Stock version 61 | SERIES 1830 - SINGLE AND DOUBLE-POLE ROCKER SWITCHES TOGGLE SWITCHES Housing color 1832.8204 1832.3407 1832.9101 1832.3307 1832.1102 1832.0113 1832.9103 1832.8112 1832.7103 1832.6112 1832.3602 1832.3313 1832.3312 Actuator color / printing Normally open contact (DPNO) Lighting voltage in V 1832.3311 double-pole ON / OFF switch (DPST) PUSHBUTTON SWITCHES ROCKER SWITCHES TO 20 (4) A 250 V AC 20 (4) A 250 V AC 1E4 20 (4) A 250 V AC 16 (4) A 250 V AC 1E4 10 (8) A 400 V AC 5E4 SLIDE SWITCHES 10 (8) A 250 V AC 5E4 10 (4) A 250 V AC 1E4 10 A 12 V DC 6 (4) A 250 V AC 5E4 6 (4) A 250 V AC 1E4 ROTARY SWITCHES 6 (4) A 250 V AC 4 (2) A 250 V AC 1E4 30 mA 12 V DC 16 A 250 V AC 1 HP 16 A 125 V AC 1 HP FOOT SWITCHES 16 A 250 V AC 1/2 HP 16 A 125 V AC 1/3 HP 16 A 125 V AC 1/4 HP 6 A 250 V AC 1/2 HP 6 A 125 V AC 1/4 HP 6 A 125 V AC 1/10 HP 4 A 250 V AC 1/10 HP 6.3 3 > Ag 6.3 > Ag 3 > Ag 3 6.3 3 > Ag 3 > Ag 3 > Ag dust protection inlay > Ag lower lying flange 3 4.8 6.3 3 > Ag lower lying flange > Ag lower lying flange 3 4.8 3 Ag lower lying flange > 6.3 3 > Ag Ag cover frame 33.2 long > Ag 6.3 > Ag 3 3 > Contact material lower lying flange Miscellaneous lower lying flange EN 60335 cap. 30 conform “G” Stock version | 62 3 Contact distance in mm SENSORS MICRO-SIGNAL SWITCHES SNAP-ACTION SWITCHES Terminal description 6.3 Terminal type 6.3 TACT AND KEY SWITCHES 6 A 125 - 250 V AC 1/8 HP SERIES 1830 - SINGLE AND DOUBLE-POLE ROCKER SWITCHES 16 (4) A 250 V AC 1E4 10 (8) A 400 V AC 5E4 10 (8) A 250 V AC 5E4 10 (4) A 250 V AC 1E4 10 A 12 V DC 6 (4) A 250 V AC 5E4 6 (4) A 250 V AC 1E4 6 (4) A 250 V AC 4 (2) A 250 V AC 1E4 30 mA 12 V DC 16 A 250 V AC 1 HP ROCKER SWITCHES PUSHBUTTON SWITCHES 1839.1518 1839.1509 1839.1507 1839.1502 1839.1410 1839.1407 1839.1402 TOGGLE SWITCHES 20 (4) A 250 V AC SLIDE SWITCHES 20 (4) A 250 V AC 1E4 1839.3512 1834.6103 1834.3603 1834.3309 1834.3302 1834.1102 1834.3312 Housing color ROTARY SWITCHES Actuator color / printing Changeover switch with OFF position in the center (DPDT - Center OFF) Lighting voltage in V 1834.3311 double-pole Changeover switch (DPDT) TO 20 (4) A 250 V AC 16 A 125 V AC 1 HP 16 A 250 V AC 1/2 HP FOOT SWITCHES 16 A 125 V AC 1/3 HP 16 A 125 V AC 1/4 HP 6 A 250 V AC 1/2 HP 6 A 125 V AC 1/4 HP TACT AND KEY SWITCHES 6 A 125 - 250 V AC 1/8 HP 6 A 125 V AC 1/10 HP 4 A 250 V AC 1/10 HP MICRO-SIGNAL SWITCHES SENSORS Miscellaneous dust protection inlay EN 60335 cap. 30 conform “G” SNAP-ACTION SWITCHES 4.8 3 > Ag 4.8 > Ag 3 4.8 > Ag 3 4.8 > Ag 3 4.8 > Ag dust protection inlay momentary function both sides 3 4.8 3 Ag momentary function both sides > 4.8 3 > Ag momentary function both sides 6.3 > Ag 3 4.8 > Ag lower lying flange 3 6.3 3 > Ag cover frame 33.2 long 6.3 3 > Ag 6.3 3 > Ag 4.8 > Ag 3 > Contact material Ag 6.3 3 > 3 Contact distance in mm Ag Terminal description 6.3 Terminal type Stock version 63 | SERIES 1830 - SINGLE AND DOUBLE-POLE ROCKER SWITCHES 16 (4) A 250 V AC 1E4 10 (8) A 400 V AC 5E4 SLIDE SWITCHES 10 (8) A 250 V AC 5E4 10 (4) A 250 V AC 1E4 10 A 12 V DC 6 (4) A 250 V AC 5E4 6 (4) A 250 V AC 1E4 ROTARY SWITCHES 6 (4) A 250 V AC 4 (2) A 250 V AC 1E4 30 mA 12 V DC 16 A 250 V AC 1 HP 1834.3402 1839.0105 1839.3602 1839.3503 1839.3502 1839.3402 1839.2203 Changeover switch (DPDT momentary) 20 (4) A 250 V AC 1839.3352 20 (4) A 250 V AC 1E4 3 TOGGLE SWITCHES Housing color 1839.7304 Actuator color / printing 3 Lighting voltage in V 1839.1602 double-pole Changeover switch with OFF position in the center (DPDT - Center OFF) PUSHBUTTON SWITCHES ROCKER SWITCHES TO 20 (4) A 250 V AC 16 A 125 V AC 1 HP FOOT SWITCHES 16 A 250 V AC 1/2 HP 16 A 125 V AC 1/3 HP 16 A 125 V AC 1/4 HP 6 A 250 V AC 1/2 HP 6 A 125 V AC 1/4 HP 6 A 125 V AC 1/10 HP 4 A 250 V AC 1/10 HP 6.3 dust protection inlay dust protection inlay momentary function one side lower lying flange cover frame 33.2 long momentary function both sides momentary function one side Miscellaneous 3 > Ag 3 > Ag > Au 6.3 > Ag 6.3 3 > Ag 6.3 > Ag 3 6.3 3 > Ag 3 > Ag momentary function both sides > Ag 3 4.8 3 > EN 60335 cap. 30 conform “G” Stock version | 64 momentary function one side Contact material Ag Contact distance in mm SENSORS MICRO-SIGNAL SWITCHES SNAP-ACTION SWITCHES Terminal description 6.3 Terminal type momentary function one side TACT AND KEY SWITCHES 6 A 125 - 250 V AC 1/8 HP SERIES 1830 - SINGLE AND DOUBLE-POLE ROCKER SWITCHES Actuator color / printing ROCKER SWITCHES PUSHBUTTON SWITCHES 1837.8108 230 1837.8102 230 1837.3102 230 1837.1118 1837.2504 230 Lighting voltage in V 230 Lamp Lamp TO 20 (4) A 250 V AC Housing color TOGGLE SWITCHES 20 (4) A 250 V AC 1E4 20 (4) A 250 V AC 16 (4) A 250 V AC 1E4 10 (8) A 400 V AC 5E4 10 (8) A 250 V AC 5E4 SLIDE SWITCHES 10 (4) A 250 V AC 1E4 10 A 12 V DC 6 (4) A 250 V AC 5E4 6 (4) A 250 V AC 1E4 6 (4) A 250 V AC ROTARY SWITCHES 4 (2) A 250 V AC 1E4 30 mA 12 V DC 16 A 250 V AC 1 HP 16 A 125 V AC 1 HP 16 A 250 V AC 1/2 HP FOOT SWITCHES 16 A 125 V AC 1/3 HP 16 A 125 V AC 1/4 HP 6 A 250 V AC 1/2 HP 6 A 125 V AC 1/4 HP TACT AND KEY SWITCHES 6 A 125 - 250 V AC 1/8 HP 6 A 125 V AC 1/10 HP 4 A 250 V AC 1/10 HP 6.3 size basic type 1835 Contact distance in mm Contact material SENSORS Miscellaneous lower lying flange EN 60335 cap. 30 conform “G” MICRO-SIGNAL SWITCHES SNAP-ACTION SWITCHES 6.3 size basic type 1835 4.8 Terminal description 6.3 Terminal type Stock version 65 | SERIES 1830 - SINGLE AND DOUBLE-POLE ROCKER SWITCHES Basic types 1830, 1831, 1833 and 1838 single-pole illuminated / non-illuminated 16.2 0.8 11 23.5 14 2 16.2 23.5 2 0.8 5.6 31.5 14 9.5 11 9.5 27.2 27.2 6.4 Quick-conect terminal 2.8 x 0.8 1838.4307 14 3 31.5 Quick-connect terminal 4.8 x 0.8 basic type 1838 Z 11 +0.1 11 +0.1 11 +0.1 26.5 15.8 9.5 15 11 0.8 27.2 9.5 34.2 27.2 Quick-connect terminal 4.8 x 0.8 basic types 1830, 1831 and 1833 Quick-connect terminal 6.3 x 0.8 1831.3815 14 9.5 16.2 27 15.8 3 5.6 31.5 3 Y 30 -0.1 30.2 -0.1 30.6 -0.1 26.55 X 0.75 ... 1.25 1.25 ... 2 2 ... 3 27 2 16.2 X = wall thickness ROTARY SWITCHES SLIDE SWITCHES 5.6 31.5 TOGGLE SWITCHES PUSHBUTTON SWITCHES ROCKER SWITCHES TO 20 (4) A 250 V AC 15 11 0.8 27.2 34.6 16.2 27.2 27.2 6.4 Quick-connect terminal 6.3 x 0.8 basic types 1831 and 1833 Solder terminal basic type 1838 16.2 14 27 11 27.2 Solder terminal basic types 1830 and 1831 11 27 5.6 0.8 9.5 31.5 14 2 16.2 2 11 0.8 9.5 0.8 SENSORS 31.5 14 9.5 | 66 Quick-connect terminal 6.3 x 0.8 basic type 1838 27 6.4 31.5 2 MICRO-SIGNAL SWITCHES 27.2 Quick-connect terminal 6.3 x 0.8 1838.3901 SNAP-ACTION SWITCHES TACT AND KEY SWITCHES FOOT SWITCHES 9.5 SERIES 1830 - SINGLE AND DOUBLE-POLE ROCKER SWITCHES 16.2 Quick-connect terminal 6.3 x 0.8 / 4.8 basic types 1832, 1834 and 1835 31.5 25 0.8 10.2 9.5 10.2 9.5 22 SLIDE SWITCHES 9.5 16.2 2 16.2 0.8 29.5 2 22 27.2 27.2 Solder terminal basic type 1832 25 3.5 5.6 25 2 2 16.2 31.5 29.5 31.5 5.6 Quick-connect terminal 6.3 x 0.8 basic type 1839 16.2 Z 22 +0.2 22 +0.2 22 +0.2 25 29.5 6.4 5.6 Quick-connect terminal 4.8 x 0.8 TOGGLE SWITCHES 27.2 31.5 Y 30 -0.1 30.2 -0.1 30.6 -0.1 10.2 22 X = wall thickness X 0.75 ... 1.25 1.25 ... 2 2 ... 3 PUSHBUTTON SWITCHES 29.5 0.8 9.5 22 27.2 Basic types 1832, 1834, 1835 and 1839 double-pole illuminated / non-illuminated 2 16.2 23.5 22.5 2 10.2 9.5 9.5 25 25 ROTARY SWITCHES 5.6 31.5 31.5 ROCKER SWITCHES 6.4 TO 20 (4) A 250 V AC 0.8 11.4 11.2 11 27.2 X 0.75 ... 1.25 1.25 ... 2 2 ... 3 Y 30 -0.1 30.2 -0.1 30.6 -0.1 Z 11 +0.1 11 +0.1 11 +0.1 Quick-connect terminal 4.8 x 0.8 basic types 1830, 1831 and 1833 22 2 9.5 FOOT SWITCHES PCB terminal basic type 1839 11.4 33.2 4.4 Solder terminal basic type 1839 22 TACT AND KEY SWITCHES 27.2 SNAP-ACTION SWITCHES 22 27.2 X = wall thickness 10.2 9.5 9.5 Basic types 1830, 1831 and 1833 single-pole, lower lying flange illuminated / non-illuminated 10 MICRO-SIGNAL SWITCHES 10 10.2 SENSORS 0.8 67 | SERIES 1830 - SINGLE AND DOUBLE-POLE ROCKER SWITCHES 33.2 24.5 10.2 22 27.2 Quick-connect terminal 4.8 x 0.8 basic types 1832 and 1834 33.2 11.2 4.4 24.5 11.2 4.4 11.4 11.4 2 2 22.2 9.5 10.2 22 Basic types 1832, 1834, 1835 and 1839 double-pole, lower lying flange illuminated / non-illuminated Quick-connect terminal 6.3 x 0.8 basic type 1832 22.2 10.2 11.2 3.6 7 10 27.2 1.3x0.8 9.5 27.2 22.2 3.4 3.2 11.2 Z 22 +0.2 22 +0.2 22 +0.2 13.5 15.5 Y 30 -0.1 30.2 -0.1 30.6 -0.1 5 X 0.75 ... 1.25 1.25 ... 2 2 ... 3 33.2 2 4.4 11.4 2 X = wall thickness 0.8x0.8 ø1.3 +0.1 10.2 10 22 4 22 4.4 PCB terminal angled basic types 1832 and 1835 ROTARY SWITCHES 22.2 7 33.2 PCB terminal basic type 1839 3.5 2 11.2 SLIDE SWITCHES 33.2 22.2 9.5 27.2 TOGGLE SWITCHES PUSHBUTTON SWITCHES ROCKER SWITCHES TO 20 (4) A 250 V AC 0.8x0.8 10.2 FOOT SWITCHES 10 22 27.2 31.5 14 16.2 2 2 16.2 25.1 11 19 27.2 27.2 Quick-connect terminal 4.8 x 0.8 single-pole size Basic type 1837 lamp single and double-pole 31.5 Quick-connect terminal 6.3 x 0.8 single-pole size 25 33.2 X = wall thickness 11.4 +0.2 0.8 10.2 20 3.5 22 22 +0.2 22 +0.2 11 9.5 22 27.2 SENSORS 27.2 | 68 Quick-connect terminal 6.3 x 0.8 double-pole size PCB terminal lower lying flange 1837.2504 1.3 +0.1 11.2 Z 2 Y 30 -0.1 30.2 -0.1 30.6 -0.1 29.5 X 0.75 ... 1.25 1.25 ... 2 2 ... 3 7 16.2 28.2 2 MICRO-SIGNAL SWITCHES SNAP-ACTION SWITCHES 11 19 20 26 2.5 14 2.5 31.5 25.1 26 TACT AND KEY SWITCHES PCB terminal basic types 1832 and 1835 SERIES 1830 - SINGLE AND DOUBLE-POLE ROCKER SWITCHES 10.6 37 Protection ap 203.731.011 SLIDE SWITCHES 36 Protection cap 203.201.011 Protection cap 203.078.011 Housing and dummy cap for doublepole size of basic types 1830, 1831, 1833, 1837 and 1838 of PA black. Housing and dummy cap for doublepole size of basic types 1832, 1834, 1835 and 1839 of PA black. Housing and dummy cap must be assembled by the customer and makes only sense in combination Dummy cap 203.146.051 Housing 217.127.491 MICRO-SIGNAL SWITCHES Housing 217.132.031 SENSORS Dummy cap 203.145.051 SNAP-ACTION SWITCHES Housing and dummy cap must be assembled by the customer and makes only sense in combination TACT AND KEY SWITCHES FOOT SWITCHES Transparent PVC-protection cap with burling. Serves as dust and water protection of the actuation side for double-pole basic types 1832, 1834, 1835 and 1839 with standard flange length 30 mm. ROTARY SWITCHES 0.6 10.6 28 Transparent PVC - protection cap for double-pole switches of basic types 1832, 1834, 1835 and 1839 with frame length 33.2 mm. Serves as dust and water protection of the actuation side. TOGGLE SWITCHES PUSHBUTTON SWITCHES 19.2 5.4 11 27.1 Transparent PVC - protection cap for single-pole switches of basic types 1830, 1831, 1833 and 1838. Serves as dust and water protection of the actuation side. ROCKER SWITCHES TO 20 (4) A 250 V AC 69 |
1838.1509-01 价格&库存
很抱歉,暂时无法提供与“1838.1509-01”相匹配的价格&库存,您可以联系我们找货
