09043.0101-00
09043.0101-00
    MARQUARDT(马夸特)
    MARQUARDT - 09043.0101-00 - Toggle Switch, On-Off-On, SPDT, Non Illuminated, Panel, 5 A
09043.0101-00 数据手册
Toggle switches 9043.0101 Product number 9043.0101 Business unit Switches, Sensors & Controls Product family Actuation type Packing unit ROHS conform Switching function Material fixed contact Contact system Number of poles connections Mechanical life endurance Toggle switches direct Rating IEC Contact resistance (new condition) Insulation resistance (new condition) Voltage strength at 250 V Ambient temperature Actuators and additional actuators Housing description Connection surface Contact material Contact type Miscellaneous Type of fastening 100 yes Changeover switch with OFF position in the center (SPDT - Center OFF) Ag Electrical life 1 - pole Solder terminal, sealed 50000 100000 4 A 30 V DC 5 A 48 V AC < 20 mOhm > 1000 MOhm small contact distance -25 °C ... +70 °C > 1000 V lever: CuZn chrome-plated bracket plate: stainless steel base plate: DAP, olivegreen threaded socket: CnZn nickel-plated, hexagonal nuts of nickel-plated CuZn bearing connection silver plated external connection silver plated Ag lifting contact locking ring and toothed washer of galvanised and chromated steel / momentary function both sides central fastening M6 x 0.75 Technical changes reserved. Dimensions are not binding. Detailed specifications available on request.
09043.0101-00 价格&库存
很抱歉,暂时无法提供与“09043.0101-00”相匹配的价格&库存,您可以联系我们找货
